Gianfranco P.
Wonderful
Peter Š.
Peter Š.
Tomislav N.
Customers reviews - There are 19569 reviews.
Antonio C.
Amazing interconnect
My review so far:
About the product itself AZ910:
✓ More distinctive layering of the music
✓ More ease, air, and energy
✓ Better clarity and transparency
✓ Slightly more neutral
✓ Much better separation
✓ nice bass (very well defined)
✓ More laid back
✓ Beautiful top-end sound
The sound is dynamic, musical, rhythmic, and unparalleled harmonic resolution providing music lovers with a new dimension in music enjoyment.
My setup is:
• Integrated amplifier - Rotel RA1592 (200w in 8Ω) +
• Technics SL-G700 Network/Super Audio CD player,
⁃ connected with Oehlbach BALANCED NF AUDIO XLR CABLE XXL SERIES (replaced with Oyaide).
⁃ Speakers Cabasse Altura Bahia(94db efficiency, frequency response 50-25000Hz), Impedance 8Ω with minimum 3,2Ω)- (very difficult to drive -can be very fast too bright)-
⁃ I’ve try with Audioquest cables impossible to hear with less good records), for the speakers and interconnects but they are not a good match.
⁃ currently connected by The Chord Company - Epic Speaker Cable.
There is fundamental differences which power cables used. Currently tried with the supplied standard cables (difference less significant that in my conclusion); kindly note that Technics a standard cable (with earth) with 3mm conductors (notorious), so matching power cable here is tricky. I thought to use the OYAIDE TUNAMI GPX-R V2 Power cable (does somebody have a good input how they mix with AZ910?). For the Rotel is even more tricky because standard power with 1mm conductors!. Amazing for such an amplifier to have such a cable!
The idea here is to go Viablue X-60 Silver AC power cable (very nice comments and reviews on this one, and mainly very neutral)
Giuseppe C.
Excellent amplificateur abordable
Je l'ai acheté pour l'utiliser avec deux casques de grande qualité, comme le Hifiman Sundara et le Sennheiser HD700.
Avec les deux casques, cet amplificateur offre un son chaleureux et détaillé, avec une grande dynamique et spatialité. La possibilité de l'utiliser avec l'entrée symétrique est très utile. Avec l'entrée équilibrée, le son s'améliore et augmente la puissance et l'espace.
Honnêtement, je ne comprends pas qui se plaint de la qualité de cet objet: il est très difficile de s'améliorer dans la fourchette de prix allant jusqu'à 300-400 euros.
Jean-François A.
Cable "usb" pour alimentation séparée
Cable très pratique afin de pouvoir injecter un 5 volts séparé de celui de l'ordinateur, bien fabriqué par Audiophonics.Vraiment pratique pour un DAC externe. Très Recommandé.
Vraiment efficace !
Etant apprenti soudeur, j'ai progressé au fur et à mesure. Je me suis trompé de référence de soudure et j'arrivait pas à souder jusqu'à ce que je comprenne que la température était de 290° ; j'ai investi dans un fer WELLER électronique. Et là c'est du beurre !
J'ai soudé des XLR Neutrik avec un câble SommerCable ALBEDO et le résulté est parfait. Tout à fait conforme à ce que le constructeur annonce, ça file super haut et c'est très doux. Ouverture détails ; grave puissant et tendu. Soudure parfaite une porte grande ouverte sur tout les détails sonores.
LAURENT M.
GUSTARD A18
Evolution significative par rapport à mon Topping D50S avec alimentation 5volts Ifi.
Plus de matière , palette sonore plus riche , grave profond , pas d'agressivité, belle image.
Etonnant de musicalité notamment en entrée Bluetooth LDAC en streamant à partir d'un téléphone un simple abonnement DEEZER Hifi.
Je note une supériorité musicale (selon mes critères) des derniers DAC's AK4499 VS Sabre ES9038.
Je recommande chaudement ce DAC qui par ailleurs inspire confiance concernant la qualité de fabrication.
Daniel P.
Qualité-prix excellent
J'enrage, j'ai acheté du câble d'alimentation plaqué argent (qui n'est pas vendu ici) 5 fois plus cher, il n'y a rien qui va. Par dépit j'ai essayé d'autres câbles que j'avais en stock, pareil, et j'avais un bout de ce câble, je l'ai monté entre mon ampli Yamaha A-S2100 et la platine CD-S1000 et miracle, tout est meilleur, le placement des instruments, les graves propres et bien présents, les voix, tout est mieux pour un prix presque dérisoire, du coup je vais le monter sur tous mes lecteurs et l'essayer sur les deux amplis, hifi et HC.
franck J.
Réelle surprise et redecouverte de mes albums
Acheté sans l'avoir écouté juste sur des avis. Frustré de ne pas pouvoir monter le volume comme je souhaiterai sur les enceintes, j'ai voulu m'acheter un meilleur casque que ceux que je possède (focal spirit one C, listen, sennheiser hd570 etc). Je souhaitais un casque ouvert et confortable et je n'ai pas été déçu. La technologie utilisée que je ne connaissais pas crée un son délicat, précis et neutre même à bas volume. Je me suis surpris à me retourner pour voir si quelqu'un était derrière moi, c'était le son du siège du pianiste. Semble reproduire tous les petits son que je n'avais jamais entendu auparavant. Je n'en suis qu'à quelques heures d'utilisation et le son semble s'améliorer. J'utilise les fiio x1 et m7, le x1 est légèrement plus puissant mais les 2 restent insuffisant pour driver le casque. Je me suis équipé de l'amplificateur nomade topping nx1s pour avoir une écoute confortable sur le classique qui a souvent un niveau d'enregistrement plus faible.
J'utilise le casque aussi avec l'ampli smsl Thx aaa sp200 en sortie du dac smsl Su9 : gain de détail et de qualité de son !
Je ne pensais pas prendre autant de plaisir à réécouter ma discothèque.
AUDIO-GD R-7HE 2021 MK2 Balanced DAC R2R FPGA I2S HDMI Amanero 32bit 384kHz DSD Accusilicon Audio-GD is developing its HE range, composed of its most top-of-the-range products. They benefit from the longest design and testing period since the brand's inception. This...
Quel rendu naturel
Ce DAC est étonnant de naturel.
On a l'impression d'être au concert. Précision des timbres, dynamique, scène sonore large et profonde, c'est formidable.
Je l'utilise en liaison USB avec Daphile.
Nécessite un cable particulièrement transparent pour en tirer le maximum.
On a plus l'impression d'entendre une source numérique.
Vincent D.
Très bon dac compact et à prix contenu
Utilisé pour contourner la sortie jack défaillante de mon LG G7 qui est doté d'un excellent dac (ES 9018 quad dac avec des mesures excellentes sur audio science review), je ne suis pas déçu! Distortion inaudible, clarté, rondeur, le son tient tout à fait la comparaison avec le dac natif du LG, avec un peu plus de pêche et de fermeté.
Il pousse très bien sur des écouteurs ou des casques faciles (AKG240, ...) ou en sortie ligne, par contre à ne pas utiliser avec un casque plus lourd à driver (pas terrible avec mon Beyerdynamic DT770, qui nécessite pour bien marcher un ampli casque).
Serge V.
SOVTEK 6H30PI / 6H30 / 6N30 / 6N30P Twin Triode Tube (Unit) This Russian-made, audiophile-quality 6H30PI power tube from Sovtek (sometimes also called 6H30, 6N30 or 6N30P), often used in pre-amplifiers, gives...
musicale et silencieuse: très satisfait
Pour remplacer une paire qui provoquait de la microphonie sur un ampli hi-fi à tubes, cette Sovtek est très musicale et silencieuse. Je suis donc très satisfait, d'autant que la livraison chez Audiophonics, que je pratique depuis 2015 sans jamais de soucis même en SAV, est toujours très rapide.
Je recommande et la 6H30PI Sovtek et Audiophonics.
Jean-Pierre B.
POWERGRIP YG-2 Power Distributor Conditioner Filtered 6 schuko surcharge overload protection For its second version, the PowerGrip YG-2 retains the same performance as its predecessor but adopts a more compact and more economical format. Like its big brother the YG1-V2,...
Une multiprise hors de prix ?
Sur un système « résolvant », (JMR Offrandes - 2 Pass Aleph 5 - Primare Pré 35 -Pré Pré Clearaudio Balance - Cellule Clearaudio Stadivardi) et en remplacement d’un Dynavox x6000 je n’entends aucune différence.
En revanche l’appareil est très joli, bien fabriqué, assez ergonomique avec un interrupteur en face avant.
Attention si vous comptez utiliser un câble secteur plus en rapport avec les prétentions et le prix du Powergrip, il vous faut une terminaison en IEC C19. Par chance J’avais un Shunyata de bonne qualité à ce format.
Mon installation étant entièrement symétrique j’envisage l’achat d’un deuxième Powergrip en remplacement d’un deuxième Dynavox. Je pense aussi monter deux câbles secteurs basés Viablue.
L’addition est très élevée. C’est mon seul reproche sur ce produit dont la valeur que je perçois est inférieure à 500 euros.
Alors une multiprise hors de prix : oui
simon c.
FX-AUDIO D802E FDA Amplifier STA326 Streamer WiFi DLNA Bluetooth 5.0 Multiroom 2x80W / 4 Ohm Silver The E version of FDA D802 amplifiers from FX Audio now includes WiFI (DLNA) connections to complement Bluetooth connectivity.
Livraison rapide , produit facile à configurer. Écran minuscule et télécommande surprenante dans l’organisation des fonctions ...mais le son est là suffisant pour sonorisé une télé avec deux enceintes bibliothèque . Les préréglages de sons très marqués permettent au moins de trouver un bon niveau de volume sur les voix pour certaines chaînes ou support médiocres. Voilà content de cet ampli qui en donne largement pour son prix .
Simon E.
the perfect upgrade for my x7 soundcard
Bought two of these and two ss3601 for my creative X7 soundcard.
They are a perfect upgrade, because
- they are small, you can´t close the hatch anymore because of the height of the ss3603, but you can still place the x7 on your desk normally
- you can HEAR the difference. I use it with a grado RS1, and the sound became more detailed
Awesome piece of hardware!
Simon E.
Bought two of these and two ss3602 for my creative X7 soundcard.
Gilles C.
NEOTECH SOST-30 Wiring Cable UP-OCC Solid Pure Silver PTFE 30AWG 0.0509mm² Neotech, leader in high-tech HiFi cable, continues its research in the field of sound reproduction and today produces the ultimate in cabling wires. The SOST Solid Core Silver...
Cable DC
Produit excellent. Triplé par pôle pour un câble DC pour un switch. Équilibré dynamique fluide et détaillé. Je recommande
parfait !
J ai acheté ces pangea pico pour stabilisé mon ampli phono ,j ai gagné en lisibilité ,et profondeur . franck
Adelmo T.
Génial
L'un des meilleurs câbles que j'ai jamais entendu, rapport qualité-prix inégalé.
TOP!
stephane j.
TRÈS SATISFAIT
Beau BLEU
BONNE QUALITÉ
MERCI
stephane j.
TRÈS SATISFAIT !!
BON MATERNEL
MERCI
Jef B.
Behuizing
Mooi afgewerkt, prijs waard.
Gian Enzo R.
the best matched EL34 quad you can possibly find
Suggested by a friend and quite many positive reviews I ordered and promptly received the Psvane EL34-PH matched quad from Audiophonics
I put them on my Audio Innovations 800mkIII valve poweramp: immediately greater and clearer sound! Bigger scene more detailed and musical. I am really happy and super impressed!
I believe I will keep these tubes on for a long while and will try Psvane again whenever I will need to change other tubes
PASCALINE S.
rien a dire tout est OK
PASCALINE S.
Insert to Screw for Wood M6x18x11mm (Unit) These inserts to screw are used to add a metal screw thread in wood or soft material. The dewclaws on the sides allow the insert to be held firmly in the material.
tout est OK comme a l'habitude
didier D.
suffisant pour le prix
Apporte un léger mieux qu'un câble de base.
Mais bon pour le prix on ne peux pas demander beaucoup mieux.
La tenue des fiches n'est pas au top.
La souplesse du câble et sont gainage est néanmoins appréciable.
Au final correct... mais sans plus
didier D.
bon produit - efficace
Bon produit, facile a mettre en place. Très efficace sur mon système moyenne gamme.
Un peu rigide pour un câble de cette taille.
Dans l'ensemble un bon produit.
Oyaide est bien une marque phare du câblage
Norman M.
Ravi de mon achat
Matériel immédiatement reconnu sur un viel Asus eeepc tournant sous Lubuntu. Gain de rendu flagrant, même sur des fichiers mp3 en 128 Kbit/s. Idem pour les radios web de qualité (Fip, France Musique etc.) Le son est plus limpide, comme si l’on avait retiré un voile, pas d’agressivité dans les aigus, des basses nettement plus franches mais sans lourdeurs. Bref, c’est le jour et la nuit par rapport à la sortie jack 3,5 du Pc. Merci pour cette belle réalisation au rapport qualité prix imbattable. J’ai quand même une question : À quoi sert cette sortie optique numérique ? Si quelqu’un pouvait m’expliquer l’intérêt ça serait sympa.
Olivier b.
Tres bon connecteur
Utilisé avec du câble Mix Stream MX6 de 6mm acheté ici même. Tres bonne compatibilité avec ce gros câble. Facile à installer, solide, bien pensé avec son système de serrage qui écarte la fiche banane en position. Un très bon produit a recommander, avec comme toujours une logistique sans faille de la part d’Audiophonics.
Aliaksandr S.
Simple solution that just works!
Works as expected! The assembly took some 30 min, the system is very straightforward and I got Spotify Connect working in just a few minutes. Scanning files from NAS took a bit longer but also simple. Overall, pretty happy! Good sound!
A couple of smaller issues:
1. Remote does not always work, still figuring out how to configure additional buttons. However, volume and source work fine and that's the most important.
2. TFT screen is not fully off when in screen saver mode. But not too bright to be a problem.
3. Spotify connect plugin can freeze if you switch tracks too often. You have to either restart the raspdac or open the UI and manually restart the plugin. Still figuring this one out.
Leonidas D.
Top product
In combination with my Bluesound node 2i the sound is more detailed , transparent, combined with quality cables , you have a cracking combo with an exceptional value for money ratio , if the same product did have the name Gustard but some other well known European brand name easily the asking price could be over a 1.000 € , fast delivery and secure packaging from Audiophonics bravo for providing such quality products
Jean Claude V.
fiche banane
ses fiches sont idéales dans les borniers isoles acryliques elecaudio bp208
livres par 4
verrouillage et montage facile et de qualité.
prix vraiment raisonnable
Jean Claude V.
fiche banane
fiche banane de qualité, a voir dans le temps
Jean Claude V.
bornier
j avais décide de changer ,mes borniers de mes 3 paires de cabasse pour mettre des fiches bananes, sans percer ou rien transformer et garder les originaux .
ils sont très bien rempli le montage.
Jean Paul E.
incoyable!
Vu le prix très abordable (par rapport aux tarifs des différents câbles HDG de prix stratosphériques que j'ai eus en 40 ans de Hifi) , j'ai tenté l''expérience avec celui-ci en DIY avec fiches Furutech pour m'amuser. Franchement, le résultat est meilleur : même quantité de détails, mais timbres encore plus naturels avec moins de froideur, profondeur inégalée! Arrêtez de vous ruiner en câbles à 5000€. (streamer Black Hole Larosita II + Mac Mini en lecture).
Realiste
Que demander d’autres à un câble?
Une écoute live, vivante et chaleureuse sur mes monitors. Beaucoup de profondeur et choses rare sensations de hauteur dans le son. Les timbres et les harmoniques sont là dans toutes les fréquences. Y’a peut-être mieux mais à combien ? Attention je parles en symétrique.
Eric M.
Le jour et la nuit
En remplacement d'un Mydac, je retrouve la joie de l'écoute. Le maillon faible ne sera plus le DAC mais l'ampli maintenant (NAD 214) et/ou les enceintes (SPENDOR S8), car je passe en mode préamp sur l'ampli de puissance directement. Ecoute stéréo élargie, pas de distorsion dans les aigus, basses tenues et mids superbes. Lecture des DSD en natif. Musical, il l'est, et c'est ce que je lui demande essentiellement ; c’est ce qui me l'a fait préférer même aux AK4499, en tenant compte de la technique, des avis et du portefeuille. Testé sur l'entrée USB avec un PC dédié sous Daphile, le DAC est reconnu d'entrée de jeu. Testé avec l'entrée optique avec un PC sous Foobar et Ableton, no problemo. Une légère différence est à noter entre les 2 entrées sur la tenue et la profondeur des basses (optique plus ferme mais moins ample). Ce ne sont pas les mêmes équipements, les mêmes câbles et les mêmes logiciels de reproduction. Plusieurs filtres FIR sont disponibles, mais non évalués. Packaging OK et livraison dans les 2 jours si dispo !
Martin v.
Great sound, great DIY project, but with some quirks–and a personal learning curve.
I really do enjoy the sound of this DAC! Recently I upgraded my sound system with a pair of Kef LS50 (meta), which already gave a huge step forward in sound staging and detail. As a source, I mainly used a RPi 3 + HifiBerry Digi+ Pro HAT, connected to a NAD D3020 hybrid digital amplifier (S/PDIF), streaming FLACs and Spotify with Volumio. After some research on the web, it became clear to me that the streamer now was the weakest link in my audio system. I therefore decided to give the RaspDAC MINI LCD a try, mainly based on the enthusiastic Darko Audio review of the previous version of the MINI (I had looked at the acclaimed, but much more expensive Volumio DAC, but Darko coudn’t tell the diffecence with the MINI). Was it perhaps for this positive review that the first batch of the MINI LCD version sold out so fast? It took about 4 weeks before the DAC was delivered (but only 3 working days to get from F to NL). Putting the thing together was instructive fun to do (and super easy with the visual guide from Audiophonics). I also like the sturdy build quality of the black box. However, when I gave the DAC a first spin, the sound was ‘OK’, but only slighly better than the Rpi3/Hifiberry combination. There were also a few other issues that tempered my original enthusiasm.
1. Using a standard RPi 3A USB-C power adapter, the system consistenly kept showing yellow flashes on the LCD screen, indicating insufficient juice. This happened both at startup and during playback. The system thus appeared quite unstable, responding with long response delays or even unexpected shutdowns when using the remote control, even spontaneously during the playback of music. Therefore I ordered another custom power adapter from my local Pi store (SOS-Solutions in NL), that was able to generate 4A. Even worse: much more high frequency noise, which also disrupted the S/PDIF input stage from functioning properly. After contact with the supplier, they kindly sent me the low noise Alli 5V 3A mini-USB adapter (also available from Audiopnonics): problem solved! It appears that the system is quite power critical. Another finding: the sound improved dramatically–much more detail and space, compared to the sessions in the previous days using HD reference music. Perhaps a linear PS could even improve the sound further?
2. The system uses a card adapter with a flat cable to guide the communication with the micro-SD card to the back of the box. This did (and does) not work in my setup. First I though this was the result of the power issue, but after switching to the Allo adapter–still dead. I tried the card adapter on other Pi’s: no problem there, so it does not seem to be broken. I now use the RaspDAC with the card inside of the box–no big deal, but if anyone has a suggestion to solve this, I would be interested to find out how.
Overall this has been a very good investment (so 5*) in terms of lessons learned ánd a better sounding audio system. My advice to future buyers is to use only a good quality power adapter of at least 3A with the MINI LCD. First I thought that Audiophonics reason to upgrade the new MINI with a RPi4 instead of RPi3 and swapping the monochrome display for the colour LCD was for the most part cosmetically (b.t.w., the added value of the LCD is –at least to me– rather limited). Now I understand that this could be related to the separate power supply of USB and ethernet connections, which makes the RPi3 potentially noisier in audio setups (particularly after my power issues of the past days…). I applaud Audiophonics for bringing such nice products to market. DIY projects are to educate and learn, so mission accomplished.
Robert g.
robert grzundkowski
heureux d'avoir trouvé ces tubes hifi sur audiophonics , je recommande vivement ce cite pour son sérieux et service après vente super réactif , encore merci
Stefano F.
A great cable!
Very detailed with no emphasis on high frequencies.
Inserted in a chain consisting of streamer Lumin U1 mini - Chord DAVE - Benchmark HPA4 - Abyss 1266 PHI TC with SC Cable. Assembled in RCA configuration on DAVE side and XLR on HPA4 side. Ground shield on both sides. It carries all micro information with great precision, equaling the quality of DAVE's headphone output.
Anne b.
cable haut parleur cuivre argent de tres bonne qualité utilisé sur enceintes kef les basses profondes le médium plus précis vraiment bien pour un cable pas tres cher je conseille vivement ce cable
Gilles A.
Bornier de qualité mais néanmoins un peu cher
Borniers de qualité avec contacts plaqués or, acceptent les cosses de connexion sans problème. Néanmoins on peut se demander si leur prix est justifié compte-tenu de la fabrication en plastique. Attention à assurer un écartement suffisant lors du perçage du châssis car leur diamètre extérieur est important, plus que des borniers plus classiques.
Pierre S.
Encore un excellent produit Audiophonics !
Encore un excellent produit Audiophonics, l'assertion constituant, de fait et à l'évidence, un parfait pléonasme ;)
Plus sérieusement, ce sélecteur de sources très bien construit remplace, bien utilement, un sélecteur de sources Dynavox qui aura tenu moins de quelques mois avant que le knob de sélection de sources commence à faire des siennes (perte d'une voie sur l'une des deux positions possibles).
Au vu de la qualité de construction du sélecteur de sources Audiophonics, il m'étonnerai beaucoup qu'il me soit nécessaire d'avoir à m'en séparer prochainement.
Bravo - one more time - Audiohonics ;)
Gilles A.
Beaucoup trop léger
Ce produit est indispensable pour monter un transfo toroïdal en position verticale et ainsi gagner de l'espace dans le châssis. Le matériau est hélas beaucoup trop mince et donc pas assez rigide pour supporter un transfo de 300 VA de diamètre 120 mm pesant plus de 3 kg. Le problème a été « résolu » en plaçant une cale sous le transfo pour le soutenir et éviter qu'il ne se balance lors des transports.
Pierre C.
Impressionnant
Résolution, précision, attaques, et une certaine douceur, pourtant déjà possesseur d'un Chord Mojo, d'un Ifi Xdsd, je suis enchanté par cette petite boîte.
Christian O.
canare une référence
Ce câble de modulation est une heureuse surprise. Il représente la quintessence des câbles que j 'ai possédés par le passé. Sa simplicité de conception en fait (comme le dirait Léonard de Vinci) sa sophistication suprême. Il véhicule la musique avec un rendu holographique. Dorénavant, je jugerai les autres câbles à l'aune du Canare. Je le recommande.
Ričardas D.
Changed to XDUOO XD 05 BASIC. I listened with the Edifier S2000MKIII, AKG K371, BQEYZ Spring2.
Subjective opinion: the sound is softer, more balanced. The whole range is kind of longer, the edges (low and high) have become stronger and more detailed. I recommend you give it a try.
Thank you
Ričardas D.
XDUOO XD05 BASIC Portable Headphone Amplifier DAC AK4490 XMOS 32bit 384kHz DSD256 xDuoo presents with its XD-05 Basic a small, affordable yet extremely powerful portable headphone and DAC amplifier. Indeed, low price doesn't always rhyme with economy of means...
Great sound.
Quickly delivered to Lithuania. The store has fulfilled the order in compliance with all term obligations.
Thank you
Juan N.
LITE AUDIO A28D Boîtier 410x100x330mm Noir
Rapport qualité/prix imbattable, bonne finition, solide et rigide.
Et en bonus, le boîtier est livré avec les prises RCA, la visserie, l’interrupteur, la diode Led, les pieds et la prise ICE.
Idéal pour du DIY.
Juan
Juan N.
Transformateur R-CORE 30VA 9V-0-9V 0.2A + 9V 0.2A + 6.3V 2A + 240V 0.05A
J'ai déjà utilisé des transformateurs R-CORE, Jamais déçu.
Très bonne qualité, idéal pour l'alimentation de préamplificateur audio.
Juan
Juan N.
Transformateur R-CORE 30VA 2x12V
J'ai déjà utiliser des transformateurs R-CORE, Jamais déçu.
Très bonne qualité, parfait pour l'alimentation de préamplificateur audio.
Juan
Sébastien T.
Indispensable :-)
Bien que destinés aux électroniques, ces plots à bille sont actuellement sous mes enceintes… Excellents résultats ! Tout gagne en propreté, la scène sonore s'ouvre… Je recommande vivement l'expérience !
