TOPPING B200 Power Amplifier Black
The Topping B200 power amplifier is a mono amplifier based on a discrete-component NFCA amplifier circuit. This enables it to achieve a considerable power level while maintaining excellent performance metrics. Indeed, the B200 is capable of delivering up to 200W of power (THD=1%) at both 4 ohms and 8 ohms.
By buying this product you get 59 loyalty points
Reference : 19588
599,00 €tax incl.
499,17 € tax excl.
Shipping date: 10-06-2026.
Topping B200 Mono Discrete Power Amplifier 200W 4 ohm Black
Topping B200 picture
The Topping B200 power amplifier is a mono amplifier based on a discrete-component NFCA amplifier circuit. This enables it to achieve a considerable power level while maintaining excellent performance metrics. Indeed, the B200 is capable of delivering up to 200W of power (THD=1%) at both 4 ohms and 8 ohms. It boasts a dynamic range of 145dB and an extremely low level of distortion. Interface-wise, it's straight to the point, with three balanced XLR/6.35mm jack combo inputs (accepts both XLR and 3.5mm jack connectors) and a speaker terminal output. A two-level gain control adjusts the output. The whole unit is housed in an attractive, solid aluminum case.
Topping B200 highlights
Topping B200: new discrete NFCA amplifier circuit
The new NFCA amplifier module enables the B200 to develop 200W of power at 4 ohms load and 8 ohms load. All with very low distortion (<0.000075%) and an extended dynamic range of 145dB.
Photo of NFCA amplifier circuit
Photo of the Topping B200 12V trigger
Topping B200: 12V trigger and gain control
The B200 features a 12V trigger that automatically switches on when your Hi-Fi system is switched on. In addition, a two-level gain control allows the B200 to adapt to different configurations and speakers: low gain 11.6dB and high gain 22.0dB.
Topping B200 overview
1ON/OFF button and source selector
2Input source indicator LED
33x Balanced XLR/Jack6.35mm input
4Speaker terminal output
5Firmware update port
6Gain adjustment
7Power connector
8Trigger In 12V
Example of HiFi configuration with two B200
Topping B200 video review by AudioScienceReview (Amir)
Product typePower amplifier
AmplificationNFCA amplifier circuit with discrete components
ChannelsMono
Inputs3x Balanced XLR/Jack6.35mm combo input
OutputSpeaker terminal block
THD (@1kHz, A-wt)<0.00008% @ 4Ω 5W
<0.000075% @ 8Ω 5W
THD (@20-20kHz, 90kBW)<0.0005% @ 4Ω 5W
<0.0004% @ 8Ω 5W
SNR (A-wt)145dB
DYnamic range (@1kHz, A-wt)145dB
Frequency response20Hz-40kHz (+/-2dB)
20Hz-100kHz (+/-0.4dB)
Output level80Vpp @ 4Ω
110Vpp @ 8Ω
Measured noise level AP (A-wt)<2.3uvrms G=L
<3.9uvrms G=H
Input sensitivity<12.5uvrms G=L
<3.9uvrms G=H
Gain11.6dB @ G=L
22.0dB @ G=H
Output impedance<5mΩ
Output impedance10KΩ
Output power200W @4Ω THD+N<1%
240W @8Ω THD+N<10%
200W @8Ω THD+N<1%
Minimum load impedance
Dimensions22x 18.5 x 9.2mm
Package1x Topping B200 power amplifier
1x 3.5mm jack Trigger cable
1x Mains adapter 64V 4A (3 poles GX connector)
Topping B200 measurements
InputJack 6.35mm
InputXLR
Channel1 (Mono)
ClassN/A
Amplifier chipNFCA
Power (W)200.0
3 reviews
A great power amplifier at a very good price.
Distortion and noise are inaudible. A spacious soundstage, thanks to exceptional time and phase coherence across the entire frequency range. Very good dynamics and resolution. I recommend B200.
This review has been posted for TOPPING B200 Power Amplifier Mono Discrete 200W 4 Ohm Black
Magnifiques !
Les 200 sont d'une qualité de fabrication irréprochable, très beaux et élégants.
Vous trouverez une scène sonore vraiment très large et d'une clarté à couper les souffle, avec des détails jamais entendu avant. Ils sont extrêmement précis, donc aussi très révélateurs de la qualité d'enregistrement.
Absolument plus que satisfait de mon achat, finalement Internet avait raison!
Toppingssime
En remplacement de mon excellent Rotel A11 Tribute Edition, ces 2 blocs mono me permettent logiquement de gagner énormément niveau scène sonore mais également sur tous les plans et singulièrement les hautes fréquences, les détails.... C'est mon dernier achat en matière d'ampli; j'ai trouvé! Vraiment sublimes avec mon Eversolo DMP-A8 et mes enceintes Revival Atalante 3.... Il ne me reste que le caisson de basse à faire évoluer. Merci
The Topping B200 power amplifier is a mono amplifier based on a discrete-component NFCA amplifier circuit. This enables it to achieve a...
