Filters
claude B.
excellent petit steamer
bonjour, je suis ravi du rendu sonore en écoute via rca numérique.
Mais aucun son par les sorties usb
et je ne comprends pas...
Jean-Pierre B.
Beau produit
Il manque un mode d’emploi.
Il faut fixer le socle en premier : tête de vis M6 à l’intérieur (tête en bas) en choisissant une...
Kostadin K.
FOSI AUDIO ZP3
A wonderful preamplifier, I listen to it in bypass mode, it sounds more bassy to me. I give it 4 stars because it arrived with...
New products
  • Ref : 21533
    The Aune AC45 is an open-back clip-on dynamic headphone featuring 40mm bio-fiber composite diaphragms. It delivers a wide soundstage and immersive bass for a highly enjoyable listening experience. Its open design provides an airy and clear presentation. The clip-on system remains extremely comfortable compared to traditional headband headphones; the hook...
    139,00 € 115,83 €Ex.
    In Stock
  • Ref : 21536
    The Aune IR300 are audiophile in-ear monitors designed to deliver precise, immersive, and customizable sound reproduction. They rely on a crystal-reinforced diaphragm that ensures rigidity and lightness for detailed sound reproduction and excellent transient response. Their symmetrical driver system optimizes diaphragm movement stability, reducing...
    In Stock
  • Ref : 21538
    In Stock
    Mundorf Msolder SilverGold solder wire is composed of 9.5% silver and 0.1% gold. It is recommended for high-end projects requiring superior conductivity (tube mounting, cable assembly, silver/gold foil). Its precious metal content is balanced by a 2.5% flux proportion (2.2.3).
    499,00 € 415,83 €Ex.
    In Stock
  • Ref : 21539
    The Aune Audio NC1 EVO is a high-end audiophile solution combining an ultra-stable 10MHz master clock and a silent linear power supply, designed to optimize the performance of DACs, digital transports, and streamers.
    429,00 € 357,50 €Ex.
    In Stock
  • Ref : 21542
    In Stock
    The xDuoo is a plug-and-play Hi-Res Bluetooth transmitter with USB-C input. Extremely convenient, it can transform many devices into high-resolution Bluetooth transmitters thanks to its Qualcomm Bluetooth 5.4 chip and support for high-definition aptX, aptX HD, aptX Adaptive, and aptX Lite/LC3 (LE Audio) codecs up to 24bit 96 kHz.
    42,90 € 35,75 €Ex.
    In Stock
  • Ref : 21550
    In Stock
    The Audio-GD R-1 MK3 is a discrete R2R digital-to-analogue converter designed to provide conversion up to PCM 32bit 384kHz and DSD512, using a matched resistor architecture driven by FPGA DSP to ensure linearity beyond 16 effective bits. This resistor ladder topology, combined with proprietary digital processing, aims to achieve a more direct analogue...
    849,00 € 707,50 €Ex.
    In Stock
  • Ref : 21553
    In Stock
    In Stock
  • Ref : 21621
    The Ludic Orpheus speaker cable is designed to transmit the audio signal between the amplifier and the speakers with low resistance and excellent electrical stability. It features an OCC copper design combined with double shielding, which helps to minimise interference whilst maintaining signal integrity. Intended for use in home hi-fi systems, it...
    399,00 € 332,50 €Ex.
    In Stock
  • Ref : 21622
    The Ludic Orpheus Interlink is an RCA interconnect cable designed to transmit audio signals between your source and your amplifier with low impedance and good immunity to interference. It features an OCC copper construction combined with double shielding, preserving signal integrity whilst minimising interference in the home environment. Designed for...
    74,90 € 62,42 €Ex.
    In Stock
  • Ref : 21627
    119,00 € 99,17 €Ex.
    In Stock
  • Ref : 21611
    Jantzen Audio Air Core Wire Coil are made from high-purity copper wire, perfectly wound to create a distortion-free inductor for all audio applications. Their low inductance tolerance of +/-3% and high power handling make them the most versatile coils on the market.
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 21541
    The iBasso AMP18 is a discrete headphone amplifier module specially designed to accompany the brand's DX300, DX320 and DX340 DAPs. It features an 80-transistor architecture, cascaded current feedback and a complementary push-pull output stage, ensuring stable and controlled amplification. Powered by 12V DC, it achieves 1740 mW + 1740 mW of power under...
    279,00 € 232,50 €Ex.
    In Stock
  • Ref : 21545
    The iBasso D17 Atheris is a high-end audiophile DAC and headphone amplifier based on a hybrid conversion architecture that strictly separates PCM and DSD processing. It combines a discrete R2R network of 284 resistors paired to 0.01% accuracy across four symmetrical channels with a 1-bit matrix composed of 64 PWM cells, achieving a THD+N of -104dB in PCM...
    1 699,00 € 1 415,83 €Ex.
    In Stock
