AUDIOPHONICS HPA-S600NCX Power Amplifier Class D NCore NCx500 2x600W 4 Ohm
The Audiophonics HPA-S600NCX stereo power amplifier, an updated and improved version of the HPA-S600NC, is now equipped with Hypex NCore NCx500 amplifier modules. These provide twice the performance in terms of distortion and output impedance than the previous model.
By buying this product you get 134 loyalty points
Reference : 17591
1 349,00 €tax incl.
1 124,17 € tax excl.
Shipping date: 06-10-2026.
Audiophonics Workshop amplifiers range
This device is delivered by default configured for an input voltage of 230V AC. A switch on the bottom of the unit allows the use of 110V AC.
Stereo Class D Power Amplifier NCore NCx500 2x600W 4 Ohm
Audiophonics HPA-S600NCX Amplificateur de puissance stéréo Class D NCore 2x600W 4 Ohm
The Audiophonics HPA-S600NCX stereo power amplifier, an updated and improved version of the HPA-S600NC, is now equipped with Hypex NCore NCx500 amplifier modules. These provide twice the performance in terms of distortion and output impedance than the previous model. Like its predecessor, this amplifier is designed for power and precision, with a large energy reserve and a clear and transparent sound reproduction.
Embedding a pair of Hypex NCore NCx500 modules, this Class D amplifier benefits from a HYPEX high efficiency power supply unit with synchronous regulation.
Like most amplifiers based on NCore architectures, the frequency response remains independent of the load and electromagnetic interference is rigorously controlled, thus greatly limiting the level of distortion and noise.
The HPA-S600NCX will thus be particularly appreciated in all conditions requiring an important power of amplification while preserving a great neutrality in the restitution of the signal. It will find its place as well in a professional studio as in the home of a private individual within a high-fidelity audio system.
Two NCx500 OEM mono modules
Each channel of the Audiophonics HPA-S600NCX has its own Hypex NCore NCx500 high efficiency, low output impedance, distortion and noise amplifier circuit. This new module has greatly improved performance in terms of distortion and output impedance. Each amplifier module is capable of delivering 700W of power at 1% THD. The HYPEX integrated 1200W power supply allows them to simultaneously deliver 600W at 0.01% THD under 4Ω.
Special care is taken in the internal wiring and assembly of the amplifier, using heavy gauge power supply wires, Canare input signal cables, and speaker cables with PTFE insulation.
AUDIOPHONICS HPA-S600NCX Amplificateur de puissance stéréo Class D NCore 2x600W 4 Ohm
Switchable inputs on RCA and XLR connectors
This power amplifier has two RCA ports (dual mono) and two XLR ports (dual mono balanced). The RCA connectors are 24k gold plated with heat resistant plastic caps. The XLR connectors are from Neutrik and ensure a high quality design with metal locking latch and gold-plated contacts.
A two-position selector switch allows you to alternate the XLR input and the RCA input with ease. You can thus connect two different preamplifiers and alternate the input sources.
High quality banana plug compatible terminal blocks
The HPA-S600NCX has two pairs of 24-karat gold-plated speaker terminals on its rear panel. These terminal blocks are designed to receive banana plugs which they will accept up to a diameter of ⌀4mm. They will also be able to accommodate bare wires thanks to a ⌀5.3mm screw lockable slot.
5-12V Trigger
A dual trigger socket (input and output) brings the comfort of an automated switch-on sequence and allows a very complete integration within your audio installation.
The power supply is connected to an IEC14 socket with gold-plated copper contacts. The latter works with a 5x20mm 3.150A fuse (supplied and already installed).
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
Heat dissipation
Because it is capable of developing considerable power, the HPA-S600NCX will be subjected to thermal stresses during use. Heat management is a key issue in achieving a high level of sonic accuracy and keeping distortion below a controlled level.
For this reason, each amplifier module is mounted on a large heat sink and is capable of dissipating heat efficiently. Also, carefully distributed ventilation holes will promote air circulation and heat removal. These heat sinks also contribute greatly to the modern and massive aesthetics of the amplifier.
AUDIOPHONICS HPA-S700NC Amplificateur Stéréo Class D NCore 2x700W 4 Ohm
Audiophonics interface board
The 2 modules are controlled in phase opposition, to cancel the "Power-Supply Pumping" effect. This makes the power supply more stable, distributing the current draw alternately on each rail, thereby increasing its capacity.
We opted for 2-level voltage regulation, to optimise the power supply to the AOPs and the auxiliary voltage supplied to the modules.
One Audiophonics OPA1656 PDU is used per channel. These are very low distortion PDUs offering the greatest transparency with very low THD. They are mounted on a DIP8 socket, allowing them to be replaced if necessary.
To suit all applications, we have opted for 4 gain settings, switchable via switch on the underside of the unit :
  • Total gain of 11.5dB - Maximum power reached with a 13.03V RMS signal.
  • Total gain of 19dB (default) - Maximum power reached with a 5.5V RMS signal.
  • Total gain of 24dB - Maximum power reached with a 3.09Vrms signal
  • Total gain of 28dB - Maximum power reached with a 1.95Vrms signal
Product typePower amplifier
Amplification typeClass D
Amplification modules2* Hypex NCore NCX500
Channels2 (Stereo)
Inputs2* Single-ended RCA
2* Balanced 3 poles XLR
TechnologyNcore
Output power2x500W @ 2Ω, 1kHz, THD = 0.01%
2x600W @ 4Ω, 1kHz, THD = 0.01%
2x300W @ 8Ω, 1kHz, THD = 0.01%
THD+N @ 20Hz-20kHz, 4ΩTyp: 0.0006%
Max: 0.001%
SNR137dB
Output noise7µV
Frequency response0Hz - 70kHz @ +0/-3dB
TriggerInput / Output
5-12VDC
Gain (switchable)11.5dB
19dB
24dB
28dB
Efficiency (max power)92%
Supply voltage115 or 230V (selectable via a switch under the device)
Max electric consumption1300W
HousingSandblasted aluminum
Total dimensions (WxDxH)435 x 355 x 73mm
Idle power0.1W
Weight5.66kg
Package1x Audiophonics HPA-S600NCX
1x Power cable
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)600.0
9 reviews
Impressionnant
N'y allons pas par 4 chemins, ça fait des années que j'écoute toute sorte d'amplis A/B, franchement on entre dans un nouveau monde avec ces modules Ncore Ncx500.
Tout y est, un punch incroyable en bas qui drive tout ce qui se présente.
Une vivacité dans les transitions hallucinante, des médiums qui filent à l'infini.
Force et finesse tout à la fois !
A faible comme à fort volume le son est enveloppant, la scène est extrêmement détaillée, les basses viennent jouer avec votre cage thoracique.
Le seul inconvénient que je trouve à ces ampli de nouvelle génération c'est qu'il devient excessivement difficile d'écouter des mastering très compressés tellement ils sont precis.
On est clairement sur un rapport qualité/prix tout à fait remarquable...
Il surclasse largement des modèles A/B au triple de son prix.
Sur des Dali Rubikore 8 le spectacle est magistral...
Vous hésitez comme j'ai hésité ? N'hésitez plus.
This review has been posted for AUDIOPHONICS HPA-S600NCX Power Amplifier Class D NCore NCx500 2x600W 4 Ohm
superbe ampli
Possédant un ampli Arcam en class G réputé costaud et une paire d’enceintes à faible rendement, je trouvai que les basses manquaient de définition. Après plusieurs recherches je tombe sur ce HPA-S600NCX par curiosité.
Une fois branché c’est la révélation je crois avoir de nouvelles enceintes tout le spectre y gagne et le grave est punchy et défini comme j’aime.
Après remplacement des aop par des sparkos ss2590 pro doublé le niveau est encore monté d’un cran.
Pour terminer ampli au rapport qualité prix bluffant
Parfait !
Très bon amplificateur, très puissant, très fin. Il ne fait que reproduire vos musiques sans apporter de couleur. Attention aux mauvais enregistrements, ils ne sont pas embellis. Si vous êtes objectiviste, comme moi, il est parfait. Si vous adorez le son du tube, les distorsions harmoniques paires : passez votre chemin.
I could not believ my ears !
I powered my Monitor Audio speakers with this flat good looking amp.
Great detail, very high dynamics, the plings en the plongs, the "s" from splendid sounds like natural singing in your ears. Overwhelmed by the superb bass control. Now waiting to test the audiophonics DAC in combination withh the amp ... .
Best bang for your bucks :-)
Now this really is an extraordinary product, both Audiophonic's housing and Hypex' amplifier are way beyond the qualitiy that you can expect in this price range, if there is some famous brand label attached to the front... I particularly appreciate the switchable RCA/XLR inputs, as I use this power amp in a configuration that allows multichannel (R+L preamp output of my AVR via RCA) and pure stereo (via XLR). Now this stereo setup, which exists of the minimum number of components, is what really blows my mind. Source is an Eversolo DMP-A6, which can also serve as preamp and has balanced output, directly connected to the HPA-S600NCX via high quality XLR cables (of Funk Tonstudiotechnik in Berlin, Germany, who produce absolutely fantastic quality cables for nearly all audio applications) which serves to a pair of ambitious middle class speakers with 89dB efficiency. All this in a very small dedicated listening room, which does not allow for a proper bass reproduction. What should I say? The HPA-S600NCX delivers a precision in bass in this acoustically unfavorable environment that not even an absolutely high-end amplifier (an ASR Emitter, that a friend had lent me for testing) could deliver. I can only assume that the extremely low output impedance / high damping factor does the trick. Anyway, it's on a level which I never would have expected. As also the clarity of sound and the realistic performance over the rest of the frequency range is first class, I can highly recommend this amp even for high-end setups. For the fun of it: If you want to enjoy the potential of this little box, listen to Yello's "The Expert" from the "Touch Yello" album at a high listening level - I'm sure you will be amazed, too :-)
 (4)
The Audiophonics HPA-S600NCX stereo power amplifier, an updated and improved version of the HPA-S600NC, is now equipped with Hypex NCore NCx500...
