KIWI EARS ALLEGRO PRO Portable DAC Headphone Amplifier
The Kiwi Ears Allegro Pro portable DAC / headphone amplifier is a small device based on the use of two ES9603 headphone amp chips. It supports high-resolution streams up to PCM 32bit 384kHz and DSD128, and is capable of delivering up to 170mW under 32Ω. This means you can enjoy high-resolution files and drive a wide range of headphones and earphones available on the market.
Reference : 20674
69,00 €tax incl.
57,50 € tax excl.
Shipping date: 19-06-2026.
Kiwi Ears Allegro Pro Portable DAC Headphone Amplifier 2x ES9603 32bit 384kHz DSD128
KIWI EARS ALLEGRO picture
The Kiwi Ears Allegro Pro portable DAC / headphone amplifier is a small device based on the use of two ES9603 headphone amp chips. It supports high-resolution streams up to PCM 32bit 384kHz and DSD128, and is capable of delivering up to 170mW under 32Ω. This means you can enjoy high-resolution files and drive a wide range of headphones and earphones available on the market. The sound reproduction offered by the Allegro Pro is clear and precise in the treble, with deep, immersive bass for a rich, pleasant listening experience. Source connection is via USB-C port and output via single-ended 3.5mm jack or balanced 4.4mm jack. Added to this is the possibility of choosing three distinct operating modes: a Hi-Fi mode for high-fidelity listening, a Gaming mode for immersive rendering, and a Movie mode for a cinematic experience. Each mode is accessed via a button on one side of the device, identifiable by an RGB LED.
KIWI EARS ALLEGRO in action
Product typePortable DAC / headphone Amplifier
OPA2x ES9603
Input1x USB-C
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
Supported sampling ratesPCM up to 32bit 384kHz, DSD up to DSD128
THD+N< 0.006% (@32Ω)
Output powerJack 3.5mm: 68mW @ 32Ω (THD+N <1%)
Balanced Jack 4.4mm: 170mW @ 32Ω (THD+N <1%)
SNR≥ 113dB (@ 32Ω, A-Weighted)
Frequency response20Hz–40kHz
Operating mode indicatorBlue: Gaming mode
Red: Music mode
Green: Cinema Mode
ColorArgent
Package1x Kiwi Ears Allegro Pro
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate384kHz
Max sampling rateDSD128
ColorSilver
ClassN/A
KIWI EARS ALLEGRO PRO Portable DAC Headphone Amplifier 2x ES9603 32bit 384kHz DSD128
The Kiwi Ears Allegro Pro portable DAC / headphone amplifier is a small device based on the use of two ES9603 headphone amp chips. It supports...
