Pack Audiophonics AP300-S250NC Amplifier + Fosi Audio S3 Streamer + Audiophonics XLR 30cm Cables
We are offering a Fosi Audio x Audiophonics product bundle comprising the Fosi Audio S3 streamer, DAC and preamplifier, the Audiophonics AP300-S250NCX power amplifier, and a pair of Audiophonics Wire XLR cables. This bundle will provide you with a connected system offering ample power reserves and high-quality sound reproduction.
By buying this product you get 77 loyalty points
Reference : 21608
779,00 €tax incl.
649,17 € tax excl.
Instead of 877,90 €
Shipping date: 12-11-2026.
Pack content
Pack Fosi x Audiophonics Fosi Audio S3 + Audiophonics AP300-S250NCX + Audiophonics Wire XLR 30cm
Fosi Audio S3 + Audiophonics AP300-S250NCX + Audiophonics Wire XLR 30cm : Front view
Audiophonics AP300-S250NCX: Hypex NcoreX 2x250W power amplifier
The Audiophonics AP300-S250NCX is a stereo amplifier based on a Hypex NcoreX NCx252MP amplifier module. This solution is ideal for those seeking substantial power reserves (2x250W @ 4Ω) without compromising on sound quality. This amplifier is suitable, for example, for driving demanding speakers, for sound reinforcement in large listening rooms, or for studio applications requiring considerable headroom without compromising on the precision and richness of the audio signal.
All components are housed in a sleek, robust 100% aluminium casing featuring vents to aid heat dissipation. Its design also helps to minimise the impact of signal interference.
View the detailed specifications for the Audiophonics AP300-S250NCX
Audiophonics AP300-S250NCX : side view
Fosi Audio S3 : front view
Fosi Audio S3: Streamer, DAC and balanced preamplifier
The Fosi Audio S3 is an extremely versatile device that serves as a network player, DAC and balanced preamplifier. Indeed, it is built around high-end components and a comprehensive chipset including a Burr-Brown PCM1894 ADC chip, an Amlogic A113X processor, an AK4493SEQ DAC chip and two OPA1612 op-amps for signal pre-amplification. Packed with technology, the S3 features WiFi 6, Bluetooth 5.3 with support for AAC and SBC codecs, and supports numerous streaming protocols: Roon Ready, Google Cast, AirPlay 2, Spotify Connect, Tidal Connect and UPnP. Furthermore, it is capable of converting signals up to 32-bit 384kHz PCM, allowing you to enjoy high-resolution streams. The Fosi Audio control app, available via Google Play and the App Store, offers a 5-band equaliser and full control of the device, including multi-room streaming. In terms of connectivity, it’s equally impressive: an RJ45 LAN port, Toslink input, HDMI ARC input, RCA input, Toslink output, unbalanced RCA output, balanced XLR output and even an output for an active subwoofer. All in all, the S3 will have no trouble integrating into any existing Hi-Fi system and becoming one of its most essential components.
View the detailed specifications for the Fosi Audio S3
Audiophonics Wire XLR: OFC copper stereo XLR interconnect cables
The Audiophonics Wire range offers a selection of affordable yet high-performance cables, hand-assembled in our workshops in France. The Audiophonics Wire XLR cable features a Mogami Neglex W2549 signal cable and Neutrik NC3MXX-B and NC3FXX-B male and female XLR connectors, ensuring excellent conductivity and durability for efficient audio signal transmission.
View the detailed specifications for the Audiophonics Wire XLR
Audiophonics Wire XLR : Front view
Pack specifications
Product typeStreamer / DAC / Preamplifier + Power Amplifier + XLR Cables
Contents of the pack1x Audiophonics AP300-S250NCX
1x Fosi Audio S3
1x Pair of Audiophonics Wire XLR cables, 30cm
Specifications of the AUDIOPHONICS AP300-S250NCX
Product typeAmplifier
ClassD
Number of channelsStereo (2)
Max. power (@ 1kHz, THD=1%)2x150W @ 8Ω
2x250W @ 4Ω
2x180W @ 2Ω
Inputs1x Single-ended stereo RCA
1x Balanced stereo XLR
OutputsSpeaker terminal blocks
Trigger5-12V
THD+N0.0015%
SNR121dB
Output noise30µV
Output impedance1.5mΩ
Frequency response10Hz - 50kHz
Efficiency92%
Input sensitivityMaximum power at 1.66V RMS
Power supply230V / 110V (automatic switch)
Case materialBrushed aluminium
Overall dimensions (LxPxH)300 x 248 x 62mm
Weight2080g
Specifications of the Fosi Audio S3
DAC
Preamplifier
DAC chipAK4493SEQ
ADC chipPCM1894
ProcessorAmlogic A113X
AOPOPA1612
Inputs1x RCA input
1x Toslink optical input
1x HDMI eARC input
Bluetooth
WiFi 6
1x RJ45 Ethernet port
Outputs1x Single-ended RCA output
1x Balanced XLR output
1x Toslink optical output
1x Subwoofer output
Other connectors1x 12V trigger output
WiFiDual-band Wi-Fi 802.11 a/b/g/n/ac/ax (2.4 GHz and 5 GHz))
10/100M Ethernet port
Supported Bluetooth codecsSBC, AAC
Supported streaming protocolsGoogle Cast, AirPlay 2, DLNA, Roon-compatible, Spotify Connect, Tidal Connect
Supported sampling ratesOptical Toslink, HDMI eARC, WiFi: PCM 24bit 192kHz
Bluetooth: 24bit 48kHz
Google Cast: 24bit 96kHz
Airplay 2: 16bit 48kHz
Roon Ready: 32bit 384kHz
Power supply12V DC 2.5A via jack DC
Dimensions173 x 173 x 47mm
ColorGrey
Specifications of the Audiophonics Wire XLR
Product typeStereo XLR cable
Connectors2x Male XLR connectors
2x Female XLR connectors
Length30cm
Conductor materialOFC copper
Conductors section0.339mm² (22AWG)
Conductors diameterØ1.9mm
Insulation materialXLPE (cross-linked polyethylene)
Outer sheathPVC
Contact materialCopper alloy
Contact plating24k gold
Shell materialPolyamide
We are offering a Fosi Audio x Audiophonics product bundle comprising the Fosi Audio S3 streamer, DAC and preamplifier, the Audiophonics...
