Connector
Max sampling rate
DAC / ADC Chip
Class
Connectic
Length
1 m - 2 m
Conductors material (Cable)
Contacts Plating (Connector)
Input
Output
Remote Control
Networking
Color
Conductors Plating (Cable)
Shielding
Vasilios K.
Ça Chauffe !
Geert J.
du haut de gamme à petit prix
J’ai acheté le JC2-FET pour relier mes sources à mon amplificateur de puissance. Mes sources n’ayant pas de réglage de volume,...
Portable DAC
The term DAC (Digital to Analog Converter) refers to a digital to analog converter. Find a selection of our USB, SPDIF, I2S, AES/EBU Audio DACs chosen for you, capable of sublimating your 24bit and 32bit High Definition audio files.
Portable DAC let you enjoy your high-definition music wherever you are, anytime.
