FOSI AUDIO S3 LITE Network Player Digital Transport
The Fosi Audio S3 Lite is a network transport designed to add high-resolution streaming to a Hi-Fi setup, without handling digital-to-analog conversion itself. It transmits streams up to PCM 32bit / 768kHz to an external DAC through its USB-A, optical, and coaxial outputs, while maintaining low digital distortion.
By buying this product you get 23 loyalty points
Reference : 22462
230,00 €tax incl.
191,67 € tax excl.
Fosi Audio S3 LITE Streamer Digital Transport WiFi 6 Bluetooth
FOSI AUDIO S3 LITE: Front view
The Fosi Audio S3 Lite is a network transport designed to add high-resolution streaming to a Hi-Fi setup, without handling digital-to-analog conversion itself. It transmits streams up to PCM 32bit 768kHz to an external DAC through its USB-A, optical, and coaxial outputs, while maintaining low digital distortion.
Compatible with Wi-Fi 6, Google Cast, and AirPlay 2, it lets you stream music from compatible apps, synchronize several listening zones, and control the main functions from the Fosi Audio app or its Bluetooth remote. Its compact form factor and 12V trigger make it easy to integrate into an existing system, whether dedicated to stereo listening or set up in a multiroom configuration.
FOSI AUDIO S3 LITE: Use with a DAC
Fosi Audio S3 Lite: High-resolution digital transport
The Fosi Audio S3 Lite is a network transport designed to modernize an existing Hi-Fi setup by adding access to streaming services, without integrating digital-to-analog conversion. The signal is transmitted directly to an external DAC through the USB-A output, with support for PCM up to 32bit 768kHz, in order to preserve the audio data up to the conversion stage. This architecture thus leaves it to the DAC and amplifier to define the final sound character of the system.
Fosi Audio S3 Lite: Digital connectivity and integration
To adapt to different configurations, the S3 Lite features USB-A, optical, and coaxial outputs, allowing it to connect to most external DACs. Its digital output shows a low level of distortion and noise, with THD+N as low as 0.000003%, while the management of track and streaming quality changes limits audible parasitic noise. The transport can thus be inserted between a music app and an external converter, whether paired with an older Hi-Fi system or a more recent installation.
FOSI AUDIO S3 LITE: Digital outputs
Fosi Audio S3 Lite: Network streaming and multiroom control
The S3 Lite receives music directly from compatible apps and relies on a dual-band 2.4GHz / 5GHz Wi-Fi 6 connection to ensure stable transmission within a stated range of up to 100 meters. The Fosi Audio app brings together configuration, playback, source and output mode selection, while integrating a 10-band parametric equalizer to adjust the output to the system in use. Google Cast and AirPlay 2 compatibility also allows synchronized playback across several rooms, with multiple S3 Lite or S3 devices controlled from a smartphone.
FOSI AUDIO S3 LITE: Fosi app
FOSI AUDIO S3 LITE: Multiroom
Fosi Audio S3 Lite: Installation and remote control
Its compact enclosure limits clutter on a desk, a shelf, or in a Hi-Fi cabinet, while the 12V trigger allows its power-on to be automatically synchronized with that of a DAC or another equipped device. The Bluetooth remote controls input selection, playback, and power up to 15 meters, which makes daily use easier without directly accessing the transport. This combination of connectivity, network control, and system integration makes it possible to add streaming to an existing system while keeping a fully digital signal path.
Technical specifications
Product typeDigital Transport
Inputs1x RJ45
WiFi 6
Bluetooth 5.3
Outputs1x USB-A
1x Optical Toslink
1x Coaxial
Supported sampling ratesPCM up to 32bit 768kHz
ConnectivityAirPlay 2
Google Cast
DLNA
Roon Ready
Spotify Connect
TIDAL Connect
Qobuz Connect
Supported Bluetooth codecsSBC
AAC
Trigger
Multiroom support
Supply voltage12V DC
Dimensions147 x 146.5 x 32.5mm
Weight502g
Package1x Fosi Audio S3 Lite
1x Remote control
1x Power adapter
1x Optical cable
InputWiFi
InputRJ45
OutputCoaxial SPDIF
OutputOptical Toslink
OutputUSB
DAC / ADC ChipNC
Max sampling rate768kHz
Remote ControlYes
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsQobuz Connect
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsChromecast
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
FOSI AUDIO S3 LITE Streamer Digital Transport WiFi 6 Bluetooth
The Fosi Audio S3 Lite is a network transport designed to add high-resolution streaming to a Hi-Fi setup, without handling digital-to-analog...
