DOUK AUDIO T6PRO Hybrid Class D Tubes Amplifier Yellow
The Douk Audio T6PRO is a hybrid HiFi amplifier combining tube amplification and modern Class D technology to deliver a sound reproduction that is both warm, dynamic, and powerful. It combines two JAN5725 tubes operating under a high voltage of 100V for true tube amplification with a high-end TPA3255 digital amplification chip capable of delivering up to 2x250W under 4Ω (THD+N=1%), allowing it to efficiently drive a wide variety of 4Ω to 8Ω speakers. Compact yet particularly powerful, the T6PRO is suitable for both desktop HiFi installations and home theater or living room systems.
4.0 / 5
By buying this product you get 20 loyalty points
Reference : 21965
209,00 €tax incl.
174,17 € tax excl.
Shipping date: 24-11-2026.
Douk Audio T6PRO TPA3255 Class D Hybrid Amplifier JAN5725 Tube Bluetooth 5.1 aptX-HD LDAC 2x 250W 4 Ohms Yellow
Photo of the DOUK AUDIO T6PRO
The T6PRO features versatile connectivity including a Bluetooth 5.1 input based on a QCC5125 chip compatible with aptX, aptX-HD, and LDAC, supporting audio streams up to 24bit / 96kHz, as well as two stereo RCA inputs and one 3.5 mm AUX jack input allowing multiple audio sources to be connected simultaneously. A 3.5mm pre-out output is also integrated to connect an additional amplifier, active subwoofer, or active speakers in order to create a 2.1 or multichannel system.
The device also benefits from carefully selected audiophile-grade components including WIMA, ELNA, and Rubycon capacitors, professional audio inductors, and fully sealed precision potentiometers to ensure excellent sound transparency and extremely low distortion of only 0.01%, accompanied by a signal-to-noise ratio greater than 102dB. It offers complete tone controls with treble adjustment at ±8dB / 10kHz, bass adjustment at ±6dB / 200Hz, as well as a Super Bass adjustment extending down to 20Hz with an amplitude of ±10dB to reinforce low frequencies and achieve particularly deep and impactful bass.
The T6PRO also stands out thanks to its imposing dual backlit analog VU meters integrated into a large single front panel offering real-time dynamic display of the audio level. Its CNC-machined aluminum chassis ensures excellent robustness as well as efficient heat dissipation, while its oversized speaker terminals guarantee secure transmission of high power levels. Powered by 24V to 48V DC, it measures 140 x 165 x 69mm for a weight of 1.4kg, offering an elegant, powerful, and particularly versatile HiFi solution.
Overview of the Douk Audio T6PRO
Overview of the DOUK AUDIO T6PRO
1Tube sockets
2Volume control
3Power on/Source selection
4Treble adjustment
5Bass adjustment
6Super Bass adjustment
7Bluetooth antenna
82x RCA inputs
93.5mm AUX jack input
103.5mm AUX jack output
11Speaker terminal outputs
1224-48V DC power input via DC jack
Technical specifications
Product typeHybrid amplifier
Amplification chipNE5532
TubesJAN5725
Bluetooth chipQCC5125
Inputs2x RCA
1x 3.5mm AUX jack
Bluetooth
OutputsSpeaker terminals
1x 3.5mm AUX jack output
Supported Bluetooth codecsaptX, aptX-HD, LDAC
Max. output power2x 260W @ 4 ohms
Recommended speaker impedance4-8Ω
Tone controlsTreble: ±8dB / 10KHz
Bass: ±6dB / 200Hz
Super bass: ±10dB / 20Hz
Frequency response20Hz-20KHz (±1dB)
Input sensitivity0.775V/0dBFS
Max. output level3V
THD0.01%
SNR≥ 102dB
Power supply24-48V DC
Dimensions140x165x69mm
Weight1.4kg
ColorYellow
Package contents1x Douk Audio T6PRO
2x JAN5725 tubes
1x 48V 5A power adapter
1x Bluetooth antenna
InputJack 3.5mm
OutputJack 3.5mm
OutputSpeaker terminal
ColorYellow
Channel2 (Stereo)
Amplifier chipTube
Amplifier chipTPA3255
Power (W)250.0
Peu mieux faire
Attendre un rodage avant jugement . On a plus la sensation t 'entendre un ampli à transistor , on ne retrouve pas la magie du tube . Alimente deux enceintes colonnes trois voies . Vu la puissance annoncée je m' attendais à mieux , il faut pousser le niveau de grave a plus de 3/4 du réglage et le super bass a + de 1/4 et celà reste passable. le son ne décolle pas des enceintes et la restitution reste trop sage et un peu en retenue . Le son n'est pas mauvais ( transparence et définition ) mais sa manque d ' enthousiasme . Ecouté uniquement en bluetooth ldac ( peut être que la section bluetooth est un peu faiblarde? ) il me semble que cet appareil est plus approrié pour les petites enceintes dans une salle d' écoute pas trop vaste . Dans cette fourchette de prix on trouve plus punchy et plus vivant musicalement .
This review has been posted for DOUK AUDIO T6PRO Hybrid Class D Amplifier TPA3255 JAN5725 Tube Bluetooth 5.1 aptX HD LDAC 2x 250W 4 Ohm Yellow
The Douk Audio T6PRO is a hybrid HiFi amplifier combining tube amplification and modern Class D technology to deliver a sound reproduction that is...
