AMPAPA H1 Headphone Amplifier Preamplifier
The Ampapa H1 is a Class A headphone amplifier with preamplifier function, designed to drive a wide variety of headphones while integrating into a Hi-Fi setup. It delivers up to 4000 mW of power and relies on ECC83 tubes custom-made by PSVANE, combining substantial output headroom with a warmer sound reproduction.
Reference : 22454
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 17-11-2026.
Ampapa H1 Class A Tube Headphone Amplifier Preamplifier 2xECC83
AMPAPA H1: Front view
The Ampapa H1 is a Class A headphone amplifier with preamplifier function, designed to drive a wide variety of headphones while integrating into a Hi-Fi setup. It delivers up to 4000mW of power and relies on ECC83 tubes custom-made by PSVANE, combining substantial output headroom with a warmer sound reproduction.
Intended for sedentary listening as well as scalable audio systems, it brings together balanced and single-ended headphone outputs, gain adjustment and preamplification connectivity. This versatility allows it to drive a headphone or control a power amplifier, while its 12V trigger, replaceable op-amp and machined aluminum enclosure make it easy to integrate and adapt over the long term.
Ampapa H1: Class A headphone amplification
The Ampapa H1 is a Class A headphone amplifier, supplied with ECC83 amplification tubes custom-made by PSVANE. This design favors a warmer sound reproduction, with smooth bass, while its 4000 mW output power lets it drive various headphones with headroom suited to their needs.
AMPAPA H1: 4000mW of power
AMPAPA H1: Headphone outputs
Ampapa H1: Practical and flexible device
Its headphone connectivity combines an XLR 4-pin output, a 6.35 mm jack and a 4.4 mm jack, to adapt the connection to the various balanced and single-ended standards. The three gain levels make it easy to adjust the output level according to the sensitivity and impedance of the headphone, while the RCA and 6.35mm jack outputs allow the device to be used as a preamplifier. The 12V trigger completes this architecture by allowing its integration into a Hi-Fi system with a synchronized power-on control.
Ampapa H1: Replaceable op-amp
The processing stage integrates an LME49720 mounted on a DIP8 socket, allowing its replacement without permanent modification of the circuit. This design allows experimentation with other compatible operational amplifiers, in order to gradually adapt the sound behavior of the device according to the components used.
AMPAPA H1: Replaceable op-amp
AMPAPA H1: Volume control chip
Ampapa H1: Volume control by NJW1195
Level adjustment relies on an NJW1195 chip, which ensures precise attenuation of the signal while limiting level differences between the left and right channels. This architecture thus maintains a stable stereo image, even during low-volume listening.
Ampapa H1: Aluminum enclosure
The electronics are housed in a CNC-machined aluminum enclosure, whose structure ensures both the protection of the circuits and passive dissipation of the heat produced by Class A amplification. This construction is suitable for sedentary use on a desk or in a Hi-Fi cabinet, where it complements the extensive connectivity of the Ampapa H1.
AMPAPA H1: Aluminum enclosure
Technical specifications
Preamplifier
Inputs2x stereo RCA
1x 6.35mm stereo jack
Outputs2x Stereo RCA
1x XLR 4-pin headphone output
1x 6.35mm jack headphone output
1x 4.4mm jack headphone output
Frequency response20Hz–20kHz (±0.7dB)
Amplification typeClass A
Output powerSingle-ended, low gain: 250mW
Single-ended, medium gain: 500mW
Single-ended, high gain: 1000mW
Balanced, low gain: 1000mW
Balanced, medium gain: 2000mW
Balanced, high gain: 4000mW
Output levelSingle-ended, low gain: 1.5V
Single-ended, medium gain: 2.1V
Single-ended, high gain: 3.0V
Balanced, low gain: 3.0V
Balanced, medium gain: 4.3V
Balanced, high gain: 6.0V
Amplification tubes2x ECC83
Input sensitivitySingle-ended: 1V
Balanced: 2V
THD+N0.04%
Signal-to-noise ratio (SNR)≥113dB
Compatible headphone impedance16–600Ω
Power supply12V DC / 2A
Dimensions155 × 124 × 42mm
Weight750g
Package1x Ampapa H1
2x ECC83 tubes
1x Power adapter
1x 3.5mm jack cable
1x 3.5mm to 6.35mm jack adapter
InputJack 6.35mm
OutputJack 4.4mm
OutputJack 6.35mm
ClassTube amp
ClassClass A / AB
Download
AMPAPA H1 Class A Tube Headphone Amplifier Preamplifier 2xECC83
The Ampapa H1 is a Class A headphone amplifier with preamplifier function, designed to drive a wide variety of headphones while integrating into a...
