By buying this product you get 139 loyalty points
The Eversolo T8 network transport allows you to connect your HiFi system to a network so you can enjoy high-resolution digital sources. Specially designed to deliver a digital stream to an external DAC or integrated amplifier, it supports numerous network protocols. This gives you easy access to various streaming platforms such as Qobuz, Tidal, Amazon Music, and Spotify. It supports high-resolution streams up to PCM 32-bit 768kHz and DSD512. With no DAC or preamplification, it focuses purely on signal transmission for flawless performance. In addition, the sound can be adjusted via DSP, equalizer, or acoustic calibration for near-perfect sound reproduction. Added to this is a beautiful 6" color LCD touchscreen with a brand new, fluid, and intuitive interface for total control of the T8. In terms of connectivity, it features a full range of digital outputs for nearly universal compatibility.
The Eversolo T8 benefits from high-quality components and a clean architecture. Starting with its linear power supply, which incorporates a shielded and insulated 4N OFC copper toroidal transformer to prevent any perceptible noise. In addition, the clock is accompanied by a femtosecond oscillator with a precision that greatly reduces jitter for clear and dynamic sound reproduction. It should also be noted that each digital output benefits from galvanic isolation and an independent decoupling circuit. Eversolo has done everything possible to ensure optimal signal transmission.
With its high bandwidth, low latency, and excellent interference immunity, WiFi 6 ensures stable and efficient wireless audio transmission for a smooth playback experience.
Offers powerful multitasking capabilities, combined with high-speed, high-capacity memory for fast caching and processing of large data sets.
A large amount of RAM (4GB DDR) ensures stable multitasking, while 64GB of built-in storage allows you to store high-quality audio files and system resources.
Thanks to its EOS operating system, the T8 gives you access to numerous streaming apps including Tidal, Qobuz, HighRes Audio, Amazon Music, Spotify, Deezer, Napster, and many more. To top it off, the T8 is compatible with DLNA and UPnP network protocols and is Roon Ready certified for access to your local network music library. Capable of supporting up to PCM 32-bit 768kHz and DSD512, this device is sure to delight enthusiasts of high-resolution files.
In addition to its network connectivity, the T8 has a Bluetooth receiver offering reliable and stable reception via a source such as your phone, tablet, or computer.
The T8 features a powerful 10-band equalizer supported by its internal DSP engine, allowing for precise adjustment of the sound output according to the listener's preferences or the characteristics of their HiFi system. A handy feature allows users to create and save various curve profiles for easy retrieval. In addition, the Evotune automatic calibration system is integrated into the T8. Using microphones and an algorithm, it analyzes the acoustics of the room and applies a correction to optimize the curve for balanced sound. Calibration can be performed using the brand's EM-01 microphone or a smartphone via the Eversolo Control app.
The two SSD slots support up to two 8TB external SSDs, providing a possible total of 16TB of storage—enough space to store tens of thousands of lossless, master-quality audio files.
Please note that SSDs are not included with the T8.
The T8 features a sturdy metal chassis and a reinforced 6" (15 cm) LCD touchscreen. It has a new, smooth and attractive interface that allows you to easily access the device settings and your music. Several display styles are available for complete customization of the T8. As an added bonus, numerous VU meters are available for display.
1 | Mains power supply |
2 | SPF fiber input |
3 | Gigabit LAN input |
4 | USB-A 3.0 / USB-A 3.0 OTG input |
5 | Isolated USB-A 3.0 output |
6 | AES/EBU output |
7 | Toslink optical output |
8 | Coaxial output |
9 | I2S output via HDMI |
10 | Trigger IN/OUT (12V) |
The I2S output via HDMI has 8 different output modes to ensure compatibility with most DACs on the market.
Product type | Network transport |
Inputs | WiFi 1x RJ45 Ethernet port 1x SFP Ethernet port 1x USB-A 3.0 OTG input 1x USB-A 3.0 input |
Outputs | 1x Isolated USB-A output 1x HDMI I2S output 1x Toslink optical output 1x Coaxial output 1x AES/EBU output |
Other connectors | Trigger in Trigger out |
Supported sample rates | USB and HDMI I2S outputs: PCM up to 32bit 768kHz, DSD up to DSD512 Coaxial, optical and AES/EBU outputs: PCM up to 24bit 192kHz, DSD DoP64 |
Supported audio formats | DSD (DSF, DFF, SACD ISO Supports DST up to DSD512) MP3,APE,WAV,FLAC,AIF,AIFF,AAC,NRG,CUE |
WiFi | Wi-Fi 6 (2.4G+5G dual band) |
SFP fiber optic network | SFP modules are not included. Supports single-fiber single-mode, dual-fiber single-mode optical modules, and SFP network communication modules. |
Streaming services | TIDAL, Qobuz, HIGHRESAUDIO, Amazon Music, Roon Ready, TIDAL Connect,Qobuz connect, DLNA etc. |
Supported network protocols | UPnP, NAS, SMB |
Screen | 6" color LCD touchscreen |
Internal memory | 4G DDR4 +64G eMMC |
Memory expansion | Dual rack for SSDs up to 16 TB (2 x 8 TB) |
Power supply | AC 110–240V, 50/60Hz |
Energy consumption | 20W |
Dimensions | 315 x 230 x 88mm (LWH) |
Package | 1x Eversolo T8 Network Streamer 1x Remote control 1x AC power cable |
Input | USB |
Input | WiFi |
Output | Coaxial SPDIF |
Output | USB |
Output | I2S LVDS via HDMI |
Output | AES/EBU |
Output | Optical Toslink |
DAC / ADC Chip | NC |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Color | Black |
Remote Control | Yes |
Streaming services & Network protocols | Roon / Roon Bridge / Roon Ready |
Streaming services & Network protocols | Qobuz |
Streaming services & Network protocols | UpnP |
Streaming services & Network protocols | Amazon Music |
Streaming services & Network protocols | Qobuz Connect |
Streaming services & Network protocols | DLNA |
Streaming services & Network protocols | Tidal Connect |
Streaming services & Network protocols | Deezer |
Streaming services & Network protocols | SMB |
Streaming services & Network protocols | Tidal |
Streaming services & Network protocols | Bubble UpnP |
Streaming services & Network protocols | Web radios |
Streaming services & Network protocols | Spotify Connect |
Streaming services & Network protocols | Spotify |
