didier N.
ok
Benoit d.
Robert C.
It is difficult to...
Customers reviews - There are 19629 reviews.
romuald m.
adaptateur de qualité.
top pour le DAC Chord Qutest.
romuald m.
Audio Extractor HDMI 5.1 to HDMI / Optical / Jack HDCP2.2 HDR 4K 60Hz ARC This extractor / splitter can support 4 HDMI input signals. Video output is 4K 60hz compatible with HDR and Dolby Vision support. The HDMI audio output allows DTS-HD, Dolby...
Extracteur au top.
m'a permis de prolonger la vie de mon préampli Yamaha CX-A5000 qui ne supporte pas le 4k 60Hz HDR de mon Apple TV. J'ai maintenant une image au top sur ma TV Philips Oled et profite du son HC de mon ensemble.
merci à Audiophonics pour les conseils. Top.
Terrific little banana
I swapped out WBT pure silver spades at one end and silver plated copper bananas at the other of my Neotech OCC copper speaker cables, and the sound is BETTER than previous. There is more sparkle and the music is just more believable than before with zero burn in.
For me, this makes no sense given that silver is a better conductor and usually imparts a finer sound than copper.
Service from Audophonics was top as usual. Had the kit delivered from France to Ireland in less than a working week. Trés bonne.
Sylvain M.
OCTAVIO STREAM Streamer Bit-Perfect WiFi AirPlay 2 Bluetooth 24bit 192kHz Octavio offers with the Stream an improved version of its first streamer model. Extremely easy to use, it is designed to modernize an existing HiFi system by transforming it...
Très bon achat !
Ravi de mon achat. Petit, sobre, simple à installer, il est compatible avec pas mal de services différents (Spotify Connect, Airplay,etc). A l'écoute je n'entends pas de différence avec mon Denon AVR bcp plus couteux (connecté à un NAIM 5S) donc c'est parfait ! Hâte de voir ce que ca va donner si Spotify nous sort un mode HiFi lossless :P
Pär L.
TOPPING D30 PRO Balanced DAC 4x CS43198 32bit 384kHz DSD256 Black Powerful and compact balanced DAC, the digital-to-analog conversion stage of the Topping D30 Pro is based on no less than four Cirrus Logic CS43198 chips. These enable it to...
Substandard product
This DAC does not work with some CD players/transports. According to Topping, this depends on the DAC's hardware. Note that the same CD player works with other DACs, but not with this one. This is a known issue that has been discussed a lot on AudioScienceReview. In my opinion, the D30Pro is therefore a substandard product that should be withdrawn from the market, or at least potential buyers should be informed of this problem before purchase.
Modern dacs weren't really designed with this type of low res source in mind.
Many sources using SPDIF toslink are also problematic (mostly "mass market" devices).
après avoir une petite panne sur l'interrupteur Audiophonics à été très réactif posté une autre gratuite super 5 étoile merci !
Matteo A.
LIVELLO TOP
Funzionano alla perfezione.
Siamo ai massimi livelli di trasmissione del segnale....
Inalterato...
SUPER CONSIGLIATI
Matteo A.
Super prodotto
Resa sonora eccellente, molto dettagli, pulizia migliorano tutti i parametri sonori.
Rapporto qualità prezzo prestazioni altissimo...
ALTAMENTE CONSIGLIATI
Radek P.
Hallo
Clean, detailed, transparent. But there's something missing on the higher bass
Jean Claude L.
Heat-shrink tubing 3:1 Ø12.7mm Transparent (1m) Thermo-retractable sheath with a ratio of 3: 1, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic, rubber, metal ...)
La qualité
Gaine d'excellente qualité, pour un résultat parfait.
Finition très pro
Jose l.
très bon son
très bon pour le prix , rodage obligatoire min, 50 h.
Luc T.
AIYIMA A200 Class D Amplifier TPA3255 2x180W 4 Ohm Bluetooth 5.0 Aptx-HD The Aiyima A200 is a powerful and affordable Class D stereo amplifier. It is based on a TPA3255 amplifier chip and a NE5532 AOP.
vers le Graal
Permettez-moi l’expression « je suis sur le cul » pour le prix et son poids, c’est 1,6 kg de précision et de puissance.
Cela fait un peu plus d’un mois qu’il excite mes Resound RS215 et jamais auparavant je n’avais écouté un ampli qui reproduisait une telle richesse de timbres et ce dans tout le spectre audible, les voix sont charnues et avec beaucoup de charme, les basses sont percutantes et d’une tenue exemplaire, les aigus d’une finesse redoutable, bref, what else !
Je redécouvre ma bibliothèque musicale, il délivre les informations avec une justesse chirurgicale.
Il lui manque juste une télécommande pour ressembler au Graal.
Je peux en conclure, en fonction de mes goûts « audiophile », que cette petite boîte est un instrument de musique à part entière.
George R.
Not the best DAC preamplifier & headphone amplifier on the planet, but excellent value for money!
I was more than a little bit surprised as to how good this unit sounded - especially after adding an Audiophonics linear PSU. With the standard switch-mode PSU supplied, the unit had the tendency to sound slightly thin & edgy, but the linear PSU addressed both of those minor concerns. Quite frankly, this level of performance would have cost in the region of €1,000 10-years ago! Yes, the remote is very critical of direction and the headphone socket is only 3.5mm, but these are minor observations and not real concerns. The automatic display mode is beneficial for late night listening.
George R.
Definite upgrade to Topping DX3 Pro+
To my ears, this linear PSU eliminated the tendency of my Topping DX3 Pro+ to sound slightly thin & edgy. Definitely worth the money. The only downside is the ridiculously bright white LED on the front panel.
Fabien F.
Stereo Amplifier Class D TPA3251 2x140W 4 Ohm This affordable Class D amplifier is based on a TOPA3251D2 amplifier chip, ensuring a power of 2x140W under 4Ω and this with high efficiency. It will therefore have no...
Très bon ampli - pourquoi mettre plus cher?
Je l'ai alimenté par une carte SMPS300RS 36V qui alimente 2 de ces amplis en fait (je pilote 2 enceintes actives), sur des HP 6-8 Ohm. La puissance de 300 W suit.
Concernant la taille des connecteurs de sortie: aucun soucis si vous utilisez des prises bananes.
Les Ampli OP sont soudés directement, donc si vous voulez les changer, pas évident. Je n'en éprouve pas le besoin: le souffle est inaudible sauf si vos enceinte sont à 50 cm de vos oreilles.
Fabien F.
SMPS300RS Switching Power Supply Module 300W 36V The Connex SMPS300RS is a half-bridge resonant switched-mode power supply (SMPS) capable of delivering 300W continuous and up to 360W peak. It is configured for a 36V output...
Bonne alim
Je l'utilise pour alimenter 2 amplis classe D TPA3251 connectés à 2 enceintes 2 vois actives. Tres silencieuse, mais je ne peux pas dire si avec une alim plus bas de gamme ca serait moins bien ...
Attention: la doc de l'alim décrit la version 2x36V (+36 / 0V / -36), ajustables avec un potentiomètre. La version que j'ai reçue est 1 sortie +36V fixe. Ce qui me suffit.
Michel B.
Dac Audiophile
Acheté il y a 1 an, ce petit boitier a remplacé mon ampli casque à tubes(6v6) + ampli tubes(el34)+Dac (DIY) et ainsi j'ai redécouvert des cd ou musique dématérialisée, mes différents casque Grado me disent merci. Sur mon systeme audio principal le résultat est moins bluffant, une légère tendance de surbrillace de l'aigu, Mais dans l'absolu ce Topping remet en cause mes 50 ans d'audiophile et d'écoutes de matériels qui ferait rêver plus d'un...
Donc un grand merci à votre équipe qui a su m'accompagner et conseiller pour mon achat il y a 1 an ...
PS: Le DX3+ fonctionne toujours sans aucun bug et l'installation sur plusieurs PC et Mac s'est toujours fait sans problème de pilotes ou de compabilité.
Holger L.
Super clean amp, lots of power, yet a decently low idle wattage. Great value for money.
My buying experience with Audiophonics was very good: detailed and instant replies to my questions, and updates on the shipment (1 day UPS shipping from France to Denmark).
Nice case and neatly done inside. Everything looked stellar. All torques screws had equal pressure, which satisfied my OCD.
Set the jumpers for bypass for best SNR. Super clean amp, lots of power, yet a decently low idle wattage. Great value for money.
Buying another one probably.
Gustavo M.
So Far So Good!
I am from the US (east coast). Ordered on a Wednesday (before 11 am UTC) and got it Friday morning!!! Unbelievable delivery speed!!! Ordered some cables at the same time from Amazon (I have Prime) and got them Saturday...
Regarding the amplifier, too soon to tell, but so far it's working great. Amazing audio and excellent built quality! Congratulations AudioPhonics!
Serge V.
A2DC Connector Gold Plated Ø3mm Black (Pair) This A2DC connector will allow you to create your own HiFi headphone cable. Beautifully made, it benefits from gold plated contacts, ensuring very good conductivity and...
pas pour ADX5000
Bons connecteurs mais incompatibles avec le casque Audio-Technica ATH-ADX5000
Christian D.
Magnifique ampli dac qualitatif et peu onéreux.
Le boitier lui même est bien plus esthétique que je m'y attendais.
Très pratique, bouton en facade, alimenté par Usb. L'ampli est surprenant. Largement assez puissant pour mes casques 32 et 250 Ohms. Les mesures montent une qualité de reproduction du Dac bien supérieur à ce qui est audible à l'oreille humaine. Donc parfait de ce coté. L'ampli lui même, je ne vois rien à lui reprocher. La garantie étant prise en charge par Audiophonic, je suis tranquille en cas de soucis. Pour finir, la livraison a été très rapide comme d'habitude. Aucun regret pour cet achat que je suis près à renouveler en cas de besoin.
Michel V.
Câble RCA-RCA ELECAUDIO.
Rapport qualité-prix imbattable. L'aigu est doux, fin et dynamique à la fois, donc sans agressivité, et le bas-médium est dégraissé et articulé, ce qui va généralement ensemble. J'émets cet avis sur la base de l'écoute sur mon système bi-amplifié 4 voies fait maison à haut rendement (on dit aujourd'hui :"DIY" et jadis : "home made"), dont les tweeters sont débafflés et calés en profondeur, donc en valeurs temporelles et non angulaires modulo 2 "pi".
ATTENTION : à la première écoute, on est très déçu pendant quelques minutes, mais ensuite le rodage produit son effet bénéfique, et plus tard on ne peut plus revenir en arrière. Mais la vie, n'est-ce pas aller de l'avant ?
VAGNER Michel, 68 ans, musicalement incurable depuis mes premières armes en 1967 (13 ans à l'époque...).
Michel V.
Condensateurs 100µF Mundorf.
Condos rares dans cette gamme de valeurs, tant en tension, généralement limitée à 450v, qu'en capacité. Ils permettent d'établir des alimentations de très faible résistance interne, ce qui est indispensable à la fermeture sur eux-mêmes des courants modulés et permet une meilleure assise des graves associée à une moindre "pollution" des aigus, ce qui va généralement ensemble.
En tant que condos chimiques, ils ne présentent pas de dureté particulière qui pourrait amèrement faire regretter la mise en œuvre alternative de condos "polypropylène", ces derniers exigeant une grande place pour les caser.
Donc une valeur sure à retenir au même titre que les "Silmic II".
VAGNER Michel, Moselle.
Rémi L.
MINIDSP IR V2 IR Remote Control NanoSharc / MiniSharc / Open DRC / DDRC88/22/24 / NanoAVR-HDA / SHD This MiniDSP IR Remote V2 is pre-programmed for use with the brand's devices. No configuration is therefore necessary.
Prfait
Fonctionne parfaitement dés la première configuration avec un NanoDigi. Efficacité supérieur à mes attentes, même pas besoin de pointer la télécommande vers le mini DSP.
Francois P.
FURUTECH HF-X-NCF HDMI 2.1 Cable 8K/60Hz 4K/120Hz 48Gbps HDCP2.3 eARC HDR10+ Silver Plated OFC Copper 1.5m Furutech offers with the HF-X-NCF a high-end HDMI cable, compatible with 4K/8K 48Gbit/s and incorporating the know-how and attention to detail of the brand.
Est supérieur à un câble HDMI Wireworld Silver Starlight niveau image avec des noirs profonds, un contraste amélioré. Côté son, c'est aussi très bien. Rien à redire.
David G.
excellent transport
que dire, un excellent transport qui apporte precision et surtout une scene sonore 3D et une scare transparence !
Eric L.
AUDIO-GD DI-20HE Digital Interface Amanero Accusilicon 32Bit / 384kHz The Audio-GD DI-20HE interface is based on an Amanero Combo 384 USB module coupled to a pair of Accusilicon 90/98M clocks. The circuit is designed to offer a plethora of options...
Impressionnant
D’abord merci à Audiophonics pour le sérieux et l’efficacité.
Commande lundi , produit livré jeudi.
Produit installé et déjà plus de détails, de douceur. Tout est en place et ce n’est que le début. Mon dac naim n’en revient toujours pas et encore je n’ai pas d’alimentation spécifique desssus.
Le bel canto ulink est enterré et pourtant il est vraiment très bien.
Merci encore
Eric
TRES EFFICACE
De tous les produits de nettoyage que j'ai essayé c'est le meilleur . Un réel gain de netteté de son vraiment audible sans avoir à tendre l' oreille . Très peu de produit suffit à chaque utilisation.
Julien N.
Merci à l'équipe d'audiophonics de nous proposer une excellente alimentation linéaire... Reçu il y a 3 jours à la Réunion grâce à une livraison rapide vers la métropole et rapporter dans la valise ...
Sur mon humble système celui-ci alimente mon lecteur réseau dac nuprime et à rendu celui-ci un cran meilleur avec des extinctions de note réel, un meilleure détachement de la voix ainsi que quelques micro détails d'enregistrement jusqu'à aujourd'hui non entendu... Je continu à commander sur votre site, peut être un jour des tarifs plus intéressants sur les colis feront sauter le pas à d'autres acheteurs ????
Joachim D.
Upgrade music hall dac 25.3: Objectif atteint!
En remplacement donc des OPA's Burr-Brown classiques montés d'origine sur ce dac: Le gain est considérable en terme de définition et de scène sonore. Fini cette purée sonore insaisissable dans les passages musicaux plus fouillés!
Je recommande pour ceux qui veulent faire monter leur système d'un cran sans passer par la case achat d'un nouveau dac de gamme supérieure...
Filip M.
Didn't expect that much of a difference. Simply amazing speaker cable, makes listening a lot more fun. It would be a good idea to get some pliers along with it, peeling the wires was a pain.
Admittedly, I bought elsewhere on a special offer. As other reviews have said, removing the central body to solder snaps the holding pins, until I realised you dont need to remove it to solder properly. Still, its an expensive plug to break so easily.
Sound? They give an instant additional sparkle to my Neotech 1120 cable and extra depth perception. There is only 50 hours burn in on them so still opening up. A worthwhile investment if you have the cables to warrant the investment.
Nils G.
Excellent appareil
Un excellent DAC ! La qualité audio est vraiment au rendez vous et cela se ressent ! La séparation des canaux est impeccable, les entrées fonctionnent très bien, hormis peut-être le Bluetooth lorsque je suis connecté en LDAC où il y a quelques rares petit sauts mais rien de grave, d'autant que ma configuration (lecture de fichiers FLAC depuis un NAS à distance via un VPN) doit jouer aussi sur ça ...
La télécommande est simple, et à mon goût intuitive, il y a 100 crans pour le volume donc on peut vraiment le régler au dB près ...
Une seule petite remarque, le filtre PCM n'est pas supprimable : il semblerait que ce soit utile pour la liaison optique, probablement pour supprimer les hautes fréquences, bien que cela me semble étrange car c'est du PCM utilisé par la liaison optique et non du DSD, rien n'est expliqué dans le manuel, bizarre ...
Bref pour l'instant un super appareil avec bien sûr une puce ESS qui offrent pour moi la meilleure sonorité (notamment dans les aigus).
DAC très recommandé !
Marc T.
Audio GD vante sa connection ACSS, qui offrirait un son plus riche, plus naturel...
A l'usage, un câble XLR de qualité sonne mieux, et se branche et débranche plus facilement.
J'ai du mal à comprendre pourquoi une marque si attachée à la qualité se contente de cet accessoire assez basique...
Gervais G.
Pourquoi avoir autant attendu ?
Depuis des années, les pointes de mes enceintes étaient posées sur des pièces de monnaie surmontées de joints caoutchouc.
Je me suis enfin décidé à commander de véritables contre-pointes. Le résultat : un grave plus étendu et un peu mieux défini, un son globalement supérieur. Le rapport bénéfice/prix est excellent.
DAVID H.
conforme, belle qualité de construction
Rene C.
NEOTECH NC-P303RH IEC Connector IEC Rhodium plated UP-OCC Ø24mm Fiche secteur IEC femelle très haute performance, idéal pour la constitution d'un câble secteur Audiophile sans compromis. Les contacts sont en Cuivre...
Best buy
Together with Neotech NC-312RH and used with a silver plated OCC- or pure OCC power cable, this is a best buy.
Look also at my review on NC-312RH
Dieter S.
great case
Very nice case. i used it for a voltage supply
Rene C.
Best buy
As normal HiFi user with a high quality mid range or a lower high end system, this schuko plug used together with a silver plated OCC - or a pure OCC cable, is best buy for the money.
Yes, Furutech makes several fine and very expensive (NCF) plugs, but in my opinion their sound is to clinical and strait out of the main street for me.
OPA1612 Dual OPA DIP8 (Unit) The TI OPA1612 dual operational amplifier benefits from excellent technical characteristics, allowing very good electrical and audio performance. It ensures a very low noise...
Pas complètement homogène
cet AOP généralement très plébiscité pour ses caractéristiques techniques n'est pas optimal sur tous les systèmes. Bon équilibre des registres sans atténuation du grave contrairement à un LME49720; très bonne définition mais aigu trop franc, pouvant facilement tendre à l'agressivité. Image stéréo large mais profondeur pouvant être meilleure (un très léger voile est perceptible). Cet OPA1612 n'est pas parvenu à détrôner mon préféré, à savoir le TLE2142 CP de Texas Instruments.
TI LME49720NA/NOPB Operational Amplifier OPA Class AB 2 Channel DIP8 (Unit) The Texas Instruments LME49720NA/NOPB is a high performance 2-channel Class AB, high performance operational amplifier (OPA) integrated in a DIP8 package. This ultra low...
Pas pour tous les systèmes...
AOP d'une grande franchise avec une dynamique très réactive quoique pas toujours bien contrôlée. Médium et aigu très piqués mais grave fortement atténué, comme gommé. Bonne image stéréo. Un AOP qui en aucun cas ne pourra atténuer la brillance d'une électronique ou d'une enceinte. A associer avec des enceintes douces et jugées trop "basseuses".
Laurent R.
Rapport qualité/prix/performance imbattable.
Après avoir essayé plusieurs Dac que je trouvais un peu dur dans le haut du spectre, je me suis laissé tenter par ce Topping E30 II.
Et je dois dire que je suis très agréablement surpris.
Branche sur une Alimentation Allo Shanti, le résultat est bluffant.
C’est fin, détaillé mais jamais agressif. J’enchaîne les écoutes et aucune dureté ou fatigue oculaire.
Le coffret est très qualitatif et bien fourni.
À ce tarif, il n’a pas (beaucoup ?) de rival.
En terme de rendu sonore, il est un cran au dessus de mon ex Teac UD-503…
Merci à Audiophonics pour l’expédition rapide et soignée.
Tomáš N.
IFI AUDIO IPURIFIER 3 EMI Filter Female USB-B 3.0 to Male USB-A In order to drastically reduce the noise of your system, iFi Audio offers you the iPurifier 3. This will reduce distortion effects and finally restore the details of your music.
ifi ipurifier
quite expensive, but amazing. After a few hours of listening, my meze classics started playing amazingly. I tried different ways of adjusting the USB signal, including battery power, etc., but now with ipurifier it is right sound. Great in conjunction with Audirvana software.The best investment I could have made. I love it.
Pierre G.
bon boitier mais emballage à revoir
Un très bon boitier pour le montage que je vouslais faire... de ce côté ça va... mais là où j'ai enlevé 2 étoiles sur la note c'est la protection du colis : un coin défoncé et troué. L'article qui se ballade dans le colis... conclusion : 2 angles des toles de dessus et dessous du boitier sont abimés... c'est tout simplement INADMISSIBLE pour le prix que le client paye! Je ne retourne pas car j'ai pu "sauver les meubles" mais une prochaines fois ce sera retour aussi sec! Je ne suis pas content de l'emballage et de la protection de l'article et je vous le fait savoir.
Laurent N.
Alimentation fragile
attention j’ai claqué déjà 2 alimentations
Vous avez sans doute un soucis sur l'appareil sur lequel vous l'utilisez.
Le SAV me confirme n'avoir que très peu de retour sur ce produit.
Peter R.
NEOTECH CU-AG-20-20 Wiring Cable OCC Copper / OCC Silver PE Insulation 0.518mm² Neotech CU-AG cabling wire ensures perfect signal transmission, using conductors made of OCC copper alloy and 20% OCC silver for optimal conductivity. Each conductor is...
Outstanding value
I have tested a number of wiring cables to connect Real Sound Processors from SPEC Corporation (RSP-AZ9EX & RSP-W1EX) to my loudpeakers. Noetech SOCT-12 OCC provided very good sound. Kimber Kable Hyper Pure VariStrand silver 20AWG provided a clearer and more open sound I twisted three wires for each conductor (1,5 mm2). Finally Neotech CU-AG-20-20 OCC 20AWG provided the sound I was aiming for. I twisted three wires for each conductor (1,5 mm2). This provided a super clean sound with excellent portrayal of inner resolution and details within an impressive soundstage. Everything from bass to treble became more natural and organic. This is my favorite wiring cable of all time so far. I give this OCC cable my highest recommendation for all who are aiming to achieve gret musical sound quality and organic realism.
Un bon compromis
Attendre une période de rodage avant tout jugement ( son un peu dur au départ ) . Ampli sensible au câble secteur associé (plusieurs essais de fiches et câbles ) . Le son est rigoureux et neutre ; en augmentant le son à forte puissance la scène sonore est inébranlable (alimente des enceintes 150 Watts 3 voies ) Ce côté maitrisé limite l’épanouissement et bride un peu l'émotion que peut engendrer la musique . Tubiste passer votre chemin . Idéal pour une chaîne secondaire . Écoute homogène .
Cédric R.
Doux et chaleureux
Je trouve que ce cable délivre un très bon son, légèrement chaleureux et rond tout en étant clair et défini.
Cédric R.
Un dac de qualité
Ce dac m'accompagne depuis plusieurs mois et n'a pas encore montré ses limites malgré mes évolutions d'amplifications et d'enceintes. Aujourd'hui il distille la musique à travers un ampli clad purifi et des enceintes audiovector r3 signature. Pour avoir mieux il faut sans doute doubler le prix..
Cédric R.
SOMMERCABLE EPILOGUE Modulation Cable Male XLR to Female XLR 1m (Pair) This high quality XLR cable pair consists of a Sommercable Epilogue modulation cable and Neutrik connectors, specially designed for optimal signal transmission. The cable...
Excellent cable
Je me suis fier à d'autres avis et j'ai tenter l'expérience :)
Cela s'est révéler très bon ! C'est un cable neutre, droit, transparent. je recommande
