DENAFRIPS HESTIA 15TH Preamplifier Silver
With the Hestia 15Th, Denafrips presents a balanced preamplifier based on 100% discrete components operating in pure class A to deliver unprecedented sound quality.
By buying this product you get 132 loyalty points
Reference : 21416
1 329,00 €tax incl.
1 107,50 € tax excl.
Denafrips Hestia 15TH Discrete Balanced Preamplifier Pure Class A Silver
Photo of the Denafrips Hestia 15th
With the Hestia 15Th, Denafrips presents a balanced preamplifier based on 100% discrete components operating in pure class A to deliver unprecedented sound quality. Its 60-step attenuator, controlled by a microprocessor and equipped with precision-adjusted resistors, guarantees perfect channel balance and an incredibly low harmonic distortion level of just 0.00023%, ensuring the clearest possible sound reproduction.
Denafrips Hestia 15TH: Smooth and precise volume attenuation
A microprocessor-controlled 60-step relay attenuator with precision-matched resistors ensures near-perfect channel balance and ultra-low distortion (THD 0.000230%). Volume transitions remain smooth, preserving natural dynamics and an immersive, fluid soundstage.
Denafrips Hestia 15TH volume control
The structure of the Denafrips Hestia 15TH
Denafrips HESTIA 15TH structure
#1 Discrete Class A gain
The gain is achieved using a network of balanced transistors and resistors.
#2 Attenuator
Relay with 60 steps controlled by microcontroller (UC).
#3 Proprietary Type-O Transformer
This is not a universal transformer, but one specially designed for the Class A architecture and high-precision components of this preamplifier. This design prevents performance losses caused by “excessive or insufficient power supply,” ensuring that every unit of electrical energy is used precisely for signal amplification.
#4 Low-noise linear power supply capacitors
A set of custom-made low-noise linear capacitors suppresses ripple interference from the power supply source; combined with a linear power supply architecture, it reduces power supply noise to an extremely low level.
Denafrips Hestia 15Th overview
With its two balanced inputs and one balanced output, the Hestia can be integrated seamlessly into any audio setup, whether it's a professional studio or an audiophile system. Its adaptive nature and compatibility ensure smooth integration into your existing setup, improving overall performance and delivering an incredibly expansive and immersive soundstage.
Overview of the Denafrips Hestia 15Th
1Input selection / Standby
2Screen
3Volume control
4Analog inputs: 1x RCA / 2x XLR
5Analog outputs: 1x RCA / 1x XLR
6115V/230V AC power port
Product typeDiscrete balanced preamplifier
ArchitecturePure Class A
AttenuatorMicroprocessor-controlled 60-step relay attenuator
Inputs2x balanced stereo XLR
1x unbalanced stereo RCA
Outputs1x balanced stereo XLR
Output levelRCA : 2Vrms
XLR : 4Vrms
Frequency response10-80kHz(-0.3dB)
THD+N0.00023%
SNR120dB
Dynamic range> 121dB
Stereo crosstalk-110dB
Input impedanceUnbalanced : 12.2K Ohms
Balanced : 60K Ohms
Output impedanceUnbalanced : 200 Ohms
Balanced : 400 Ohms
GainUnity gain
Power supply110/240V AC 50/60Hz
Energie consumption1W (iddle)
20W (operating)
Dimensions322 x 348 x 74mm (WDH)
Weight6.5kg
ColorSilver
Package1x Denafrips Hestia 15TH
1x Remote control
InputXLR
ColorSilver
ClassClass A / AB
Remote ControlYes
DENAFRIPS HESTIA 15TH Discrete Balanced Preamplifier Pure Class A Silver
With the Hestia 15Th, Denafrips presents a balanced preamplifier based on 100% discrete components operating in pure class A to deliver...
