Robert g.
Pascal H.
Adrian W.
Killer cable
Beautifully full open ,sweet cable with solid bass,no part of the frequency spectrum is out of place,all presented in a cohesive whole,things appear out of the mix with astounding clarity,but unforced and naturally placed ,just outstanding quality....this occ cable is well made and very affordable when you consider what is on the market,what matters most is its musicality fast open clean clear warm and very addictive ,this cable just sounds right ,one word of caution do change the brass plugs for pure copper ones to get the very best ,i upgrade the banana plugs for the ramm audio Tellurium copper gold plated plugs and it just made a great cable even better....For me the search is over and now my pmc speakers sing freely with these cables .....highly recommended .Zavfino have achieved what they have set out to do with this cable GREAT STUFF.
Adrian W.
Quality
I have tried various plugs and have found Tellurium copper plugs to be the best sounding ,these plugs have a naturalness to them and transmit the sound with ease ,i upgraded the plugs on my Zavfino prima loudspeaker cables with these beauties which made a great cable even better,no brainer buy with confidence sit back and enjoy your music
Serge J.
Borne de masse
Très bon produit conforme à la description.
Francisco Javier R.
Produit de qualité
Parfait pour souder directement les AOP
Francisco Javier R.
Bon product
Parfait! Ils sont également venus avec les soudures effectuées.
Ross B.
Excellent build quality, performance and value for money
I bought the power supply for a NUC that is the core for my Roon setup that uses an Innuos Zenith II as a bridge and an Auralic Vega DAC. Music is stored locally on both the NUC and the Zenith II and I mainly use Qobuz for streaming content. When unpacking the item the first thing I noticed was how substantial and well build it is; definitely built to last. In use it has had a positive impact on the finer details of the sound of my system. The noise floor seems slightly lower allowing for even better resolution of the fine details of the music. Bass seems better resolved and the separation of voices and instruments in all genres of music is more palpable. There also seems to be more richness of tone colour with the nuances of individual performers more apparent. I highly recommend this product as an excellent value for money addition to any NUC based music system.
Patrice C.
Très bon produit et rapport qalité/prix top
Fiches solides, bon placage or, contact fiable, faciles à utiliser.
Fixation du câble par 2 vis très fiable et solide. Gaines thermo pour identification des canaux gauche et droit.
Soyons réaliste, inutile de dépenser plus, même pour un système haut de gamme, ce qui est mon cas.
Philippe r.
produit bien conçu, mais taille limite sur les sorties
Ce splitter est bien fabriqué, et entièrement démontable, ce qui m'a permis de repercer les quatre sorties de 5mm à 7mm pour le passage de mes câbles.
Joël R.
Très bon appareil sauf que...:-)
Sauf qu'un mode d'emploi - si possible en FR ne serait pas inutile, par ex. pour comprendre la fonction EQ. Performances d'ensemble positives mais la connection casque aurait été mieux à l'avant. Beau look mais un peu petit quand même. Télécommande impeccable.
Frederic N.
Interrupteur
Magnifique interrupteur de très bonne qualité.
Frederic N.
bouton poussoir
Magnifique bouton poussoir de très bonne qualité.
Alain K.
OYAIDE Tunami TERZO XX V2
Câble d'un très brande cohérence, résolution remarquable, naturel sans aucune accentuation dans le haut du spectre
Laurent C.
Excellent petit ampli...!!!
Associé à une paire d'enceinte Cabasse "bibliothèque", il se fait très discret dans mon salon, dans le meuble télé.
Associé à mon téléphone en Bluetooth, j'écoute musisque et radio. Relié à la télé, en connexion optique, il me sert d'Home cinéma.
Le son est claire et très largement assez puissant pour une pièce de 35 m².
Bref, pleinement satisfait de cet achat !
Guy A.
HATTOR AUDIO THE BIG Unbalanced Passive Preamplifier Vishay SMD Black / Silver This passive remote-controllable preamplifier with dual attenuators with 1% accuracy SMD resistors offers the latest in sound reproduction refinement. Both passive preamplifier...
Royal
Une petite merveille musicale. Magnifique avec mon Job 225.
Silicone Insulation TO-3P TO-247 for transistor (x10)
"Grip Test" test tip black (unit)
Boutique sérieuse
Conformes à mes attentes, envoi rapide.
Johann a.
Pas mal du tout!
Achat suite au premier avis, et aussi le prix. Monté sur un caisson large-bande DIY (Supravox) à la sortie d'un ampli à tube. Médium riche et équilibré, le haut du spectre s'affirme pas mal. Le bas médium reste cependant plus timide, moins rond. A voir avec le rodage
Johann a.
Abordable et de qualité
Je rejoints les deux premiers avis, beau médium et une belle définition. Se prête bien aux applications "large-bande" et baffle-plan. La clarté du spectre rend cependant le bas-médium moins affirmé. A voir avec du rodage. Merci Audiophonics
Johann a.
Beau, mais...
Produit de qualité, mais attention à la taille de vos câbles car c'est riquiqui 2mm. J'enlève une étoile pour le concepteur, car 3 ou 4mm de câble est envisageable pour la même compacité. Surtout si on garde des entrées opposées comme ce qui est proposé.
Johann a.
PANASONIC FC Low ESR Capacitor 50V 1200μF Panasonic FC capacitors benefit from a high design quality and a low ESR. They will be suitable for most of your projects, whether for DIY creation or as a replacement for...
Un bon maillon!
Les condensateurs Panasonics figurent dans les références de tous bons "recapeurs". Reste neutre et efficace lors d'une restauration d'une platine Hi-end. Merci Audiophonics
Johann a.
Une valeur sûre!
Ami des "recapeurs", c'est le meilleur choix à la fois neutre et efficace pour rajeunir sans se ruiner vos appareils TDA 1540, 1541 et autres. Bref, du Nichicon. Merci Audiophonics
Johann a.
Pas mal!
Pas cher et un peu cheap (la membrane semble avoir été monté en vitesse), je l'attendais au tournant côté sonorité. Verdict, pas mal du tout, branché après des vieux condensateurs en papier huilé. Adepte du planar (en casques), on y retrouve clarté, rapidité et matière. Très bon choix pour débuter en Hi-Fi de qualité sans se ruiner.
Johann a.
Pratique!
Oui, pratique et simple. On espère que ça ne s'oxyde pas vite comme les marques concurrentes. A recommander
Super DSP
L’apport du Dayton DSP-408 par rapport à mon ancien filtre analogique est incroyable. Utilisé pour filtrer des HP grave de 38 cm, son utilisation est simple, et ses possibilités de réglages nombreuses. Aucun souffle, aucun bruit de fond, très musical, l’interface avec le logiciel via PC fonctionne parfaitement. Merci Audiophonics pour les conseils.
Adrian W.
Prima rules
I have lived with Kimber 8vs for 15 years now ,i have tried a fair few cables but always returned to the kimber kable this was because they had a good balance,now i have found a great cable ,these Prima-occ cables are the buisness....they cover all frequency extremes in balance,bass,midrange,treble all presented in a cohesive whole ,fast delivery from what seems like a black background,treble is sweet and you dont have to listen too hard for instruments jumping out of the mix ,the midrange is perfectly matched voices whether male or female they are delivered just as intended,bass is firm and full these cables have certainly made my PMC 25 26 sing ,Zavfino have achieved what they have set out to do with these cables and that is make music,its hard to say goodbye to my Kimbers but with the Prima in place its adios and thank you for years of service....Hello prima many more years to come,Great cable buy with confidence
Christophe L.
Incroyable
Deuxième avis après 300h de rodage. J'ai acheté un deuxième câble pour mon ampli m10, c'est tout simplement de la folie ce câble avec l'alpha 3 qui est très bien c'est comme si il y avait un mur entre les enceintes et moi. La musique est devenue magique je me repasse tout mes cd et je découvre une nouvelle orchestration. Le cuivre occ de l'alpha 3 est beaucoup plus montent avec ofc c'est plus neutre mais il y a beaucoup plus de détails de chaleur c'est complètement envoûtant. Enceinte jm lab diva utopia, audio gd master 10, cd denon 3910, câble uniquement furutech diy le plus haut de gamme, je n'ai pas de dac alors on voit vraiment la différence un he7 viendra bientôt. Bonne écoute
Emmmanuel D.
Tres bien, Mais !
Génial comme petit ampli
fonctionne a merveille avec des Tannoy pbm8
livraison rapide, mais pas le bonne COULEUR :(
Enfin rien de bien dramatique
Jean-Paul S.
MATRIX X-SABRE PRO MQA FULL DECODER DAC USB I2S ES9038PRO 32Bit/768kHz DSD1024 Black With this updated version of the X-Sabre Pro, Matrix offers us a 32bit DAC based on an ES9038Pro chip. This new version adds support for Master Quality Authenticated (MQA)...
Exceptionnel
J'ai reçu mon nouveau Dac un "MATRIX X-SABRE Pro MQA" et je voulais vous faire part de mes premières impressions. En premier la qualité de fabrication est irréprochable digne de modèles coutant 3 à 5 fois plus cher. Côté rendu musical, le gap est très important par rapport à l'Audiophonics , tout deux équipés pourtant, de la même puce "SABRE ES9038 Pro". Heureusement qu'il y a une différence car côté tarif on joue pas dans la même division, 469€ pour l'Audiophonics contre près de 1900€ pour le Matrix.
Côté son, je dirais que ce Matrix est fait pour les fichiers en haute résolution ( HI RES, DSD et MQA ) et là il est loin devant. Une scène plus profonde ou chaque instrument est bien à sa place. Dans un enregistrement en LIVE au moment des applaudissement, on devine la profondeur de la salle et si un applaudissement se détache des autres on pourrait le situer.
Cet AM j'ai écouté un album que je connais bien "Getz At The Gate (live) en qualité MQA, c'était magique. Dans le morceau "52nd Steet Theme" à un moment il y a un solo de batterie, quel pieds ! j'avais l’impression que la batterie était physiquement dans ma pièce d'écoute là devant moi à droite.
Après une cinquantaine d'heures d'écoute je dirais que ce MATRIX est vraiment un Dac audiophile de référence. J'avais jamais eu l'occasion d'écouter des Dac valant plusieurs milliers d'euros, mais je pense que celui-ci est vraiment capable de convaincre des audiophiles très exigeants.
Un grand merci à Audiophonics pour la qualité de leurs services.
Guy M.
J'avais déjà un modèle précédent de fabrication voisine, mais pas en aluminium.
Cette multiprise 6 ports me semble de bonne facture et la mise en place d'un câble (3 fils en 2,6 mm²) accompagné d'une prise Schuko ne m'a posé aucun problème particulier.
La terre a été reliée via une cosse soudée au câble que j'ai installé et vissée sur le plot présent dans la multiprise.
Les câbles phase et neutre ont été connectés sur le bornier prévu à cet effet.
Bref, mon montage est très propre et cette multiprise me satisfait.
Aurélien D.
Installé dans un préamp Rotel, ce module BT me donne pleine satisfaction.
Bonne qualité, fonctionne en 12v sans problème.
câble USB-C
Acheté pour remplacer le câble usb/chargeur d'un téléphone Samsung
Commande
Passée le lundi matin, reçue mercredi matin
RAS
Alix b.
Amplifier Module TPA3116D2 with Tone Control 2x25W 8 Ohm This small complete amplifier module is based on a TPA3116D2 amplifier chip. This allows it to deliver a power of 2x25W under 8Ω. In addition, the architecture of this chip...
Les + : Le son de qualité avec une très faible distorsion même au maximum, la petite taille, la possibilité de gérer les aiguës et les graves fort pratique pour adapter le rendu sonore à vos haut-parleur sans avoir recourt à des filtre complexes, le prix, livrés avec les boutons et les écrous pour une fixation simple
Les - : pas de bluetooth
Alix b.
Tweeter utilisé en remplacement sur des caisson récupéré. L'emplacement des trou était parfaite et le rendu sonore à largement été amélioré en haut médium. J'ai dû élargir le trou de quelques millimètre pour faire passer l'aimant donc rien d'insurmontable. C'est un produit que je recommande pour vos remplacement de tweeter ou réalisation de caisson "à l'ancienne"
Alix b.
produit satisfaisant avec un très bon rapport qualité/prix j'avais acheté par le passé un récepteur plus cher , d'une qualité supérieur mais ne fonctionnant qu'en 12v. Le module ici présent accepte un courant de 5 à 35v ce qui le rend de ce fait compatible avec tout mes projets. En cherchant un peu sur le net je n'ai pas vu de puce Bluetooth permettant une telle liberté. Que dire d'autre? Le bruit est audible quand on y prête attention mais ce coupe en même temps que la musique, la qualité du signal est bonne sans être excellente. Bref, pour ce prix vous ne trouverez pas mieux
Alix b.
haut parleur de 133cm avec une très belle restitution de grave et des voix amples. Le cône est d'une bonne résistance et le montage est facilité par la largeur des trous. Associé idéalement à un petit tweeter le Dayton ND140-4 devrait donner des résultat impressionnant dans tout type de projet
Un ampli de grande qualité
Un ampli avec transistor bipolaire 2x70w d’une trentaine d’années alimentait mes HP grave de 38 cm. J’ai décidé de le remplacer suite aux conseils d’Audiophonics par cet amplificateur Hypex Ncore qui est remarquable, il est très défini avec beaucoup de dynamique et d’impact. Il descent très bas, et apporte beaucoup de profondeur à l’image. Je l’ai essayé dans le médium/aigu (à ruban)pour le comparer à mon ampli MC Intosh KT88 2x 75w ( beaucoup plus cher), l’Hypex est transparent, défini mais je préfère mon Mc Intosh. Ensuite je l'ai essayé sur des enceintes classiques électrodynamiques, il est dynamique, neutre, défini, il est difficile de lui trouver des défauts. L’ampli est bien construit, ne chauffe pas et prend peu de place.
Alexandre G.
qualitatif, robuste et facile à instaler
Très bon produit,
Il faut prévoir au montage, une différence de longueur en raison de l'insertion du fil terre nécessitant 1 cm de plus que les deux autres.
Alexandre G.
Prise murale de qualité, mais...
Dans mon cas, maison ancienne, la prise n'était pas adaptée à la boite d'encastrement de l'époque, une modification/Adaptation a été nécessaire. Par ailleurs les lames de contacts internes sont très rigides. Obligé d'accompagner l'insertion de la prise Schuko avec un tourne vis cruciforme par l'arrière afin d'écarter les lames. L'avantage est une fixation robuste, mais le temps de trouver cette parade, j'en ai abimé ma prise furutech plaqué rhodium toute neuve… Autre détail, une finition noire aurait été apprécié.
Alexandre G.
Matériel de qualité, solide et insataltion "facile", MAIS...
Livré dans une boite alu cylindrique. Matériel, facile à monté, bien que mon câble de diamètre proche du max admis m'a donné beaucoup de difficulté à l'installation. Visserie de qualité, matériel globalement robuste. Cependant, il est clairement indiqué sur l'embout de le prise, qu'il s'agit ici d'un 10A sous 250V et non 16A comme précisé sur le site. Quant à la qualité et la plus value à l'oreille … Je n'ai pas l'info, car j'ai modifié l'intégralité des éléments d'alimentations.
Il s'agit ici des limites de la certification CE.
La donnée constructeur est bien de 16A / 250V :
http://www.oyaide.com/ENGLISH/AUDIO/products_category/power_plugs_iec_connectors/pg472.html
P v.
Amazing price / performance
After being impressed by the performance of its bigger brother, the AMADEUS 5, which I use for power and speaker cable, I bought this cable to make a XLR cable. I used 1 strand per phase, so 1 m of this cable and 2 pairs of Neutrik gold plated XLR plugs was all I needed. A total of around Eu 65.
The sound is very similar to the AMADEUS 5. It creates a very nice 3D space with a very natural rendering of instruments and voices and nice layering. It is detailed but still very musical. Dynamics of my setup has improved, more slam and it has an excellent PRAT (pace, rithm and timing). This presents sometimes a new musical interpretation of some recordings I heard already many times in the past. Amazing... I also compared this cable to some commercial XLR cables I had laying around (some of them 10 - 20 times more expensive) and it beats most of them or plays at least on an equal level.
Highly recommended!
(probably it will also perform very similar to the AMADEUS 5 when used as speaker or power-cord but I did not use it like that so I can't comment on it.)
Connecteur Pile 9V
Très bien.
M'a permis de réparer un équipement dont le coupleur de pile était hs
alexis P.
Quelle Découverte ce FDA _ L'essayer c'est l'adopté !
Pour 95% des enceintes Hi-Fi, si votre source principale est numérique, c'est l'ampli de référence.
2 écoutes m'ont suffi pour enterrer un atoll dac 100se et un marantz pm90se.
La clarté du signal est vraiment palpable. C'est instantané, l'image stéréo est meilleure. La musique plus agréable !
Pour le prix, je recommande cet ampli à tous mes amis !
Les petits + :
+ L'entrée auxiliaire analogique
+ La sortie Sub
+ La personnalisation des couleurs d'affichage
+ Les presets DSP pour donner une coloration au son
+ La sortie casque
Les moins - :
- La taille des borniers HP petit, obligé de passer avec des connecteurs bananes si vos câbles font plus de 1.5mm.
- Le manque de puissance pour des enceintes gourmandes inférieures à 90db de rendement.
alexis P.
Top ! caisson clos de 29l
Vraiment top le caisson clos ! Je voulais un sub home cinéma qui soit propre niveau diffusion. Les modèles basses reflex ne m'ont jamais convaincu. L'autre avantage est la petit taille du caisson, pour une surface émissive d'un 30 cm.
J'ai réalisé la caisse en CP de 22mm avec renforts internes, sans matériaux amortissant. Cote 36 x 36 extérieur. plan Speaker Box Lite.
Le HP est bien fini et a une belle allure si l'on parle d'esthétique.
Je l'ai également utilisé en Hi-Fi sur des sons Electro ! Ça remue vraiment bien tout en restant propre. Top !
Frederic S.
VIABLUE STONE Braided Sleeve 5-13mm This Viablue Stone braided sleeving accepts cables from 5mm to 13mm in diameter, providing effective protection against mechanical stress. Its fine braiding ensures a totally...
The Classe
Il est très beau, il est flexible et facile à à travailler, top.
Frederic S.
Superbe erreur
Acheté pensant que c'était du câble pour relier un élément hifi à une barrette; en fait c'est plutôt fait pour courir derrière les murs "mono brin", j'ai quand même décidé de le monter sur tout mon système: préamp tube/cd drive/alim de DAC, vers barrette.
Primo; j'étais assez septique sur le possible rendu d'un câble secteur, ayant acheté auparavant un sois disant "bon câble", kapton, pour ne pas le citer....Rien: ni sur l'ampli ni sur le préamp ne changeait le son.
Celui-ci, si on accepte un manque de souplesse/torsion assez acceptable, a réellement changée la donne dans mon cas; articulation dans le secteur bas, contrastes sur tout le spectre,simplement.
Thierry B.
Jack 4 pôles
Parfait pour raccorder un micro électrostatique en sortie de préamp (alim phantom) sur l'Ipad de mon fils. J'ai même rajouté un jack femelle en parallèle pour récupérer la sortie casque. Mon fils est ravi !
Le câble de 60cm est un peu court. 30cm de plus eut été parfait !
Et l'équipe Audiophonics toujours au top et très réactif. Merci
Marc V.
Super performance
The iBasso IT01 produce great sound and solid base. Not exaggerated but good.
My only comment: If you have narrow ear canals, you may need to try many of the eartips in order to get a good fit. For my ears, there should be smaller tips included. This is the reason for the 4 stars.
Marc V.
Great result
Excellent little gizmo to upgrade sound on your phone or tablet or computer. If you have spent + € 100,- on headphones or IEM, then the DC02 is a wise investment.
Marc V.
Excellent result for improved audio performance!!
These cables deliver a significant / audible improvement on audio quality: Wider soundstage - more detail - more smooth base, mids & highs.
Overall the cable have a very good build quality. My only remark is that the connectors to the DAC and amp are a bit loose fitting. They don't "snap" in. (That is why I give only 4 stars.)
IMO: if you have a hifi system (dac + amp + speakers) of over € 2.000,- then it is worth to invest an extra 10% in quality power cables.
Fabrice V.
Produit de très bonne facture
Produit reçu rapidement dans un emballage parfait.
Ce da
