Center Channel Speaker 2 Way 80W 4 Ohm 86dB 60Hz-20kHz
The Dayton Audio MK442 2-way centre speaker (two woofers and a tweeter) offers excellent sound reproduction at a more than reasonable price.
The Ø1.9cm (0.75") diameter silk dome tweeter, located in the centre of the MK442 loudspeaker, provides soft, airy highs for a delicate, non-aggressive sound.
On either side of the speaker, Ø10.2cm (4") diameter woofers are used to reproduce low frequencies up to 60Hz. The frequency response of these woofers is not cut off, allowing them also to unveil beautiful low-midrange/midrange, for a deep and coherent reproduction.
| Specifications | |
| Product type | Center channel speaker |
| Number of ways | 2 |
| Speaker drivers | 2x Treated-Paper Woofer Ø10.2cm (4") with 4 layers voice coil 1x Silk dome Tweeter Ø1.9cm (0.75") with ferrofluid cooling |
| Input impedance | 4 Ohm |
| Power handling | RMS : 80W Max : 160W |
| Frequency response | 60Hz - 20000Hz |
| Sensitivity | 86dB 1W/1m |
| Crossover | Third order high-pass Second order low-pass |
| Terminals | Speaker terminals (compatible with banana plugs) |
| Port tuning | 57Hz |
| General | |
| Color | Black |
| Dimensions | 14.94" x 5.75" x 6.6" 37.9 x 14.6 x 16.8cm |
| Weight | 8.7lbs. 3.9kg |
| Color | Black |
| Impedance (Ω) | 4 |
| Efficiency / Sensitivity (dB) | 86.0 |
| Lowest frequency (Hz) | 60 |
| Highest frequency (Hz) | 20000 |
| Power (W) | 60.0 |
| Number of loudspeakers | 3 |
| Speaker type | Passive |
| Speaker form factor | Center speaker |
