MUSICIAN GEMINI Power Amplifier Black
The Musician Gemini is a stereo Class AB power amplifier with a fully discrete and truly balanced design, engineered to drive demanding speakers with stable power and precise control. Its power supply combines a 600 VA toroidal transformer with 36 high-capacity capacitors, while its output stages deliver 120 W RMS per channel into 8 Ω and 220 W RMS into 4 Ω.
By buying this product you get 226 loyalty points
Reference : 22404
2 269,00 €tax incl.
1 890,83 € tax excl.
MUSICIAN GEMINI Class AB Stereo Power Amplifier 2x220W 4 Ohm Black
MUSICIAN GEMINI: Front view
The Musician Gemini is a stereo Class AB power amplifier, with a fully discrete and truly balanced design, engineered to drive demanding speakers with stable power and precise control. Its power supply combines a 600VA toroidal transformer with 36 high-capacity capacitors, while its output stages deliver 120W RMS per channel into 8Ω and 220W RMS into 4Ω.
Designed for stereo Hi-Fi systems, it relies on four pairs of power transistors per channel to maintain linearity and thermal stability during high current demands. Its frequency response of 10Hz to 80kHz (±2dB) preserves rapid signal variations and information located at the extremes of the spectrum, thereby combining dynamic headroom, speaker control and compatibility with variable-impedance speakers.
Musician Gemini: Class AB amplification
The Musician Gemini uses Class AB amplification, fully discrete, truly balanced and designed to reduce distortion while maintaining a stable dynamic response. Its power supply stage combines a 600VA toroidal transformer with 36 high-capacity capacitors of 200µF and 400µF, in order to provide sufficient energy reserve during rapid signal variations and high current demands. This architecture thus supports the amplifier's stability on complex loads, while maintaining precise speaker control and consistent reproduction at high levels.
MUSICIAN GEMINI: Transformer
MUSICIAN GEMINI: Transistors
Musician Gemini: Simultaneous dual amplification
The Gemini simultaneously delivers 120W RMS per channel into 8Ω and 220W RMS per channel into 4Ω, with both channels operating. These values, measured under conservative operating conditions, ensure sufficient headroom to maintain speaker control during dynamic passages and impedance variations.
Each channel incorporates four pairs of high current-capacity power transistors. This configuration balances drive power, linearity and thermal stability, allowing precise speaker control while maintaining structured bass reproduction, a dense midrange register and consistent treble extension.
Musician Gemini: Extended frequency response
The frequency response extends from 10Hz to 80kHz (±2dB), in order to preserve information located at the extremes of the spectrum in high-resolution recordings. This bandwidth also helps maintain a stable response in the audible range, without limiting the amplifier's behavior on rapid transients.
Technical specifications
Product typePower amplifier
Inputs1x Stereo XLR
OutputsSpeaker terminals
Amplification typeClass AB
SNR118dB
Frequency response10Hz-80kHz (±2dB)
Power2x220W @4Ω
2x120 @8Ω
Input impedance22kΩ
Input sensitivity1.8Vrms
THD+N0.002%
Gain26dB
Dynamic range121dB
Crosstalk-110dB
Supply voltage115V AC / 50Hz
230V AC / 60Hz
Weight16.6kg
Dimensions375 x 334 x 124mm
Package1x Musician Gemini
1x Power cable
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)220.0
The Musician Gemini is a stereo Class AB power amplifier with a fully discrete and truly balanced design, engineered to drive demanding speakers...
