david D.
setup simracing
Le BST-1 est un excellent produit pour débuter et obtenir une vraie immersion à petit budget.
Bien installé + bon ampli +...
George R.
Amazing value for money once upgraded!
In stock form, this preamplifier is pretty good value for money. However, it was transformed into something special once I...
George R.
Massive improvement pver original Opamps in Aiyima T20
OMG - these dual OpAmps were a massive improvement over the original Opamps installled by the OEM in my Aiyima T20 elevating...
Customers reviews - There are 20876 reviews.
THIERRY P.
TOPPING NX7 Portable Headphone NFCA Amplifier Balanced Black The Topping NX7 is a compact and powerful portable amplifier, offering a beautiful precision and richness of sound. It is equipped with a new NFCA amplifier circuit specifically...
Etonnant Nx7 !
Couplée avec le Dx170, vous prenez un gap sonore bluffant, la profondeur de scène et énorme, ainsi qu`une basse présente et bien texturée, la largeur de scène prend aussi de l`ampleur, le tout et magique ! Un achat de haute qualité.
THIERRY P.
Etonnant Nx7 !
Sur mon DX170 couplee avec le N
Joel G.
Passive Preamplifier converter RCA to XLR / XLR to RCA Silver This passive stereo 10kΩ volume controller allows you to switch from balanced XLR to unbalanced RCA inputs and vice versa, from unbalanced RCA to balanced XLR. The two...
Very good for its price
This little box works great when used from balanced in to balanced out. When going from unbalanced in to balanced out, I experienced some quality loss, but only on certain loud numbers / passages. I guess it is not expected for a passive pre in this price range to be able to balance an unbalanced source. Unbalanced in to unbalanced out worked great too. The only case I didn’t try was balanced in to unbalanced out. As a curious person I opened my unit and saw that the potentiometer has printed C20K, I guess it is actually a 20K potentiometer? Anyway, it sounds great and the price is great
Rodolphe L.
Bon Ampli
Bon ampli avec des composants de qualité, qui marche bien, simple à mettre en œuvre. Cet ampli image très bien en stéréo, tout les instruments sont bien localisés. La bande passante est large, les basses sont rondes et bien tenues. Le médium-aigu ressemble à un son d'ampli à tube.
Ensuite affaire de gout, très subjectif j'aurais aimé un peu plus de texture, de matière sur les timbres pour que ce soit parfait, Je sais je suis exigeant. Cette remarque qui n'enlève rien à la qualité du produit qui est très bon.
Enrico R.
MAXWELL Supercapacitor 2.7V 325F This Maxwell supercapacitor provides significant energy storage for demanding applications. Supercapacitors are an ideal choice for applications requiring large amounts of...
Pay attention to soldering
Pay attention to the supercapacitor soldering because their mass need for a powerful soldering tool (at least 80 W, but i suggest also 100W) and a good practice skill. I also suggest a liquid flux for electronics.
Enrico R.
IAN CANADA UCCONDITIONER Ultra Capacitor Conditioner Board 5V The UcConditioner 5V is a ultra capacitor signal conditioner board operating with a 5V power supply. It will significantly improve the quality of your...
Pay close attention for supercapacitor soldering.
Very good product. It transforms the power supply at a higher quality level, with a better sound quality (if the audio circuit is equally audiograde). Pay attention to the supercapacitor soldeing because their mass joined to the large soldering area need for a powerful soldering tool (at least 80 W, but i suggest also 100W) and a good practice skill. I also suggest a liquid flux made for electronics.
Enrico R.
IAN CANADA SHIELDPI PRO Multifunction Board EMI Shielding / Power Supply Filter for Raspberry Pi Ian Canada's ShieldPi Pro is not only a universal EMI shielding module for Raspberry Pi, but also a high performance power supply filter, ON/OFF control button and GPIO...
Excellent product
At this price this is a really excellent product, the effect on the sound is clearly perceptible. I put it on my Raspberry 3B between it and a R2R DAC and the result leads to an undeniable clarity improvement.
Rodolphe L.
Bon module
Très bon module. Très transparent, belle bande passante et amplificateur vivant. Ne pas hésiter à mettre une très belle alimentation pour en profiter pleinement.
Enrico R.
Good product
Good product, correct price. Fastening is really efficient and long-lasting.
Rodolphe L.
HYPEX SMPS1200A180 Switching Power Supply Module 1200W 2x46V The Hypex SMPS1200A180 is a high performance Class 2 switched mode power supply, originally designed for UcD / NCore amplifier modules. Capable of delivering 2x46VDC at 1500W,...
Bonnne alimentation
Utilisé pour alimenter des modules classe AB. Fait bien le job pour un poids très contenu.
Fabien M.
DAC multi plates-formes
Association avec un amplificateur HPA-S400ET ,cordons XLR,Focal aria 948.
Ce boîtier est vraiment plein de ressources au niveau connecteurs d'entrées et de sorties, il est très simple à utiliser via son écran tactile et possibilité de cast cet écran sur votre téléphone, un must pour le pilotage dans le canapé. Il prend en charge sans soucis Amazon music en 192khz mais pas pour spotify....
Le son est vraiment excellent, sans exagérer, précis et clair, on redecouvre ses flac.
Pour stocker les musiques j'ai installer un SSD de 512go qui me suffit amplement, l accès pour le transfert se fait simplement sur une adresse IP comme un lecteur réseau sous Windows. Les transferts en WiFi sont très rapides 900mb en 30sec.
L interface est rapide et sans soucis. Même sur le téléphone, quelques légers lags si le cast est activé mais rien de grave.
Bref que du bon à part sur un point pour moi, je voulais mettre un HDMI in et j'ai essayé avec un adaptateur sur l usb type c mais cela ne fonctionne pas... j'aurais aimé profiter de la bande passante HDMI pour récupérer le son de ma TV, si quelqu'un a une solution, je suis preneur
Fabien M.
Une performance audio inédite pour moi
Bonjour, après essais de plusieurs amplificateurs Technics,onkyo RZ900, yamaha, advance paris A10...j étais à la recherche de celui qui pourrait exploiter mes Focal aria 948, étant conseillé par un ami puis par Audiophonics (merci beaucoup pour vos réponses à toutes mes questions) je me suis lancé sur cet amplificateur et je redécouvre mes aria 948,des basses sèches et bien présentes, un aigu précis et un médium mieux spacialisé. Un amplificateur qui rempli a merveille tous mes critères
SOMMERCABLE Schuko Type E/F Power Connector 16A IP54 Ø13mm This robust and affordable Schuko power connector from Sommercable will allow you to design quality power cables at a low price. It accepts cable diameters up to 13mm and is...
Top du top !!
Une fois la vis inox retirée, la prise s'ouvre sans forcer.
On peut y visser 3 fils de grosse section (j'ai du power câble 4 mm2).
Le diamètre externe de mon câble est de 15 mm2 est ça rentre !!
Superbe prise secteur, c'est du Sommercable, c'est tout dire.
Belles fiches, un peu de bricolage...
Ces fiches sont superbes, j'ai pu y entrer 2 sections de 4 mm2 de mon Sommercable Elephant mais c'est juste pile poil pour 8 mm2.
Ne croyez pas les installer en 5 minutes, j'ai dû bricoler un peu.
Déjà la clé Allen n'est pas fournie, mon jeu de clés Allen n'a pas une clé aussi petite. J'ai dû utiliser un tournevis miniature de mon jeu de tournevis d'horloger. Jusque_là c'est bon, en enlevant le plus petit manchon le câble de 2x4mm2 rentre.
Petite déception, la vis du haut de la fourche tient le capuchon de la fourche mais pas le câble. C'est la vis du bas qui serre le câble mais directement en l'écrasant. J'ai dû rajouter une petite cale pour que la vis vienne presser la cale sur le câble et ne pas le mâchonner.
Sinon c'est très positif, la qualité de ces fourches est extra.
Ce n'est pas si courant de pouvoir entrer une section de 8mm2 dans une fiche !!
Je crois d'Audiophonics a un contrat de transport avec le super héros Flash, les livraisons se font toujours le surlendemain de ma commande, je n'en reviens pas !!
Yvon B.
Très bon appareil
La restitution du son est parfaite et supporte sans problème le 24/192 entre autre à partie de qobuz.
Thomas V.
TINYSINE TSA7800B Class D 2.1 Amplifier Board TPA3116D2 DSP Bluetooth aptX 2x50W + 1x100W The TinySine TSA7800B module is a 2.1 Class D amplifier, capable of delivering a power of 2x50W + 1x100W. It also embeds a Bluetooth 5.0 AudioB receiver, supporting the high...
Lieferung und Ablauf
Audiophonics ist ein Top Lieferant mit einem klasse Service und Kundenservice.
Hervorragende Preise und schnelle Lieferung.
Kann man nue empfehlen.
2éme avis
Très bon résultat sous une platine vinyle . J'ai découpé des carrés collés par paire sous chaque pieds de ma platine . Ecouté apaisée et plus propre . De plus collé sur une paroi de deux de mes meubles j'ai supprimé des résonnances dû à la salle d'écoute . A utiliser avec prudence car comme dans mon premier avis si vous en ajoutez de trop le son peut être étouffé.
efficace
Alimente un récepteur Bluetooth . Grosse différence avec l'alimentation d' origine qui délivrait un son plat . Cependant j' obtiens un petit plus en le remplaçant par une batterie . Bon achat toutefois.
PRE-TC10 review
I have posted a review of this recently bought product at ASR:
https://www.audiosciencereview.com/forum/index.php?threads/audiophonics-pre-tc10-preamp-with-tone-controls-review-and-measurements.44930/
The preamp function is good at affordable price, it is helpful especially in cases we use a record player or cassette recorder. However, there was a QC failure with this product, the negative voltage regulator LM337 did not work and sent -23V to the LME49720 negative supply pin. This, together with +14V positive supply (correct value) made total supply voltage of 37V and this exceeds datasheet absolute maximum value which is 36V. The op amps have survived and I have replaced the faulty LM337 for a new part. However, this should have been tested by the manufacturer.
Joel G.
So happy with this amp
After 3 months with this amp I am very very happy with my purchase. I have used it plugged to a DAC with volume control with only rca out, a passive preamp with xlr, an active preamp with both rca and xlr -it does great with all of them-. I tried all of the 3 gain settings and ended up with the medium gain which I think suits better my preamp, speakers and room. Great design Audiophonics, merci!
Elsa A.
Banana Plugs Gold Plated Lockable Ø9mm (The pair) These affordable banana plugs allow a quick and easy connection to the terminals of your speakers and amplifiers, while ensuring an optimized contact. The contacts are...
Fiches banane à verouillage
Excellente fabrication , acceptent de forts diamètres de câble, verrouillage impeccable grâce au diamètre de bague extérieure important.
Roland S.
AUDIO-GD R-7HE 2021 MK2 Balanced DAC R2R FPGA I2S HDMI Amanero 32bit 384kHz DSD Accusilicon Audio-GD is developing its HE range, composed of its most top-of-the-range products. They benefit from the longest design and testing period since the brand's inception. This...
Finally sound to love
un-artificial, believable, strong and like real. I confirm Herb Reichert’s review at Stereophile. Many years of search without arriving for me. All this oversampling filters or dsd conversion which I studied: interesting but not satisfying in the end, since it never sounded really real. Now with this chinese monster dac baby, I always come back to NOS after playing with different oversampling settings (Hqplayer). And so it will stay. This dac must be have been developed by someone who loves to listen. Many, many thanks to this person(s)!
Still, the r7he mk2 needed some help to shine. In my case I added a singxer su-6 as a ddc, connected by I2S. Better now, but still it was not the sound I wanted. A sound-killing dryness was there. The singxer has a poor switching power supply and the claim is that for its super-capacitor it does not need a proper linear power supply. Simply wrong, at least in my case for this dac. Exchanging the standard PSU of the ddc by a linear PSU was the missing last piece in the puzzle. I guess, if you go with the ddc from audio-gd you get a direct goal. Et voila: my search ended, music is playing to happy ears :-)
Jani B.
energijaj@gmail.com
plug for the main starting point from the wall, top quality and power with a nice sound
Dominique V.
Contrepointes Aluminium
J'ai acheté ces contrepointes car c'était l'élément manquant pour mes pieds d'enceintes. Sur les photos elles sembles jolies, mais une fois installées c'est nickel. Elles finissent et embellissent parfaitement mon ensemble pieds / enceintes DYNAUDIO. Concernant le son, même si s'il est déjà très bon, je pense qu'il y aura encore une amélioration. De plus j'ai commandé des câbles Dynavox, que j'attends car rupture de stock, et là ce sera le TOP.
Merci à Audiophonics de proposer des produits de qualité à des prix adaptés à toutes les bourses.
BENOIT D.
Fait l'affaire !
Fonctionne parfaitement, le son est bon. Parfait pour le pour le prix.
P.S. à l'attention d'audiophonics : l'alimentation que vous préconisez sur votre site n'est pas adaptée au récepteur car ce dernier possède une entrée en USB C alors que l'alim. est encore avec l'usb première génération. Donc l'alimentation que j'ai reçue ne me sert à rien, dommage.
Miroslav T.
XH 2.54mm Female to Bare wires Cable 3 Poles 1 Connectors Gray 30cm 24AWG (Unit) This good quality shielded cable has a 2.54mm 3 pole XH connector and 3 bare wires (red, white, black). It will allow you to carry out simpler assemblies on your PCBs also...
nice product
I am very satid+sfied with this one
Fabien F.
Petit mais costaud (et propre)
Monté dans une enceinte close 2 voies de 10l, qui fait aussi sub. Il monte dans les medium et avec un filtre à 2k + Tweeter, on a un son de basses/sub très propre et pas de "boooom" baveux. mais... nécessite une équalisation forte avec DSP (moi j'ai un module Arylic) qui boost les fréquences en dessous de 80 Hz, + mode Deep Bass, vu que le rendement chute rapidement dans une enceinte close, contrairement à un bass reflex.
Il faut donc pas mal de puissance pour bien ressentir les basses si vous voulez un encombrement minimum. Mais n'achetez pas un ampli de 200 W (la puissance du HP annoncée par Dayton): j'atteins le xMax avec un ampli de 80 W. Le HP peut aussi être monté avec 2 radiateurs passifs de la même gamme Epique.
Hugo Á.
SOVTEK 6H30PI / 6H30 / 6N30 / 6N30P Twin Triode Tube (Unit) This Russian-made, audiophile-quality 6H30PI power tube from Sovtek (sometimes also called 6H30, 6N30 or 6N30P), often used in pre-amplifiers, gives...
Good Quality
There are New, 2022, original valves by Sovtek. They replaced used ones, from 2004. They sound good. Recommend.
DIMITRIOS T.
XDUOO XD05 BASIC Portable Headphone Amplifier DAC ES90108K2M XMOS 32bit 384kHz DSD256 xDuoo presents with its XD-05 Basic a small, affordable yet extremely powerful portable headphone and DAC amplifier. Indeed, low price doesn't always rhyme with economy of means...
powerful entry-level amp and good dac
It sounds clean and detailed. There is enough power to drive any headphone even on low gain. The dac seems fine and works well when connected to an external amp (this is not a pre-amp so no volume control for the line-out, volume control is only for the headphone-out.) there very little channel imbalance on extremely low volume (you will never listen to that low even with iems) The pachage has all the accesories you would need except from an aux cable (only needed to connect to external amp) there is even a very handy resusable adhesive to use if you want to "glue" this device to your phone or DAP. Battery lasts about 7 hours depending on use so pretty good. There is no hiss or noise even on very sensitive iems although the volume is too much to pair it with such iems, better suited for harder to drive stuff, unless you lower the volume from the phone-computer-dap. Generally Very satisfied with the purchase.
franck l.
Très bon lecteur, comparé au blu.... dernière génération que je possède également, et relié au même amplificateur avec dac, le son est équivalent voir un poil supérieur. Le chromcast est très pratique, ce qui fait aussi la différence avec blueso....affichage des pochettes des titres diffusés des radios. Livraison impeccable, merci à audiophonics
antoine L.
ELECTRO-HARMONIX GOLD 12AU7 / ECC82 Tube (Unit) The Electro-Harmonix Gold 12AU7EH is a dual triode tube with gold-plated contacts. Its excellent linearity makes it an ideal choice for preamplification.
ELECTRO HARMONIX GOLD 12AU7
je reviens sur mon avis du 06/12/2022, c'est vrai j'avais préféré le tube Psvane, qui apportait plus de matière, en réécoutant le ELECTRO HARMONIE GOLD, ce tube apporte plus de finesse comme des micros informations supplémentaires, lors de ma comparaison le tube ELECTRO HARMONIE n'etait pas rodé, donc la comparaison n'etait pas équitable, pour le moment ce tube n'est pas disponible, je vais donc attendre un peu et en recommander un autre, merci à Audiophonics pour leur sérieux,
Davor M.
After the long break-in period I can only say that cables are
amazing. I have 5 time more expensive cables but this is pure music. Recommended.
Raffaele V.
DAC R2R vs DS
Preso più per curiosità che per necessità, ora è il mio rigerimento. ho trovato un R1 usato su Subito (sempre Audiophonics) e confermo che è un ottimo marchio (Audio-GD) e un ottimo sistema. Appena possibile mi compro il R11 MKII.
André G.
Copper / Silver Wiring Cable 4mm² PTFE Sleeve Ø3.6mm Black This 3.6mm diameter cable has a single 4mm² conductor made of Silver plated OFC Copper. This provides excellent signal conductivity while providing the conductor with high...
Câble hp cuivre argent
J utilise ce câble pour alimenter un hp grave avec succès. Bonne tenue des basses
Raffaele V.
TUNG-SOL 12AU7 / ECC82 Tubes (Matched Pair) The Tung-Sol 12AU7, manufactured in Russia, ensures very low noise. It has been designed to mimic the performance of American NOS 6189 tubes. This one proposes an open...
COPPIA SELEZIONATA ECC82
Splendida coppia selezinata, motata su un TotemPole, sono risultate praticamente perfette.
MONACOR MDM-2 Speaker Damping Polyester 130g 63x33x3.5cm (Set x2) This environmentally friendly damping material for thermal and sound insulation is made of 100% Polyester fibres. It is therefore ideal as a sound absorber to be installed...
Complément amorti synthétique, obstruction des évents.
Je l'utilise en complément d'amortissant interne d'enceintes tout en bas, bourrage du bas de l'enceinte, me permet de boucher les évents en laissant le passage de l'air grâce à son faible amorti.
Pour les parois internes, je mets la plaque en feutre Jantzen amortissant de 1mx1m bien plus absorbante et hautement qualitative.
Tapisser les parois internes des enceintes.
Génial comme amortissant interne d'enceintes, j'ai découpé cette plaque épaisse de 1 mètre sur 1 mètre, collé les morceaux avec un pot de colle gel néoprène sur les parois internes.
L'amorti est très supérieur aux matières synthétiques, c'est propre (pas de particules) et en plus c'est tout doux.
Bravo à Audiophonics de proposer un tel matériau !!
Pour remplacer mon Sommercable Orbit 240 mkII 2x4mm2.
Remplace mon Sommercable Orbit 240 mkII en 2x4mm2 déjà excellent pour passer en bi-câblage ou en 2x8mm2.
Ce câble est agréablement très souple bien plus flexible que l'Orbit, facile à dénuder, diamètre extérieur identique à l'Orbit 4mm2 donc pas si gros (rond quand l'Orbit est plat).
Ecoute toujours chaleureuse, pas de dureté, c'est transparent, le rodage améliorera encore le son.
Au prix proposé au mètre, c'est une affaire exceptionnelle, j'ai testé de très nombreux câbles ésotériques pour m'arrêter sur Sommercable (en modulation le câble Sommercable Epilogue arrive en tête aussi).
Merci à Audiophonics pour la qualité de l'envoi !! (emballage et transport).
Yordan K.
The cable is of very good quality. I give 4 stars only for the delay in delivery.
Bruce P.
AUDIOPHONICS Network Patch RJ45 Ethernet Cable High-End Cat 7 10m Hand assembled in our workshops and made from the best components on the market, this RJ45 cable provides you with the best possible interconnection quality at this price.
Audiphonics Network Patch RJ45 Ethernet Cables High-End Cat 7, 10 metre and One metre
Beautifully made and of excellent quality and performance. Comes in a nice "velvet" bag. Marked improvement to my streaming setup. Superfast shipping to Australia. Highly recommended upgrade.
Alain R.
J'ai utilisé cette pince sur une trentaine de contacts XH.
Ils ont tous été parfaitement sertis sur un fil multibrins de 0,24mm² et isol
Sorin A.
Didn't expect to make a difference.
Bought it to replace the stock DC cable of the Pro-Ject Accu Box S2 which powers my EAT Glo Petit phono preamp. The only reason was to replace an ugly cheap looking cable, never expected to actually make a difference sound-wise.
Christophe A.
Produit solide qui pèse son poids. Gain dans la puissance du son par rapport au produit que j’avais avant et qu’il remplace. Écartement prises cinch non au standard amplificateur. Nécessite une rallonge rca pour brancher le récepteur Bluetooth advanced à acoustic wtx 500 mais rien de grave. Bref parfait pour donner une seconde jeunesse à mon vieil ampli nad.
Denis S.
En remplacement
Très étonné par ces câbles, pour le prix, ils n'ont rien à envier à mes stratus 7.... 3 fois plus cher... Ils sont même plus énergique et clair, moins pataud... Un petit hic, mais à corriger avec barrette la phase et a l'envers... Pour petit budget, c'est à recommander.
Pascal B.
Fait le job !
Acheté pour alimenter une centrale Focal CC1008 Be, il se balade avec présence et impact !
Il ne chauffe pas en étant totalement silencieux, juste un très très léger petit souffle en collant l'oreille au tweeter Be donc rien à signaler.
A noter que le trigger fonctionne très bien derrière mon Marantz AV8805 sans aucun bruit, ni ploc à l'allumage.
Pascal B.
Solide & performant !
Un beau boitier tout métal, une sélection de source souple et totalement silencieuse, pour l'instant tout est parfait !
Il ne faut pas se tromper à la commande sur les entrées/sorties, le boitier étant stable et relativement lourd, il ne bouge pas même avec 6 câbles XLR connectés.
Christophe M.
avis number 2
Alors je n'enlève rien à l'avis précédent mais le souci est que parfois il faut tout réinstaller. On se lève, on veut écouter de la musique et rien ne fonctionne, les WiiM ne sont plus détectés. Ca prend du temps, c'est anxiogène, désagréable. Mais quand ça fonctionne, le produit est très bien. Est ce parce que j'en ai deux??
Mickael P.
Pour Drop + Hifiman HE4XX
Mousse fournie d'origine sur le casque Drop + Hifiman HE4XX. Parfait pour remise à neuf du casque avec pièce officielle.
Joris J.
Great value, but bit harsh on top
Spacious soundstage, transparent, good bass BUT a bit harsh/digital sounding on the top end. That spoiled the listening experience to me, so I am still looking for a better DAC.
Warning: despite info on datasheet : NO remote control included!
fernando B.
XDUOO TA-30 DAC Tube Headphone Amplifier ES9038Q2M XMOS XU208 Bluetooth 5.0 32bit 768kHz DSD512 The xDuoo TA-30 is a high-performance tube and DAC headphone amplifier combo, offering rich and detailed sound reproduction. Its headphone output amplified by a pair of power...
todo perfecto
Sonido ce calidad
