The LM-15ST is a stereo passive volume attenuator designed to precisely adjust the level of an audio signal without requiring a power supply. It offers six selectable attenuation levels: 0dB, -3dB, -6dB, -9dB, -12dB and -15 dB, making it easy to adapt the signal level to the equipment being used. Its versatile connectivity includes 6.35mm Jack, 3.5mm Jack and RCA inputs and outputs, providing compatibility with various audio sources and devices. Thanks to its passive operation, which requires no power supply, and its different adjustment levels, the LM-15ST provides a simple solution for controlling the level of a stereo signal in a Hi-Fi or audio system.
Technical Specifications
| Specifications | |
| Product type | Volume attenuator |
| Inputs | 1x 6.35mm Jack 1x 3.5mm Jack 1x RCA |
| Outputs | 1x 6.35mm Jack 1x 3.5mm Jack 1x RCA |
| Adjustment levels | 0/-3/-6/-9/-12/-15dB |
| Input impedance | 50 Kohms |
| Output impedance | 50 Kohms |
| General | |
| Dimensions | 78 x 70 x 25mm |
| Weight | 140g |
| Packaging | 1x Stereo passive volume attenuator |
| Input | Jack 6.35mm |
| Input | Jack 3.5mm |
| Input | RCA |
| Output | Jack 3.5mm |
| Output | RCA |
| Output | Jack 6.35mm |
| Color | Black |
| Class | N/A |
| Remote Control | No |
