Jean-Louis R.
ne chauffe plus assez
Wojciech S.
Great sound for the price
These tubes are not as prone to failure as the Chinese ones, they are made solidly and will serve for many years. They give a...
CARLIER B.
Idéla pour synthétiseur yamaha MM6
Je recherchais un encodeur rotatif pour mon synthétiseur yamaha MM6. J'ai contacté le service client Audiophonics qui...
Customers reviews - There are 19311 reviews.
andoni g.
LINDY CROMO LINE Gold Plated Male USB-A / Male USB-B 2.0 Cable 2m The Cromo series is the most powerful USB cables manufactured by Lindy. This one relies on a well thought out design and oriented towards a technical reality, to meet a need for...
cheap cable
i buy it for more longer cable, plastic stetic but it works well
andoni g.
XDUOO XA-10 Headphone Amplifier Balanced DAC 2x AK4493 Bluetooth 5.0 32bit 768kHz DSD512 The xDuoo XA-10 is a balanced headphone and DAC desktop combo amplifier. With a beautiful design, it delivers excellent audio performance for rich, accurate and immersive...
Sounds good but...
Sounds Good but need some improvements, first buy better and longer usb cable to put the pc or phone far of dac for avoid interferences, the dac need a bit of isolation, separate the electric and audio cable if you use the rca output.
Rca output sound incredible for stereo sistems.
Filters except 4 and 2 don't work, are inaudible.
rca in dont work
Paulo M.
TOPPING BC3 audio reveicer Bluetooth 5.0 aptX HD LDAC DAC ES9018Q2C 24Bit/96kHz Black Battery-powered Bluetooth 5.0 Wireless High-Res receiver with integrated ES9018Q2C DAC. Offers line out, headphone out and even mini-toslink optical out. Compatible with...
Topping BC3
Very good bluetooth receiver. Little but sturdy. I don't see a huge difference for wi-fi.
Paulo M.
Topping E30
Excellent DAC, nice and sturdy. Good inputs and outputs. The sound is clear, clean and consistant. I'm very satisfied.
Carmela F.
DD TC44B Headphone Amplifier DAC Adapter Balanced USB-C Hi-Res 2x CS43131 The TC44 is an extremely compact balanced portable headphone and DAC amplifier combo, featuring a USB-C male input and a dual balanced 2.5mm jack and 4.4mm jack output.
Excellent quality
It feels good very well, especially if you use with IEM headphones.
Exceptional seller, super quick shipping.
Paul P.
J'avais déjà acheté une autre version il y a quelques années, il ne m'a pas déçu.
C'est la même chose avec celui-ci : un excellent rapport qualité/prix et un format très pratique.
Bernard B.
Des bons matériaux
J'ai été surpris de la qualité matériaux des câbles, notamment de la partie tressée. Ils font un certain poids ce qui est rassurant. Les fiches banane sont très pratiques à connecter. La section des câbles est assez épaisse, je ne m'attendais pas forcément à cela. A l'écoute, branchés sur mes Triangle Lunn, pas de souci.
David H.
Ca sert et ça serre bien!
Bonne fiches bananes, se montent comme un jeu de Meccano!
Sympa pour le prix!... et merci à Audiophonics
David H.
Ca connecte bien!!!
Très bon câble de qualité, en remplacement d'un autre de piètre qualité, sur un ampli des années 70 vers un DAC, qui connectait mal et amenait bruit de fond et grésillement. Celui-ci est est précis dans la transmission du signal et ses fiches, une fois en place ne gigotent pas. Rapport qualité prix correct. Je recommande... et merci à Audiophonics
David H.
Quoiqu'il en soit, une bonne entrée dans le monde du FDA!
Très déroutant comme ampli, la restitution sonore et la puissance sont parfait pour mes enceintes (monitoring passive DIY avec haut-parleur coaxial , sensibilité 89 db, puissance admissible 100 W), une modification de la courbe cible proposé par un certain Dominique P.(ceux qui savent le reconnaîtrons) et vous avez une qualité musicale indéniable (cela reste mon avis) pour un coût modeste. En ceux qui concerne les bruits de fond après plusieurs test, rien à signaler,aucun bruit. Je précise que je suis sur Linux (Ubuntu Studio),l' USB Xmos est reconnu directement sans manipulation, avec le bon taux échantillonnage en sortie. Pour 115 Euros, Le bonheur des petites bourses. Pourvu que ça dure.... et merci à Audiophonics.
PHILIPPE D.
Condensateur mundorf oil
Produit conforme à ma commande.
Pas encore monté.
Je suis surpris de la rapidité de la prise en charge de ma commande et de l'expédition, bravo pour ce professionnalisme.
Je suis super satisfait de tous les articles achetés chez Audiophonics
Philippe. D
PHILIPPE D.
Fiche banane hicon
Produit de très belle qualité, corps isolé, très bon contact
à recommander
PHILIPPE D.
Fiches de très belle qualité, de plus isolées.
Belle fabrication
Olivier V.
Efficace et discret
C'est mon deuxième ipower, on lève un voile et on diminue le grain... Première commande chez Audiophonics et entièrement satisfait: rapidité du traitement de la commande, suivi et livraison 48h. Merci
Yohann B.
envoi rapide, super ampli. Entrée usb testée sous linux en 24 bits 96 Khz nickel avec audacious. Compact, bien fini. Du très bon pour le tarif. Je n'ai pas pu tester la puissance, enceintes en rodage mais je n'ai pas de doute la dessus. Je recommande.
Gilles J.
VIABLUE UFO XL Vibration Absorbers Black Ø65mm (Set x4) Viablue UFO XL absorbers can dampen harmful vibrations by placing themselves under your speakers or HiFi devices. Due to their optimal pressure on the lower surfaces of the...
Une belle réussite !
Beau produit, fabrication sérieuse, livraison rapide, rien à dire si ce n'est que ces absorbeurs ne passent pas inaperçus sur mes préamplis à tubes, esthétiquement et fonctionnellement.
A recommander à un prix très attractif.
jean paul g.
JLG
produit excellent je l'ai associé à mon ampli tubes pour commander mes entrées USB, optique, etc, le tout enfermé dans un boitier métallique non relié aux masses de l'électronique .pas de bruit de fond .....super
Luis V.
LOXJIE D50 DAC AK4499 USB XMOS Bluetooth 5.0 MQA 32bit 768kHz DSD512 Loxjie presents the D50, a resolutely modern DAC based on an excellent AKM AK4499 chip and XMOS USB interface. It supports PCM streams up to 32-bit / 768kHz, DSD512 and MQA...
SUPREME PRODUCT
Extreme well-built aluminium box, the sound quality is the best i ever heard on a DAC, we can even use the both outputs simultaneously, XLR and RCA to connect several devices.
I can even say this DAC sounds as good as DACS 4 times more expensive.
Dusan H.
Fast delivery, good packaging and product without problems, as in all previous deliveries!
christophe t.
le cable est de qualité,les fiches ne bougent pas quand on le connecte,trés bon produit et envoie rapide
Lutz B.
Works as designed, but...
Plus and play. Very good Addition for my Multimedia raspberry system (shutdown is quite fast, but boot process takes minutes)
I am using RaspBerry Pi 3B with 5inch touch LCD and HifiBerry DAC plus.
The issue: Since using the power control unit the operating system (volumio) alerts 'low power'. Disconnecting the power control unit changes this.
Obviously, this power control unit does not deliver enough power/unstable 5V.
Any idea in this?
Cheers
.:.lutz
Arnaud D.
Vraiment top
Pour ce prix, le rendu est de qualité. Il consomme très peu, très facile à utiliser malgré l'interface minimaliste. La qualité est au rendez-vous. Un bon système stéréo pour une pièce de 25m^2 en tout cas. Assez bonne restitution des basses et une bonne dynamique, même à faible niveau. Design soigné, livraison sans soucis, bref, tout est ok. Très surpris d'avoir un ampli de cette qualité à ce prix.
Fabrice T.
Pour remplacer des Norstone classique 2.5mm2, bi-amplifié pour l'avant Triangle Antal 202 et bi-cablé pour l'arrière Triangle Zerius 202 , il n'y a pas photo, de la basse ample et propre, mieux défini qui tient sur volume élevé, medium nickel autant paroles musique que voies en HC et pour les aigu Idem, mieux défini moins montant plus de détails , j'en avait besoin pour mes triangles, du coup on à tendance à écouter plus fort tellement c'est bon.
Carrément fan de ces câbles au tarif défiant toute concurrence.
Fabrice T.
R.A.S
Conforme à la description.
Fabrice T.
Super pratique
Utilisé pour déclencher deux ampli de puissance quand j'allume mon ampli Home Cinéma, c'est simplement parfait.
Fabrice T.
Utilisation parfaite pour doubler la sortie trigger d'un ampli HC vers deux amplificateurs de puissance avec prise IEC déclencheur .
Mohamed Nabil M.
Yarbo SP 1100 PW - Amazing cable
I run 2 accuphase amplifiers on B&W 8th series speakers. and i bought expensive sets of cables to use for my system. out of curiosity I ordered 2 meters of this cable combined with Neotech terminals to test how good they stack compared to my AQ Hurricanes, and once I get the cable in my system i felt the difference. so much musicality and reveal. tonal balance and layering is excellent, sound stage as wide as it could be.... this cable beats the best cable i had in my system. i retuned the cables that i had still unopened and i purchased enough Yarbo to replace all the power cables in my system... cannot wait to see the final results.. highly recommended for high end gear
Paulo L.
ASTELL&KERN A&NORMA SR25 Digital Audio Player DAP HiFi 2x CS43198 Bluetooth WiFi 32bit 384kHz DSD256 MQA The SR25 is the second model in Astell&Kern's A&norma range, a high-end DAP that fully embraces the brand's philosophy and technology, now available to the general public. The...
A mixed experience
5 stars for Audiophonics.
3 stars for SR25.
Very well built, small form factor and aesteticaly pleasant. In the sound quality department: honestly, no better than my DC04, also bought here, docked to my Galaxy S10+ 12GB/1TB version! And the processing power it's not enough to handle Tidal offline properly!
Pascal g.
bon produit à petits prix
pour ma part je peux vous dire que ce produits est conforme à mes attentes, et surtout que le vendeur est très sérieux serviable et très réactif!
Arnaud F.
Très très bon dac Français !
Je suis très ravi de mon dac.
Le fait de monter soi même son dac est ludique et très facile à mettre en œuvre.
Toutes les pièces sont de très bonnes qualités et tout se montent facilement.
J'ai associé à l'evo-sabre, son alimentation audiophonics dédiée pour mieux l'alimenter.
Le dac est branché sur un préampli Atoll Pr200se, un ampli am200 signature Atoll avec des câbles rca Canare.
Mes sources sonores viennent de Qobuz.
L'écoute est très belle, la scène sonore est ample sans agressivité avec des graves présents mais non envahissants, des médiums et aigus bien définis sans être criards.
Je le pilote grâce à bubbleupnp (très bonne application avec un développeur très réactif) depuis mes appareils Android.
Pour le faire fonctionner, mon choix s'est arrêté sur Volumio qui me donne sur mon installation, le meilleur résultat: scène large, écoute de chaque instrument détaillé, grave présent et bien défini, médium et aigu sont agressivité et donc pas de fatigue à l'écoute.
L'écoute est également détaillés avec beaucoup d'informations et de précisons.
De plus, avec volumio s'est très facile à installer et l'utilisation est quasi immédiate après l'installation.
J'ai fait d'autres essais pour piloter le EVO-SABRE.
Avec MoOde: je n'ai pas du tout aimé, la scène était trop centrée ce qui faisait que je perdais la largeur de la scène, tout semblait confus, beaucoup moins défini, un gros bof !
PiCorePlayer: moins facile à installer que Volumio ou MoOde mais avec les tutos que l'on trouve sur leur site, cela se fait facilement quand même.
L'écoute est agréable, les graves sont encore plus précis que Volumio mais la scène est beaucoup moins large et n'utilise pas tout l'espace possible entre les enceintes.
L'écoute est également moins détaillés moins analytique.
Par contre point de vue utilisation depuis un appareil, c'est beaucoup moins pratique qu'avec Volumio ou MoOde grâce à bubbleupnp.
Si je n'ecoutais que du rock, funck, jazz, je crois que mon choix pourrait resté sur PiCorePlayer mais comme j'écoute énormément de musique musique classique en plus de celle citées avant, ma préférence va pour Volumio pour sa largeur de scène sonore et à la présence de beaucoup plus de détails.
Par contre, j'ai un petit reproche à l'utilisation du EVO-SABRE avec bubbleupnp, c'est la durée de la mise en place d'une playlist à cause de la version du openhome dans l'image Volumio proposée par audiophonics.
Mais grâce à la très grande écoute de ses clients et à la très grande réactivité de leurs services, ce petit reproche devrait être corrigé dans une future mise à jour de la version Volumio.
Une dernière remarque, c'est l'immense qualité de service chez Audiophonics, je n'ai jamais rencontré une entreprise sur le net qui soit autant à l'écoute de ses clients et qui cherche à aider, résoudre les problèmes avec autant de gentillesse, d'écoute et de professionnalisme.
Vive le fabriqué en France et bravo à Audiophonics !
Très pratique
Les liaisons fibre optique sont très pratiques : pas de parasites, pas de perte de qualité, pas de soudures, et fil très fin.
Le plus gros, c'est le connecteur, mais avec cette solution de connecteur à clipser, on peut faire des câbles à la longueur voulue, et on peut les tirer dans une gaines même déjà par mal encombrée (acheter un câble optique audio, couper l'une des extrémités, puis refaire la connexion une fois la fibre passée en gaine).
Vytautas Š.
VYTAUTAS
prodotto di qualità
Joseph W.
Conforme à mes attentes.
Vytautas Š.
VYTAUTAS
prodotto di qualità
Vytautas Š.
Joël C.
MUNDORF MLYTIC AG Capacitor 63V 8200μF These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of...
Condensateur 63V 8200µF
Très bon produit de qualité ! Servis rapide ! Le prix un peu élevé...
Arnaud F.
Très bonne prise
Très bonne prise secteur.
Très facile à mettre en œuvre.
Je ne sais pas si cela apporte une meilleure qualité audio mais de sûr les contacts sont très bons.
Arnaud F.
Très bon câble secteur
J'ai acheté ce câble sur recommandation de audiophonics pour alimenter mon dac EVO-SABRE.
Le câble est facile à mettre en œuvre.
Comme c'est mon 1er vrai câble secteur, je ne sais pas si il est meilleur qu'un autre mais en tout cas il a apporté une certaines sérénité dans les écoutes comme avec mon alimentation séparée audiophonics.
L'écoute de la scène sonore est plus ample, mieux définie.
Arnaud F.
Très bonne prise
Très bonne prise, facile à mettre en œuvre.
Après je ne sais pas si elle apporte une meilleure écoute mais les contacts sont de très bonnes qualités.
Arnaud F.
J'ai acheté ce câble sur recommandation de audiophonics pour alimenter mon ampli et préampli ainsi que mes barrettes secteurs (j'en ai même profité pour refaire le câblage intérieur en étoile en enlevant les barrettes d'origine).
Le câble est facile à mettre en œuvre et malgré sa section est assez souple.
Andrea G.
Eccellente
Prodotto ottimo, tempi di consegna perfetti.
Jérôme S.
POWER DYNAMICS PDX015 Phono USB Preamplifier - Audacity The PDX015 preamp by Power Dynamics allows you to connect a vinyl player to a computer or a laptop. A recording software is provided to convert your disk collection to...
Copie amélioré
Appareil compact et simple d'utilisation avec le logiciel Audacity.
Possibilité de copier tout type d'appareils y compris des CDs pratique quand on ne possède plus d'ordinateur de bureau...
Qualité du son amélioré par le système riaa permettant de redécouvrir ses vieux vinyles !
Jean Jacques S.
NICHICON KG GOLD TUNE HiFi Audio Capacitor 50V 10000µF The Nichicon capacitors of the KG range have been specially designed for audio. Thus, they allow to achieve a high fidelity sound reproduction and can be integrated in different...
Qualité
Condensateur audio qui remplit bien son rôle et de abrication sérieuse.
Gustav W.
Best dac for me!
Great smooth sound! Big and detailed. Can only recommend! Solid build and really everything one could need. Maybe there are better dacs out there, marginally better maybe but not price/performance ist simply stunning
Gustav W.
Great cable for mobile devices
Great cable! Solid build. Can only recommend. As usual, Audiophonics is a really good shop!
Gustav W.
FIIO BTR5 2021 Balanced Headphone Amplifier DAC Bluetooth 5.0 Receiver 2x ES9219P CSR8675 XMOS 32bit 384kHz DSD256 MQA The FiiO BTR5 2021 is a compact, portable headphone amplifier, offering excellent design quality and versatility for enhanced listening at home or on the go.
Great dac!
Great produkt! Great sound, well made. Using it in my car and improves sound vastly. Highly recommended! Reconnects right away when I unlock the car
Benoit N.
ELECAUDIO BP-207 Binding Posts Carbon / Gold Plated 24K Ø5.5mm The BP-207 from Elecaudio is a resolutely HiFi speaker terminal (sold in pairs), whose contacts are fully 24k gold plated. It accepts large diameter cables (up to Ø5.5mm)...
Très belle qualité de fabrication, grande robustesse. Ils sont assez imposants, j'aime bien leur look.
Niveau qualité sonore: RAS, je ne m'avancerai pas à dire qu'il y a une quelconque différence sonore avec d'autres car je n'ai pas testé et de toute façon il faudrait avoir un système d'une qualité incroyable pour entendre une différence.
Vivement conseillés, car ils font propres, pro et pas cheap.
silence dynamique naturel des voix etc.
très beau câbles finitions superbe. du pro a prix contenu. utilisé entre prise secteur et conditionneur secteur keces bd1200. toutes les qualités trouvées sur le petit frère a 50euro. en mieux partout avec un aigus superbe qui file haut sans dureté et une belle fluidité.. les graves ont prix en profondeurs dynamique et définition incroyable. le medium et aussi fluide et musical et l espace stéréo et plus précis large et profond.. excellent câbles donc a recommander les yeux fermés.il y a se pendent un probleme .le câble que j ai reçu na aucune indication de la marque du model et surtout du sens de fonctionnement.. j ai du le faire a l oreilles et démonter remonter les prises a deux reprise pour trouver la bonne direction ;-).. svp audiophonics. vérifier avant l envois que sais le bon câble avec au moins les indications sur le tronçon du bon sens pour un montage facile ..merci pour le service impeccable quand les articles sont en stock ;-)
ps; y a t il une astuce pour trouver le bon sens de fonctionnement sans avoir a démonter remonter pour l entendre.. si qq un a une idée ;-)
Alfredo B.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 3.9µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Muy buena relación calidad / precio.
Recibido muy rápido, excelente comportamiento y mejora de prestaciones en crossover.
Alfredo B.
