KIWI EARS AD1 Portable DAC Adapter
The Kiwi Ears AD1 adapter is equipped with a KT02H20 DAC chip, enabling it to support sampling rates up to PCM 32bit 384kHz.
Reference : 21760
9,57 €tax incl.
7,97 € tax excl.
Kiwi Ears AD1 Portable DAC Adapter USB-C to Female Jack 3.5mm KT02H20 32bit 384kHz
Photo of the Kiwi Ears AD1
The Kiwi Ears AD1 adapter is equipped with a KT02H20 DAC chip, enabling it to support sampling rates up to PCM 32bit 384kHz. Its 3.5mm female jack complies with the CTIA standard but is not compatible with OMTP, TS, or TRS microphones. It does, however, support headphones and built-in microphones, as well as volume control, play/pause, and headphone button functions. Made from durable materials and featuring a highly robust structure, it effectively withstands the mechanical stresses of daily use.
Product typeAdapter portable DAC
Amplification chipKT02H20
Connectors1x USB-C
1x 3.5mm female TRRS jack (CTIA standard)
THD+N< 0.004% (32Ω load, A-weighted)
Noise level< 3μV (A-weighted)
Frequency response20Hz-20KHz
DNR100dB
Packaging1x Kiwi Ears AD1
OutputJack 3.5mm
DAC / ADC ChipKT02H20
Max sampling rate384kHz
KIWI EARS AD1 Portable DAC Adapter USB-C to Female Jack 3.5mm KT02H20 32bit 384kHz
