DAYTON AUDIO SS8-PR Passive Radiator
The Dayton Audio SS8-PR is a 20.32cm (8") passive radiator designed to extend the low-frequency response of a compact speaker, particularly as a complement to the SS8-22 subwoofer. By replacing the port with a passive membrane, it allows tuning of the enclosure volume without airflow noise or the need for a long port, which facilitates the design of low-footprint systems.
Reference : 22530
74,90 €tax incl.
62,42 € tax excl.
Grantie 5 ans
DAYTON AUDIO SS8-PR Passive Radiator 37.4Hz Ø20.32cm
DAYTON AUDIO SS8-PR: Front view
Its construction reuses the aesthetic and mechanical elements of the Signature Series range: cast aluminum frame, anodized cone, and rubber surround. This membrane is designed to accommodate the large excursions required to reproduce low frequencies, while the Sandwich Mass Structure (SMS) system holds the tuning mass between the spider and the surround to preserve symmetrical movement.
Tuning is done using a threaded rod, a wing nut, and a Nylock lock nut, which allow the added mass to be adjusted and then secured. The five supplied 46 g masses offer several options for adjusting the tuning frequency, to adapt the radiator to the enclosure volume and the desired behavior. Paired with the SS8-22, the SS8-PR is thus suitable for compact home theater, hi-fi, or car audio configurations.
DAYTON AUDIO SS8-PR: Dimensions
Technical specifications
Product typePassive radiator
Nominal diameter20.32cm (8")
Thiele-Small parameters
Resonance frequency (Fs)37.4Hz
Membrane surface area (Sd)198.6cm²
Mechanical quality factor (Qms)2.55
Total moving mass + air load on the membrane (Mms)85g
Mechanical compliance of suspension (Cms)0.212mm/N
Compliance equivalent volume (Vas)0.42ft³
Max linear excursion (Xmax)25mm
Mounting informations
Cutout diameter18.41cm (7.25")
Depth7.36cm (2.9")
Number of mounting holes8
Total outer diameter21.41cm (8.43")
Materials
MembraneAluminum
FrameCast aluminum
SurroundRubber
Weight1.45kg
PackageSold individually
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)203.2
Diaphragm typeAluminium
Max Linear Excursion (Xmax) (mm)25.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
The Dayton Audio SS8-PR is a 20.32cm (8") passive radiator designed to extend the low-frequency response of a compact speaker, particularly as...
