István R.
not easy to assemble
Paul M.
Excellent speaker cables
Paul M.
Straightforward excellent pre-amplifier
Initially I bought this pre-amp for use with active speakers. Excellent at that. Shortly after that, I bought the accompanying...
Customers reviews - There are 18997 reviews.
Philippe L.
Comme d’habitude excellent
Ça fait quelques années que je command du matériel sur audiophonics et à chaque fois j’apprécie la vitesse d’expédition et la qualité des produits
Top !!!
Bo K.
What you would expect from a German manufacture.
Good quality. Soft cable with a good finish. Quick delivery.
Bo K.
Topping DX3 Pro. Good value for money
All over a very nice product. Supper fast delivery with the tnt option.
François D.
Cable au mètre
Attention ce câblé est vendu au mètre, ça ne se voit pas au premier cout d'oeil. Le vendu au mètre apparait, en haut a gauche dans les catégories de câble
Cette information est disponible en tête de page, dans la catégorie et dans le fil d’Ariane du produit.
Charles M.
IAN CANADA FIFOPI Q2 ULTIMATE Reclocker Module FIFO PCM 32bit 768kHz DSD1024 DoP The  FiFoPi Ultimate  from  Ian Canada  was designed to significantly reduce the jitter of the digital audio signal produced by a Raspberry Pi, before...
Great idea but no support
I purchased this after reading Ian's posts demonstrating that it worked with Buffalo III DAC. I have not been able to get these two boards to work together. After reaching out for support over a period of weeks there have been some replies but none simply describing how to configure and connect these two devices. Great idea but of no use without support.
Bas D.
Bas
High quality RCA connector
Renaud d.
FIIO Q3 Balanced DAC Headphone Amplifier THX AAA-28 AK4462 XMOS XUF208 32bit 768kHz DSD512 FiiO's Q3 is a high-performance, portable balanced headphone amplifier and DAC combo. Featuring a meticulous design using high-end components, it offers excellent performance...
Je cherchais un dac pour pouvoir compléter mon iPhone et je dois dire que je ne regrette absolument pas
Charles C.
Matériel mis en route que depuis quelques jours. Pour le moment testé seulement en connexion Bluetooth. Connexion d’ailleurs très facile pour ce mode. Lecture de fichiers Flac et mp3 sur smartphone. A noter que les enceintes utilisées pour l’instant sont très basiques mais pour le moment cet ampli me donne satisfaction, simple d’utilisation, télécommande fonctionnelle, le son est plutôt bon et me satisfait pour ce que je dois en faire : sonoriser une véranda.
A noter je j’ai reçu initialement le matériel sans l’alimentation mais suite à ma demande, très bonne réactivité d’Audiophonics qui m’a rapidement envoyé une alimentation.
DANIEL L.
NICHICON KW Electrolytic Audio Capacitor 50V 220μF The KW series is a range of electrolytic capacitors specially designed for audio use. They offer excellent performance and technical characteristics.
Valeur sûre.
Du NICHICON. Superbe sélection pour recaper un ampli vintage.
Merci AUDIOPHONICS.
DANIEL L.
NICHICON KW Electrolytic Audio Capacitor 50V 10000μF The KW series is a range of electrolytic capacitors specially designed for audio use. They offer excellent performance and technical characteristics.
Valeur sûre.
Merci AUDIOPHONICS.
DANIEL L.
Valeur sûre.
Merci AUDIOPHONICS.
André G.
recepteur bluetooth exceptionnel
j'ai longuement hésité entre le Fiio (plus de fonctions mais plus cher et indisponible) et le Smsl B1..j'ai choisi le SMSL et franchement je ne regrette rien...je lui décerne les 5 étoiles sans hésiter..je l'ai connecté avec tout ce que j'avais en bluetooth et dans toutes les marques..NICKEL et aucune perte de connexion..quant au son...il est branché sur un ampli NAD et enceintes FOCAL 826..et bien autant en flac qu'en mp3 je suis encore bluffé par la qualité et l'image sonore qu'il délivre...
une seule question..: pourquoi ne l'ai je pas acheté plus tôt?
j'ai pas encore testé la sortie casque..mais je suis pas inquiet..
livré en supersonique par audiophonics et à un prix très correct il mérite tres largement son QUOBUZ d'or...
André
daniel f.
boitier eco
oui bonjour , reçu le produit emballage correcte , le rap/qua / prix excellent , bonne finition donc , absolument rien à dire .
Hubert K.
super rapport Q/P; font le job; seul point légèrement négatif, déjà évoqué dans les avis: les rondelles rouge/noire détrompeuses se ballade du fait que le serrage ne peut se faire complètement, dû à l'épaisseur du câble.
Hubert K.
Fait parfaitement le job; aucune perte audible
daniel f.
embase femelle 10A-250V
oui bonjour , le produit correspond aux caractéristiques sur le site , bon R/Q prix .
daniel f.
DYNAVOX Wall Plate with 4 Speaker Terminals Stainless steel brushed plate matt finish to be embedded in a wall using 2 fixing screws provided. It is equipped with 2 pairs HP terminals compatible with large section cables...
plaque murale à quatre bordiers hp
oui bonjour, reçu le produit conforme aux caractéristiques sur le site .
francis h.
excellent produit
Très bonne prise fabrication très sérieuse, je confirme ce qui est mentionné dans l'avis précédent il faut souder le fil de terre sur une petite cosse qui est fournie avec la prise mais qui n'apparaît pas sur les photos, pas très compliqué quand on possède un fe à souder
Jean-Louis T.
SMSL SP400 Balanced Headphone Amplifier THX AAA-888 MQA SMSL offers with its SP400 an excellent headphone amplifier, based on a solid internal design. It integrates a THX amplifier chip, known for its incredible performance, as well...
Trés bon produit
Combiné au M400 cet ampli est un peu moins puissant que le SP200 mais l’équilibre des canaux est parfait, l’écoute est très propre avec des basses puissantes mais pas trop.
Piotr L.
Precise and easy assembly with all the part that you need, but ...
I've got this one because I hate drilling holes in aluminum. Unfortunately, some drilling was inevitable: volume pot oppening is not made for Alps RK27, so needed to fix this. Included binding posts are set for 12mm oppenings but the openings are 11mm, so more drilling on the back. Other than that, it is a pretty good box with all the part that you need for the piece of mind. Binding posts are good, so are the RCA connectors. I'd give it 5 stars should it not have issue mentioned above.
Piotr L.
Great quality box
It is not chek but worth the price. Solid, precise, stiff, and quite heavy. Very good box indeed.
Joel S.
ERATO DAC100 V1 Balanced DAC XLR 24bit / 192Khz 2x AK4497 DSD128 XMOS U208 The DAC 100 uses two 32-bit AKM AK4497 AKM chips to provide very accurate stereo digital decoding while maintaining a minimum noise level (128dB signal-to-noise ratio and -166...
Très bien, mais...
Très bon DAC et bonne surprise au regard des filtres qui se révèlent simples et efficaces. Le son est comparable et souvent meilleur que celui de mon streamer 3D Lab beaucoup plus couteux.
Deux bémol néanmoins: la présentation qui est vraiment basique au regard des qualités de l'appareil et la livraison de la poste (COLISSIMO) catastrophique. (carton déchiré et cabossé, à demi ouvert..). AUDIOPHONICS affirme laisser le choix dans le cadre du transporteur mais en réalité, lors de la commande, COLISSIMO est imposé. Pour ma part, je suis résolu à ne plus valider aucune commande de produits à risques avec COLISSIMO.
Yannick B.
Magique .
Ce joli petit bloc massif branché sur mon Smsl Q5pro est une merveille.L'alimention parfaite pour le petit ampli qui devient d'un coup un véritable ampli haut de gamme.Que de détails passés avant inaperçus,aigus superbes et basses bien controlées.Je ne suis pas un expert du son,mais ,à moins d'être sourd,l'apport est incontestable.
Possesseurs de Q5 Pro,ne vous en privez pas !
PS: Envoi sous 4 jours malgré les 15/25 jours annoncé sur la fiche produit,Noel sera donc musical pour moi.
Merci Audiophonics pour votre sérieux.
Sandy G.
cable modulation symétrique
produit de très bonne qualité, déjà visuellement.
A l'écoute, le résultat est excellent.
Sandy G.
connecteurs RCA
Ce produit est de super qualité, bien serti, aucun jeu.
le serrage sur le câble est excellent
a recommander
Sandy G.
boitier universel
produit de bonne facture, idéal pour réaliser une alimentation, par exemple.
Sandy G.
MUNDORF BS100 Copper Wire Ferron Core Coil 2.7mH Mundorf BS100 coils are high performance models for low frequency filtering. The core is made of Feron which is heat treated after production. This treatment gives it an optimal...
self pour filtre haut parleur
matériel de qualité, envoi réalisé soigneusement.
Olivier L.
DAYTON AUDIO DTA30HP Class D Amplifier TPA3116D2 2x15W 4 Ohm The highly effective amplification of the Dayton Audio DTA30HP unveils an incredible scene and sound presence, as well as great clarity and precision. It integrates an amplifier...
Dayton Audio
Surpris par ce petit ampli de qualité, très bien
Olivier L.
Power Plug Adapter Female US NEMA 1-15 / C Type to Male FR C Type This power adapter allows you to use US format power cables on European, Schuko or French plugs. The female part of the adapter can also be used for Type C / Schuko.
Adaptateur
Pratique
françois r.
AUDIO-GD PRECISION 3 2020 EDITION Balanced Class A Amplifier ACSS 2x 70W 8 Ohm Audio-GD is upgrading its Audio-GD Precision 3 by offering this 2020 edition. It is based on the previous model, but with a modified circuitry and adjusted sound performance to...
Ampli
Très bon ampli encore en rodage belle définition et assez de puissance pour moi
daniel f.
support Bornier
oui bonjour, le produit correspond bien aux photos sur le site .
Saphon I.
Magic
Son cristallin
Son claire comme l’eau
Son cuivré et dorés
Conclusion (aucune déformation,son authentique )
Cedric C.
AUDIOPHONICS HPA-Q400ET 4-channel Class D amplifier Purifi 4x400W 4 Ohm We are proud to present AUDIOPHONICS HPA-SQ00ET, a class D 4 way power amplifier based on 4x PURIFI 1ET400A modules.
Parfait pour la multiamplification
les modules purifi sont ce qui se fait de mieux avec les modules Ncore 40à en classe D.
Cet ampli ne chauffe pas (essayé en stéréo 2 voies uniquement) et est très transparent. Seul regret , pas d'entrée RCA (mais il n'y a pas trop la place à l'arrière, il est vrai)
Christophe m.
Très bon produit et très bon conseil de Audiophonics.
Je recommande ce produit ainsi que la qualité de service de Audiophonics
Ivano D.
Filtro antirumore 230V
Sono soddisfatto del prodotto di cui nemmeno sapevo dell'esistenza. Risolve problemi di disturbi provenienti dalla rete di alimentazione. Molto soddisfatto dell'acquisto
Ivano D.
Alps 100k stereo
Ottimo potenziometro professionale che non necessita di commenti. Produttore giapponese che è sinonimo di qualità. Completamente soddisfatto.
Miguel O.
Miguel O.
Très bon amplificateur. Excellent rapport qualité / prix. Construction robuste. Son avec de très bonnes basses, une bonne scène sonore et un excellent timbre.
Très bon connecteur
Concernant ces prises bananes,pour le prix elles font le travail qu'on leur demande : le système de verrouillage permet de bien bloquer sur les enceintes ou amplificateur
Seul chose a signaler,il serait judicieux d'indiquer dans le descriptif la taille du tournevis torx(la il faut un T6) pour serrer les vis.
Hubert L.
Mise en route sans souci, doc bien expliquée. Etre précautionneux pour les sorties HP car elles sont proches les unes des autres.
Pour la mise en route de la télécommande, bien lire la doc car il faut l'initialiser. Le son qui sort dans mes enceintes est tout à fait correct et aussi bon que celui que j'avais avec mon ampli Hifi ancienne génération. J'ai testé toutes les entrées.
Comme en plus, je désire écouter mes disques vinyle, je vais devoir acheter un préampli phono, mais c'est évident car le niveau de tension est insuffisant à la sortie de la platine. Je suis satisfait de mon achat. L'encombrement est réduit et l'utilisation est simple.
François D.
Publicité qui tente a induire en erreur le consomateur
Je viens de recevoir ma commande, et oh surprise, je n'ai reçu qu'un métre. Et je viens aprés reception, et uniquement dans la fiche technique que ce produite est vendu au métre, alors que sur la photo du produit, ont peut voir une belle bobine. Et même sur ma commande la longueur du cable n'apparait pas. Je crois que je vais rechercher un site, qui ne vous induit pas en erreur. Adieux Audiphonic.
Thierry C.
MINIDSP IR V2 IR Remote Control NanoSharc / MiniSharc / Open DRC / DDRC88/22/24 / NanoAVR-HDA / SHD This MiniDSP IR Remote V2 is pre-programmed for use with the brand's devices. No configuration is therefore necessary.
Excellente
Je l'utilise avec un 2x4 HD qui est disposé latéralement donc récepteur caché, aucun problème, peu directive et répond bien. Agréable en main aussi. Côté Audiophonics, je précise que l'expédition a été immédiate et rapide, bien emballée, cela concerne aussi le miniDSP commandé en même temps. Merci !
Thierry C.
Je l'utilise configuré tel que fourni c.a.d. 2 voies par canal. 1er essai sans rien changer donc partage à 1000 Hz/48dB/oct. sans réserves question distorsion, bruit de fond, transparence, ouverture, on l'oublie, la séparation est d'une efficacité parfaite (j'avais un filtre actif analogique). Ensuite passé à 200 Hz/24dB pour mes large-bande + grave sur baffles ouverts, encore mieux. Réglages faciles, pas de distorsions audibles, pas de clipping, en sortie 2 amplis stéréo pot. entre 25 et 30%. Mesures avec R.E.W. et Umik1 partagé avec un ami, export/import fichier facile aussi, mais c'est là que ça se corse, il faut apprendre à ne pas en abuser. A ce stade mon impression est que la recherche d'une courbe vraiment linéaire est peut-être une fausse piste mais je n'ai pas assez de recul, il faut expérimenter et il y a de quoi faire, surtout si on s'aventure du côté des filtres F.I.R.! . En tous cas je ne regrette pas, c'est un outil sérieux, pratique, efficace. Un petit bémol, je comptais lui dédier un mini pc Asus avec Windows XP et je n'ai pas pu faute de compatibilité du logiciel fourni avec je crois Adobe AIR (nécessaire en version récente refusée par XP), dans les fichiers fournis il y a pourtant un pilote pour XP-Vista ce qui induit en erreur, mais ce n'est pas grave. L'interface de commande/synchronisation est un peu rustique mais fonctionne très bien. Donc je suis très satisfait et aussi très conscient du chemin à faire pour en exploiter les possibilités. Très intéressant !!!
Sylvain R.
Etonnant vu son prix
Préampli acheté pour remplacer un volume passif avant une paire d'enceintes actives Bang & Olufsen Beolab 6000.
Je cherchais à avoir les corrections grave/aigu qui me faisaient défaut, la présence des tubes était la cerise sur le gâteau.
Une fois branché, quelle surprise !
Avec les tubes 6K4 d'origine, le son prend une spatialisation étonnante, il n'est plus "projeté" par mes enceintes, mais se matérialise dans mon salon avec une foule de détails, notamment les réverbérations des salles de concert. C'est bluffant.
La contrepartie de cette reproduction "holographique", ce sont les voix qui sont reléguées en arrière plan et qui manquent de vie, avec un aspect limite synthétique.
J'ai un son qui me correspond mieux avec les tubes 6J1 vendus sur le site. Les mediums reviennent, les voix reprennent leur place, avec la rondeur qu'on attend d'un préamp à lampe. On perd pas mal de cette spatialisation étonnante des 6K4, mais c'est plus polyvalent tout en restant détaillé et vivant.
Les 6J1 sont très sensibles à l'environnement électromagnétique, éloignez votre box internet ou votre mobile qui peuvent parasiter le son.
Prochain test : les tubes GE 5654 que j'ai hâte de recevoir !
Jacky P.
Amplificateur à tubes.
Transformateur pour un amplificateur à tubes 4 x EL84 et 2 x Ecc83.
Réalisation professionnelle et conforme aux spécificités indiquées à la commande:
- sortie 1 HT 230/0/230. 150mA x 2. + Ecran.
- 2 sorties BT séparées: 6,3 v. / 3A. chaque.
Surprenant pour le prix
Je l'utilise en mono cablage (donc 2 câbles par polarité),et a ma grande surprise c'est bien mieux que le modèle monocablage 2S11F:le son est moins crispé,l'image steréo est plus large et profonde si l'enregistrement est bien fati,le grave moins "pneumatique".
Pour ma modeste installation, c'est parfait.
Fabrice D.
Boîtier recommandé à 100 %
J'ai passé pas mal de temps sur le site d'Audiophonics pour trouver LE boîtier qui conviendrait à mon projet d'ampli classe D DIY.
Quand j'ai vu celui-ci et qu'il correspondait à mes critères (dimensions intérieures et extérieures, qualité des matériaux et de construction, aspect esthétique, prix), je n'ai pas hésité.
Au déballage, la première impression est très bonne : çà sent la qualité à tous les étages ! Lors du montage (attention, pour les moins bricoleurs, il n'y a pas de notice mais il n'y a rien de bien compliqué en même temps), on s'en rend compte immédiatement car tout tombe en face, les fraisages pour les vis sont parfaites, il n'y a pas de jeu et rien ne force.
Si l'aspect esthétique vous convient, que vous cherchez un boîtier 100 % aluminium et qu'il rentre dans votre budget, alors foncez !
La cerise sur le gâteau serait peut-être de revoir la couleur de la visserie. Celle qui est livrée est de couleur argent, je pense que le boîtier serait encore plus joli avec une visserie noire... mais c'est une histoire de goût !
Ioannis P.
Excellent cable from an excellent retailer
Furutech Powerflux is indeed a step up from lesser models. The detail and ambience increase is not at the expense of tonal balance.
hugo g.
+ 1 pour la facilité d'implantation
Très bon DAC, presque plug and play avec RPI, configuration en deux clics.
Niveau audio une belle qualité mais qui nécessite de pousser un peu le volume, commun pour deux nombreux DAC. Couplé avec Moode et un ampli rega +dali zensor. La 5e étoile sera lorsqu'une solution de shutdown du RPI sera intégrée, et la 6ième lorsqu'il sera possible de ne pas lancer automatiquement le RPI. En effet, si vous utilisez le bluetooth par exemple, la dernière source est mémorisée, mais le RPI sera lancer quand même avec l'alimentation de la carte. Le paramètre idéal serait que le RPI soit alimenté uniquement lorsque la source RPI est sélectionnée. A suivre
Denis Gabriel G.
Apres un an toujours plus jouissif , mais...
Après un an d'écoute, je remets mon grain de sel.
La qualité du Quloos m'a amené à changer : mon steamer, mes enceintes et mes câbles.
Comme le souligne Jean-François C. une mauvaise association peut lui être fatal. Dans mon cas, le changement d'un câble audio USB a rendu les aigus agressifs. C'est seulement avec l'arrivée d'un nouveau steamer (ALLO USBridge Signature) que j'ai pu utiliser le câble.
Donc vigilance, car l'incroyable précision du Quloos peut être aussi son pire ennemie.
Mais avec de bonne associations, je n'ai pas trouvé une tel qualité sonore (j'aime l'ultra précision) dans d'autre système (ampli+dac) qui coute jusqu’à 10 fois plus chère.
Frédéric M.
Pourquoi payer plus cher quand on frise le parfait
Ayant en ma possession un AKG K-702, j'étais à la recherche d'un casque moins analytique et pas des aigus "métalliques". C'est désormais chose faite avec le Sundara. A la première écoute, j'ai eu la sensation d'un scène sonore plus réaliste et une plus grande proximité avec les musiciens. C'est un casque assez remarquable sur tout le spectre avec un mention spéciale pour le bas médium qui est excellement restitué. C'est un casque qui s'accommode avec tous les styles musicaux, peu de casques peuvent se targuer d'une telle qualité. J'écoute essentiellement du jazz et du classique, un pur bonheur! Je continue de faire des écoute comparatives avec le K702 mais le Sundara le surpasse sur tout les plans. Bref, un casque d'une très grande qualité et dont la concurrence à ce prix a de quoi frémir.
