Dayton Audio DS175-PR - 16.5cm Passive Radiator
The Dayton Audio DS175-PR is a 16.5cm passive radiator designed to replace an existing model or fit a new speaker enclosure. It allows a lower tuning frequency to be achieved in a reduced volume. Its coated paper cone and rubber surround ensure a clean reproduction of low frequencies. Its stamped steel frame integrates a rear brace to reinforce its stability, while the M5 thread allows mass to be added in order to adjust the enclosure tuning. It has a resonance frequency of 24.5Hz and an emissive surface measuring 128.7cm².
Reference : 22305
25,90 €tax incl.
21,58 € tax excl.
Dayton Audio DS175-PR Passive Radiator Paper Speaker 16.5cm
Photo du DAYTON AUDIO DS175-PR Passive Radiator Paper Speaker 16.5cm
DAYTON AUDIO DS175-PR Diagram
Technical Specifications
Product typePassive radiator
Nominal diameter16.5cm
Thiele-Small Parameters
Resonance frequency (Fs)24.5Hz
Cone surface area (Sd)128.7cm²
Mechanical quality factor (Qms)5.57
Total moving mass + Air load on cone (Mms)36.6g
Mechanical compliance of suspension (Cms)1.15mm/N
Compliance equivalent volume (Vas)0.95ft³
Max linear excursion (Xmax)8mm
Mounting informations
Baffle cutout diameter14.3cm (5.63")
Depth4.78cm (1.88")
Total external diameter17.6cm (6.94")
Number of mounting holes5
Materials
ConePaper
FrameSteel
Weight0.32kg
Package1x Dayton Audio DS175-PR
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)165.0
Diaphragm typePaper
Max Linear Excursion (Xmax) (mm)8.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
The Dayton Audio DS175-PR is a 16.5cm passive radiator designed to replace an existing model or fit a new speaker enclosure. It allows a lower...
