IFI AUDIO GO LINK 2 MAX Portable DAC Headphone Amplifier
The IFI AUDIO GO Link 2 MAX is a portable USB DAC with integrated headphone amplifier designed to deliver audiophile-grade sound quality from a smartphone, tablet, or computer. It features a balanced architecture based on two ESS Sabre ES9219 DAC chips, with each converter dedicated to a single channel to improve stereo separation and reduce background noise. Compatible with high-resolution audio streams up to PCM 32bit / 384kHz, DXD 384kHz, and DSD256, it ensures precise and transparent conversion of the most demanding audio files.
Reference : 22047
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 26-11-2026.
iFi Audio Go Link 2 Max Portable DAC Headphone Amplifier 2xES9219 32bit 768kHz DSD256
IFI AUDIO Go Link 2 MAX
The iFi Audio Go Link 2 Max is a portable USB DAC with integrated headphone amplifier designed to deliver audiophile-grade sound quality from a smartphone, tablet, or computer. It features a balanced architecture based on two ESS Sabre ES9219 DAC chips, with each converter dedicated to a single channel to improve stereo separation and reduce background noise. Compatible with high-resolution audio streams up to PCM 32bit 384kHz, DXD 384kHz, and DSD256, it ensures precise and transparent conversion of the most demanding audio files.
The Go Link 2 Max features a USB-C input, a balanced 4.4mm headphone output, and a 3.5mm S-Balanced output, compatible with single-ended headphones and earphones while reducing crosstalk. It delivers up to 241mW into 32Ω or 4V into 300Ω via the 4.4mm output, and up to 100mW into 32Ω or 2V into 300Ω via the 3.5mm output, allowing it to efficiently drive a wide variety of headphones and earphones.
The Go Link 2 Max also integrates several proprietary iFi technologies, including Dynamic Range Enhancement (DRE), providing up to +6dB of additional dynamic range, THD Compensation for harmonic distortion correction, and a jitter reduction circuit for more accurate audio reproduction. Its USB connection uses a silver-plated copper cable featuring individual polymer insulation and a twisted-pair structure. This design helps reduce parasitic inductance and capacitance while improving electromagnetic interference rejection. Unlike many conventional audio cables, the Go Link 2 Max preserves signal integrity even when used near sources of electrical interference. The package includes the Go Link 2 Max DAC and a USB-A to USB-C adapter.
iFi Audio Go Link 2 Max: iFi NEXIS App for Customization and Updates
The Go Link 2 Max is compatible with the iFi NEXIS app, which allows firmware updates to be performed directly from an Android smartphone without requiring a computer connection. The application also provides access to various digital filters, including Hybrid and Linear modes, allowing users to tailor the sound reproduction to their preferences. This platform also ensures ongoing product evolution through future software updates provided by iFi Audio.
IFI AUDIO Go Link 2 MAX: iFi NEXIS App for Customization and Updates
Technical Specifications
Product typePortable DAC / Headphone amplifier
Chipset2x ES9219
Input1x USB-C
Output1x 4.4mm balanced jack
1x 3.5mm jack
Supported sample rates32bit 384kHz, DSD256
Frequency response10Hz–80kHz (-3dB)
Output impedance< 0.7Ω (Balanced)
< 0.35Ω (S-Balanced)
Output power≥ 241mW @ 32Ω; 4V @ 300Ω (Balanced)
≥ 100mW @ 32Ω; 2V @ 300Ω (S-Balanced*)
SNR/DNR≥ 130dBA (Balanced @ 600Ω)
≥125dBA (S-Balanced @ 600Ω)
THD+N≤ 0.0007% (Balanced 2.4V @ 32Ω)
≤ 0.001% (S-Balanced 1.27V @ 32Ω)
Power consumptionNo signal ~0.6W
Max. signal ~3.2W
Dimensions143 x 15 x 9.4mm
Weight11.5g
Package contents1x iFi Audio Go Link 2 Max
1x USB-A to USB-C Adapter
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipES9219C
Max sampling rate384kHz
Max sampling rateDSD256
ColorBlue
IFI AUDIO GO LINK 2 MAX Portable DAC Headphone Amplifier 2xES9219 32bit 768kHz DSD256
The IFI AUDIO GO Link 2 MAX is a portable USB DAC with integrated headphone amplifier designed to deliver audiophile-grade sound quality from a...
