IAN CANADA UCPURE QUAD Supercapacitor Power Module Class A 5V
Ian Canada's UcPure is a supercapacitor power module. It uses large supercapacitors of 3000F to provide a high-performance power supply. It is a totally passive module, with no feedback and no active components. In pure output mode, only the set of pre-charged supercapacitors is applied to the load.
Reference : 19182
249,00 €tax incl.
207,50 € tax excl.
Shipping date: 21-10-2026.
Ian Canada UcPure Quad Supercapacitor Power Module Class A 5V / 3.3V
Ian Canada UcPure Quad power supply module
The UcPure is equipped with a synchronous charging function (SYNC) to enable the supercapacitors to be recharged when music playback stops.
The Ian Canada UcPure Quad is an improved version of the UcPure. It uses a new architecture to run four 3000F supercapacitors in parallel (two groups), to deliver exceptional performance. It is thus capable of delivering a current of up to 4800A with an internal ESR of just 0.23mΩ (continuous output mode). The UcPure Quad therefore represents a high-quality, low-noise, high-dynamic power supply system for enhancing the sound quality of sensitive audio peripherals such as low-jitter clocks, DACs, FIFO buffers and many other types of circuitry.
Supercapacitors are sold separately.
Key features:
  • High-performance supercapacitor power supply.
  • Supercapacitors operate in Class A, with current flowing in one direction only.
  • The output can be configured as 3.3V or 5V (default) using the module's jumpers.
  • The outputs are totally isolated from the charger and power input in pure mode.
  • Can be controlled by an ON/OFF chain (optically isolated) as part of a power supply package.
  • Supplied with built-in and external ON/OFF buttons.
  • Optical isolators are used for all internal processing logic.
  • Integrated protection scheme to prevent supercapacitors from depletion or low output voltage.
  • Synchronous charging function (SYNC). Supercapacitors can be recharged when the music stops. This function can prevent a drop in output voltage or protection even when listening to music for long periods. The SYNC control signal can be connected to the MUTE signal of a MonitorPi Pro or FifoPiQ7 (sold separately). Several UcPure units can operate together using the signal as a control chain. The signal is isolated from the UcPure so as not to affect power supply performance.
  • Designed for 24/7 use.
  • Four 3000F capacitors operate in parallel to reduce output ESR to a very low level, never achieved before. Noise is also reduced by 1/√(2).
  • New dual PCB architecture to completely eliminate wires between the UcPure and the supercapacitors, thereby improving performance, with cable resistance even higher than the ESR of the supercapacitors.
  • ESR :
    Continuous outputs J10, J13: 0.23mΩ + ESR fuse
    Switched outputs: J7, J9: 0.43mΩ + ESR fuse.
  • Balancing functions have been integrated directly into the PCB, so there's no need for an external balancing/protection module.
  • Horizontal and vertical mounting brackets.
  • Fast charging current of 5.3A or 8.1A, configurable via jumpers.
  • Optimized 12V AC input. Can also operate with 15V to 20V DC input voltage.
  • Double copper thickness, 4-layer PCB for low ESR.
  • Two groups of continuous and switched outputs for enhanced compatibility.
Ian Canada UcPure: Dimension diagram
Product typeSupercapacitor power supply module
Output voltage5V DC (default) or 3.3V
Input voltage12V AC or 15-20V DC
InputScrew terminals
OutputScrew terminals
Output voltage (V)3.3
Output voltage (V)5.0
Output current (A)4800
Input voltage (V)15.0
Input voltage (V)12.0
Input voltage (V)20.0
Power SupplyUltracapacitor power supply
IAN CANADA UCPURE QUAD Supercapacitor Power Module Class A 5V / 3.3V
Ian Canada's UcPure is a supercapacitor power module. It uses large supercapacitors of 3000F to provide a high-performance power supply. It is...
