AUDALYTIC DR80N Streamer DAC Black
New
The Audalytic DR80n is a network player and discrete resistor-ladder R-2R DAC, designed to play network music streams and convert digital signals to analog. Its 26-bit architecture supports PCM files up to 768 kHz and DSD up to DSD1024.
By buying this product you get 71 loyalty points
Reference : 22659
719,00 €tax incl.
599,17 € tax excl.
Audalytic DR80N Streamer R2R Discrete DAC 768kHz DSD1024 Black
AUDALYTIC DR80N: Front view
The Audalytic DR80n
is a streamer and R-2R DAC with a discrete resistor ladder, designed to play network music streams and convert digital signals to analog. Its 26-bit architecture supports PCM files up to 768kHz and DSD up to DSD1024.
Intended for a hi-fi system, it combines network playback, wired inputs and Bluetooth 5.1 reception to accommodate various sources. Its low-impedance output stage and analog volume control allow it to be used as a DAC or connected directly to a power amplifier.
Audalytic DR80n: Discrete 26-bit R-2R conversion
The DR80n relies on a proprietary discrete R-2R module, in which a precision resistor network converts the digital signal into an analog signal. Its 26-bit balanced architecture is based on rigorous resistor matching, essential to conversion linearity. Rather than entrusting this stage to an integrated DAC chip, Audalytic thus adopts a discrete component design, whose precision depends directly on the quality of the network and its assembly.
AUDALYTIC DR80N: R2R DAC
AUDALYTIC DR80N: FPGA
Audalytic DR80n: FPGA-driven digital processing
Upstream of the conversion, the programmable FPGA handles several essential functions of the DR80n: clock management, digital shaping, DoP demodulation and anti-pop switching between PCM and DSD streams. This configurable logic coordinates signal processing and ensures controlled transitions between formats. The CK-01 clock module provides a femtosecond reference to the entire DAC in order to synchronize its various circuits.
Audalytic DR80n: Amanero USB interface
Jointly developed by Gustard and Amanero, the USB DDC interface relies on an ARM Cortex-M7 processor, which handles data processing with low latency. It accepts PCM streams up to 768kHz and DSD up to DSD1024, allowing the DR80n to receive high-resolution files from a computer source or a compatible digital transport.
AUDALYTIC DR80N: Amanero USB interface
AUDALYTIC DR80N: Power supply
Audalytic DR80n: Power supply distributed by circuit
Segmented filtering and multi-rail regulation assign a distinct function to each power supply line in order to limit interactions between the different stages. This arrangement provides the digital circuits, the conversion stage and the analog outputs with a power supply suited to their respective needs, helping preserve their operation within a complex architecture.
Audalytic DR80n: Volume control
At the DAC output, a low-impedance analog stage allows the DR80n to adapt to a wide range of downstream loads while preserving the signal. The built-in analog volume control allows fine level adjustment; when the unit is connected to a preamplifier or an amplifier with its own control, direct mode bypasses this function.
AUDALYTIC DR80N: Volume control
AUDALYTIC DR80N: Bluetooth chip
Audalytic DR80n: Bluetooth 5.1
In addition to its digital inputs, the DR80n features a Bluetooth 5.1 receiver based on a Qualcomm QCC5125 chip. Compatible with the LDAC, AAC, SBC and aptX codecs, it allows music to be streamed from a smartphone or another Bluetooth source, while wired connections remain available for high-resolution digital sources.
Audalytic DR80n: Network player function
The DR80n also integrates the CelWare network playback platform, developed with Cel Audio around a hardware and software architecture dedicated to music. Its system, based on a Linux kernel optimized for real-time audio, prioritizes the processing of music streams and allows unused protocols to be disabled to lighten playback. Settings are accessible from a browser via "dr80.local" or from the Bridge app on iOS and Android, to control the network function from a computer, tablet or smartphone.
AUDALYTIC DR80N: Network player function
Audalytic DR80n: I2S pinout
AUDALYTIC DR80N: I2S pinout
Technical specifications
Product typeDAC with volume
Streamer
Inputs1x Coaxial
1x Optical Toslink
1x HDMI I2S
1x RJ45
1x USB-B
1x USB-C (Firmware update)
1x SD card
Bluetooth
1x Balanced stereo XLR
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD1024
DAC chipsR2R
Frequency response20Hz-20kHz (±0.2dB)
Output levelRCA: 2Vrms
XLR: 4Vrms
Dynamic range> 114dB
Signal-to-noise ratio (SNR)> 115dB
Total harmonic distortion more noise (THD+N)< -134dB
EN IMD0.009%
Output impedance100Ω
Supported Bluetooth codecsLDAC / AAC / SBC / APTX
Network protocolsRoon Bridge
AirPlay
HQPlayer NAA
UPnP
Spotify
Supply voltage100/240V AC, 50/60Hz
12-15V DC, ≥2A
Power supply< 12W
Dimensions300 x 230 x 58mm
Weight2.8kg
Package1x Audalytic DR80n
1x Power cable
1x Remote control
InputRJ45
InputSD Card
InputI2S via HDMI
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD1024
Max sampling rate768kHz
NetworkingYes
Remote ControlYes
Streaming services & Network protocolsHQPlayer NAA
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsUpnP
AUDALYTIC DR80N Streamer R2R Discrete DAC 768kHz DSD1024 Black
The Audalytic DR80n is a network player and discrete resistor-ladder R-2R DAC, designed to play network music streams and convert digital signals...
