BERRYBAK PS-SP16113 GCB-60 12V Capacitor Power Filter for Car Audio
The Berrybak PS-SP16113 GCB-60 is a 12V capacitor-based power filter, designed to stabilize the voltage delivered by a battery in an onboard audio system. It relies on a 122400µF capacitance and a 60A RMS current handling capability, allowing it to absorb rapid consumption variations while maintaining a more stable power supply to amplifiers.
Reference : 22201
89,91 €tax incl.
74,92 € tax excl.
Shipping date: 24-11-2026.
BerryBak PS-SP16113 GCB-60 12V Capacitor Power Filter for Car Audio
Thumbnail of the BerryBak PS-SP16113 GCB-60
Intended for car audio installations or any system operating on a 12V battery, it combines energy storage, noise filtering and electrical protection, allowing voltage drops and interference related to switching power supplies to be reduced. This approach enables it to be integrated between the battery and the amplifier, while maintaining stable operation during dynamic demands.
Berrybak PS-SP16113 GCB-60: Energy storage and stabilized power supply
The GCB-60 relies on a total capacitance of 122400µF, achieved through 18 capacitors of 6800µF with low ESR, allowing the creation of an energy reserve that can be immediately mobilized during rapid current demands. This architecture limits voltage drops during heavy loads, particularly at low frequencies, thereby maintaining a more consistent power supply to the amplifier.
This capacitance is combined with a 60A RMS and 90A peak current capability, enabling it to respond to rapid demand variations without causing power supply voltage sag. The use of MOSFETs with low internal resistance facilitates current flow between the battery and the audio system, while limiting losses and heat generation, thereby maintaining a more stable power supply in an onboard environment (car, utility vehicle or equivalent 12V installation).
Side view photo of the BerryBak PS-SP16113 GCB-60
Image of a protection feature of the BerryBak PS-SP16113 GCB-60
Berrybak PS-SP16113 GCB-60: Electrical filtering and impact on the audio signal
The combination of high capacitance and low ESR capacitors ensures voltage variation filtering, by limiting ripple from the battery and switching power supplies. This stabilization reduces parasitic noise such as hum and interference, allowing a cleaner audio signal to be maintained.
This energy reserve improves response during rapid load variations, by providing immediate support to the amplifier during demand peaks, which limits dynamic drops during the most demanding passages. The module thus stabilizes the power supply, enabling more consistent operation of the entire onboard audio system.
Berrybak PS-SP16113 GCB-60: Protection, connection and system integration
The module integrates comprehensive electrical protection management, including reverse polarity protection, reverse current blocking and adjustable undervoltage protection (8.8V, 11.0V, 12.9V), allowing the battery and installation to be secured in abnormal conditions. This safety is complemented by overcurrent protection via two 40A fuses associated with electronic control, as well as overvoltage protection ensuring controlled operation within a 11 to 16V range.
Integration relies on DC connectivity with 1 input and 1 output via JSZ214A screw terminals. The soft start over approximately 3 seconds limits inrush current when connecting to a 12V battery, preventing sparks and eliminating the need for pre-charge.
Power and charge LED indicators allow quick status verification of the module. The GCB-60 integrates directly between the battery and the amplifier, where it stabilizes the power supply in a car audio installation or any 12V-powered system.
Connection diagram of the BerryBak PS-SP16113 GCB-60
Technical specifications
Product type12V power filter
Input voltage12V DC (11-16V)
Input1x screw terminal (JSZ214A)
Output1x screw terminal (JSZ214A)
Total capacitance122400µF (18x 6800µF)
Continuous current60A RMS
Max current90A
Overvoltage protection
Reverse polarity protection
Undervoltage protection8.8V / 11.0V / 12.9V
HousingAluminum
Dimensions89 x 241.3x 48.5 mm
Weight1.005kg
Packaging1x BerryBak PS-SP16113 GCB-60
4x Mounting brackets
8x M3 countersunk Phillips screws
2x 40A fuse
InputScrew terminals
OutputScrew terminals
Output voltage (V)12.0
Output current (A)60
Input voltage (V)12.0
Power SupplyPower supply filter
The Berrybak PS-SP16113 GCB-60 is a 12V capacitor-based power filter, designed to stabilize the voltage delivered by a battery in an onboard audio...
