LHY AUDIO LPS-T10 Linear Power Supply Module for Eversolo T10
New
The LHY AUDIO LPS-T10 is an internal linear power supply upgrade kit specifically designed for the EVERSOLO T10 audio player.
By buying this product you get 68 loyalty points
Reference : 22588
689,00 €tax incl.
574,17 € tax excl.
LHY Audio LPS-T10 Linear Power Supply Module for Eversolo T10
LHY AUDIO LPS-T10
The LHY Audio LPS-T10 is an internal linear power supply upgrade kit specifically designed for the EverSolo T10 audio player. It replaces the original power supply with a fully linear dual-transformer architecture, featuring a custom toroidal transformer with 7N OFC oxygen-free copper windings and a dedicated Talema transformer for the display, control and standby circuits. Its LT4320 ideal rectifier circuit, low-noise linear regulation and increased main filtering capacitance are designed to reduce residual ripple and power supply-related interference.
The kit provides a regulated 12V DC output and accepts a 115V or 230V AC mains input, selected manually. Designed to reuse the original mounting points and internal connectors, it fits into the T10 chassis without requiring any cutting and preserves its external appearance, controls and functions. This is an internal replacement kit that requires opening the device, not an external power supply.
Warning: disassembling the Eversolo T10 Digital Network Transport Player and replacing its power supply will void its warranty.
Mesures LHY AUDIO LPS-T10
LHY Audio LPS-T10: Dual-Transformer Architecture and Low-Noise Linear Regulation
The LPS-T10 divides the power supply between two dedicated circuits: a custom toroidal transformer designed by LHY Audio for the main power supply and a Talema transformer for the auxiliary circuits. The main transformer uses 7N OFC copper windings. The main circuit combines LT4320-based ideal rectification, ADI LT3042 low-noise linear regulation with PNP transistor current amplification, and wideband output filtering. The auxiliary circuit uses LT3041 linear regulation. In the LHY Select configuration, the total capacitance of the main filter capacitors reaches 90000µF, compared with 28200µF for the original power supply, approximately 3.2 times higher.
LHY AUDIO LPS-T10 : Architecture à double transformateur et régulation linéaire à faible bruit
LHY Audio LPS-T10: Internal Integration and Dedicated Installation for the EVERSOLO T10
The LPS-T10 is designed to fit directly into the EverSolo T10 chassis, reusing the original mounting points and internal connectors. The kit includes the AC input and EMI filtering module with a Talema transformer and auxiliary linear power supply, the DC regulation board in the selected configuration, the custom main toroidal transformer, a set of OCC output cables, 6-pin connection ribbon cables, a Phillips screwdriver, a hex key and protective gloves.
LHY AUDIO LPS-T10 : Intégration interne et installation dédiée à l'EVERSOLO T10
Technical Specifications
Product typeUpgrade kit for a fully linear internal power supply
CompatibilityEversolo T10 Digital Network Transport Player
ArchitectureFully linear, dual-transformer
AC input115V or 230V AC, manual selection
Regulated output12V DC
Main transformerCustom LHY Audio toroidal transformer (7N OFC windings)
Main filter capacitanceLHY Select: 90000µF (3.2 times the original capacitance)
RectificationLT4320 full-wave rectification
Linear regulationADI LT3041 on the auxiliary board and LT3042 on the main DC board, both with PNP current amplification
Output wiringSet of OCC cables
Package contents1x AC input and electromagnetic interference (EMI) protection module with Talema transformer and linear regulation
1x DC linear regulation board
1x Custom 7N OFC toroidal transformer designed by LHY Audio
1x Set of OCC output cables
1x Set of 6-pin ribbon cables
1x Phillips screwdriver and hex key
1x Pair of protective gloves
InputPCB Connector
OutputPCB Connector
Output voltage (V)12.0
Output current (A)NC
Input voltage (V)240.0
Input voltage (V)110.0
Power SupplyRegulated Linear Power Supply
