AUDIOPHONICS LPA-S450ET Power Amplifier Stereo Purifi 1ET6525SA
We're proud to present the Audiophonics LPA-S450ET, a Class D stereo power amplifier based on two Purifi 1ET6525SA modules. Electronically similar to the HPA-S450ET, this version is housed in a more compact case, making it easier to use in environments where space is at a premium, and its architecture also limits the length of internal connections.
4.9 / 5
By buying this product you get 129 loyalty points
Reference : 20206
1 290,00 €tax incl.
1 075,00 € tax excl.
Audiophonics Workshop amplifiers range
This unit is supplied with a 230V AC power supply as standard. If you require a 110V input voltage, please select this using the switch on the underside of the unit before connecting it to the mains.
Audiophonics LPA-S450ET Class D Stereo Amplifier PURIFI 1ET6525SA 2x450W 4 Ohm
Audiophonics LPA-S450ET: 3/4 view
This ready-to-install, ready-to-use model is aimed at audiophiles looking for a foolproof amplification solution, with considerable power reserves and impeccable definition. PURIFI modules are among the most rigorous Class D amplification solutions on the market, with measured performance that is simply outstanding.
The result is a high level of sound reproduction, suitable for use with demanding speakers, large listening rooms or studio applications requiring considerable headroom without compromising on the precision and richness of the audio message.
All components are housed in a sober, robust and compact aluminum case. It features openings to facilitate heat dissipation. Its design also limits the impact of interference on the signal.
Audiophonics LPA-S450ET : PURIFI 1ET6525SA module
Audiophonics LPA-S450ET: Two PURIFI 1ET6525SA modules
  • Each channel of the amplifier circuit uses its own PURIFI 1ET6525SA module. These high-performance Class D amplifier circuits each deliver a very comfortable output power of 450W at 4Ω or 230W at 8 Ohm, while benefiting from the high efficiency of Class D amplifiers.
  • The 1ET6525SA modules feature a high-gain loop in excess of 85dB over the entire frequency band, providing high performance across the entire spectrum, surpassing any amplifier of any class.
  • Highly effective in terms of intermodulation distortion (IMD), these modules enable the LPA-S450ET to deliver a stereophonic image of formidable precision across the entire spectrum, for redoubled clarity, even during the most complex musical works.
  • Harmonic distortion (THD) is kept extremely low at all power levels. This translates into an absence of sound signature and the ability to reproduce all types of music without coloration.
  • Output noise is negligible, allowing deep silences and favoring the appearance of detail when listening at low volume.
  • The circuit benefits from a high level of rejection (PSRR) that minimizes the impact of the power supply on audio performance.
  • The load-independent frequency response makes it possible to enjoy all the qualities of this amplification technology, even with the most difficult-to-drive speakers.
  • Low quiescent power consumption and electromagnetic radiation (EMI). The high-gain loop considerably relieves the workload on the MOSFETs, enabling them to operate under optimum conditions, reducing losses and EMI emissions.
  • The LPA-S450ET's amplifier modules are linked by a specially developed interface board for optimum integration.
Audiophonics LPA-S450ET: Hypex SMPS1200A400 power supply module
The SMPS1200 switched-mode power supply is an ultra-high-efficiency model capable of developing a rated power of 1200 Watts in an extremely compact design. It has been specifically designed and developed by Hypex to supply the 2x64V voltage required to operate the most demanding amplifier modules.
This high-quality, low-noise power supply meets the power requirements of the amplifier modules in every respect. What's more, the modules themselves have an excellent ability to reject power supply noise. As a result, the LPA-S450ET is extremely insensitive to mains imperfections and voltage/current variations that can cause parasitic noise.
Audiophonics LPA-S450ET : Hypex SMPS1200A400 power supply module
Audiophonics LPA-S450ET: Audiophonics interface board
The 2 modules are controlled in phase opposition, to cancel the “Power-Supply Pumping” effect. This makes for greater power supply stability, alternately distributing current calls on each rail, thus increasing its capacity.
A voltage regulation stage is used to optimize the power supply to the OPAs and the auxiliary voltage supplied to the modules.
One Audiophonics OPA1656 OPA is used per channel. These are very low-distortion OPAs offering the highest transparency with very low THD. They are mounted on a DIP8 socket, allowing them to be replaced if necessary.
To suit all uses, we have opted for 4 gain settings, selectable via jumper on the underside of the unit: 12.5dB, 20dB (default), 25dB and 29dB.
Audiophonics LPA-S450ET: Connectors
Designed for easy integration, the LPA-S450ET features both single-ended (RCA) and balanced (XLR) stereo inputs. Bipolar selectors make it easy to change input sources, and even allow independent control of channels.
At the output, BP-207 carbon / 24k gold insulated terminal blocks Ø5.5mm ensure an excellent connection with the speakers.
Moreover, a 5-12V Trigger In operating on a 3.5mm mono jack allows the amplifier to be switched on automatically.
Audiophonics LPA-S450ET : Rear view
Audiophonics LPA-S450ET : THD vs Freq
Audiophonics LPA-S450ET : THD+N
Audiophonics LPA-S450ET : Frequency response
Test du AUDIOPHONICS LPA-S450ET par QOBUZ
If we had to keep just one power amplifier, it might just be this Audiophonics LPA-S450ET. It isn’t an entry-level product. But it’s equally far from the high end, and yet, it offers impeccable sound reproduction capabilities, both on paper and in practice. The power is there, but it takes a backseat to the music, which is reproduced with all its finesse, complexity, and presence. The LPA-S450ET will be a solid foundation to any high-quality Hi-Fi system.
 Logo Quobuz
Product typePower amplifier
Inputs1x Balanced stereo XLR
1x Single-ended stereo RCA
Outputs2x Speaker terminals
Other connectorsTrigger In (5-12V)
Power2x230W @ 8Ω, 1%THD
2x450W @ 4Ω, 1%THD
2x510W @ 2Ω, 1%THD
Total harmonique distorsion (THD+N)0.00035% @ PO=1W, f=1kHz
0.0001% @ PO=10W, f=1kHz
0.00005% @ PO=100W, f=1kHz
0.00035% @ PO=1W, f=20Hz-20kHz
0.00029% @ PO=10W, f=20Hz-20kHz
0.0001% @ PO=100W, f=20Hz-20kHz
IMD (CCIF)0.0000003% @ PO=1W, f=18.5kHz+19.5kHz
0.0000006% @ PO=10W, f=18.5kHz+19.5kHz
0.0000005 % @ PO=100W, f=18.5kHz+19.5kHz
IMD (DIM)0.002% @ PO=1W, DIM30
0.002% @ PO=10W, DIM30
0.009% @ PO=100W, DIM30
Idle Noise6.6µV (A-Weighted)
Dynamic range137dB @ 4Ω (A-Weighted)
SNR137dB @ 4Ω (A-Weighted)
Frequency response20Hz - 20kHz ±0.01dB @ RL=8Ω
20Hz - 20kHz ±0.01dB @ RL=4Ω
20Hz - 20kHz ±0.01dB @ RL=2Ω
Output impedanceIout = 1A @ 0.03mΩ, 1kHz
Iout = 1A @ < 0.35mΩ, 20Hz-20kHz
Input impedanceRCA : 10kΩ
XLR : 20kΩ
XLR Input gain / sensitivity for max power at 1% THD12.5dB / 10.06Vrms
20dB / 4.24Vrms
25dB / 2.39Vrms
29dB / 1.51Vrms
RCA Input gain / sensitivity for max power at 1% THD12.5dB / 5.03Vrms
20dB / 2.12Vrms
25dB / 1.24Vrms
29dB / 0.75Vrms
Default gain20dB
Power supply110-230V AC (230V par défaut)
Total dimensions (WxDxH)191 x 386 x 82mm
Weight3.17kg
Housing materialAluminum
Package1x Audiophonics LPA-S450ET
1x Power cord
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chip1ET6525SA
Power (W)450.0
23 reviews
Consegna nei tempi previsti,sono molto soddisfatto del mio acquisto,descrizione accurata e coerente con la realtà,qualità audio molto elevata,rumori,fruscii,ronzio a frequenza di rete assente,risposta ai transitori eccellente, potenza ottima,lo ricomprerei.
This review has been posted for AUDIOPHONICS LPA-S450ET Class D Stereo Amplifier PURIFI 1ET6525SA 2x450W 4 Ohm
Bluffé
Je pensais qu'un très bon ampli se devait d'être en architecture class A, puis j'ai vu des commentaires sur cet ampli de la part de Qobuz et surtout j'ai demandé conseil à David.
Je suis bluffé par cette association de modules purifi conçue par Audiophonics. J'adore le son, il est détaillé, la scène sonore est profonde et je ne ressens aucune fatigue à l'écoute. En plus il est léger et ne chauffe pas.
Je recommande fortement.
Merci à Audiophonics.
Oubliez tous les autres
Ayant récemment acquis une paire de Chario Aviator Nobile, j'étais à la recherche d'électroniques à la hauteur de leur qualités acoustiques, sans me ruiner. Comment dire... Dès les premières secondes d'écoute on se rend compte de la supériorité technique incontestable de la classe D mise en oeuvre avec talent par audiophonics et purifi dans ce boitier. Inutile de chercher ailleurs, les mesures parlent d'elles même, on est dans le domaine de la perfection. On gagne en précision, en dynamisme sur absolument tous les plans à tel point que mon Atoll AM100 semble appartenir à un autre temps. Achetez le les yeux fermés et gardez le longtemps.
Incroyable !!
Je possède depuis une vingtaine d’années du Naim Audio (NAC 282 / HICAP / NAP 250.2) couplé à des ATC SCM 50 Passives.
Très satisfait du résultat. Très musical comme je l’aime depuis des années.
Par contre je n’ai jamais pu complètement ignorer les dires comme quoi les ATC sont difficiles à driver… etc… etc…
Un peu plus de grave à bas volume n’est pas refus.
J’ai donc voulu essayer quelque chose de non conventionnel. Raccorder mon preampli Naim sur un ampli classe D. Dans la communauté Naim c’est un délit très grave :)
La condition était de conserver le PRAT Naim mais avec plus de patate pour voir l’impact sur les ATC.
Ce LPA-S450ET cochait toutes les cases. De la puissance, du facteur d’amortissement et de la neutralité.
Après quelques échanges sympathique avec David ici même j’ai sauté le pas.
Le câblage chez Naim n’étant pas conventionnel, Il a fallu trouver un câble DIN pour sortir de la HICAP vers du symétrique pour l’Audiophonics.
Depuis plusieurs heures ça joue. Et ça joue très très bien. Je suis bluffé. Le PRAT est conservé. Je ne suis pas dépaysé comparé au NAP 250.2 mais il y a un peu plus de tout. Le grave est un peu plus présent à bas volume. Donc sur ce point c’est validé. La scène sonore ne change pas. Le médium est le même et toujours magnifique à nos oreilles. La musicalité de la source et du preampli est conservée et c’est ce que je recherchais. À fort niveau ça n’a rien à voir ça envoie vraiment très fort sans tassement ni distorsion comparé au NAP 250 qui pouvait forcer un peu.
La neutralité de cet ampli est exceptionnelle. On dirait de la classe AB. Rien de montant ou de fatiguant.
Je me retrouve avec une source et un preampli Naim couplé à des ATC SCM 50 et au milieu un ampli classe D de 1300€. Beaucoup diraient que c’est du n’importe quoi. Mais non. Ça chante. Comme quoi…
Reste à voir la fiabilité. Le système est sous tension 24/24 et 7j/7.
Merci David pour les conseils.
Very impressed!
More out of curiosity about how far Class D quality had progressed, I decided to buy this amplifier, complementing an old-school tube and Nakamichi 420 power amps. Fortunately, since I specifically desired a European solution, the combination of Purifi hardware integrated into an Audiophonics chassis was the perfect opportunity for me. Examining the internal components and wiring shows excellent workmanship, putting the narrow chassis to effective use. I was very impressed with the dynamics and definition of the few CD‘s that I listened to for preliminary testing. I had combined this purchase with replacement Mundorf capacitors for my 30 year old B&W speaker crossovers, which I had also immediately installed, so I need to become accustomed to the sound to make a long term evaluation. Since I love to tweek my components from time to time(AFTER the warranty elapses), this amplifier allows the possibility to test alternative op-amps, and for the more adventurous, maybe replace the 15 volt voltage regulators on the interface board with Sparkos regulators.
The order and delivery process to Germany, basically next door, was quick and simple and I will continue to visit their website should I need any parts or accessories in the future.
We're proud to present the Audiophonics LPA-S450ET, a Class D stereo power amplifier based on two Purifi 1ET6525SA modules. Electronically...
