DOUK AUDIO P7 MM Phono Preamplifier with Tubes
The Douk Audio P7 is an MM tube phono preamplifier designed to bring warmth, musicality, and harmonic richness to analog HiFi systems.
Reference : 21949
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 24-11-2026.
DOUK AUDIO P7 MM Tube Phono Preamplifier with ECC83 Tubes
Photo du DOUK AUDIO P7
The Douk Audio P7 is an MM tube phono preamplifier designed to bring warmth, musicality, and harmonic richness to analog HiFi systems. Operating with genuine PSVANE ECC83 tubes powered by a high 180V voltage supply, it combines the sonic qualities typical of tube circuits with a modern design integrating both an MM phono preamplifier and an RCA line preamplifier. Compatible with MM cartridge turntables as well as line-level sources such as CD players, TVs, smartphones, or streamers, the P7 features one MM Phono input and one stereo RCA input.
On the output side, it offers dual connectivity with an unbalanced RCA output and a true balanced XLR output, allowing better noise immunity and improved dynamics when used with compatible amplifiers or active speakers. Depending on the source used, it can deliver up to 2V on RCA and 4V on XLR via the RCA line input, or respectively 0.5V and 1V in phono mode. It also benefits from excellent signal quality with extremely low harmonic distortion of 0.03% in phono mode and a signal-to-noise ratio reaching up to 109dB via the line input.
The P7 also integrates a switchable 20Hz high-pass filter (HPF) in phono mode to eliminate subsonic noise and unwanted vibrations often present during vinyl playback, thus improving clarity, dynamics, and bass stability. It also features bass/treble tone controls with a ±6dB adjustment range, as well as a bypass mode allowing the correction circuits to be completely bypassed in order to obtain a pure and unmodified audio signal. Compliant with the RIAA curve in phono mode, it ensures accurate and faithful vinyl playback. Powered by DC 12V / ≥2A, the P7 benefits from a robust compact aluminum chassis measuring 155 x 124 x 42mm and weighing 707g, offering elegant integration into any analog or hybrid HiFi system.
DOUK AUDIO P7: MM phono preamplifier and RCA line input
The P7 combines two functions within a single device:
  • an MM phono preamplifier compatible with MM cartridge turntables
  • an RCA line preamplifier for standard audio sources
This versatility allows it to be used both in a vinyl setup and in a modern HiFi system with DAC, CD player, or streamer.
DOUK AUDIO P7 : Préamplificateur phono MM et entrée ligne RCA
DOUK AUDIO P7 : Sortie XLR symétrique véritable
DOUK AUDIO P7: True balanced XLR output
In addition to its traditional RCA output, the P7 features a true balanced XLR output.
This connection effectively reduces interference and background noise while improving dynamics and channel separation when used with compatible equipment.
It represents a real advantage for high-end HiFi installations or long audio cable runs.
DOUK AUDIO P7: 20Hz high-pass filter for cleaner vinyl playback
The P7 integrates a switchable high-pass filter in phono mode in order to suppress subsonic frequencies below 20Hz.
This function helps reduce unwanted vibrations, mechanical rumble, and certain resonances that may affect speaker or audio system performance, while improving bass precision and cleanliness.
DOUK AUDIO P7 : Filtre passe-haut 20Hz pour lecture vinyle plus propre
DOUK AUDIO P7 : Réglage de tonalité et mode bypass
DOUK AUDIO P7: Tone control and bypass mode
The preamplifier features bass and treble adjustment over a ±6dB range in order to easily adapt the sound rendering to the speakers, listening room, or personal preferences.
The bypass mode allows the tone circuits to be completely bypassed in order to preserve a direct and uncolored signal for the most faithful listening experience possible.
Overview of the DOUK AUDIO P7
1POWER / RCA-PHONO source selector
2TONE/BYPASS selector
3Bass adjustment
4Treble adjustment
5Operating indicator
6Volume adjustment
720Hz HPF/FLAT selector
8MM Phono input
9RCA input
10RCA output
11XLR output
1212V power input via DC jack
Technical specifications
Product typeTube Phono Preamplifier
TubesPSVANE ECC83
Input1x MM Phono Input
1x RCA Input
Output1x RCA Output
1x Balanced XLR Output
Input sensitivityPhono: 5mV
RCA: 0.775V
Output levelPhono Input: RCA Output: 0.5V / XLR Output: 1V
RCA Input: RCA Output: 2V / XLR Output: 4V
THD+NRCA Input: 0.1%
Phono Input: 0.03%
SNRRCA Input: ≥109dB
Phono Input: ≥82dB
Frequency responseRCA Input: 20Hz-20KHz (±0.8dB)
Phono Input: RIAA compliant
Bass/Treble adjustment range±6dB
High-pass filter cutoff frequency20Hz
Power supply12V DC ≥2A (5.5/2.1mm DC Jack)
Dimensions155x124x42mm
Weight707g
Package contents1x P7 Preamplifier
2x PSVANE ECC83 Tubes
1x 12V DC Power Adapter
InputPhono
ClassTube amp
DOUK AUDIO P7 MM Phono Preamplifier with ECC83 Tubes
