AUDIO-GD XA-150 Balanced Dual Mono Amplifier Diamond Differential Design 2x300W 4 Ohm
The Audio-GD XA-150 is a high-end balanced amplifier consisting of two separate mono blocks in pure Class A with a Diamond Differential Design architecture. This structure allows it to develop a power of 100W per mono block, with an exceptional sound quality.
By buying this product you get 439 loyalty points
Reference : 14698
4 390,00 €tax incl.
3 658,33 € tax excl.
Audio-GD XA-150
Balanced Dual Mono Amplifier Diamond Differential Design 2x100W
Audio-GD XA-150 Amplificateur Double Mono Symétrique Diamond Differential Design 2x100W 8 Ohm
Its extremely careful design integrates 4 toroidal transformers for a total of 1700W and numerous Audio Grade capacitors for a cumulative capacity of 180000µF. The non-feedback output stages include no less than 48 transistors. The power supply stage is composed of 8 pure Class A PSUs to provide all circuits with a perfectly clean electrical signal, essential for a transparent sound reproduction.
The result of this design is quickly noticeable: great musicality thanks to exceptional dynamics and a rich sound that is extremely detailed in every detail.
Class A
Class A has the particularity of having its active components always in conduction. The quiescent current remains higher than the output current, thus limiting harmonic distortion. The output signal of the XA-150 is therefore of excellent quality, due to the absence of this famous sine wave crossover distortion.
Technical data
Product typeBalanced amplifier
Amplification typeDual mono
Class A
Power2x100W @ 8Ω
Gain28dB
InputsXLR
OutputsSpeaker terminals
Consumption (for two mono blocks)700W
Dimensions (for one mono block)375 x 510 x 273mm
Weight (for two mono blocks)90kg
THD+N @ 5W, 8Ω
THD+N @ 10W, 8Ω
THD+N @ 20W, 8Ω
Noise output level : 0.25mV
InputXLR
OutputSpeaker terminal
ChannelDual Mono
ClassClass A / AB
Amplifier chipN/A
Power (W)100.0
The Audio-GD XA-150 is a high-end balanced amplifier consisting of two separate mono blocks in pure Class A with a Diamond Differential Design...
