IFI AUDIO GR 2 MT Headphone Amplifier Portable DAC
New
The iFi Audio iDSD GR 2 MT is a portable DAC and headphone amplifier designed to handle digital-to-analog conversion and drive headphones or an audio system. It delivers up to 1513 mW into 32 Ω and is built around a Burr-Brown PCM1795 DAC, paired with an OV4627A-based I/V stage, to convert the signal accurately before amplification.
By buying this product you get 72 loyalty points
Reference : 22708
725,00 €tax incl.
604,17 € tax excl.
iFi Audio GR 2 MT Headphone Amplifier Portable DAC PCM1795 Bluetooth 32bit 768kHz DSD512
IFI AUDIO GR 2 MT: Front view
The iFi Audio iDSD GR 2 MT is a portable DAC and headphone amplifier designed to handle digital-to-analog conversion and drive headphones or an audio system. It delivers up to 1513mW into 32Ω and is built around a Burr-Brown PCM1795 DAC, paired with an OV4627A-based I/V stage, to convert the signal accurately before amplification.
Intended for both portable and desktop use, it combines high-resolution conversion, extensive connectivity and touchscreen control to manage wired and wireless sources. Its design allows it to play a central role in a compact audio system while adapting to different types of headphones.
iFi Audio iDSD GR 2 MT: Digital conversion and signal architecture
The iDSD GR 2 MT retains the Burr-Brown PCM1795 DAC of the iDSD GR 2, but replaces its I/V stage with OV4627A devices combined with audiophile-grade tantalum resistors. This stage, located after digital-to-analog conversion, turns the current produced by the DAC into voltage to feed the following analog stages. The aerospace-grade hydrocarbon ceramic circuit board aims to reduce signal losses, while the simplified audio path, free of electronic switches, limits loading effects and distortion.
The architecture remains fully balanced, from the DAC to the headphone amplification, to avoid internal conversions and reduce phase deviations. It supports PCM streams up to 768kHz and DSD512, with four digital filters and K2HD and K2 processing. The GR 2 MT also adds two signature filters designed by Steve Levine, one optimized for PCM and the other for DSD. Stated measurements are 0.006% distortion at the headphone output, 0.0005% at the line output and a signal-to-noise ratio of 115dB.
IFI AUDIO GR 2 MT: PCM1795 DAC chip
iFi Audio iDSD GR 2 MT: Amplification and headphone matching
The headphone stage delivers up to 1513mW into 32Ω from the balanced output, with a voltage of 6.94V, and 119mW into 600Ω at 8.60V. This headroom maintains a usable level with high-impedance headphones. The GR 2 MT uses Audio Note KAISEI capacitors in its amplification stage and retains the stated performance on the S-Balanced output: 567mW into 32Ω and 30mW into 600Ω.
Output impedance is 0.4Ω balanced and 0.2Ω S-Balanced, which limits the amplifier's influence on the load. The iEMatch circuit allows it to be raised up to 4.5Ω to better suit sensitive IEMs, while low-impedance MOSFETs help protect and stabilize the output stage.
iFi Audio iDSD GR 2 MT: Connectivity and audio interfaces
The iDSD GR 2 MT features three digital inputs: a USB-C input dedicated to data, an S/PDIF input combining optical and coaxial signals, and a Bluetooth 5.4 interface. The latter supports aptX Lossless at 16 bits 44.1kHz and LDAC up to 990 kbps, as well as the aptX Adaptive, aptX, LHDC/HWA, AAC and SBC codecs, to match the capabilities of the wireless source.
The analog section includes two line inputs/outputs, 4.4 mm balanced and 3.5 mm unbalanced, to integrate the unit into different audio systems. Two headphone outputs, 4.4 mm balanced and 3.5 mm S-Balanced, complete the connectivity. A separate USB-C input provides 5 V power, keeping audio and power functions separate.
IFI AUDIO GR 2 MT: Nexis mobile app
iFi Audio iDSD GR 2 MT: Power, control and operation
The 4900mAh lithium-polymer battery provides approximately seven hours of playback and recharges in 3.5 hours with a 5V USB-C power supply rated above 1.8A. Three operating modes adapt the power supply to the use case: Battery for standalone use, Desktop to power the unit directly without drawing on the battery, and Hybrid to prioritize external power while using the battery during consumption peaks.
Hybrid mode then automatically returns to the main power supply once demand stabilizes, limiting charge cycles. Control is via a 2.3-inch high-resolution color touchscreen, complemented by a backlit screen-printed logo. The iFi Nexis app provides access to advanced settings and OTA updates.
Technical specifications
Product typeDAC
Headphone amplifier
Digital inputs1x USB-C
1x S/PDIF (Optical / Coaxial)
Bluetooth 5.4
Analog inputs and outputs1x 3.5mm single-ended jack
1x 4.4mm balanced jack
Headphone outputs1x 3.5mm S-Balanced jack
DAC chipsBurr Brown PCM1795
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
Signal-to-noise ratio (SNR)115dB
Total harmonic distortion more noise (THD+N)0.006% @ 16Ω (headphone output)
0.0005% @ 0dBFS (line output)
RMS output power6.94V/1513mW @ 32Ω; 8.60V/119mW @ 600Ω (balanced)
4.26V/567mW @ 32Ω; 4.27V/30mW @ 600Ω (S-Balanced)
Output impedance≤ 0.4Ω; ≤ 4.5Ω with iEMatch (balanced)
≤ 0.2Ω; ≤ 4.4Ω with iEMatch (S-Balanced)
BatteryLithium-polymer 4,900mAh
~7h battery life
Power supply5V/>1.8A via USB-C
~3.5h charging time
Supported Bluetooth codecsaptX Lossless, aptX Adaptive, aptX, LDAC, LHDC/HWA, AAC, SBC
Dimensions141 x 75 x 19mm
Weight268g
Package1x iFi Audio iDSD GR 2 MT
1x USB-C to USB-C cable
1x USB-C to Lightning cable
1x USB-A to USB-C cable
1x Carrying case
InputJack 4.4mm
InputJack 3.5mm
InputS/PDIF
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipPCM1795
Max sampling rate768kHz
Max sampling rateDSD512
ClassClass A / AB
IFI AUDIO GR 2 MT Headphone Amplifier Portable DAC PCM1795 Bluetooth 32bit 768kHz DSD512
The iFi Audio iDSD GR 2 MT is a portable DAC and headphone amplifier designed to handle digital-to-analog conversion and drive headphones or an...
