DD HIFI TC44GRIP Portable DAC Headphone Amplifier
The ddHiFi TC44GRIP is a portable USB-C DAC/headphone amplifier designed to enhance the audio quality of compatible smartphones, tablets, and computers. Based on an architecture featuring two Cirrus Logic CS43198 DACs and two SGM8262-2 operational amplifiers, it supports PCM streams up to 32bit / 768kHz as well as native DSD256.
Reference : 22163
159,00 €tax incl.
132,50 € tax excl.
ddHiFi TC44GRIP Portable DAC Headphone Amplifier 2x CS43198 2x SGM8262 32bit 768kHz DSD256
DD HIFI TC44GRIP
The ddHiFi TC44GRIP is a portable USB-C DAC/headphone amplifier designed to enhance the audio quality of compatible smartphones, tablets, and computers. Based on an architecture featuring two Cirrus Logic CS43198 DACs and two SGM8262-2 operational amplifiers, it supports PCM streams up to PCM 32bit 768kHz as well as native DSD256. It features a 3.5mm single-ended headphone output delivering up to 80mW into 32Ω (1.7Vrms) and a 4.4mm balanced output providing up to 330mW into 32Ω (3.3Vrms), with a signal-to-noise ratio of ≥125dB, a dynamic range of ≥125dB, and total harmonic distortion of ≤0.0004%. Its USB-C Power Delivery connector allows the connected smartphone to be charged simultaneously at up to 60W while listening. A shielded pure silver USB-C cable, its ergonomic "Grip" design that attaches to the back of the phone using the included magnetic plates, and two decorative pads (black and khaki) complete a package designed for portable audiophile use.
ddHiFi TC44GRIP: Dual CS43198 DACs and Dual SGM8262 Amplification
The TC44GRIP combines two Cirrus Logic CS43198 DACs with two independent SGM8262-2 amplifiers to provide high-resolution decoding and powerful amplification with exceptionally low noise and distortion. Compatible with PCM 32bit 768kHz and native DSD64 / DSD128 / DSD256, it delivers a precise and detailed audio signal suitable for both in-ear monitors and more demanding headphones thanks to its balanced 4.4mm output delivering 330mW into 32Ω.
DD HIFI TC44GRIP: Dual CS43198 DACs and Dual SGM8262 Amplification
DD HIFI TC44GRIP: Simultaneous Listening and Charging
ddHiFi TC44GRIP: Simultaneous Listening and Charging
Thanks to its USB-C Power Delivery port, the TC44GRIP allows you to enjoy your music while charging the connected device. Compatible with Power Delivery chargers up to 60W, it prevents interruptions during extended listening or gaming sessions. Actual charging power naturally depends on the capabilities of both the connected device and the charger.
ddHiFi TC44GRIP: Ergonomic Grip Design
Unlike conventional USB DACs that hang from the cable, the TC44GRIP adopts a "Grip" form factor that attaches directly to the back of a smartphone using the supplied magnetic plates. Its shielded pure silver USB-C cable is integrated into the enclosure and slides into a specially designed groove to reduce mechanical stress during connection and disconnection. Two decorative pads also improve grip while allowing you to personalize its appearance.
DD HIFI TC44GRIP: Ergonomic Grip Design
DD HIFI TC44GRIP Overview
1USB-C Charging Port
2USB-C input / Charging output
33.5mm headphone output
44.4mm balanced headphone output
Technical Specifications
Product TypePortable DAC Headphone Amplifier
DAC Chip2x CS43198
Amplifier Chip2x SGM8262-2
Input1x USB-C Male
Outputs1x 3.5mm single-ended jack
1x 4.4mm balanced Jack
Additional ConnectivityPD Fast Charging Port 60W
Supported Sample RatesPCM up to 32bit 768kHz
DSD up to DSD256
SNR≥ 125dB
Dynamic Range≥ 125dB
THD+N≤ 0.0004%
LED IndicatorBlue: PCM ≤ 48kHz
Green: PCM ≥ 88.2kHz
White: DSD
3.5mm Jack Output (32Ω Load)
Output Power≥ 80mW
Output Voltage1.7Vrms
Max. MIC Input60mW
4.4mm Jack Output (32Ω Load)
Output Power≥ 330mW
Output Voltage3.3Vrms
Package Contents1x ddHiFi TC44GRIP
3x Magnetic Pads
2x Decorative Pads
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipCS43198
Max sampling rate768kHz
Max sampling rateDSD256
ColorSilver
DDHIFI TC44GRIP Portable DAC Headphone Amplifier 2x CS43198 2x SGM8262 32bit 768kHz DSD256
The ddHiFi TC44GRIP is a portable USB-C DAC/headphone amplifier designed to enhance the audio quality of compatible smartphones, tablets, and...
