IBASSO D17 ATHERIS Headphone Amplifier DAC
The iBasso D17 Atheris is a high-end audiophile DAC and headphone amplifier based on a hybrid conversion architecture that strictly separates PCM and DSD processing. It combines a discrete R2R network of 284 resistors paired to 0.01% accuracy across four symmetrical channels with a 1-bit matrix composed of 64 PWM cells, achieving a THD+N of -104dB in PCM and -114dB in DSD. This dual topology is based on a Gen 3 FPGA Master responsible for routing and reclocking via Accusilicon femtosecond oscillators, in order to maintain temporal consistency despite the use of two distinct conversion architectures.
By buying this product you get 169 loyalty points
Reference : 21545
1 699,00 €tax incl.
1 415,83 € tax excl.
iBasso D17 Atheris Headphone Amplifier DAC R2R/1bit 32bit 768kHz DSD512
iBasso D17 Atheris : Front view
Beyond conversion, the D17 incorporates a symmetrical amplification stage with dual 6P1 Nutubes powered by 24V, preceded by a dedicated buffer, delivering up to 1200mW + 1200mW into 32Ω. The whole unit is based on a damped mechanical structure and a dual battery power supply separating the digital and analogue sections, while a volume control combining a 24-position analogue attenuator and DSP processing ensures precise level management without inter-channel imbalance.
iBasso D17 Atheris: R2R/1-bit conversion
The D17 Atheris adopts a differentiated conversion architecture, isolating PCM and DSD stream processing to avoid any intermediate conversion. For PCM signals, it uses a discrete R2R network comprising 284 resistors paired to within 0.01% and distributed across four symmetrical channels. This precision pairing guarantees the linearity of the voltage steps and achieves a THD+N of –104dB. This approach favours direct conversion by analogue weighting, reducing quantisation errors and ensuring stable reproduction across the entire dynamic range.
At the same time, DSD streams are handled by a 1-bit architecture based on 64 PWM DAC cells organised into eight independent groups. This parallelisation smooths modulation noise while increasing instantaneous processing capacity. The system thus achieves a THD+N measured at –114dB. This strict separation of conversion paths allows each format to be exploited according to its native structure, without any algorithmic compromise between PCM and DSD.
iBasso D17 Atheris :DAC R2R
iBasso D17 Atheris: FPGA-Master Gen 3
At the heart of the digital system, the FPGA-Master Gen 3 handles signal processing upstream of the conversion stages, dynamically determining which circuit to use depending on the nature of the incoming stream. Beyond simple PCM or DSD routing, it applies full reclocking based on two Accusilicon femtosecond oscillators with very low phase noise, establishing a unified time reference independent of the source.
This approach is extended by high-precision timing control and real-time clock regeneration, which compensate for the timing differences inherent in R2R and 1-bit architectures. By maintaining phase consistency despite the use of two distinct conversion technologies, the FPGA reduces jitter and stabilises the harmonic structure at the output, which is essential in a device combining a dual conversion topology.
iBasso D17 Atheris :FPGA Master 3
iBasso D17 Atheris : Tube Korg 6P1
iBasso D17 Atheris: Balanced tube amplification
The amplification stage is based on two Korg 6P1 Nutube tubes in a symmetrical architecture, a configuration that helps reduce common mode noise and improve channel separation. The anodes are powered by 24V, which is higher than in conventional portable implementations, improving linearity and expanding the available dynamic range.
Upstream, a BUF634A buffer ensures impedance matching and stabilises tube driving, maintaining the consistency of the signal from the DAC while ensuring sufficient current capacity. This chain results in an output power of 1200mW + 1200mW under 32Ω, allowing demanding headphones to be powered without any problems.
iBasso D17 Atheris: Reduction of microphonic effects
The internal structure is based on a double-layer PCB combined with integrated damping materials. This composite construction increases mechanical rigidity while dispersing vibration stresses. Beyond simple structural strength, this approach limits the transmission of vibrations to the tubes, thereby reducing the microphonic phenomena inherent in the amplification architecture used.
iBasso D17 Atheris : multi-layer PCB
iBasso D17 Atheris : Double battery
iBasso D17 Atheris: Dual battery power supply
The D17 Atheris adopts a dual battery architecture that physically separates the power supply for the digital section from that dedicated to amplification. This separation limits interference between high-switching stages and sensitive analogue stages, reducing noise feedback and dynamic interactions during load variations.
This separate power supply helps maintain stable voltage at the tubes and output stages, which is essential for preserving linearity and dynamic consistency under complex loads.
iBasso D17 Atheris: Analogue and digital volume control
Volume management is based on a dual complementary approach. The analogue section is handled by a 24-position, four-section mechanical attenuator developed in-house, guaranteeing a maximum deviation of ±0.1dB between the left and right channels.
At the same time, digital processing relies on a professional DSP that allows for precise signal adjustment prior to conversion. This analogue/digital combination enables fine tuning to the headphones used while preserving the effective resolution of the signal. This control architecture thus maintains tonal consistency and spatial accuracy across the entire volume range.
iBasso D17 Atheris : Volume control
Product typePortable DAC
Portable headphone amplifier
Inputs1x USB-C
1x Jack 3.5mm Optical/Coaxial
Outputs1x 4.4mm balanced jack
1x 3.5mm single-ended jack
Supported sampling ratesUSB-C: PCM 32bit 768kHz / DSD512
Coaxial: PCM 32bit 768kHz / DOP256
Optical: PCM 32bit 768kHz / DOP128
Frequency response15Hz-22kHz (-1dB)
15Hz-40kHz (-2.5dB)
Charging portUSB-C
Autonomy15h
Charging time3h
DAC R2R amplified outputs
Output levelJack 4.4mm: 7Vrms
Jack 3.5mm: 3.5Vrms
Output powerJack 4.4mm: 1200mW + 1200mW @ 32Ω
Jack 3.5mm: 320mW + 320mW @ 32Ω
Total harmonic distortion more noise (THD+N)Jack 4.4mm: -76dB
Jack 3.5mm: -70dB
Signal-to-noise ratio (SNR)Jack 4.4mm: 116dB
Jack 3.5mm: 112dB
Dynamic rangeJack 4.4mm: 116dB
Jack 3.5mm: 112dB
CrosstalkJack 4.4mm: 129dB
Jack 3.5mm: 125dB
Output impedanceJack 4.4mm: 1.9Ω
Jack 3.5mm: 1Ω
DAC R2R line outputs
Low gain output levelJack 4.4mm: 2.4Vrms
Jack 3.5mm: 2Vrms
Output power gain fortJack 4.4mm: 4Vrms
Jack 3.5mm: 2.4Vrms
Total harmonic distortion more noise (THD+N)Jack 4.4mm: -104dB
Jack 3.5mm: -103dB
Signal-to-noise ratio (SNR)Jack 4.4mm: 126dB
Jack 3.5mm: 120dB
Dynamic rangeJack 4.4mm: 126dB
Jack 3.5mm: 120dB
CrosstalkJack 4.4mm: 120dB
Jack 3.5mm: 100dB
DAC 1bit amplified outputs
Output levelJack 4.4mm: 3.5Vrms
Jack 3.5mm:1.7Vrms
Output powerJack 4.4mm : 340mW + 340mW @32Ω
Jack 3.5mm : 87mW + 87mW @32Ω
Jack 3.5mm: -70dB
Signal-to-noise ratio (SNR)Jack 4.4mm: 109dB
Jack 3.5mm: 104dB
Dynamic rangeJack 4.4mm: 109dB
Jack 3.5mm: 104dB
CrosstalkJack 4.4mm: 123dB
Jack 3.5mm: 118dB
Jack 3.5mm: 1Ω
Low gain output levelJack 4.4mm: 2Vrms
Jack 3.5mm: 1Vrms
Output power gain fortJack 4.4mm: 2.4Vrms
Jack 3.5mm: 1.2Vrms
Total harmonic distortion more noise (THD+N)Jack 4.4mm: -114dB
Jack 3.5mm: -110dB
Signal-to-noise ratio (SNR)Jack 4.4mm: 118dB
Jack 3.5mm: 114dB
Dynamic rangeJack 4.4mm: 118dB
Jack 3.5mm: 114dB
Jack 3.5mm: 100dB
Power supply voltage5V/3A
Dimensions145 x 86.3 x 31.6mm
Weight470g
ColorSilver
Package1x iBasso D17 Atheris
1x Protective case
1x USB-C to Lightning cable
1x USB-C to USB-C cable
1x USB-A to USB-C cable
1x 4.4mm jack to 4.4mm jack cable
1x 3.5mm to 3.5mm Jack Cable
InputJack 3.5mm
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipR2R LADDER DAC
DAC / ADC ChipPWM
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
ClassTube amp
IBASSO D17 ATHERIS Headphone Amplifier DAC R2R/1bit 32bit 768kHz DSD512
The iBasso D17 Atheris is a high-end audiophile DAC and headphone amplifier based on a hybrid conversion architecture that strictly separates PCM...
