DAYTON AUDIO DS90-PR Passive Radiator
New
The Dayton Audio DS90-PR is a 7.62cm (3") passive radiator designed to complement the paper cone drivers of the Dayton Audio Designer series or to replace an existing model. In a compact enclosure, it allows lowering the tuning compared to a conventional port, without requiring a duct.
Reference : 22544
22,90 €tax incl.
19,08 € tax excl.
Grantie 5 ans
DAYTON AUDIO DS90-PR Passive Radiator 42.4Hz Ø7.62cm
DAYTON AUDIO DS90-PR: Front view
The Dayton Audio DS90-PR is a passive radiator of 7.62cm (3") designed to complement the paper cone drivers of the Dayton Audio Designer series or to replace an existing model. In a compact enclosure, it allows lowering the tuning compared to a conventional port, without requiring a duct.
Its treated paper cone, medium-profile rubber surround and steel frame reuse the construction of the drivers in the range. An integrated mass provides a starting point for tuning, while the rear M5 thread allows adding weights to adapt the tuning to the enclosure. The frame edge is also designed for surface mounting, particularly in hi-fi or portable speakers.
DAYTON AUDIO DS90-PR: Dimensions
Technical specifications
Product typePassive radiator
Nominal diameter3"
Thiele-Small parameters
Resonance frequency (Fs)42.4Hz
Mechanical quality factor (Qms)5.9
Compliance equivalent volume (Vas)0.124ft³
Mechanical compliance of suspension (Cms)2.55mm/N
Total moving mass + air load on the diaphragm (Mms)5.5g
Max linear excursion (Xmax)4mm
Diaphragm surface area (Sd)31.2cm²
Materials
DiaphragmPaper
SurroundRubber
FrameSteel
Mounting informations
Total external diameter9.22cm (3.63")
Cutout diameter7cm (2.76")
Depth2,18cm (0.86")
Number of mounting holes4
Weight100g
PackageSold individually
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)76.2
Diaphragm typePaper
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
The Dayton Audio DS90-PR is a 7.62cm (3") passive radiator designed to complement the paper cone drivers of the Dayton Audio Designer series...
