By buying this product you get 28 loyalty points
With the Mono Combo Pack, Fosi Audio offers a product pack tailor-made for a dual mono installation. It consists of two V3 Mono amplifiers, a power supply noise reducer, a 48V 10A mains adapter and a dual DC jack to power your two amplifiers.
The Fosi Audio V3 MONO is a compact and powerful mono amplifier at an affordable price. It is based on a TI TPA3255 amplifier chip and can deliver 240W of power at 4Ω. In addition to its amplification chip, this amplifier is equipped with a number of audiophile components such as Japanese ELNA and German WIMA capacitors and a pair of TI NE5532 DIP8-mounted AOPs, so you can replace them if you want a specific sound coloration. In terms of connectors, the Fosi Ausio V3 Mono offers an XLR/ balanced 6.35mm jack combo input, an RCA input and a speaker terminal block for the output.
View complete product page of Fosi Audio V3 MonoThis Fosi Audio power supply noise reducer accepts a voltage range of 12V to 55V and a current of 10A via DC 5.5/2.5mm jack. It reduces power supply noise and protects your equipment from possible electromagnetic interference thanks to capacitors and filter coils. Another advantage of this power supply noise reducer is that it reduces the impact of power surges and current spikes on devices, thereby extending their life.
View complete product page of Power Noise FilterThis Fosi Audio mains adaptor takes a 100-240VAC input voltage and provides a 48V DC output voltage for a maximum current of 10A, i.e. a power of 480W. Its output connector is a 5.5/2.5mm DC jack. This power supply unit uses gallium nitride (GaN) to provide a reliable power supply for your equipment.
View complete product page of Fosi Audio AC/DC Switching Power AdapterTechnical characteristics
Product type | Amplifiers + Mains adapter + Noise reducer |
Contenu du package | 2x Fosi Audio V3 Mono 1x Fosi Audio Power Noise Filter 1x Fosi Audio AC/DC Switching Power Adapter 1x DC jack doubler |
Fosi Audio V3 Mono specifications | |
Product type | Mono class D Amplifier |
Inputs | 1x Balanced XLR/jack 6.35mm combo 1x RCA (choice of 25dB or 31dB gain) |
Outputs | 1x Speaker terminals |
Amplification chip | TI TPA3255 |
OPA | 2x TI NE5532 |
Output power | 240W @ 4Ω 48V/5A 160W @ 6Ω 48V/5A 120W @ 8Ω 48V/5A 100W @ 4Ω 32V/5A 65W @ 6Ω 32V/5A 55W @ 8Ω 32V/5A |
Speaker impedance | 2Ω - 8Ω |
Frequency response | 10Hz-30kHz(±0.06dB) |
SINAD | XLR: 101dB RCA: 93dB |
Total harmonic distortion (THD) | < 0.006% |
Signal-to-noise ratio (SNR) | ≥ 123dB |
Gain setting (RCA input) | 19dB 25dB |
Power supply | 32-48V DC |
Color | Black |
Product dimensions | 142 x 107 x 41mm |
Fosi Audio Power Noise Filter specifications | |
Product type | Power supply filter |
Operating voltage | 12-55V DC |
Max. operating current | 10A |
Connectors | Jack DC 5.5/2.5mm |
Color | Black |
AC/DC Switching Power Adapter specifications | |
Product type | Power adapter |
Input voltage | 100-240VAC 50/60Hz |
Output voltage | 48V |
Output current | 10A |
Input connector | IEC C14 |
Power cable included | |
Output connector | Jack DC 5.5/2.5mm (câble 1.5m) |
Block dimensions | 195 x 94 x 42mm |
Input | RCA |
Input | XLR |
Output | Speaker terminal |
Color | Black |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | TPA3255 |
Power (W) | 240.0 |
Remote Control | No |
