Robert g.
Pascal H.
Thomas J.
Revelation
This DAC replaces a Geek Pulse. Listening to it after letting it run for a few days was disturbing. DSD and hi-resolution PCM files sounded distorted! Nothing like my Geek, nor the Calyx M DAP I have. I wondered if I had blown my Audeze LCD2 headphones. And then I realized that what I was hearing was not distortion from the DAC or headphones, but sounds I had never before noticed. Audience sounds In classical recordings, maracas way to the left on Bob Marley LIVE (24-192), actual distortion from electric guitars. This DAC, especially mated via HDMI/I2Sto the RaspTouch I bought to go with it, delivers so much more from recordings than I am used to hearing. The jump in sound quality is similar to what I experienced moving from cassette tapes (metal on a 3-head Nakamichi, so pretty good) to CDs in the 80s. But from a much higher bar. There is NO noise that I can discern - similar to my Calyx M DAP. But the resolution is in another league. The Gustard is extremely well built, offers the “blackest” of backgrounds, delivers dynamics (micro and macro) with ease, and transports you to the musical performance beyond anything I have experienced in decades of being an audiophile. Just make sure the rest of your playback chain is up to the task! Highly recommended.
Charles M.
Excellent rapport qualité prix à un détail près
Entièrement métallique , de bonne facture, très bon rapport Q/P. Petit détail esthétique, la bague en plastique rouge ou noir ballote une fois qu'on a serré le câble, car elle n'est plus plaquée par la vis serre câble. Cést pas très judicieux, mais ça reste un très bon produit
JF L.
Ce câble est excellent. C'est aéré, vif, ça laisse tout passer, le meilleur comme le pire, selon les enregistrements ! Nul besoin d'aller se ruiner !
Bruno M.
Simple, efficace (commutation sans parasites).
Niveau de sortie trop faible
Après analyse des caractéristiques avec un banc de mesure audio, ce petit préampli est vraiment excellent.
Son seul défaut, et il faut que je me penche sur le sujet, est son niveau de sortie un peu faible pour attaquer des enceintes amplifiées tel que des FOSTEX PMO.5n qui fonctionne très bien avec d'autre préampli. En effet le contrôle de volume n'est réellement opérationnel que de -50 à 0 db alors que la page de fonctionnement est de -90 à 0db.
Dommage qu'après plusieurs remarques sur le sujet le fabricant n'est pas rectifié le tir et changé la valeur de de la résistance de gain de son ampli OP interne.
Pour la télécommande beaucoup de boutons pour pas grand chose. je n'ai toujours pas compris à quoi servent certains boutons de celle-ci.
je recommande ce petit produit qui fera très bien l'affaire pour constituer une micro chaine audio de très bonne qualité car comparé avec des préamplis de 5 à 20 fois sa valeur, il en impose par sa simplicité et son excellent rendu.
Pierre
Andis O.
For lovers of pure sound
Great product at this price.
Clear, detailed sound.
The sound stage is not very wide.
Fast and dynamic.
The low frequencies are not highlighted, but are very detailed.
The double bass and bass guitar sounds fantastic.
The vocals sound great.
Also a symphony orchestra.
Not suitable for those who like big bass.
Not suitable for systems with low bass.
Good and clearly visible display.
Slight noises are heard when switching to MQA.
Only 3 feet.
Didier R.
Conforme à la description
Une face arrière en tôle aurait été suffisante (le produit livré avait une face avant et arrière en alu)
Jean-Luc B.
Câbles enceintes , straps ;
Très bon produit , de bonne qualité et surtout très facile à utiliser .
Recommandé !
Jean-Luc B.
Très bon produit , bien conçu ,et surtout très pratique à utiliser .
Recommandé !
insatisfaction totale
Bonjour je viens d'ouvrir ce matin le colis car absent ! Enorme déception ce n'est absolument pas le bon produit , autre aussi d'ailleurs !
Pour le rouge le diamètre est de 4 mm et pour le noir je dirai 8 cm !
Comment peut on se tromper à ce point ?
Je vous renvoie bien évidemment les 2 produits !
A votre écoute
Laurent Olivier M.
Une excellente surprise
Sur les - excellents - conseils du service client d'Audiophonics, j'ai sauté le pas et troqué mon Creek Evo2 contre cet ampli.
Et je ne le regrette certainement pas !
Je ne peux que confirmer ce qui a déjà été écrit ici, en particulier l'étonnante impression de 3D sonore qui se dégage de ce tout petit ampli.
L'extension dans l'aigu donne un relief saisissant aux meilleures prises de sons dont elle révèle les détails sans une trace d'agressivité.
L'image sonore est particulièrement stable et profonde et la dynamique surprenante, heureusement que je n'ai pas de voisins immédiats !
L'impression d'ensemble est celle d'une grande transparence, comme si les enregistrements sortaient directement des enceintes. Les colorations que je remarquais avant ont totalement disparu.
Revers de la médaille, les prises de son médiocres ne sont aucunement enjolivées...
Dans l'absolu, c'est excellent, et pour le prix, je conseille vraiment d'essayer !
Petar S.
TOPPING D10S DAC USB 32bit/384kHz DSD 256 XMOS U208 ES9038Q2M Silver Revisited version of the D10 from Topping, the D10s is an office DAC with impressive capabilities in its price range. This second version includes an ESS ES9038Q2M 32bit...
Topping d10s
Audiophonic is reliable partner with fast delivery and accurate description of products.
Françis S.
Françis S
Confirmation de la bonne tenue acoustique de ce câble . Prévue pour relier la sortie casque d'un téléviseur à un émetteur de casque sans fil , cela change complètement la donne . plus de clarté , plus de détails , meilleurs timbre et un peu plus de niveau .
guy s.
Après avoir galérer avec les pointes de découplage Elipson, je me suis tourné vers les Superpikes, j'ai hésité à cause du prix mais finalement je ne regrette pas mon achat. Ces pointes font parfaitement le job et de plus je peut déplacer mes colonnes sans problème.
Victor D.
Bon récepteur, signal transmis, même assez loin.
Très pratique pour éviter de changer de DAC.
Service Audiophonics toujours au top !
THIBAUT F.
INDISPENSABLE POUR CELUI QUI FAIT DU STREAMING
Pas envie de changer de dac? pas envie de changer d'ampli?
Commencez par acheter ceci. le gain est incroyable.
Jean-Marc F.
Sélecteur de source RCA
Ce sélecteur de source RCA est bien conçu. Il fait appel à des relais (donc des contacts "secs") pour la transmission du flux audio. Il n'est pas question de perte ou de coloration du signal, comme cela est bien souvent remarqué avec des commutateurs à transistors. De plus, cette technologie permet de faire transiter le signal dans les deux sens(1 entrée vers 3 sorties ou 3 entrées vers 1 sortie), suivant la configuration exigée. Pour le prix, il n'est pas question d'hésiter.
beau son, bel objet
objet audiophile sublime! merci Audiophonics!
Gaetan P.
FX-AUDIO D502BT Amplifier FDA TAS5342A Subwoofer Output Bluetooth 5.0 2x60W 4 Ohm Black The FX-Audio D502BT is, as its name suggests, the successor to the D502. The D502BT takes over its base and components, but this time it comes with a Bluetooth 5.0 receiver,...
la scène sonore est en retrait
- la télécommande est très bien pensée ... voire géniale
-les fonctions sont très bonnes
-l'usb sous Windows 10 est reconnu directement et la musicalité est bien meilleure qu'avec les autres sources
-le son porte loin d'un bon niveau de qualité
-pour le son de la TV... génial!!
-----Avec des enceintes EVA de Davis-----
j'ai utilisé précédemment un Alientek qui est nettement mieux pour la scène sonore
mais fatigant et moins pratique...
...que ce FX-AUDIO tout doux peut-être un peu trop
ce petit ampli qui reste très bien avec Equalizer et Tone pour corriger sérieusement le son sans que cela soit compliqué
Un prix très serré
KLEI CLASSIC HARMONY RCA Plugs Silver Plated Copper (Pair) The RCA KLEI Harmony Perfect RCA bases offer excellent design quality for enhanced performance, based on a certain know-how, the fruit of the brand's many years of experience....
superbe musicalité
monté sur l entrée de mon ampli et sur mon dac en sortie analogique. quel ouverture et quel clarté redoublée.. tous est a sa place avec un plus partout.. malgré le contact qui est qu' un pin de 2mm sur 1 mm touchant la pin de la prise rca point chaud.. le resultat est vraiment bluffant.. j ai monté des wbt argent pur en sortie de mon lecteur cd x ray..de 18 ans d Age et en entrée numérique de mon dac. audio gd.. quel claque.. déjà que sais excellent sans.. la sais superbe. .j ai même essayer une interface ifi digital ..et la je sens littéralement les personne les timbale les violons.. ils sont devant moi ..dans mon salon.. comme quoi un upgrade resonné et bien fait. améliore vraiment.. se qui est déjà bon.. sa deviens excellent.. pas pour tous bricoleur du dimanche. .mais avec un peut d adresse et de bon conseils. ont peut atteindre une sorte d excellence.. prochainement je craquerais pour une interface de chez audio gd. avec alimentation régénérative..
Guillaume L.
Pas trop mal
acquises pour remplacer des prises droite Merten installées sur des cables "Powertrans", gain esthétique et saillie moins importante permettant de rapprocher n meuble du mur.
A voir, le rapport prix/solidité.
Jérôme R.
Produit conforme, excellent rapport qualité prix.
Thomas J.
RASPTOUCH LVDS Streamer I2S HDMI Audio-GD Compatible IIS Audiophonics is back with a brand new version of its RaspTouch, designed for experienced audiophiles. It includes a Raspberry Pi 4, an Allo Kali reclocker and an I2S output...
The Definitive Squeezebox Touch Replacement?
Both my SBT and my DAC, a Geek Pulse, recently died. I tried a Volumio Primo, but the HDMI touch screen I added was much too slow, the functionality of Volumio software not up to the task of dealing with my large music library, and the Squeezelite plug-in problematic. I came to Audiophimics for a new DAC (the impressive Guatard A18) and found this by happenstance. Lucky day. The RaspTouch is fantastic. A better screen that is very responsive. A simple but well-built case. Setting it up with PiCorePlayer was far easier than the Volumio Primo, especially with the help of David, who was incredibly patient and helpful. Combined with the Gustard it sounds truly fantastic. I recommend both the hardware and Audiophonics without reservation.
Claude H.
Une réussite
L’Armature Hecate a été inséré entre la sortie USB d’un Mac Book et l’entrée S/PDIF d’un convertisseur Musical Fidelity X-DAC V8.
Le périphérique est identifié automatiquement par le MAC, il n’y a rien a faire.
Le résultat est immédiatement probant, pas de rodage des oreilles nécessaire…..
Net amélioration de la profondeur, de la dynamique de la reproduction des détails.
Le progrès technologique est passé par la, produit très recommandable.
Gerard S.
Améliorer l'inertie
Parfait pour apporter une isolation et masse complémentaire suivant l'épaisseur choisie à une platine vinyle, un laser, un ampli ou même des enceintes.
Gérard.S
Gerard S.
Couvre plateau posé sur une Thorens TD166 modifiée. je le préfère de loin au modèle caoutchouc pour filtrer les bruits. Excellent rapport qualité prix.
Gérard.S
Gerard S.
Aération et superbe scène sonore
CES 2 tubes JJ ECC82 sont placés dans un Mélody SP3. Après avoir réalisé plusieurs comparaisons, la première qualité de ce tube est pour moi la transparence. La scène sonore est très aérée avec des basses biens présentes et des aigues d'une grande finesse. Elle me semble avoir une courbe de réponse très légèrement creusé dans le médium. Ce sont mes ECC82 préférées. Toute la magie réside dans l'association des tubes de caractéristiques différentes pour arriver au Graal.
Gérard.S
Gerard S.
Excellent tube
J'ai mis 2 tubes 6922 EH dans un Mélody SP3 à la place des JJ dont je trouvais le haut médium en avant sur mon système. je suis étonné et satisfait du résultat. je trouve que les EH ont une courbe de réponse plus linéaire avec une dynamique étendue sur tout le spectre sonore, des basses tendues, des bas médium bien définies, des médium présent sans aucune agressivité, et des aigues fins et déliés. De plus j'ai trouvé une nette amélioration sur le placement des instruments augmentant la profondeur de la scène sonore.
Gérard.S
PIERRE R.
fil argent 1 mm en audio
Ce fil d'argent de 1 mm gainé de téflon avec le fil de retour plaqué contre la gaine pour le bifilaire et le tout entouré d'une gaine téflon plus large réalisent le meilleur câble de liaison entre le lecteur et le préampli à ce jour dans mes réalisations . En câblage interne il est remarquable en fluidité et précision !
Klaus B.
Impressing SPDIF-source at low price
I use this Interface combined with a RPi 3B and Volumio (which I already used before). My DAC is the AK4495SEQ-Board from Audiophonics.
This Interface is absolutely astonishing: very tight bass, nice voices and superb positioning of the Musicians. I didn't await this quality for that price!
Nicolas Rafail P.
Solid, goodlooking, professional
I immediately loved it, a piece of equipment that complements every desk! Clear sound that perfectly matches my SMSL SP200. I really like the display depicting audio format (PCM or DSD) and sampling rate of the track playing.
Nicolas Rafail P.
POWER and THX quality combined!
This is trully an afordable, serious piece of equipment capable of producing the cleanest of sounds with enough power to drive ANYTHING you give it.
Nicolas Rafail P.
Really good quiality and looks nice on my desk!
Apart from the quaity i really valued the fact that 75cm version exists, that 100% suits my needs.
Nico V.
Great DAC !
Excellent DAC ! All in one - Amplifier with volume control incl. Remote control and working fine ! If you use a UP-OCC self made USB power cord it is even better in performance. Toslink is working fine.
Nyirö F.
fast shipping!
I'm still testing the sound.
Volker E.
Incredibly good DAC: Fantastic sound, stylish and very affordable!
First of all I would like to praise the support here, who answered all my (partly senseless) questions before and after the purchase.
To the initial situation: I have Adam active loudspeakers, which are controlled by an Abacus preamplifier. My old DAC was getting on in years. I have been thinking for a long time about which new DAC to buy. The only thing that was clear was, that it should be a Sabre, because I love its timbre. So I came to this product, which sounds at least five times more expensive than priced here. The room expands dramatically, both in width and depth. And even if it sounds like a cliché, you can now hear details that were previously imperceptible. At the same time the sound remains harmonious, because it does not dissolve in the manifold details, but wins through this in harmony - in my opinion a quality of the Sabre-Chips, which was perfectly staged here. The bass range plays much more nuanced. The highs are now even faster but silky smooth - The Adam performs very well with this DAC.
The assembly was easy, Volumio explains itself and the speaker looks stylish with the display. The remote control is a real asset, because you don't have to constantly reach for the iPad to control the playback.
I can only recommend the DAC all around. Thank you very much for this cheap and great device and many greetings from Berlin, Volker
Jean-Marc H.
Excellentes fiches, très belle fabrication.
Branchées en sortie de blocs mono à tube.
Ce qui a motivé cet achat était de remédier à l'inévitable oxydations de l'extrémité du câble, qui apparait au bout de quelques temps, lorsqu’on branche en direct sur les embases.
A ma grande surprise on y gagne aussi en qualité sonore. Oui surpris, car jusqu'alors, j’étais convaincu que moins on met de connecteurs sur le trajet d'un signal mieux on se porte.....et pourtant !
Attention la différence n'est pas énorme, un léger gain en clarté dans le haut médium et un grave un poil mieux articulé.
Eetu B.
Very good version of the LM3886
First pair of the amplifier boards I ordered were broken out of the box and I had to send the boards back. Despite the inconvenience, Audiophonics replied kindly and took quick action on replacing the boards. Thankyou for the excellent support! I've had the amplifier boards in use now for half a year and they sound awesome. bursting some real power out of them has never been a problem, since the board is well designed and has good fail safe mechanisms. Only improvement I can think of would be a rigid packaging for safer transport and some kind of note containing the boards information and hardware requirements.
Paul C.
Allo Digione Player Raspberry Pi 4 avec alimentation Allo Shanti
Après avoir installé le kit EvoDac avec Raspberry PI 4 dont les résultats étaient déjà excellents, mon souhait était ensuite d'installer un DIRAC Live numérique.
Pour ce faire, ce Dirac (à venir) devra être installé entre deux sources numériques, d'ou l'acquisition du Allo Digione player Raspberry PI 4 avec son alimentions Allo Shanti, directement branché sur le EVO DAC.
Les résultats sont impressionnants au niveau des différents critères auditifs. Nous gagnons encore en profondeur de champ auditif, aération holographique, définition, assise et impact des graves et bien sûr en musicalité.
Toute ma reconnaissance pour les conseils et assistance des personnes d'audiophonics, qui n'ont pas ménagé leur effort pour m'aider à cette installation dans mon système actuel.
Très bon produit!
J'ai des modèles Neotech argent et cuivre en usb, permettant aussi de comparer avec ce Pulsar.
D'emblée, le Pulsar procure une restitution détaillée, avec de jolis timbres. Comparé au Neotech usb cuivre, c'est le même niveau de qualité pour ce qui est de la définition. Le Pulsar sans doute grâce à l'argent, procure cet aigu fin et capable de variété, sans que ce soit aussi marqué que sur le Neotech argent.
Sur mes appareils, le Pulsar a un équilibre plutôt rond, concernant le grave, le haut grave et le bas médium. Comparé au Neotech cuivre, le médium semble un peu en retrait mais il a une douceur de velours qui à mon avis est un des caractères du câble.
Attention ce qui est valable chez moi ne l'est pas forcément ailleurs!
Ce qui est certain, ce câble est de grande qualité pour un prix accessible, et peut être essayé à côté des meilleurs câbles usb.
Je le préfère sur mon installation casque, et réserve le Neotech cuivre sur ma chaîne avec enceintes car le résultat et l'équilibre sont les meilleurs que j'ai trouvés pour l'instant.
Sur casque, le Pulsar fonctionne très bien, je le préfère au Neotech usb silver. Ça joue sur peu, sans doute des goûts personnels plus que la qualité des câbles.
très recommandable
J'utilise depuis longtemps le Neotech usb argent.
Surprise avec le cuivre, je n'ai pas le même rendu! dans le bon sens car c'est très équilibré, avec un médium bien présent. C'est cohérent, lié du grave en passant par le haut grave le bas médium, jusqu'au médium.
Globalement équilibre ressenti comme neutre, le grave n'est jamais envahissant, il est défini et à sa place, les voix chantées sont très cohérentes. L'aigu est de très bonne facture, je dirais qu'après avoir essayé d'autres câbles avec de l'argent, le rendu est sensiblement différent avec le cuivre seul. J'ai tendance à préférer, mais avantages et inconvénients aux deux métaux.
Pour le Neotech usb argent, c'est plus rond en bas, un aigu fin et détaillé comme l'argent sait apporter, mais son gros défaut chez moi est le médium qui semble en retrait, chose que je n'ai pas du tout avec le Neotech cuivre. Les 2 apportent autant de détail, la qualité de ces câbles est là, en dehors d'histoires d'équilibre.
Attention c'est sur mes appareils et je pense que ce n'est pas transposable forcément ailleurs! le Neotech silver chez un ami rend différemment, il est sec en bas et plutôt montant.
Diego H.
Trés bon pour le prix!
J'ai acheté cet op-amp en 2014 avec le AD797 et le BB OPA2604AP pour mon Audinst hud-mx1 dac-amp, et comparé au LME49860 de stock, le OPA627 était le meilleur pour moi. C'est curieux, il est le BB OPA627AU en double re-furbished, le prix du même est de 24€ sur Digikey et Mouser..
J'ai eu la peine d'essayer les quatre opamps soigneusement et vraiment j'ai coincidé avec des autres rapports sur internet: il est un peu plus dark, mais plus naturel. Il est moins 'étincellant' aux aigus mais plus vrai aux moyens-freqs.
Six ans se son't passés de célà, ja'i comparé avec d'autres dacs et toujours content. Merci Audiophonics.
Kevin H.
Anodized Aluminium Push Button with Orange Light Circle 2NO2NC 250V 5A Ø19mm Black This bistable switch (two positions) 250V 5A in anodised aluminium incorporates a beautiful orange LED. It is ideal for all your DIY projects and assemblies, especially as an...
Nice power switch
I bought a couple of these to change the original in some mono block power amplifiers. They work just as a switch should do, and the orange LED ring is very discrete. I am happy with my purchase.
Gabriel A.
Le boitier ultime ?
Cela faisait quelque temps que je cherchais un lecteur réseau/préampli/DAC avec quelques caractéristiques spécifiques:
- sorties XLR
- lecteur réseau "open-source", ici avec un Raspberry
- DAC de qualité
- pilotable via télécommande
Je dois dire qu'au vu de la fiche technique, ce modèle était idéal. De plus, chapeau à Audiophonics, vous montrez les mesures et faites tester certains de vos produits sur Audiosciencereview. A l'heure où nombre de marques audiophiles ne montrent quasiment pas de mesures, ça fait plaisir.
Ma chaine hifi: enceintes amplifiées Rowen AT1 (les ancêtres des PSI A215M), lecteur CD usb Asus Impresario, platine vinyle Stanton ST150 (sorties SPDIF). Il faut dire que les enceintes sont très précises et ne pardonnent pas un mauvais maillon.
L'assemblage: est relativement facile pour une personne comme moi qui a déjà monté des ordinateurs. Il y a eu une erreur de vis (la mauvaise dans le sachet) mais c'est entré en ordre avec Audiophonics facilement (très bon service d'ailleurs)
La finition du boitier respire la solidité. c'est beau, on a envie de le mettre en avant. Rien à dire.
La configuration du lecteur est facile, mais étant habitué au monde Windows en X86, allumer et éteindre un ordinateur se fait souvent à chaque utilisation. Ici j'ai eu le souci qu'en gardant cette habitude, le système d'exploitation ne fonctionnait plus au bout de quelques jours. J'ai donc changé la physolophie et je laisse le DAC H24 allumé. J'ai installé l'image Volumio modifié par Audiophonics, cela marche impeccablement.
A utiliser c'est très facile, le produit se pilote facilement. L'utilisation à la télécommande fonctionne très bien.
Le son ? Rien à dire. Il suffit de voir le test sur Audiosciencereview pour voir que ce DAC est très bon. Gros avantage: j'ai littéralement aucun souffle provenant du DAC. Il faut vraiment coller les oreilles aux enceintes pour entendre un petit frrrrrr mais c'est du aux enceintes.
Deux points d'améliorations à mon gout:
1) pouvoir dimmer la puissance des écrans
2) ce souci étant lié à la plateforme raspberry et Audiophonics n'y peut rien: avoir un stockage en SSD via connexion PCI-E. En esperant que le prochain Raspberry 5 le fasse et que son format soit au milimètre près le même que le 4 pour facilement upgrader. En effet, le stockage via micro-sd est assez lent.
En résumé: un excellent produit au très bon rapport qualité/prix.
Maxime D.
Très bon produit, très facile d'utilisation, sur Windows, il suffit d'installer le pilote et c'est terminé. La qualité est top, même sur du matériel bas de gamme, comparé à une carte son de PC, c'est le jour et la nuit. Je n'ai pas encore testé avec du DSD.
C'est vraiment une solution tout en un ce boîtier, plus de problème de son selon l'appareil que l'on branche, du coup pas besoin de se réhabituer.
Michel L.
Mon seul point de comparaison étant les IPods de Apple je ne peux qu’être content
Le rendu est bon le son reste clair la scène sonore a même un peu de relief
Je les ai connectés sur mon ampli casque sédentaire on entend la différence ce qui est également une preuve de qualité
Excellent rapport Q/P
Alain R.
Sheath 100% PTFE Transparent AWG18 Ø 1.0mm This PTFE insulation sheath allows to insulate a bare or already insulated conductor of 1mm diameter maximum. Transparent, it leaves the conductor visible.
Bon produit pour câble DIY.
Je rectifie mon précédent avis.
J'ai écrit que cette gaine était trop petite pour passer un fil de 1mm de diamètre.
En fait, les tolérances de fabrication font que vous pouvez tomber sur une gaine de 0,9mm ou sur une gaine de 1,1.
D'autre part, cela dépend aussi de la longueur que vous voulez gainer. Si c'est 50 cm, c'est assez simple, si c'est plus d'1m ça va se corser. E si vous voulez gainer du fil de cuivre émaillé (qui fait un peu plus d'1mm de diamètre...
Il faut donc prendre en considération tous ces éléments.
Alain R.
J'ai utilisé cette gaine pour isoler un fil d'argent de 0,8mm de diamètre, sur environ 1m.
Pas de problème.
Par contre, elle est trop petite pour un fil de 1mm et pour 3 fils de 0,5mm torsadés. Il faut prendre la taille au dessus, la 1,5mm de diamètre.
Alain R.
PTFE Sheath AWG14 Ø1.5mm Transparent This PTFE insulation sheath allows to insulate a bare or already insulated conductor of 1.5mm diameter maximum. Transparent, it leaves the conductor visible.
J'ai utilisé cette gaine pour enrober trois fils d'argent de 0,5mm de diamètre.
Il faut cette gaine de 1,5mm pour passer ces trois fils de 0,5.
La gaine de 1mm est trop petite.
J'ai passé mes trois fils sur 1m, sans problème.
Alain R.
Très joli connecteur XLR
Je voulais abandonner la connectique dorée et revenir à l'argentée.
Mais l'argent fini par noircir.
La protection rhodium est idéale, c'est dur en surface et ça ne bouge plus.
Le connecteur est parfaitement usine avec une belle finition.
Isolant en téflon pour une excellente isolation.
Il se connecte parfaitement avec l'embase du même fabricant CF201.
Le rhodium est un peu délicat à souder à l'étain. Il faut soit le gratter un peu pour arriver à la couche inférieure argent ou cuivre, soit chauffer un peu fort.
Par de risque, le téflon résiste parfaitement.
La doc dit qu'il ne faut pas un câble de plus de 11mm. Je rajoute que le câble ne doit pas descendre en dessous de 8mm, sinon le connecteur ne pourra pas assurer son maintien, le serre câble intégré s'arrête à 8mm. Il faudra avoir recours à de la gaine thermo si le câble est un peu plus petit.
