Bernard B.
fiio BTR 17
Pas d'ataptateur secteur...
Laurent G.
Petit mais super efficace !!
Alain S.
Vous...
Wayne M.
Jantzen Z-Caps
did exactly what i wanted these to do used in crossover with fantastic results, really brought my vintage speakers alive onced more to live on
Wayne M.
Jantzen Z-Caps
Wayne M.
Jantzen Z-Caps
Peter W.
Great Unit
Good build quality. All metal with rubber feet. Even the selector knob is metal. I think though the ABCD letters above the selector should be more clear. Perhaps in red? The unit was well protected in the shipping box. Recommended!
Andrea M.
AUDIOPHONICS DA-S125NC Class D Integrated Amplifier NCore NC122MP DAC ES9038Q2M Bluetooth 2x125W 4 Ohm 32bit 768kHz DSD256 Versatile and powerful, we offer you with DA-S125NC an integrated amplifier with digital inputs to which you can add speakers to enjoy your music in the best possible way....
Great product
Purchased to pair with B&W bookshelf speakers in my bedroom system.
Fantastic DAC + ampli combination for both sound and ease of use (small footprint and clean, no frills industrial design) at a very attractive price. Connected to a DVD player and an Apple TV using coax and optical (Apple TV is also used to stream music from Qobuz app). Power is more than adequate for the room and speakers used, which never sounded so good. Highly recommended.
Very good service by Audiophinics (advice, fast shipping, support), as always.
Andreas P.
SMSL PO100AK USB Interface XMOS XU316 DAC AK4493S 32bit 768kHz DSD512 MQA The SMSL PO100AK is an extremely powerful and incredibly compact USB interface with integrated DAC. Despite its small size, the PO100AK is based on an architecture using high...
As a dac
The first impression is that it has a serious problem with the stereo cross talk;huge difference between left and right and generally not the warm sound you would expect from an asynchronus usb dac.Also do not use the included cable as it makes the problem worst.
Jean Marie L.
TOPPING E30II
Très content de ce DAC, paraît encore plus analytique que le D50s Reste que cela nécessite une très bonne source sonore, sinon mieux vaut du plus coloré...
Pour ceux qui n'ont pas besoin de BT c'est top à ce prix
L'entrée USB est bonne et en entrant en coaxial avec un DAP c'est super
En plus l'alim et la Télécommande sont identiques au D50s ce qui m'a permis de d'avoir des pièces de rechange.... Content surtout que la TLC du E30 fonctionne bien, ce qui n'est pas toujours le cas de celle du D50
Merci à Audiophonics pour la qualité de ce qu'ils proposent et sur leur sérieux
Franck P.
TRIANGLE OPERA OS100C Speaker Cable OFC Copper 2x4mm² Developed by Triangle, Opera speaker cables guarantee excellent electrical signal transmission quality. To achieve this, they incorporate braided OFC copper conductors, each...
Pierre-Marin L.
Je pars d'une barette Sopra avec filtre, le remplacement par la stealth (non filtrée) a clairement muté le son, mais je pense que la raison fondafentale en est que les Ifi AC purifier font mieux leur boulot sur une barette non filtrée, je pense aussi que mon Audio GD Master 7 Singularity préfère aussi ne pas être filtré. Bref un saut de qualité extremement important du à l'abandon de la barette filtrée, et sans doute aussi à la qualité de cette barette.
Philippe H.
Musicalité avant tout
A peine le montage sur Viborg pur cuivre terminé, installé sur mon DAC Hegel HD30 ça sonne déjà, naturel, extrêmement nuancé dans le jeu, très différencié dans les timbres … quelques jours après, la scène sonore est stabilisée, davantage profonde que large, le retour en arrière sur Zavfino Majestic est tout simplement impensable.
Guillaume B.
très très bien
Les amplis ronflent un peu trop fort par moment, j'ai donc acheté 2 DC Blocker, le bidule y marche bien, dit donc! y ronflent plus les n'amplis!! super!!
Merci à Audiophonics d'exister pour nous proposer des produits utiles et de qualités, bravo!!
Guillaume B.
Quel très bon conducteur neutre ET entier!
Choisi pour son architecture et ces matériaux, avec 2 x 7m de longueur entre des JBL 260TL(entièrement refiltrée) et les blocs mono XA-220 Advance, l'ensemble de la bande de fréquence est entendu et ressentie!
Pas de déséquilibre désagréable ou flatteur, je n'y trouve pas de défaut rédhibitoire ou légèrement gênant, la puissance et le message passent avec quiétude de la mélopée lyric au concert de boeufmetal, tout ce tiens sans bousculade, un véritable élément hifi.
Je recommande vivement!!
Pierre N.
AUDIOPHONICS TPA-M50 Class D Mono AmplifierTPA3116 1x60W 4 Ohm Black The Audiophonics TPA-M50 is a compact amplifier with a low price but very good sound performance. The TPA-M50 is based on an amplification chip TI TPA3116D2 capable of...
Deuxième nuance
J'ai changé le câble RCA vers mini jack entre le DAC et l'ampli par un câble de 0,5 m au lieu de 2 m et cela a très nettement diminué le bruit de fond.
David S.
1877PHONO FUSION PURE RCA MKII Modulation Cable PC-OCC RCA-RCA (Pair) 1.5m The Fusion cable series is the perfect integration with pure silver strands and Japanese monobrin PC-OCC copper. Designed with rigour and great precision, this Fusion series has...
très bon câble RCA
Utilisé en sortie d'un préphono, la liaison vers l'amplificateur est à mon avis primordiale. Câble neutre, transparent et détaillé, sans perte d'énergie, avec beaucoup plus de définition dans les graves que mon câble précédent.
Excellent rapport Qualité/Prix, la rigueur de fabrication se retrouve à l'écoute, sans tomber dans une tranche de prix délirante.
Julien R.
SOVTEK 12AX7LPS Twin Triode Tube (Unit) This Sovtek 12AX7LPS dual triode tube is a dual triode offering high linearity, making it an excellent replacement for a 12AX7 tube.
Un bon tube avec une tonalité linéaire et précise.
Vincent D.
WONDOM JAB5 AA-JA33286 Amplifier Module Class D Bluetooth 5.0 DSP ADAU1701 4x100W 6 Ohm The JAB5 is an integrated 4-channel audio amplifier board with Bluetooth 5.0 (aptX HD support) and DSP ADAU1701, offering a true all-in-one audio solution. It delivers 4x100W of...
Very powerfull amplifier!
This is a very good and powerfull amplifier. The integrated DSP allows you to tune your speaker very nicely. For programming the DSP please use SigmaStudio and not their own Miumax software. The Miumax software cannot write the config to the amplifier itself but only store it in the ICP5 programming module. So you have to keep it connected which causes a very loud pop when you turn on the amplifier and causes crackling/popping noises at a louder volumes.
If you use Sigmastudio, you can write the config to the amplifier so it will be saved if you turn off the amplifier.
The amplifier itself is build very nicely. I can't hear any hissing noise when it is turned on! It also does not give a feedback signal when you connect to it via bluetooth or power on the amplifier. For me this is a good thing, since i don't like the feedback tones and voices that most chinese amplifiers have.
Overall, for the money this is a very good amplifier board with a lot of functionalities!
Ken P.
Absolute reliability
My dealings with audiopnoics: Australia to France, have been reliable in every way possible, Thanks.
Lubos S.
HoloAudio Spring 3 level3
So this is the second best DAC I've heard. The first is an order of magnitude more expensive MSB.
This thing plays way better than my own Accuphase DP750.
And I really didn't expect that.
It excels with HQPlayer on DSD 256-512 via USB, but is also excellent on 44.1/16 via coax.
It is good to play Holoaudio for a few days, the sound improves.
FURUTECH Alpha-S14 Speaker Cable µ-OCC Copper Alpha Treatment 2x2mm² Ø8.9mm This FURUTECH Alpha S14 speaker cable in multi-strand OCC copper with Alpha treatment (anti-magnetic, cryogenic) is an elegant solution. Here's a simple, effective loudspeaker...
Je laisse mon avis pour confirmer l'avis précédent. Sa section de 2mm ne l'empêche pas de délivrer un message plein avec une belle scène, riche en timbres, détaillé, et avec une belle dynamique jamais fatigante. Dommage qu'il soit si cher ici, je l'ai trouvé à 2 fois moins cher mais je vous le recommande.
GILLES G.
Nette amélioration de la qualité sonore
Envoi rapide et soigné. La qualité sonore de mon système (Atoll DAC200 Signature et IN200 Signature + JM Reynaud Cantabile Jubilée) a été nettement améliorée. Meilleure présence des basses, ainsi que plus de clarté et de détails dans l'ensemble du spectre sonore. Je recommande fortement cet investissement.
Laurent B.
Excellent dac
Je me suis fié aux avis et je ne suis vraiment pas déçu.
Superbe qualité de fabrication, UI fluide et ergonomique et qualité sonore top niveau en sortie de carton.
Un vrai plaisir à l'écoute, très détaillé sans être analytique, soundstage très large et chaque instrument est à sa place. Couplé à un ampli Pathos Aurium c'est vraiment du bonheur!
J'ai failli prendre un Gustard A26 mais je ne pense pas que j'aurais eu plus de plaisir pour presque le double du prix.
Bravo à Eversolo et à Audiophonics toujours aussi sérieux.
Tero S.
Soundstage monster
This has one of the biggest soundstages iw heard. Also instrument separation is far superior to almost any THX AAA based AMP.
BLACK background, sounds just happen all around you.
BUT needs absolutely top notch DAC to get most out of this.
Vincent P.
DD TC44A DAC CS43131 Male USB-C to Female Jack 4.4mm 32bit 384kHz DSD256 This TC44A DD adapter for smartphone is composed of a male USB-C connector and a female 4.4mm jack. It also includes a CS43131 DAC for efficient conversion of the audio signal...
Très bon rapport encombrement / performances
Excellente qualité de fabrication, encombrement minuscule, son clair et détaillé, signature sonore neutre... Ce micro DAC/AMP fait très bien son boulot, il drive correctement des intras ou des casques à faible impédance.
Lubos S.
SMSL SU-8S Balanced DAC ES9068AS USB XMOS 32Bit 768kHz DSD512 MQA The SMSL SU-8s is a symmetrical DAC featuring the new ESS ES9068AS digital to analog conversion chip. This last one supports high sampling rates, up to PCM 32bit 768kHz and...
SMSL SU-8S
DAC suitable for high-quality active PC speakers.
It doesn't seem like a suitable adept for a large lineup, but absolutely ideal for a PC.
I run it with a Genelec 8330CP speaker via XLR and the sound is fine.
Lubos S.
SMSL D1SE Balanced ES9038PRO DAC CPLD Altera XMOS 32bit 768kHz DSD512 Black The D1se from SMSL is an extremely powerful DAC, based on a symmetrical architecture using a high-end ESS ES9038Pro digital to analog conversion chip. Taking advantage of a...
SMSL D1SE
Big surprise for little money.
I bought this DAC for my weaker setup that I run in my studio.
Minimac M1- HQPlayer- SMSLD1SE- Accuphase E210 - Wharfedale Linton Heritage.
The performance is excellent, the sound is more reminiscent of something between an AKM and R2R than a Sabre.
Surprisingly, it held its own even in my large home setup, but there it competed with the much more expensive Accuphase DP750 and yes - it lost.
But the difference was not abysmal.
It is a suitable DAC for a set (amplifier, cables, loudspeaker) with a total value of around 5,000 EUR.
Alain S.
Avis de Paul G totalement faux
Vous pouvez apprécier le produit pour ce qu'il est mais dans la réalité des faits il est parfaitement possible de faire beaucoup mieux pour beaucoup moins cher.
Ce produit n'est qu'un SOC à 50 € dans une boite sans avoir l'évolutivité logiciel et hardware des susnommés "system on a chip"
Sans parler du fait qu'il soit bloqué sur Volumio la seule solution out tout est payant ...
Excellent streamer dans un tarif contenu, gagne à y ajouter une alim linéaire. pour faire mieux il faut y mettre beaucoup plus cher.
Parmis la meilleure connectique RCA
Excellents connecteur neutres qui se font totalement oubliés sur le trajet du signal, 5 étoiles très méritées
Un must
Certainement un des meilleurs conducteurs électriques il le fait aussi bien en CS qu'en strapps HP.
Merci Néotech et Audiophonics de nous permettre de disposer d'un aussi bon conducteur
Mario V.
ELECTRO-HARMONIX GOLD 2A3 Power Tube Platinum Gold Plated Grid (Matched Pair) The high quality Electro-Harmonix 2A3 power tubes are tubes with direct triode heating by oxide cathode. They are ideal for a low frequency power amplifier in the amplifier...
Lampes fantastiques.
Bonjour, je viens de recevoir les tubes EH 2A3 et je les ai déjà montés sur mon ampli, le son est déjà fantastique, sans préchauffage, supérieur en richesse harmonique et en détail par rapport aux Golden Dragon en ma possession.
Je tiens à vous remercier pour le service rapide et courtois et j'ai hâte de faire d'autres achats dans votre boutique.
Joyeuses Pâques et salutations d'Italie!
Mario V.
Pascal P.
Génial
Petit objet très efficace : j'ai vraiment gagné en clarté du son, moins de dureté, un rendu plus analogique. De mes 4 connexions USB et/ou Xmos, c'est la meilleure. En plus il fonctionne sans alimentation et peut donc être nomade : super bon avec mon téléphone. A 75 € il ne faut surtout pas s'en priver.
Bon sélecteur de source.
Un bon sélecteur de source, assez massif, mais qui n'est pas donné. Pas d'effet sensible sur le signal, au sens positif: c'est propre, sans atténuation. Utilisé pour switcher le signal de mon DAC SU-6 (très bien, Audiophonics aussi) entre preamps à tubes ou en direct sur mon Pioneer A30-K
Bon et élégant petit préampli
Un bon et élégant petit préampli (c'est comme ça que je l'utilise). Le son est propre, clair, détaillé. Cependant il est moins "tuby" que d'autres preamp, comme le Tube 03 de FX Audio. Pour le "roulement de tube", les tubes installés dépassent peu, et sont un peu difficiles à retirer cependant (actuellement j'utilise des Sylvania des années 60).
Fabulous cable
For CD source, I decided to replace my Oyaide Tunami cable with this cable terminated with IeGO silver plated IEC/Schuko. My experiment has paid off.
The sound has developed even more detail than before while opening up slightly. As magnificent as the Oyaide was, the sound is a very heavy one, where the Noetech presentation is "lighter" without losing any coherency.
I cant wait to hear the result in a few months after burn in. The cable has less than 20hrs on it and the improvements are very noticeable. A very worthwhile investment.
Helmut M.
DYNAVOX Speaker Cables 2m
fast delivery
very solid cable !
good quality !
Elsa A.
Switching Power Supply Module 700W +/-60V This LLC switch mode power supply module has a main output delivering ±60V. The resonant circuitry uses a high frequency sine wave, ensuring excellent stability and a...
SMPS
Excellent rapport Q/P, tensions vérifiées : très propres . Encombrement réduit . parfait pour modules UCD 400.
J'aurais préféré des sorties principales sur faston plutôt que sur borniers à vis, à voir sur la durée.
Helmut M.
WIIM Pro
fast delivery
I'm using Android
Connection with Coax to my Amplifier with built-in DAC.
I tested successfull internet radio and DLNA streaming
from my server (minimserver) with a lot of flac-files (16 / 44.1)
gapless playback works very well.
browsing through my big flac-library works fast.
very good!
the WIIM Pro is also detected from other DLNA control-software
for example "Audionet Remote Control Point RCP" for windows 10
gapless playback works her as well.
I like the WIIM Pro device
Pierre N.
Bruit résiduel.
Je nuance mon premier avis car comme cela a déjà été signalé il y a un bruit résiduel quand on pousse le volume. Mais comme l'ampli est très puissant ce n'est pas nécessaire.
Pierre N.
Génial
Je viens de le recevoir. L'alim commandée séparément est plus grosse que l'ampli. Il est connecté sur une enceinte pour TV mono. Grâce à la fonction sommateur G+D les voix sont plus lisibles que si il n'y avait que la voie gauche ou la voie droite. Auparavant j'utilisais un SMSL AD18 que sur une voie. Le son est bien plus précis dans tous les registres et me semble équilibré sans agressivité. Dans la limite de l'enceinte qui n'est pas une haut de gamme (100€). Le test a été fait avec la sortie Toslink de la TV, puis un DAC SMSL à 200 € avant l'ampli. L'amélioration vient donc de l'ampli mais aussi du convertisseur puisque avant le SMSL AD18 faisait les 2.
Daniel C.
La qualité de la prise RCA est indiscutable, cependant, il serait pratique que la rondelle en plastique corresponde à la couleur de la fiche en question (rouge ou noir) pour faciliter le branchement. Idem pour la couleur de la matière dans la prise
Mathieu J.
1MII LAVAUDIO DS200 PRO Bluetooth 5.0 Receiver aptX LDAC CSR8675 DAC ES9018 Black The 1Mii DS200Pro is a compact and powerful Bluetooth 5.0 receiver, using a Qualcomm CSR8675 Bluetooth chip. This one is compatible with the codecs of high resolution...
2eme en commande
Le son est excellent pour écouter les redifs arte concert sur youtube depuis le laptop ou le portable. Mes deux chaînes seront équipées
Patrice J.
Voltage Display Voltmeter with Green LED 60-500VAC Ø22mm This voltmeter will allow you to monitor the voltage of a device. Its green LED display is easy to read. The voltmeter accepts voltages from 60VAC to 500VAC. Its...
Comme à son habitude Audiophonics vend d'excellents produits.
En ce qui me concerne une erreur de la part d'Audiophonics a été commise sur cet article, son SAV s'est empressé de me le remplacer dans les plus brefs délais.
Merci encore à Audiophonics pour sa bienveillance au service de ses clients.
Daniel P.
Conception vraiment nulle
Le son est bon, mais pour le montage... Pour la phase et le neutre on peut mettre du 5mm, et pour la masse c'est tout petit, et ce n'est pas le même mode de fixation. C'est n'importe quoi, je ne comprends pas cette marque. Quand au serre câble, là aussi, il faut avoir l'esprit tordu. Pour moi, Neotech c'est terminé.
Helmut M.
WIIM Pro
fast delivery
Connection per Coax to my Amplifier with built-in DAC.
I'm using Android
I tested successfull internet radio and DLNA client
access to my server (minimserver) with a lot of flac-files (16 / 44.1)
gapless playback works very good.
browsing through my big flac library works fast.
very good!
the only missing thing is a windows client from WIIM Home.
therefore I use "Audionet Remote Control Point RCP" as player on win10.
it detects the WIIM Pro as DLNA client and plays my flac-files gapless.
Helmut M.
WIIM Pro
WIIM Pro
fast delivery
I'm using Android
very good!
Mathias S.
Parfait en sim racing
Parfait pour du simracing piloté par Simhub.
J'en ai 2, peut être un 3eme et c'est assez impactant comme résultat !
connexion facile et rapide.
Helmut M.
WIIM Pro
fast delivery. device works fine.
I testet Internet Radio + local music library (UpNP/ DLNA) per coax
I have have a large library with flac files 16 Bit 44.1 kHz
scrolling through the library is very fast
gapless playback works fine. PERFECT
Pedro P.
Indispensable !
Installés sur mes amplis AUDIOPHONICS LPA-S400ET, la symbiose est parfaite. Après avoir essayé des OPA1656 et 1612, j'ai voulu essayer ces petits joyaux sans trop en espérer, j'avoue... Grand bien m'en a pris, c'est juste le passage vers un autre monde, celui qui passe de la très très HiFi à la musique pure tout court ! Il a tout, le détail, la patate et la musicalité et mon sourire d'audiophile comblé :) Que la musique commence !
Pedro P.
Fabuleuse résolution, impressionnante dynamique et musicalité !
Autant ne pas tourner autour du pot, cet ampli est fabuleux ! D'ailleurs, ce n'est pas le premier que j'achète car ils sont destinés à mon système actif. D'abord, je tiens à dire qu'avec les OPA fournis, il est déjà excellent, je les ai remplacés par des OPA1656 (un peu mou) puis des OPA1612 plus dynamiques. Aucun n'a vraiment réussi à me convaincre à 100% aussi je me suis (en me pinçant un peu le nez) laissé tenter par les SPARKOS LABS SS3602 et là, comment dire, ça sonne comme aucun ampli que j'ai pu avoir ou écouter auparavant. Cela inclu des amplis à tubes, MosFet Class AB (Holton Precision Audio) et mes précédents Class D qui avaient chassé les anciennes technologies. Pour rester bref et ne pas tomber dans le lyrisme, cet ampli mérite les Sparkos pour en tirer la plus haute musicalité possible. Mes HP sont tenus comme jamais, on pousse le volume et le bonheur monte d'un cran, le son est pur, extrêment défini et pourtant jamais fatigant, c'est ni chaud ni froid, c'est tout simplement pur (non, je ne vais pas faire un jeu de mots là). Bravo à Audiophonics, cet ampli est une totale réussite, très bonne qualité de fabrication/finition à un prix raisonnable qui ravira les plus exigents d'entre nous.
