Lionel B.
Excellent
Ampli livré 2 semaines après la commande, comme annoncé. Très bon matériel. Le boitier est bien fini et compact. L'ampli...
Bruno L.
Superbes!
A mon avis et dans mon cas d’usage il sont excellents et supérieurs aux MUNDORF SUPREME SILVERGOLD OIL que j’utilisai jusqu’à...
Zean V.
Bon produit - logistique à améliorer
Bon produit pour la calibration avec REW.
Réception après 8 jours (lent quand on à l'habitude d'Amazon)
Le suivi...
IEAST AUDIOCAST PRO M20 Streamer WiFi AirPlay DLNA Bluetooth 5.0 24bit 192kHz - reviews - There are 3 reviews.
Pavel V.
Very good streamer
I would like to share my opinion about this AudioCast Pro M20 that I have tested after purchase from Audiophonics, delivered perfectly just few days after the order.
I have decided to try Pro M20 and improve that way my Hi-Fi setup after positive experience with small M5 that I have been using about year without any issue.
Connectivity to WiFi – simple and new device has been found/installed within a minute.
Connectivity to LAN – simple, immediately
Then listening of various music (TuneIn internet radios, local files in MP3 to FLAC lossless, Spotify…) using original AudioCast app, directly Spotify, but also BubbleUPnP – everything works perfectly
Audio output – very impressive, this is sophisticated sound of very high quality audio device with great dynamics, sound stage space and voice separations. I have no idea if ES9023 DAC is still used as some other older Pro models refers, but this audio output provides Hi-Fi audiophile level sound.
Digital output (sending digital signal to my older Onkyo amplifier equipped with AK4586 (24/96) DAC) – this is absolutely awesome sound, top clarity and dynamics. This is my favourite and preferred way how to use this streamer.
Just for the curiosity, I have also tried to open Spotify directly in mobile phone and send the stream via Bluetooth – this also works and Pro M20 smoothly switched to Bluetooth mode.
So overall, I am very happy with this Pro M20, and thank you Audiophonics for fast delivery.
luc M.
Fait le job !
Je l'utilise comme streamer, branché sur un dac externe et je le pilote avec Bubble Upnp; Dans ces conditions les 2 seuls points négatifs : ne lit pas mes WMA et lorsque je règle le volume avec Bubble Upnp la valeur affichée ne change pas; j'utilise Bubble Upnp depuis des années et c'est la 1ere fois que je rencontre ce problème (peut-étre un bug de l'implémentation Upnp/DLNA d'audiocast)
J'en possède 2, un et branché en ethernet et l'autre non, dans les 2 cas aucun problèmes;
N'utilisant pas le dac interne je n'ai pas d'avis sur la qualité du son;
J'ai utilisé l'appli dédiée pour programmer l'alarme (remplace mon radio réveil );
Samuel C.
Non fonctionnel
Je l'ai acheté car c'était moins cher qu'une wiim mini. Je regrette. La connexion au réseau wifi affiche "échec" mais fonctionne. L'appli n'est pas fluide et à chaque fois que je retourne dessus elle stoppe la musique plusieurs fois d'affilée pendant une demi seconde à 2 secondes, plus une longue coupure qui coïncide avec le chargement de l'image de l'album ... Si c'est vraiment ça c'est assez pourri. Chaque changement de chanson est suivi de 2 à 3 secondes de coupure, plus celle de chargement de l'image de l'album. Parfois il y a des coupures sans raison. Si c'est la wifi alors la gestion des pertes de connexion est catastrophique. Si c'est l'appli qui bug sur le téléchargement de la chanson ou sa transmission à l'audiocast, l'appli est juste pas stable. En gros le problème va consister en des coupures de 1s à 4s plus d'une quinzaine de fois, la musique jouant une fraction de seconde à chaque fois. Et parfois au bout d'un moment il va sauter deux ou trois chanson et en commencer une nouvelle. Parfois la coupure est un énorme blanc sans fin où le timer de la chanson avance de 5s puis renvient en arrière. Via l'appli audiocast, on a accès à plein de services de musique/radio. Sauf qu'il faut utiliser son interface. Elle est intuitive mais tout est enterré sous des tonnes de menus et je dois souvent recommencer la manip entière quand je veux chercher une autre chanson. Ouvrir une playlist me prend 7 clicks (+ temps d'attente) contre 3 sur l'appli du service de streaming (quasi pas d'attente entre les cliques). La connexion (mdp) au service de streaming est efficace. Modifier des playlists, liker des titres ou faire d'autres actions basiques est soit très bien caché, soit difficile, soit impossible. L'audiocast n'est pas détectable via les appli de streaming directement. Youtube et Deezer par exemple ne vont pas la détecter contrairement à d'autres lecteur réseau WiFi. On est obligé de passer par l'appli et de se farcir tous ses bugs. En fait pour moi le produit n'est juste pas fonctionnel et utilisable dans l'état. Je ne comprends pas que ça ait été commercialisé.
PS : j'ai déjà posté cet avis mais il n'a pas été autorisé par les mods et ils m'ont dit d'ouvrir un ticket. Maintenant que j'ai fait le ticket, j'espère que cet avis va être publié :)
contre testé par le SAV, tout est fonctionnel
The iEast Audiocast Pro M20 is a streamer that acts as a gateway to a truly connected audio system. It features a Wi-Fi connection as well as an...
