TRUTHEAR KEYX Portable USB DAC
The TRUTHEAR KEYX is a portable USB DAC with integrated headphone amplifier designed to significantly improve the audio quality of smartphones, tablets, computers, and other devices equipped with a USB-C port.
Reference : 22041
32,91 €tax incl.
27,42 € tax excl.
Truthear KEYX Portable USB DAC CS43131 32bit 384kHz DSD256
TRUTHEAR KEYX
The Truthear KEYX is a portable USB DAC with integrated headphone amplifier designed to significantly improve the audio quality of smartphones, tablets, computers, and other devices equipped with a USB-C port. Compact and lightweight, it is built around a Cirrus Logic CS43131 digital-to-analog conversion chip, renowned for its excellent audio performance and low power consumption. The KEYX supports high-resolution audio streams up to PCM 32bit 384kHz and DSD256, offering broad compatibility with modern Hi-Res audio files. Its 3.5mm TRRS 4-pole jack output allows not only the connection of stereo earphones or headphones but also supports an integrated microphone for voice calls, gaming, or video conferencing. Capable of delivering more than 50mW of output power into 32Ω, it is perfectly suited to the majority of in-ear monitors and portable headphones. The KEYX also delivers excellent technical performance with a signal-to-noise ratio of 122dB, a dynamic range of 122dB, and total harmonic distortion plus noise reaching only -107dB with a 32Ω load and -112dB with a 600Ω load, ensuring precise, detailed, and silent audio reproduction.
TRUTHEAR KEYX
Truthear KEYX: Online Parametric EQ via EQTool
One of the key features of the Truthear KEYX is its compatibility with the EQTool online equalization platform, accessible directly from a web browser through Truthear's dedicated service. This solution allows users to easily adjust the DAC's sound signature without requiring the installation of complex software.
Through this interface, users can apply custom EQ profiles tailored to their earphones or listening preferences, modify various frequency parameters, and save their settings directly to the device. This approach provides great flexibility and enables quick optimization of sound reproduction according to the equipment used or the music genre being played, while maintaining simple and accessible operation across different operating systems.
TRUTHEAR KEYX: Online Parametric EQ via EQTool
Technical Specifications
Product typePortable DAC
DAC chipCS43131
InputUSB-C
Output3.5mm Jack (SE+MIC)
Supported sampling ratesPCM 32bit 384kHz
DSD256
Output level≥ 50mW @ 32 Ohms
THD+N @1kHz 0dBFS-107dB @ 1Vrms 32 Ohms
-112dB @ 2Vrms 600 Ohms
DNR @1kHz 60dBFS122dB @1Vrms 32 Ohms
122dB @2Vrms 600 Ohms
SNR @1kHz 0dBFS122dB @ 1Vrms 32 Ohms
122dB @ 2Vrms 600 Ohms
Package contents1x Portable DAC
1x Keychain
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rateDSD256
Max sampling rate384kHz
TRUTHEAR KEYX Portable USB DAC CS43131 32bit 384kHz DSD256
The TRUTHEAR KEYX is a portable USB DAC with integrated headphone amplifier designed to significantly improve the audio quality of smartphones,...
