Richard H.
Dayton Audio BST-300EX
précis et chaleureux
Eric v.
bonne prise
Joris J.
Pricy, but best sounding caps for the money. I use them also as kathode bypass caps in my SET tube amp.
Joris J.
Gold Plated Male USB-C 3.1 DIY Connector This connector to mount will allow you to create your own cables with gold-plated USB-C connectors. This will allow you to take advantage of the reversible format of this...
Fragile
Hard to make a study connector. My soldered connection broke at use.
Joris J.
Good product
In combination with “ Linear Power Supply board MJE15034G Low noise 4.8V à 24V 2A" this transformer gave huge improvement in sound quality of my DAC e.a.
Joris J.
Gave my huge improvement of sound quality of DAC and another one in sound quality op raspberry SPIDF HAT, both in combination with a 30W R-core transformer.
Joris J.
Adjustable Soldering Iron with Screen 110W 500°C This 110W soldering iron offers an adjustable heating temperature from 80°C to 500°C. Its use is facilitated by a display showing the heating temperature and various...
Disappointing
I expected faster warm up, at warming up the real temperature of the tip is reached much later than is indicated on the display. At soldering the reheating/step up in warming seems to be lagging; that causes problems at soldering f.i. chassis parts. In stand by mode, you need to switch it off and on to reheat.
Joris J.
Quality product. Great value.
Good, sturdy, quality wiring.
I used it to solder and seperate little circuit around the sparkos ss3602, powered by seperate power supply (seperate from digital part of the DAC.). Spectacular improvement over the sparkos directly dropped in.
Joris J.
Great value
Very precise cutting. Sharp and strong.
Joris J.
Usefull
I use it more often than I expected to do.
Joris J.
Disappointing
Physical qualities are very good, but for high end sound quality the semi-balanced use of a symmetrical cable (shielding connected at only one end) is just better, I experienced.
Joris J.
Better than SC-221OOC
I first tried the ELECAUDIO SC-221OCC because that has PTFE isolation, but this less expensive Neotech cable simply sounds better with my SET tube amplifier. And a bit easier to work with.
Gernot E.
A delight for audiophile ears
The unit is easy to assemble, helped by very clear illustrated instructions. The quality of the housing is very good, the aluminium surfaces are beautifully brushed and all parts fit together perfectly.
The sound quality is outstanding, and the display with the large ticker showing the metadata of the music currently playing is also very nice.
The documentation of the DAC functions and the remote control can be found in the article description of the DAC board ("Datasheet Evo Sabre"). Unfortunately, this documentation leaves many questions unanswered and some of the items in the settings menu that are accessible via the remote control are not addressed or are perhaps no longer up to date.
Example: According to the documentation, the Raspberry Pi cannot control the power supply state of the DAC board. But in the settings menu, the item "GPIO Power Control" (not mentioned in the documentation) appears, which, when set to "yes", seems to let the Raspberry Pi shut down the device in a controlled manner.
Conclusion: A beautiful and high-quality device that is a lot of fun. However, the documentation could be improved.
Alexis M.
3 mois plus tard : parfait
Le titre pourrait se suffire à lui-même mais je vais un peu détailler.
Ce qui m’a attiré au départ c’est la connectique parfaitement adaptée à mon usage : TV sur la fibre optique ; platine vinyle sur l’analogique ; RPi + serveur MPD sur USB. Le prix très attractif aussi.
Les enceintes sont des quarts d’ondes diy (90dB/W/m) qui donnent tout leur potentiel avec ce petit ampli bien cool.
Les plus : petit, consomme peu, facile à prendre en main et à utiliser, s’allume tout seul quand on a la bonne source de sélectionnée, s’éteint tout seul quand il n’y a plus de son, puissance très suffisante pour une utilisation quotidienne ; télécommande ok…
Les moins : un peu de souffle sur l’entrée analogique RCA qui s’efface dès qu’on passe le 10/12 en volume, pas de souffle audible sur les entrées numériques ; les presets ne sont pas fabuleux et je reste un flat avec les réglages eq à zéro ou éventuellement +2dB sur les basses ; l’écran en affichage en spectre est mal foutu, c’est en linéaire et ça va de 100Hz à 20kHz, donc pas d’affichage du bas de spectre et le linéaire c’est pas très représentatif ; l’éran pourrait être moins lumineux (ou réglable en intensité). Ne s’allume pas en auto si on a pas le bonne source sélectionnée précédemment.
Divers : je n’ai pas testé le casque, je n’écoute pas de musique au casque. Ce petit ampli donne avec mes enceintes sont plein potentiel à partir d’un niveau de 20/25 (faut avoir de gentils voisins), le son est très percutant sans être agressif.
Content de cet achat, il fait le job, il est discret, il est pratique.
La bonne mesure
La valeur affichée est conforme à celles mesurées: 8,17µf sur le premier condensateur et 8,19µf sur le second. Avec une tolérance de 5%( soit 0;41µf en + ou en -) . C'est parfait pour l'application prévue en filtre passif d' enceinte. Merci Audiophonics.
Jean Louis L.
Mes câbles secteurs étaient tous des Pangea AC14SE, très bons pour leur tarif, mais je souhaitais expérimenter quelques choses plus haut de gamme avec 2 câbles DIY, le Furutech TCS31 et ce Yarbo SP-1100PW, tous deux avec des prises secteurs Viborg VE502S en cuivre pur plaquées argent, en tous point excellentes.
J'ai réalisé de nombreux essais avec ces deux câbles secteurs, sur l'ampli (un Elekit TU9200, petit ampli à tubes à simple étage de 7581A Tung-Sol + Psvane 12AU7, merveilleusement musical), le DAC (Denafrips Ares II) et la barrette secteur. Ces deux excellents câbles secteurs ne sont pas des concurrents mais par contre, ils se complètent à merveille, à la condition de les placer judicieusement dans votre système audio.
Le combo magique chez moi est le Yarbo entre la prise murale et la barrette secteur et le Furutech TCS31 entre la barrette et l'ampli.
Le remplacement du Pangea par le Yarbo apporte une scène sonore en 3D étonnante, large et surtout profonde, des voix sans aucune sifflante, pures. C'est d'ailleurs souvent une constante avec le cuivre OCC, une impression d'une reproduction musicale pure et naturelle.
Le Furutech TCS31 apporte lui une grande richesse harmonique, des voix charnelles, émouvantes, un grave qui descend très bas. C'est une écoute pour ceux d'entre nous qui recherchent une proximité avec les artistes, le jeu des musiciens, les voix, presque une communion.
Tout le contraire d'une écoute exacerbée et démonstrative, presque intime, vraiment sublime sur les voix, les instruments acoustiques, le jazz vocal, la musique baroque, les voix de Brel, Nougaro, Stacey Kent, Youn Sun Nah, Véronique Gens...
La dynamique est effectivement sage ici et la douceur l'emporte, avec quand même une analyse troublante sur les voix, mais qui demeurent charnelles et douces. Si vous vous reconnaissez dans cette description musicale, ce combo est fait pour vous !
Sinon, pour une écoute plus transparente et dynamique, une analyse plus poussée, mieux vaut aller voir ailleurs.
Étonnant et un peu mystérieux de constater à quel point des câbles secteurs peuvent apporter tellement sur la reproduction musicale.
Yannick r.
Un DAC aussi précis que doux à l'oreiller
Suite aux différents avis sur le site et ailleurs, j'ai décidé de tenter ce D70s qui semblait bien prometteur.
Alors malgré quelques frayeurs après une mise à jour et un câble USB défectueux (rapidement remplacé par ailleurs), le joujou électronique fonctionne superbement. Une quantité de détails impressionnante, une dynamique au rendez-vous et une délicatesse en haut du spectre, tout est là pour se lancer dans de belles et longues écoutes. A voir maintenant si les iPurifier et iSilencer de chez iFi audio pourront optimiser les qualités intrinsèques de l'appareil, lisant la musique depuis un PC Windows, et bientôt depuis un streamer.
Attention cependant à la sensibilité en entrée de l'ampli si vous utilisez les sorties XLR. Sur mon ampli casque, j'ai utilisé le mode DAC, la puissance disponible est phénoménale, mais les distorsions ont commencé à se faire entendre sur certains morceaux. Si cela arrive, préférez le mode Pré Amp et atténuez le niveau de sortie. En revanche, rien à signaler sur les sorties RCA, qui bénéficient également d'un bon niveau de sortie et d'un rendu tout à fait plaisant.
La navigation n'est pas trop compliqué et l'affichage est assez lumineux à mon goût.
Pour conclure, ce DAC a tous les atouts pour être au centre d'une installation de qualité, eu égard à son niveau de performance.
jean michel G.
MUNDORF MRESIST SUPREME MRES20-1.5 Resistor 20W 1.5 Ohm The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these resistances allow to obtain finer...
Merci pour votre retour
Petr K.
An excelent simple DAC
This DAC ,despite its sophisticated internal architecture is simple to attach to RPI4, no boring I2C control, OPA necessary, worked immediately with Volumio generic DC i2S driver. I connected it to TI 2x50 W TPA3116D2 chip amp. With two Magnat premium 102 speakers the set generates great sound, for a daily listening. Can compare to PCM5102A which I installed to another DIY DAC, both are good ones, Sabre seems to me better in high freq, IT in lower ones. May be its a little bit subjective view.
Exelent utilisée avec le Ifi digital interface.
J ai utilisé ma 2eme Ifi interface pour améliorer grandement le son tire de mon extracteur audio hdmi. Avec une Ifi I power standard. Pas mal. J ai utilisé une Ali Ifi x power si dessus la différence est impressionnante. Plus d épaisseur de naturel et de dynamique sur une largeur de bande encore plus étendue. Le prix et bien étudié pour les performance audio. Si vous voulez aller encore plus loins. La version élite elle. Sais encore mieux. Bien mieux. Ses deux alimentations sont génial. À recomender sans retenue.
Bon produit, de bonne facture, j'ai juste une remarque au sujet de l'affichage qui aurait pu être réglable, car ça brille un peu fort dans le noir, et dans une chambre, c'est pas terrible.
Serge H.
Un accessoire incroyable
Sceptique au départ, Il faut le voir pour l'entendre.
Couplé à un conditionneur de 1000 euros sur une multiprise pour les sources audio, cet accessoire apporte une plus value incroyable au système.
Une extinction des notes qui ne s'arrêtent, son palpable...
L'accessoire le plus bluffant à ce jour.
Damien C.
TOPPING EX5 Headphone Amplifier DAC 2x ES9038Q2M Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA Black Topping offers with its EX5 an extremely powerful DAC and headphone amplifier combo. Its conversion stage is indeed based on two ES908Q2M DAC chips and allows the reading of...
Meilleur rapport Q/P
Après avoir longtemps cherché, je voulais un DAC avec prise casque, alimentation intégrée, prise USB B plus robuste que le micro USB d'un SA300 par exemple, et des sorties XLR en remplacement d'un ampli DAC Yamaha A-U670.
Totalement satisfait par ce petit bijou. L'intégration des composants est au top (partenariat et expérience partagée entre Topping et Shenzhenaudio oblige), le son est pure comme jamais même s'il n'utilise pas les flagship comme le ES9038Pro ou le AK4497/99 à 60 ou 70€ la puce !
Il est tout de même équipé de 2 ES9038Q2M offrant des caractéristiques similaires à son grand frère mais ici 1 puce par canal.
Un bon compromis et largement suffisant de le cas d'une utilisation pc fixe à la maison avec 2 enceintes Wharfedale Diamond 220 et un petit caisson de basse Yamaha.
Pour le moment je l'ai connecté à un SMSL SA300 (celui de mon fiston) en attendant la réception d'un SMSL AO200 (adieu les bruits parasites je ne vous regretterai pas) non encore dispo au moment de passer commande mais dont le rendu sonore est, selon les tests et vidéos, plus chaleureux que sur le SA300 sans toutefois atteindre celui des amplis de class-a.
Je tiens enfin à remercier le service client et support d'Audiophonics pour leur professionnalisme et la qualité de nos échanges. Dommage juste qu'on en puisse les contacter au téléphone, çà apporte un côté plus humain tout de même.
Damien C.
Très bon adaptateur
Utilisé sur un DAC TOPPING EX5, des écouteurs FIIO FH7 et un câble de remplacement FiiO LC-4.4D 4.4mm (introuvable en France...).
Le serrage est parfait. Cet adaptateur est suffisamment flexible, résistant et respire la qualité tant physique qu'au niveau du son.
Laurent C.
J'ai du mal à le croire !!!
Après avoir essayé du Real cable, Qed, Nordost à des prix bcp plus élevés, avec le Canare j'ai tapé ds le mille. Connecté entre un Roksan kandy k2 et Marantz na6006 clarté, détails et des basses rondes sans aucune agressivité sur des Focal aria926. Incroyable. Bravo Audiophonics de proposer des produits de cette qualité à ce tarif. Chapeau !!!
Nico V.
NEOTECH STDCT-20 Hook-up wiring multi strands UP-OCC SIlver PTFE 20AWG This Neotech silver multi-strand cable with PTFE insulation isthe best deall for rewiring and enhancing tube amplifiers, or any high-end Hifi device with wiring in the air. A...
For DIY power cable
I used this cable to power my Topping D70S DAC. Phase + Neutral are UP-OCC silver, ground is UP-OCC copper. All cables are screened separately by the copper sleeves. Sleeve-ends are connected to the power plug input (ground). With Furutech connectors and you have a ultra high end power cable and it is all save because of fused DAC and no more than ..mA of current dissipation.
Diogo P.
Worth it
Good weight, good copper and the aluminium body a must.
rodrigue L.
Voilà une semaine que je l ecoute via qobuz usbridge ampli atoll enceintes jmr.
Par rapport à mon ancien dac ds ess9018
Soundstage plus grand plus profond sans nul doute.
Timbres plus réaliste
Timing plus précis.
Je ne trouve pas que cela dégage une chaleur dans le son trop prononcé et il n est pas mou du genoux.
En résumé
Soundstage très bon ecoute plus live plus enveloppant
Timbre excellent instruments cuivre,cordes parfait.
Voix j aurais aimé plus de corps de grain encore.
tous les styles de musique passe je suis très ecliptique
Bref je suis refait .
Un belle achat
Thierry W.
Très bon streamer
Très bon streamer, surtout au regard du tarif affiché.
S'utilise avec Volumio ou en direct avec l'adresse IP.
Comparable à un Rasberry Pi, mais en plus compact et plus propre. Pas besoin de deux alimentations non plus.
J'avais un Lumin U1 mini avant, mais l'interface est moins bien et moins intuitive que le stream. Sans compter la différence de prix :-)
Pas de différence en terme de qualité sonore... Juste plus de sorties sur le Lumin....
A recommander !!
jean michel G.
Idéal pour basse ou haute fréquence ?
Je me pose cette question.
Le mieux pour ce type de résistance.
Idéale pour toute la bande, basse et haute fréquence, grâce à la conception double enroulement à moins de 75µH.
Antoine P.
Câble de qualité
Très satisfait par ce fil, utilisé pour refaire le câblage interne d'une alimentation. Souple, facile a dénuder et l'isolant ne souffre pas lors de la soudure.
Tomas H.
SMSL TABEBUIA WAVECOR Bookshelf Speakers 2 Way 100W 4Ω 88dB 56Hz-32kHz Black (Pair) The Tabebuia are the first loudspeakers offered by the acclaimed and recognized SMSL brand. These compact bookshelf models include a tweeter and a woofer from Wavecor, a company...
Great quality from small, easy to drive speakers
I am connecting these speakers to Astell&Kern ACRO L1000 DAC/AMP for a very nice near-field set-up on my working desk. Despite the modest output of my amp (15W per channel), these speakers produce wonderful music, very enjoyable, full of detail and color. They do not get very loud of course, but they render the music with authority and help me get through my working day with more joy and energy :) I can highly recommend these.
Finesse...
Montés sur un HA-B6120 après des Muses02.
On gagne beaucoup en finesse, en quantité de détails entendus. L'aigu est fin et semble filer haut. La scène sonore n'est peut-être pas la plus large mais c'est très précis, les Muses02 le sont beaucoup moins.
Bel équilibre les basses sont là sans excès de rondeur, les aigus pas en avant comme avec certains AOP...
Sur la musique classique c'est top, dont un enregistrement qui n'a jamais passé aussi bien que sur ce set... Visions of Prokofiev par Lisa Batiashvili: grosse caisse énorme d'origine qui est à sa place, violon parfait pas du tout acide, séparation de tous les pupitres un vrai régal! mais tous les styles passent bien et on distingue facilement les prises de son/éditions qui sont bonnes, quelque soit le choix sonore de la prise.
Le capot de l'ampli chauffe davantage, sachant que l'on est en été avec des 30° dans la journée.
Cet ampli gagne à être connu. J'ai utilisé d'autres amplis à base de l'excellente puce d'amplification TI TPA6120, celui-ci est le meilleur.
Présence d'AOP en entrée, je l'ai écouté avec des Muses8920, Muses02 et Burson V6 Classic. Avec les Muses c'est très bon, je préfère les V6 Classic encore plus fins et détaillés.
Le HA-B6120 drive facilement tous types de casques, à basse et haute impédance. Il a plein de fonctionnalités en entrée et en sorties casques (asymétrique, symétrique). Il est puissant j'alimente un HE-6 sans problème au 1/3 du volume en gain bas.
Même pour beaucoup plus cher difficile de trouver mieux, c'est neutre, puissant, détaillé, musical.
Coaxial Cable OFC Copper Gold Plated Shielded 0.75m This Coaxial cable has a Copper OFC conductor for excellent conductivity. It also benefits from shielding and ferrite to limit the impact of interference on the signal. The...
bon cable petit prix
Cable numérique qui fait son job,suffisant pour un Dac d'entrée de gamme
Michael L.
It works
I though it was faulty(coilwhine thru my speakers), tried a diffrent power distributor no high pitched sound thru my speakers, because of that i will only give it 4 stars
Thomas G.
Beau rendu
Bonne qualité du boîtier dans l'ensemble. L'aluminium semble de bonne qualité. Se perce facilement. Sur les parois à l'intérieur il y a plusieurs rainures parallèles ce qui est pratique pour faire passer les câbles et les coller.
Côté pratique aussi il y a des rainures sur la plaque de dessus et de dessous pour laisser passer la chaleur.
Une fois les connecteurs en place et une belle plaque en aluminium sur la face avant, le rendu est pratiquement professionnel.
Seul petit bémol, les deux arrêtes de côté de la face avant n'étaient pas 100% plate, un coup de ponçage et c'est Nickel !
A conseiller, super produit !
Dominique M.
Des matériels de qualité
Ces blocs mono, en classe D, permettent une restitution de qualité, associés au préampli phono à tube Dynavox TPR-2.
A recommander
Dominique M.
Excellent matériel !
Ce préamplificateur phono à tube constitue un excellent matériel, avec un très bon rapport qualité / prix.
Il a été associé à des blocs mono AUDIOPHONICS MPA-M250NC Amplificateur Mono Class D NCore 1x250W 4 Ohm, rendant une restitution de grande qualité.
Le tube tube initial (12AU7) a été remplacé par un tube plus qualitatif permettant de tirer le meilleur parti de ce préampli.
A recommander
Avis mitigé
Je partage l'avis précédent. C'est un câble analytique ça manque un peu de rondeur et de souplesse pour moi. Pour cette raison Je mets un avis mitige car j'espérais mieux compte rendu des avis excellents que j'avais lu... mais pour 5 euros c'est un bon rapport qualité prix tout de même, et facile à souder. Par contre message pour les anglais.. ce n'est pas un câble hp mdr les brins sont fins comme des cheveux....
Avez vous bien rassemblé les brins par deux à chaque extrémité ?
Pierrick P.
TECTONIC BMR TEBM65C20F-8 Speaker Driver Full Range Paper 20W 8 Ohm 81dB 80Hz - 20kHz Ø 8.9cm Tectonic's BMR range consists of wideband loudspeakers designed to cover a very large part of the audible audio spectrum. Thus, the TEBM65C20F-8 has an extended frequency...
Ma commande
j'aurais aimé être informé avant la finalisation de la commande qu'il y avait un réapprovisionnement.
Ioannis P.
Value for money
Musical and balanced cable
Excellent price/performance ratio
Bruno C.
Pas assez cher mon fils!
Et oui n'en déplaise aux irréductibles puristes qui ne jugent la qualité de leur système qu'au prix d'achat, il est possible de se faire un grand plaisir pour une somme raisonnable.
N'ayant plus de préampli, en panne, depuis longtemps, j'étais d'abord passé par un potentiomètre de volume de chez FX audio.
Moyennement satisfait de la sensibilité du réglage volume j'ai contacté Audiophonics pour des conseils. Je n'ai pas été déçu du tout et la proposition qui m'a été faite sur ce DAC prouve une fois de plus la compétence et l'écoute de cette maison.
Raccordé à une vieille platine Microméga de 25 ans d'âge en optique directement sur mon bloc de puissance Cyrus c'est une pure merveille. Aucune agressivité, tout est propre du grave aux aigus, un médium criant de vérité, une scène sonore correctement dimensionnée, belle dynamique, du détails sans en rajouter, bref que du positif. J'ai juste soigné l'alim que j'ai pris chez eux aussi, une Ifi à 49€.
Donc si votre platine CD commence à souffler beaucoup de bougies une cure de ce DAC vous redonnera la banane!
Merci Audiophonics.
Tunaru A.
Goood
Best amplificators subwofer.
Hervé C.
SHUGUANG TREASURE 6CA7-Z Amplification Tubes (Matched Pair) Shuguang's 6CA7-Z power tubes incorporate a grid with gold wires and a glass with black internal HPCC (High Polymer Carbon Compound) coating. The latter has the...
SHUGUANG TREASURE 6CA7-7
sur ma commande initial une lampe ne marchait pas, &( mois après une lampe claque. ne seraient-elles pas fragiles ? Sinon très bon rendu.
Elle ne sont pas plus fragile que les autres marques, peut-être un soucis de réglage de Bias
Roland B.
Iscott
Très bon produit et facile au montage.
Roland B.
Iscott
Très bon produit.
Roland B.
Iscott
Câble très bien construit et il agit sur la musicalité et la différence est audible de suite par rapport aux autres câbles mais la restitution est très douce et feutrée manque de dynamique a marier avec des électroniques agressives .
Jean-Michel P.
Un + vraiment appréciable
En remplacement de l'alimentation fournie en standard avec mon 3D LAB Nano Transport Sonata V5...
Le gain se situe au niveau l'attaque des sons. Encore plus nette et plus propre !
(sinon, comme Arnaud, je trouve que la LED éclaire un peu trop :) )
Aikaterini A.
Nothing special
I bought rhis dac because of Amirm' review. By using it I found it nothing more than a typical modern Chinese dac you can find at much smaller price. I wonder why, while they knew that their choice of this volume /source control was a joke , they dodnt give us the chance to bypass it. At least....
Vraiment decu
Andre T.
Recommendation
This little amplifier was an audiophile surprise for me. To say it in advance: it can definitely compete with amplifiers from the 1000€ league.
The first thing I noticed about the sound was the authority of the bass. It seemed as if my speakers were now supported by a very controlled subwoofer. Effortlessly and without strain, the MOS-120 controls the cones. This indicates a good damping factor. This sovereignty continues into the midband, which is wonderfully detailed and wide. The result is a spaciousness that I have never experienced with my speakers before. The high frequency range is accentuated and airy, giving the treble that typical audiophile melting. You can hear that this amplifier has a superior audio bandwidth.
The MOS-120 is a very good example of what makes a good analogue amplifier. It is puristic, but focuses on exactly what an amplifier must be able to do. I am considering ordering a second MOS-120 to use them channel separated. Unfortunately, my loudspeakers don't have a bi-wiring option and the MOS-120 can't be bridged, but this setup might give me even better channel separation.
Je l'utilise avec un Audio-GD R7-HE21. Tout est parfait de l'extrème grave à l'aigu, pas de dureté. Cable franchement excellent.
