Connector
Max cable diameter (mm)
Rated current (A)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
Bruno R.
Alain p.
top du top
OGUZHAN O.
With Bluesound Node N130
I use it with Bluesound Node N130 and it gave lots of sound improvements
Power Plugs & Sockets
Power Plugs & SocketsDiscover our wide range of power plugs, IEC, Schuko or other formats, to design your HiFi power cables.
  • IEC Connectors
    IEC Connectors
    Discover our range of IEC connectors of all sizes, for the design of your HiFi power cables.
  • Schuko Connectors
    Schuko Connectors
    Discover our range of Schuko power connectors, for the design of your HiFi power cables.
  • Various Internationals
    Various InternationalsDiscover our range of sector connectors in international formats, for the design of your HiFi power cables.
  • Schuko Inlets
    Schuko Inlets
    Discover our range of Schuko plugs, for the installation of your wall sockets.
  • IEC Inlets
    IEC Inlets
    Discover our range of IEC plugs of all sizes, for the integration of a power connector on your HiFi devices.
