SMSL PL150 CD Player CS43198 Silver
The SMSL PL150 is a CD player based on a CS43198 DAC chip, a proprietary mechanism and a PLL (Phase Locked Loop) circuit for high-quality playback and conversion of your favorite CDs.
Reference : 20924
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 17-11-2026.
SMSL PL150 Lecteur CD CS43198 Silver
Photo of SMSL PL150
The SMSL PL150 is a CD player based on a CS43198 DAC chip, a proprietary mechanism and a PLL (Phase Locked Loop) circuit for high-quality playback and conversion of your favorite CDs. Versatile, it reads both standard CDs (Ø12cm) and mini CDs (Ø8cm), and supports numerous formats: CD, CD-R, CD-RW and MP3 CD. Connections include an analog RCA output, and two bit-perfect SPDIF coaxial and Toslink optical outputs. There are also two headphone outputs on the SMSL PL150's front panel, as well as an attractive color display and various control buttons. The balanced 4.4mm jack and 3.5mm jack headphone outputs deliver up to 2x60mW @ 32 ohm, and are accompanied by a 75-step volume control for a pleasant listening experience. The user experience is further enhanced by IR remote control. All in all, the PL150 is a versatile and, above all, high-performance device that will brighten up your music library.
SMSL PL150: A CS43198 DAC chip
The PL150's CS43198 DAC chip is a low-power audio converter offering superior audio performance. It ensures clear, optimal reproduction on all the device's outputs.
Photo of CS43198 DAC chip
SMSL PL150: Bit-perfect outputs
On the rear panel of the SMSL PL150, SPDIF coaxial and Toslink optical outputs bypass any analog distortion for connection to a DAC or integrated amplifier. These outputs bring out the most authentic details and dynamics emanating from CD media.
PL150 Bit-perfect outputs
SMSL PL150 headphone outputs
SMSL PL150: Balanced 4.4mm jack and single-ended 3.5mm jack headphone outputs
Capable of driving two headphones simultaneously, the 4.4mm jack and 3.5mm jack outputs deliver up to 2x 60mW of power at 32 ohms. They also feature a 75-step volume control for precise sound level adjustment.
SMSL PL150: Mechanical stabilization
The SMSL PL150 features highly efficient shock absorbers to withstand vibration and harsh environments.
The mechanical stabilization of the SMSL PL150
SMSL PL150 overview
SMSL PL150 overview
1Control buttons
2Screen
3Balanced 4.4mm jack headphone output
4Single-ended 3.5mm jack headphone output
5RCA output
6Toslink optical output
7Coaxial output
8Alimentation 5V 2A via jack DC
Technical charcacteristics
Product typeCD player
DAC chipCS43198
InputCD
Outputs1x RCA output
1x Toslink optical output
1x Coaxial SPDIF output
Supported CD formatsCD / CD-R / CR-RW / CD MP3
Supported CD sizesStandard Ø12cm
Mini Ø8cm
Headphone output power60mW sous 32 ohm
THD+N0.001%
SNR110dB
Power5V 2A
Energy consumption4W
Standby : 0.1W
Dimensions205 x 42.8 x 144.7mm
Weight1.145kg
Package1x SMSL CD player
Extremely capable as a CD transport.
I chose this player to use it as a transport feeding my DAC. I like the fact that it is a very well-proven device, as its Philips mechanism has been widely tested and is very stable. In addition, the remote control is more complete than that of the higher model.
The device includes a built-in DAC for those who wish to connect it directly to their amplifier via RCA. Its sound is acceptable, although perhaps a bit too sibilant in the high frequencies, but for the price you can’t really ask for more. I recommend buying it.
This review has been posted for SMSL PL150 CD Player CS43198 Silver
The SMSL PL150 is a CD player based on a CS43198 DAC chip, a proprietary mechanism and a PLL (Phase Locked Loop) circuit for high-quality...
