Efthymios X.
As per title really.
Efthymios X.
As good as it always was
Plus reliable. That's it :)
Patrick R.
Customers reviews - There are 21000 reviews.
Jean-Christophe M.
Tinned OFC Copper Wiring Cable 2.6mm² Silicone Sheath Ø4mm Red This cable sold by the meter includes a 2.6mm² (13AWG) cross section stranded conductor. This conductor is made of tinned OFC Copper, ensuring good signal conductivity. The...
Acheté pour câbler un ampli DIY, ce câble est de très bonne facture cuivre OFC étamé les soudures se font très bien, la gaine épaisse protège bien c'est donc bien sécurisé. Seule chose à savoir il s'agit d'un câble très souple, pour twister les câbles entre eux prévoir beaucoup de serres câble mais ça se fait très bien.
Jean-Christophe M.
Bonne qualité, seul soucis les cosses sont trop petites pour passer des câbles de plus de 1,5 mm carré
Andoni G.
VIABLUE SC-2 Splitter 1x12 to 2x5mm Viablue splitters prevent cable ends from breaking while providing professional conductor guidance. The splitter is made of black anodized aluminum.
Perfect fit
If yoh are serious to hifi take those spliters for good asembly and looking of your cables
Andoni G.
Perfecto ratio price quality
For me is the perfect ratio for soeaker cable
Use it with mcintosh amps
Andoni G.
VIABLUE RACE Braided Sleeve 6-14mm Black Red Gray This Viablue braided sleeve is suitable for cables from Ø6mm to Ø14mm. It is ideal for protecting your high quality ropes against mechanical wear, tear,...
Good quality and good looking
I use it with sc2 and it has good quality and easy fit
SMSL PO100 Digital Interface USB-C to Coaxial / Optical XMOS 24bit 192kHz DoP64 Black The SMSL PO100 is a high performance digital interface based on a XMOS chip. The input is USB-C and the output is Coaxial or Optical Toslink. It supports streams up to PCM 24bit...
Problème Windows 11
Malgré la bonne qualité de finition de cet appareil,je n'ai pas réussi à le faire fonctionner correctement sous Windows 11:téléchargement du driver sur votre site,mais fonctionnement aléatoire,et surtout son dégradé (comme des saturations),bref retour du produit
Henrik S.
Powerful enough and without hiss and hum
I tried other TPA 3116/3118 amps, that all suffered from an audible hiss. This one is really quiet.
Bluetooth connection is automatic and fast.
I have been able to power it from 8 volt to 20 volt without issue
Jean-Christophe M.
très beau boitier
Acheté pour la réalisation d'un amplificateur DIY haut de gamme je voulais un boitier esthétique et adapté, le résultat est là belle esthétique belle finition. Gros dissipateurs boitier ventilé usinage travaillé et non approximatif. Il ne me reste plus qu'à le travailler moi-même correctement pour les perçages.
Juste à noter comme sur d'autre boitiers DIY les pieds fournis ont un caoutchouc curieux laissant des traces vertes sur certaines surfaces... Je règle le soucis en collant des patins dessous, ou alors utilisez d'autres pieds !
Jean-Christophe M.
beau produit
J'ai choisi ce produit pour la solidité et la sécurité procurée par la présence de deux vis de serrage et pour son esthétique.
La qualité est là, belle esthétique. juste à noter qu'elles sont un peu dures à enficher mais au moins ça tient bien !
Jean-Christophe M.
beau produit
j'ai pris ce modèle pour la présence de deux vis, cela donne une meilleure solidité et sécurité et pour l'esthétique aussi.
la qualité est là belle esthétique et fiche solide, un peu dure à enficher mais au moins ça tient !
Gregory P.
Tres bon
J'utilise Allo Nirvana pour alimenter un DAC Topping e30 Mk II au bureau. Jusqu'a present, j'alimentais ce petit DAC avec une batterie pour telephone. Comme je l'ai deja ecrit pour le Allo Shanti, le probleme est que les batteries retire beaucoup de dynamique et de texture au son. Avec le Allo Nirvana, la musique a beaucoup plus de dynamique et tout est plus texture meme s'il ne s'agit que d'alimenter un e30. Pour avoir compare Allo Nirvana avec Allo Shanti sur du material haut de gamme, il est possible d'affirmer qu'il y a une difference perceptible entre les deux alimentations en faveur d'Allo Shanti. En revanche, lorsqu'il s'agit d'alimenter un DAC de la gamme du Topping e30, cette difference est inaudible.
Gregory P.
Assez decu
La construction semble serieuse et n'appelle vraiment aucune critique. Sur ce plan, c'est un cable de qualite. Tout en ayant a l'esprit qu'il s'agit d'un cable a 40 EUR ou presque, il m'a decu en ce sens qu'il pose une sorte de voile sur la musique de telle sorte que le son devient terne et ennnuyeux. Le son que vehicule ce cable n'en devient pas mauvais pour autant. C'est juste qu' a l'ecoute, on perd des details dans le haut du spectre de meme que (encore une fois) une certaine clarte. Un coaxial de 75 Ohms a 40 EUR de chez Boaacoustic fait desormais mieux en eliminant ce voile de telle sorte que tout devient plus "lumineux" et texture. Je suis donc decu surtout au regard des commentaires dithyrambiques des autres possesseurs de ce cable.
Vous êtes bien le premier en 15 ans à nous faire un tel retour sur l'un des seuls vrai 75 ohm du marché ...
Si l'on jette un œil au produit auquel vous faites référence :
https://www.boaacoustic.de/p/blackberry-rca
Une seule certitude ... il ne respecte pas la norme (connecteurs non sertis ) et dans la mesure ou ce sont les mêmes que sur les câble non numériques certainement pas 75 ohm.
Un peu de littérature sur le sujet :
https://www.petoindominique.fr/php/cablenum.php
Accessoirement leur AES avec des connecteurs inconnus est facturé 300 €
https://www.boaacoustic.de/p/evolution-black-xlr-digital
Didier C.
pourri
M'a cassé dans les doigt en manipulant le câble. Pas sérieux
Brice P.
Qualité au rdv
Je voulais donné plus de clarté à mes enceintes Kef LS 50 et j'ai opté pour ces cables audiophonics.
Je ne suis absolument pas déçu du rendu. J'ai gagné en clarté au niveau des aiguës et bas mediums. Les graves sont plus marqués.
La spatialisation est aussi plus présente avec un vrai étagement.
Cabe de qualité, très rigide, robuste et vrai gain au niveau de l'écoute. Je ne peux que conseiller. Merci
Eric R.
Que dire ..
Il est très dur de trouver un sélectionneur à faible "bruit"..
Quand la tension du transformateur est trop élevée ... plus de 19V
Les diodes n'aiment pas !!!
Dans le texte de l'article:
Chaque relais s'accompagne d'une diode de commutation 1N4148 à faible fuite de courant.
Reymond Eric
Eric R.
Un bon produit.
Simple de conception et rassurant sur ces composants.
la photo ne ment pas. conseillée pour des personnes exigeantes.
Reymond Eric
Eric R.
Un bon produit
Un bon produit avec une bonne longueur pour des panneaux ou faces épaisse.
Reymond Eric
Eric R.
Cela change mais pas le prix !
Anciennement les condensateurs étaient de grade ou de meilleur qualité "Nichicon".. et le prix est resté le même.
Reymond Eric
Eric R.
Un bon mauvais produit.. si fait le vendredi
Un bon produit.?
Ayant commandé ce produit à deux reprises, je pensais que la qualité ne devait pas faire défaut.
Quand je reçois des éléments je les contrôle à la loupe.
Soudures des transistors au revers de la carte. "seulement"
Dissipateurs des transistors angle ou arrête coupante.
Ce qui n'étais pas le cas des éléments de la première commande.
Sûrement assemblé un vendredi!
Reymond Eric
TOPPING PA3S Amplifier Class D Balanced 2x MA12070 2x65W 4 Ohm Silver Topping offers with its PA3s a small balanced Class D amplifier, simple, powerful and affordable. It is based on two Infineon MA12070 amplifier chips and has two balanced and...
Classe D
Après rodage, ce petit ampli fonctionne très bien avec une puissance suffisante. Il rend toute la finesse de mon DAC D70 de la marque. Ce qui est remarquable, c'est son absence de dureté dans le haut du spectre (souvent un défaut que j'ai constaté sur mes amplis classe D précédents ) pas de perception de distorsion sur mes enceintes haut rendement et par conséquent pas de fatigue auditive. A noter, il ne chauffe pas et donc peut fonctionner même par temps de canicule ! De mon point de vue il présente deux petits défauts, le bouton de mise sous tension tactile semble fragile et les sorties symétriques pour Jacks 6.35 compliquent la connectique pour l'usage de ce type de matériel (je n'ai pas trouvé de câbles jack/XLR pour relier à un DAC pourvu de ce type de connexion).
Jean-Michel M.
Pour une Freebox Revolution
Comme indiqué dans un autre commentaire, ça fait le taf pour utiliser une télécommande universelle OneforAll sur une Frrebox Revolution avec le code associé STB Alice (et le bouton Power est déplacé sur List).
Pascal F.
WONDOM AA-JA32472 JAB2-30 V2 Class D Stereo Amplifier Module Bluetooth 5.0 DSP 2x30W 8 Ohm Here is a versatile Bluetooth 5.0 Stereo amplifier module that delivers 2x30W with 8 ohms load. It belongs to the JAB series that offers amplifier modules for mobile use.
Très simple à connecter
Je cherche à monter une enceinte à partir d'une Bose Soundlink Mini.
J'ai connecté la carte JAB2V2 aux hauts parleurs sans problème, mais la qualité du son est nettement inférieure à la Bose.
Sachant que les hauts parleurs sont de 2 x 10 Watts / 4 Ohms, est-ce un problème de puissance par rapport à la carte qui a une sortie de 2 x 30 Watts / 8 Ohms ?
Ou dois-je ajouter un module DSP ICP5 pour renforcer les basses ? Une fois les réglages effectués depuis un PC, sont-ils conservés en mémoire lorsque la carte ICP5 n'est plus reliée ?
Merci de m'éclairer.
Serge L.
Question to Patrick L
Sorry Patrick but I don't get the way you build the DoubleRAMM : you write :
"So I take two Amadeus 5 cables that I twist together, one in the direction of the directional arrows; the second oriented in the opposite direction.
I connect the Schuko connector to the Phase with the direction of the arrows towards the IEC connector, the other cable, with the arrows pointing from the IEC to the Schuko will be used for Neutral;"
If the two cables are twisted together with the arrows in opposite direction there's no longer a "privileged" direction ? How can the arrows go towards the direction of the IEC as each cable seems to point to a different direction ? Sorry for the stupid question if I am the only one not getting the point. Thanks in advance. Regards
Sékou K.
Grande musicalité
Connecteurs exceptionnels, dynamique foudroyante, précision et respect des timbres. Ils apportent une grande musicalité au système sans aucune agressivité ou dureté mais sans mollesse non plus. Un maître achat.
Richard I.
Balanced Preamplifier RCA XLR 10x NE5534D 4x NE5532D ALPS Motorized Potentiometer with Remote Control This balanced preamplifier offers an excellent design quality based on circuits recognized for their performance and the quality of their sound reproduction. It integrates no...
Crisp and clear
Transparent xlr sound, 220v no switch,so you will need a step up transformer if your in a 110v region. I'm using a acupwr 100w transformer, works amazingly.
Marc D.
Efficacité assurée!!!
Câble dont la fabrication est sérieuse, il est également très efficace, offre un bel équilibre et est très homogène sur toute l'étendue du spectre. Un superbe rapport qualité/prix.
Service top, merci!
Guillaume V.
tres bonne fiches associées a un cable atohm, le résultat correspond aux attentes, que ce soit pour le son la robustesse ou la finition.
livrées avec une gaine thermo.
wilfrid M.
Premier tests
Très satisfaisant, le son est très détaillé, enveloppant , permet d'écouter du Hi-Res avec tous les avantages. Je suis très agréablement surpris. Pour le prix cela permet d’accéder au son haute définition avec un budget très raisonnable.
Michel J.
Inhabituel mais vraiment excellent
J'ai acheté un Ergo Model 2 sur le conseil d'un ami, sans l'avoir essayé auparavant. A son arrivée, gros choc devant l'aspect massif de la bête : du coup, j'ai mis plus d'un an avant de vraiment lui donner sa chance, lui préférant jusque-là le Sennheiser HD555 qu'il était censé remplacer pour les séances Home cinéma nocturnes. Je l'utilise en continu depuis un mois, à peu près tous les soirs, et le rodage a vraiment fait de l'effet. Après une trentaine d'heures, on découvre un casque à la sonorité TRÈS au-dessus de son prix : bel équilibre, grande richesse de tonalité - avec un fourmillement de détails présentés sans aucune duret, avec un équilibre frappant entre précision, richesse harmonique, et "liquidité". Grande cohérence à travers tout le spectre, aigu filé mais jamais sibilant, médium riche, grave - absent avant rodage - très beau, assez profond mais surtout très bien défini et contrôlé. Et puis, le gros point fort : la scène sonore, très large latéralement et très profonde, avec une précision franchement diabolique dans la spatialisation. Comme il est facile à driver, il est branché sans ampli sur un pre pro Marantz AV 7005 qui gère le Dolby Headphones : la sensation d'espace qu'il est capable de re-créer est hallucinante... Avec une seule limite : il est quand même BIEN massif, et sans être inconfortable, il ne se laisse pas oublier.
A tester pour voir si sa forme vous convient (ça n'est dit nulle part, mais il est ajustable) : si c'est le cas, et que vous cherchez un casque audiophile éclectique, il n'y a rien en-dessous de 1000 Euros qui touche celui-ci.
Michel C.
Nice but one small remark
Used these to change the cheap binding posts on my amplifier. I believe in excluding big chunks of brass/metal (same principal like WBT connectors). These ones are much cheaper but one remark, these are excellent for banana plugs but for spades the contact area is really small.
Jean-Christophe M.
Produit conforme aux attentes
Jean-Christophe M.
Presque Parfait
Déjà commandé pour deux autres projets DIY, la qualité est bonne, l'isolation par rapport au boitier est bonne je recommande.
attention toutefois si vous soudez directement dans l'âme il est parfois difficile que le flux de soudure adhère bien ! préférez peut être mettre une cosse
Jean-Christophe M.
ELECAUDIO BP-206 Gold Plated Binding Post Acrylic Isolated Ø19mm x 47mm Red This high quality Elecaudio BP-206 terminal block uses gold-plated copper alloy as conductor, ensuring excellent conductivity and resistance to oxidation.
Presque Parfait
Jean-Christophe M.
Déjà commandé pour deux autres projets DIY, la qualité est bonne les soudures se font bien, l'isolation par rapport au boitier est bonne je recommande.
Jean-Christophe M.
Bonne qualité mais difficile de s'y retrouver dans tous ces boutons !
La qualité est très bonne rien à dire par contre ce n'est pas adapté à ce que je voulais, il est difficile de se retrouver dans les descriptions
il ne s'agit en aucun cas d'un interrupteur mais d'un simple bouton qui fait contact électrique que lorsqu'on appuis dessus dès qu'il est relâché le contact est coupé. Bref c'est un bouton pas un interrupteur.
Jean-Christophe M.
Inutilisable
Je ne sais pas comment les personnes précédentes ont réussi à utiliser cette tresse.
Trouver des tresses à dessouder qui marchent devient très compliqué, celle-ci comme la grande majorité vendues dans le commerce n'est pas étamée, impossible de déssouder correctement avec ça, l'étain ne rentre pas du tout pas capillarité dedans ! Pour fonctionner une tresse a besoin d'être étamée avec un étain contenu du flux de soudure sinon cela ne peut pas marcher, qaudn aux pompes à déssouder ce n'est pas adapté aux petites soudures.
Ce n'est malheureusement pas un cas isolé depuis la fermeture des magasins d’électronique de ma région j'ai toute les peines du monde à trouver une tresse qui marche ! j'en suis à plus de 10 références différentes achetées sur différents marchands internet aucune ne fonctionne...
Jean-Christophe M.
Gaine isolante insuffisante !
J'ai acheté ce câble pour câbler un amplificateur DIY je voulais du 2,5 mm carré avec cuivre OFC, une gageur à trouver depuis que les magasins en électronique sont tous fermés dans ma région ...
C'est bien de l'OFC argenté, la câble est un peu rigide mais le gros problème c'est la gaine isolante très mince ! à la longue j'ai peur des court circuits si je twiste les câbles entre eux bref pas très adaptés à cela...
Bon câble
Monté sur des prises Furutech, il vient remplacer un câble d'origine sur une barrette Furutech, ça marche mieux. Fort diamètre attention aux prises.
Jubilatoire
Câble monté sur un dac R7 avec des Furutech FI-E48 et une FI-12 en IEC pcq peu de place à l'arrière. Mon dac s'est réveillé, il chante déjà à merveille alors que le câble n'est pas encore rodé. Câble de qualité qui mérite de bonnes prises pour du bon matos, et bien respecter la phase secteur évidemment.
Sékou K.
Le fleuron de la marque
Insurpassable à mon avis sur le grave medium, une dynamique exceptionnelle, une transparence et une précision difficilement concurrencée. A acheter sans hésiter si vous le pouvez.
LAURENT G.
Décevant pour le prix
Câble manquant d'ouverture et de dynamisme pourtant monté avec des prises ETI en Ag pur.
Par contre, ceux qui cherchent à calmer un système montant ne seront pas déçu, son charnu mais manquant d'aération.
Pierre L.
Très bien !
Excellent adaptateur qui remplace avantageusement celui du cordon Vertere Pulse Dfi d'origine, plus de coupures son !
Anthony L.
AUDIOPHONICS HPA-S400NC Power Amplifier Class D Stereo NCore NC400 2x400W 4 Ohm This block constitutes an amplification solution with a formidable reserve of power (up to 400W / channel) while fully respecting the amplified signal. It is ideally suited for...
Branché sur AUDIO-GD R-28 et Martin Logan Ascent
Reçu 24h chrono après paiement. Les fourches des câbles d'enceinte ne passent pas complètement, mieux vaut des bananes, Cet ampli a remplacé un Audiolab à transistors (8000P). Le résultat est bien meilleur, surtout au niveau de l'image stéréo, les plans sonores sont circonscrits entre les enceintes et derrière le plan des haut-parleurs (impression d'une écoute monitoring). L'image est beaucoup mieux centrée, avec une continuité entre les instruments (au lieu de points polarisés). L'impression d'avoir un écran panoramique devant soi, avec une grande profondeur d'image.
Le son est très dynamique, dès les faibles volumes. Pas besoin d'écouter fort.
Les timbres des instruments sont très riches, je redécouvre certains disques (Ragtime de Fabrice Eulry). Et les voix sont incroyables (Sicilien de Roberto Alagna). Même sur des disques de hardrock, je redécouvre des détails et des prises de sons incroyables (Roots de Sepultura).
Très naturel au niveau du rendu, dans le grave comme dans l'aigue.
Je recommande !
Sékou K.
karamoke
Câble absolument exceptionnel! J'en ai trois sur mon gros système : prise murale-filtre secteur, ampli à tube AYON, DAC streamer Atoll ST300. Assemblés avec les meilleurs connecteurs Oyaide M1-F1 et P004-C004, le résultat est époustouflant.
Exceptionnel RQP
Je l utilise depuis deux ans passé. Monté sur des rca eti link full argent. Naturel, fluide et transparent. Details et ouverture sans aucune mesure faxe au prix. Je vais le monter en xlr viborg cu rho. Pour essayer sur mon vincent sv238. Qui fait des merveilles après qq modif.. Par la suite le model sup incluant deux fils rod up occ argent suppl. Ecouté sur un syst THde gamme.. Sais encore pluss a tous les etage. Neotech pas connu la plupart du temps, venant du vrai pro audio a prix etudié. Miam
stoica r.
Natural sound
After tray diferent cables from vdh neotech3200 and furutech i receve a pair from a frend to tray. My speakers go to 2ohms amp is purifi with sparkon. Sound is natrual base is down and texturate afte 500h of burn in.
THIERRY A.
NEOTECH NEET-1008 Ethernet RJ45 CAT6E Cable UP-OCC Silver 1m Neotech offers with its NEET-1008 an excellent RJ45 Ethernet cable, benefiting from an exceptional design. It incorporates four pairs of silver UP-OCC conductors with a...
Bluffant le résultat, tout est mieux et ça s’entend. Vaut toute marque connu dans les gammes haut de gamme.
Meilleure définition, du graves tendu, pas d’agressivité, du bonheur.
A acheter les yeux fermés.
Delacour j.
MONOLITH M1060C Planar Magnetic Closed Back headphones 90dB 18 Ohm 10Hz - 50kHz The Monolith M1060C headphones feature redesigned planar magnetic drivers capable of reproducing a detailed and accurate soundstage in a closed-back design. Low distortion and...
Un son de grande qualité.
Un rapport prix qualité du son imbattable. Que ce soit sur l'AudioGD NFB 29-38 ou sur le Musical Fidelity X-Can 3 la musique prend une dimension tridimensionnelle que peu de casque même plus chers sont capables de faire naitre .
david h.
A optimisé pour un exelent resultat
J ai acheté en suisse se model avec des probleme decrit par se messieur. Renvoyé trois fois. Trois fois le meme probleme. Je me suis fait remboursé et je l est acheté chez audiophonicd qui en avais enfin en stock. Aucun probleme. Ali ifi elite 15v. Cable ali oayde pure cuivre 4,5mm carré et prise viborg rhodium chucko et oayde t004 cu berilium pl platine palladium iec. Genial. Description deja faite au dessus.. Mon bonn n8 avec ali elite 5v et ali cable neoteck cui argent et viboeg rhodium. Rj45 neotech Neu cuivre. Bientot argent.. Top fu top. Certe cela enfle le prix. Mais ont arrive a une qualité proche d un g1 auralic. Voir mieux suivant le dac utilisé. Donc a chouchouté un peut pour en retiré la quintessence.. Miam. ????
