By buying this product you get 85 loyalty points
With the SW-6 SPF, LHY Audio offers us a network switch featuring 5 RJ45 ports, one of which is digitally isolated, a fibre optic SFP port and a BNC input connected to the 10mHz OCXO clock. All this is housed in an elegant anodised aluminium enclosure machined from solid material and designed to separate AC current processing, DC current processing and audio signal processing.
For its power supply, the SW-6 SPF deploys a Talema 15VA encapsulated transformer coupled to an RFI suppression filter. Once transformed, the current passes through a high-speed voltage rectifier, a 3-stage CLC filter circuit and finally a LT3042 + PNP linear voltage regulator. This multi-stage processing ensures a perfectly stable power supply without the slightest parasitic noise or artefact.
In terms of signal processing, the LHY Audio SW-6 SPF has 5 RJ45 ports, one of which is digitally isolated, and an optical SPF port. But that's not all: the SW-6 SPF has a high-precision 10 MHz OCXO clock at its heart, itself connected to a BNC input if you wish for your network switch to be synchronised to an external clock.
Product type | Optical Fiber Ethernet Network Switch |
Interface | 4x RJ45 ethernet port 1x Isolated RJ45 ethernet port 1x SFP fiber optic connector 1x entrée BNC pour horloge 10MHz (impédance d'entrée 50Ω/75Ω) |
Power supply | 220V ~ 240V AC |
Dimensions | 240 x 175 x 50mm |
Weight | 2kg |
Color | Silver |
Package | 1x LHY Audio SW-6 SPF 1x Power supply cable |
Color | Silver |
Length (m) | N/A |
Shielding | NC |
Section (mm²) | N/A |
Connector | BNC |
Connector | Optical |
Connector | RJ45 |
Conductors material (Cable) | N/A |
Conductors Plating (Cable) | NC |
