Nikolaus S.
Parfait sur un bureau
MICHAEL K.
Recommended
Customers reviews - There are 19275 reviews.
Adrien D.
Excellent pour le prix
Parfait pour son prix, livré bien emballé, ne chauffe pas tant que ça
Bert B.
Super amplifier.
I had been searching for a long time to find an amplifier with Hypex modules. The Audiophonics MPA-S250NC was my perfect fit for a very good price.
I wasn't satisfied with the sound of my system and I thought it was because of the quality of my speakers(Millon Phantom-S).
Now that I replaced my Yamaha amplifier with the MPA-S250NC the speakers sound so much better.
I didn't expect an amplifier to give such an improvement.
The trigger input to power on the amplifier from my pre-amplifier is also a very welcome option.
Delivery to The Netherlands within 3 days for a reasonable price is also perfect.
So, nothing to complain!!
Fabrizio M.
Confermo ottimo prodotto
Prodotto valido per musicalita' e definizione, medi ottimi, alti abbastanza definiti,bassi un po' da potenziare.
Il prezzo non ha paragoni abituato a classe A e ab , migliorabile ma immaggino che con moduli differenti, che si trovano nel market, credo
di potermi divertire.
Fabrizio 62
mathias b.
Parfait pour ampli scott A436
S'adapte tres bien a mon ampli, lumiere et puissance parfaites
Jean-Marie M.
excellent inserts pour enceintes colonnes
Jean-Marie M.
pas mal
bon rapport qualité/prix mais plus adapté à 2,5 mm au minimum
Tony B.
OK
Achat pragmatique basé sur la puissance de mon ensemble et la distance des enceintes mais également rapport qualité/Prix. En remplacement d'un câble de grande distribution premier prix.
Utilisé avec Atoll IN80 et Kef Cresta, j'obtiens un résultat plus clair, net et un équilibre plus intéressant entre aigu et grave.
Donc une bonne amélioration mais pas une révolution.
Tony B.
Extensible Telescopic DVB-T/T2 Antenna This DVB-T/T2 telescopic antenna connects directly to the antenna jack of a device or module. Its articulation allows it to be easily oriented for optimal reception. The antenna...
Well Done!
Fonctionne parfaitement bien dans mon environnement.
Initialement prévu pour du provisoire, cette antenne va finalement rester indéfiniment.
Connectée à un Atoll TU80se.
Robin V.
Belle qualité
A savoir : les vis de serrage de câble sont des Torx de 5.
Donc prévoyez l'outil spécifique...
Pierre L.
SHUGUANG 12AX7-T High Quality Amplification Tube (Matched Pair) This high-performance Shuguang 12AX7-T tube from the Natural Sound range is a high-gain, low-noise dual triode. It is ideal to replace advantageously a 12AX7, 12AX7A, 7025 or...
Sonorité moderne
Tube bien construit, solide avec une sonorité légèrement creusée dans les médiums. La transconductance est bonne. Conviendra bien en cathode follower pour attaquer l’ampli de puissance.
Jeannot G.
Does everything a power cable needs to do. Used on power amplifiers and very happy with the result!
Guntram G.
Perfekt!
Passt perfekt!
Yann G.
Une Merveille
Acheté en remplacement d’un câble REGA pour assurer la connexion de mon pré amplificateur phono cube se de ma platine rega Rp6 à mon pré amplificateur Audio GD Master Singularity 11, ce fût une révélation. Tout est plus beau. Qualité des timbres, scène, positionnement des instruments. Évidemment, difficile de savoir ce qu’il apporte par apport aux autres câbles de la marque. Mais je ne peux que le recommander ! Vraiment une belle découverte !
Jean-Louis G.
SHANLING UP4 Portable Headphone Amplifier DAC Balanced 2x ES9218P Bluetooth 5.0 CSR8675 Compact, affordable, yet high-performance, the Shanling UP4 is a DAC combo and portable symmetrical headset amplifier with Bluetooth 5.0 connectivity. It will accompany your...
Bon amplificateur
Bon produit qui offre un son dynamique, plutôt enthousiasmant contenu de son utilisation en bluetooth. L'attache vestimentaire n'est pas très pratique. Toutefois, je recommande ce petit amplificateur, un des meilleurs dans sa catégorie. La livraison par chronopost a été une fois de plus lamentable avec un délai non respecté.
Anne b.
ampoule navette led blue
changement ampoule navette pour ampli tuner akai l éclairage est extraordinaire rien a voir avec de simple ampoule basique l éclairage est sublime tout simplement
Anne b.
fil de cablage multibrins cuivre argent isolé ptfe bleu
j ai utilisé ce cable pour le cablage interne célestion five avec soudure a l argent beaucoup plus de clarté et de précision dans les graves et médium ansi que le tweeter plus fin
Anne b.
tres bon cable basse profonde effet spatial tres bien détaillé vraiment bien pour un cable cuivre argent
Raspdac mini excellent petit lecteur réseau
J'ai bien reçu mon Raspdac mini 4 (Référence : 15148) et j'ai réussi à tout faire fonctionner correctement....
Ok pour mon NAS, DD usb et les radios internet avec Volumio.
OK pour Qobuz avec BubbleUpNp, mais dommage que les jacquettes ne soient pas affichées et que l'écran défile
tout le paragraphe interprète, sans donner le titre du morceau, du cd ou du chanteur.
La télécommande ne fonctionnait pas, mais vite réglé par le sav avec une maj de volumio!
La led rouge ne s'allume qu'au démarrage, c'est dommage!
J'ai acheté ce Raspdac pour ma maison secondaire et aussi pour servir de spare à mon ancien Linn Akurate : les premiers jours l'écoute s'est avérée décevante, mais s'est bien améliorée au bout de quelques jours!
Aujourd'hui je l'ai installé pour test sur la chaine principale en lieu et place du Linn et le raspdac se débrouille très bien.
La qualité est bonne, mais bien sûr la Linn est devant (avec un prix multiplié par 20!).
Je pense essayer de bricoler une alim 5v audiophile pour essayer d'aller plus loin, car avec l'alim basique je vois quelques raies verticales à l'oscillo....
En conclusion, le rapport qualité prix excellent!
Jef B.
Zeer goede versterker
Met 2x36V AC voeding met een filtering van 4x10000 microfarad en zwaar koelelement krijg ik een fenomenaal resultaat. Veel vermogen en zeer zuivere klank, te vergelijken met de beste commerciële HD versterkers.
De signaal ruis verhouding is tevens uitzonderlijk goed.
Nicolas G.
Pourquoi s'en priver ?
Utilisés pour remplacer les condensateurs d'origine (27 ans) d'enceintes JM Lab DB 19, le son est bien meilleur et les aigus libérés et bien placés.
Je recommande.
Nicolas G.
Meilleur son
Super produit, boitier alu, port USB supplémentaire. Depuis qu'il est alimenté par cette alim, la Raspberry est content: plus de flash du led indiquant une trop faible tension, et j'ai vraiment le sentiment de l'entendre.
Il est plus "confortable" pour délivrer du son.
Merci !
Henrik S.
Reduced some "boomy"-ness of my sub
I used the Iwoofer pro app for iOS, and even though the software seemed "rough around the edges", I managed to perform a room correction, and I perceived the result as better than before the correction. I think I may tweak even more out of this little box, but it will require some trial and error. Maybe an updated app will improve the user experience........but in summary, my sub sounds better after using this box
jean michel G.
Ring Crimp Terminal Gold Plated Ø5mm (x10) Here is a set of 10 gold-plated grommet lugs accepting cables with maximum diameter Ø 6mm (M6). The inside diameter of the ring is 5mm, and the total length of 22mm.
Bonne cosse
Bonne cosse, m'a servi pour le bornier enceintes vers filtres, malheureusement achat précipité car le diamètre de l'œillet trop petit, j'ai du joué de la visseuse.
WILLIAM S.
Très bien, bien emballé et arrivé rapidement.
Jonathan K.
Neutre et serein
Cela fait huit ans que j'alimente mon ampli principal avec ce câble, je pense avoir assez de recul pour en dire tout le bien que j'en pense. Image sonore élargie et qui respire. Câble ayant la faculté première de supprimer les agressivités surtout dans les aigus. J'ai pu reconfirmer ce dernier point avec la confection d'un second câble pour mon préampli phono. Une fois ce dernier installé, et avec peu de rodage, la différence est évidente. Tout est plus posé, équilibré et tend vers une certaine neutralité. Un des meilleurs rapport qualité-prix à ma connaissance.
François R.
renaissance
j'étais , au départ , un peu septique quant à l’intérêt de ce filtre mais à l'écoute c'est assez fantastique:aération , précision , découverte d'instruments qui semblaient en retrait.En bref une nouvelle lecture et une redécouverte de mes CD.Même constatation avec l'écoute d'un lecteur de réseau.Merci des bon conseils d'AUDIOPHONICS
Charles C.
Application Android
Après quelques mois d'utilisation mon ampli fonctionne toujours aussi bien, je complète mon avis pour savoir s'il serait possible au constructeur de mettre à disposition une application Android qui permettrait de piloter l'ampli avec un smartphone?
Ab c.
Perfect with STAX L500 MK2
Perfect with STAX L500 MK2 porable sound, the treble extension make stax sounds bit livier, perfect portable and also drives normal 3.5mm dynamic hp.
Giovanni G.
a great power cable
i love this solid core cable.. great quality and fine result to the sound of my pass xp12 preamp... the quality of the copper its simply evident
Raphael F.
MEZE EARPADS Headphone Earpads for Meze 99 Series Meze offers replacement pads in spare parts for its 99 Classics and 99 Neo helmets. These are perfectly identical to the original models. These pads are made of shape memory...
Produit conforme
Site très sérieux
Envoie rapide
Que du ++++++
Raphael F.
Dac qui donne de très bons résultats sonore
Produit de qualité
Site très sérieux et rapidité d envoie
Rien a dire tout est parfait
Jean-Marie C.
LINDY ANTHRA LINE Male USB-C to Male USB-C 2.0 Cable Gold Plated 3m Lindy's Anthra Line cables are high quality products, ideal for professional installations. This is a USB-C male to USB-C male cable with standard 2.0 and transfer rates up to...
Avis Câble USB-C
Rien à dire. Le câble fonctionne très bien, suffisamment long pour avoir de la marge et la livraison a eu lieu comme prévue.
Didier C.
Très bonne prise
Prise d'excellente qualité, RAS pour le prix payé.
Albert h.
AUDIO-GD PRECISION 3 2020 EDITION Balanced Class A Amplifier ACSS 2x 70W 8 Ohm Audio-GD is upgrading its Audio-GD Precision 3 by offering this 2020 edition. It is based on the previous model, but with a modified circuitry and adjusted sound performance to...
client
très bonne appareil pour moi je ll'écoute avec un casque electrostatique ,bonne définition et puissance de réserve, à conseiller
Philippe R.
Sheath Natural cotton for cable Ø 5 - 8mm Red 100% natural cotton cable insulation for cable insulation.
Pour 2 cables fils 2mm²
Vraiment pas mal. Prévoir large ! C'est à la fois bien extensible et bien rétractable. Donc prenez plus long et plus large que vous avez mesuré. Aussi prenez bien votre temps devant la tv car c'est long de passer deux câbles de 2 fils de section 2mm² sur 10 mètres.
Emmanuel T.
Un pur plaisir auditif.
C'est mon premier DAC, et je n'ai donc pu faire aucune comparaison avec un autre modèle. Néanmoins, le contraste ressenti entre la sortie audio de mon PC et celle du DAC est saisissante. Testé avec beemusic en écoutant du classique au rock, les instruments sont sublimés, détachés les un des autres. Cette satisfaction totale m'incite à encoder en flac mon audiothèque dont mes vinyles. Et tant qu'a faire investir dans un ampli un peu plus audiophile.
Patrick D.
1877PHONO Z-Litz Câblage Cellule OFHC 50mm
Livrés rapidement, ils savent rester neutres et sont d'un bon rapport qualité / prix. Font leur job... font leur job.
Christian L.
Aluminum Button D Shaft 40mm Ø6mm Black This sturdy black aluminum button has a diameter of 40mm. It can be easily fixed on the flat axis of a potentiometer or attenuator with a hexagon screw and will contribute to...
comment il se fixe ?
joli bouton alu noir mais s'il dispose bien d'un perçage de fixation fileté il n'y avait pas de vis sans tète fournie...
et pour trouver une petite vis de cette dimension (3.5mm?) bonjour...
inutilisable
Il se trouve en accessoire de cette fiche, des petites vis parfaitement adaptées à ce bouton.
M. S.
Fait son job.
Utilisé sur une installation haut de gamme tri amplifiée: fait parfaitement son job.
BENOIT D.
HIDIZS S9 Portable Amplifier DAC AK4493EQ Balanced 32bit 768kHz DSD512 The Hidizs S9 is a portable headphone and DAC amplifier combo, perfect for giving you the best sound quality wherever you are. It integrates high quality components in a...
Parfait pour moi
Connecté à Qobuz, je l'utilise en sortie d'une tablette Samsung S5e, branché sur un casque Grado GW 100. Superbe définition, reconnait les fichiers HiRes. Très satisfait. Je me dis que j'aurais peut-être du attendre le nouveau modèle S9 Pro. Mais tant pis, je très satisfait. Merci Audiophonics pour la livraison rapide.
Pascal D.
Dual Linear Power Supply Module LT3045 LT3094 +/-15V This dual regulated linear power supply module provides a clean and stable DC electrical signal with a noise level close to 0 by using a positive LT3045 Ultrahigh PSRR linear...
A ne pas utiliser pour ampli phono sans modification
En alimentant un ampli phono, une fréquence d’environ 1kH est présente à l'écoute.
En cherchant sur le datasheet des LT3045 et LT3094, c’est préconisé de mettre un condensateur de 4,7uF céramique sur la pin Set des ICs et non pas 470nF comme d’origine, et en sortie 10uF toujours céramique et non pas 100nF. Après avoir effectué ces modifications, l’alimentation fonctionne correctement.
Olivier C.
FX-AUDIO BOX02 Phono MM/MC Preamplifier NJM2068 TL071 The FX-Audio BOX02 is a low-cost phono preamplifier, offering a very high quality design. It supports the board with MM and MC cells, a switch under the device to select one of...
Magnifique
Ma platine vynile avait un préampli intégré qui donnait un résultat plutôt moyen sur un ampli, plutôt moyen également j'avoue... Néanmoins le préampli intégré dans la platine étant "désactivable", je me suis dit que j'allais rechercher un préampli ad hoc. Et bien je ne regrette pas une seule seconde d'avoir fait cet achat. Le résultat est tout simplement un énorme plaisir à réécouter mes vinyles, que je connais par coeur, mais que je redécouvre totalement... c'est génial. Je dirais que le son a gagné en clarté, en précision, en spatialité, en profondeur, en chaleur.... l'effet "melasse" et "distordu" qui commençait à m'agacer sérieusement a totalement disparu. La finition du produit me semble d'excellente facture. Livré très rapidement par audiophonics. Pour moi c'est un 5/5 sans hésiter. Merci !
Christian L.
Ce serait mieux avec la visserie.
La qualité semble au rendez-vous. Je pourrais en dire plus lorsque j'aurais reçu la visserie qui manquait dans l'emballage. J'aurais aussi un aperçu de la réactivité du SAV.
La visserie vous sera envoyée au plus vite.
Encore désolé pour cet oubli.
excellent resultat, seul remarque la prise ;-(
je vais pas expliquer se que les gens si dessus ont écrit sur cet magnifique interface.. juste dire mon scepticisme face a la qualité de la prise secteur qui plus est avec interrupteur. pour le prix un interrupteur en façade aurais été plus pratique. perso je la laisse allumée 24/24.. j ai l intention par la suite de jeter cet prise ridicule par une furutech rhodium. Après la fin de la garantie bien sûre. j ai déjà changé une prise sur un dac pré.. qui en pré ne fonctionne pas.. je devrais l envoyer en réparation. toute fois j attend un remplaçant d occase ..si non plus de musique réseaux ni tv. trop frustrant si il faut attendre plusieurs semaine ;-). le son a gagner sur tous, même avec une prise cuivre pl or furutech. j ai fait de même sur mon lecteur cd xray.. 18ans d âge. Avec remplacement des fiche coax spdif et analogique par des cuivre pl argent klei.. la aussi du meilleurs a tous les étages. après 20h de rodage. a pars cela sa donne envie d aller encore plus loin en disant a tous qu' avant de changer votre lecteur cd ou autre source numérique d acheter se bijou la.. ou le model avec alimentation régénérative.. sa couterai tj moins cher que du nv matos de qualité.. et la vous en avez pour votre argent et bien plus.. la prise et ridicule .certes mais les écoutes se sont montrée impressionnante.. .
Leigh S.
Very difficult to work with
My hands are exhausted and torn up from trying to get these connectors to work with a Furutech stiff cable with a 16mm diameter. Very difficult to manage.
Aleksandar J.
I always order from you guys! Great service and quality pots!
Thank you!
Olivier M.
Génial
Je viens d'en commandé un deuxième.
Le premier équipe un scott 235s+ dac pcm50102+ enceinte higland audio.
Le tout pour mon ordi........... Génial, tube d'origine je n'éspérait pas tant.
C'est précis, chaleureux, la stéréo est accentué, pourtant mes oreilles se font vieille.
Le deuxième va équiper mon scott 250s. Entre parenthèse cet ampli est une merveille et je ne pense pas qu'il y ai besoin de pré ampli tube. Alors pourquoi?..... petite astuce, le fx audio a un réglage de volume et donc au maxi, celle permet de soulager le 250s.J'ai branché 4 enceintes en simultanées (mariage parfais de deux enceintes différentes) sur le scott. Donc je me retrouve avec 4 ohm et même si le 250s est fait pour ça cela m'assure une sécurité supplémentaire en mettant un gain assez important en entrée.
Je suis fan des vieux scott pour leur son et leur adjoindre un fx tube cet une tuerie. Je viens de m'acheter une paire de 5654W pour comparer.
Audiophonics parfait comme dab.
Patrice C.
Doit faire ses preuves
J’ai acquis une barrette de secteur Neodio PW1 qui a apporté une amélioration sensible l’écoute. Je l’ai reliée à une prise murale FURUTECH FT-SDS NCF (R) Schuko plaquée rhodium, connectée et reliée directement à un disjoncteur dédié par un câble de secteur SOMMERCABLE NYM-ST-J Câble cuivre OFC 3x2.5mm². Je n’ai pas pu constater d’amélioration sensible par ce câblage. Peut-être est-ce aussi dû à mon ensemble d’appareil hifi de gamme moyenne (Naim Uniti 2, enceintes Melusine…) ???
Patrice C.
FURUTECH FT-SDS NCF (R) Power Plug Schuko Type F for Power Distributor Rhodium Plated The Rhodium-plated Schuko Furutech FT-SDS-R NCF plug is a new version with a body using the brand's technological advances. Taking up the recognized qualities of the technical...
Doit faire ses preuves...
Jean-Michel B.
Tres bien
Ecoute apres 50 heures de rodage.
Remplace ma "Xmos" audiophonics qui beneficiait deja d une alimentation externe stabilisee Audiophonics.
Cette hecate , sans cette alimentation extérieure, manque un peu de plénitude sonore , relativement a la vielle xmos (celle ci avec alim.stabilisée )tout en ayant déjà une meilleure spatialisation.
Avec l alim. Stabilisée, sa froideur initiale ( et relative) disparaît et les timbtres me semblent alors plus "analogiques',donc plus vraisemblables.
Belle et nette évolution donc au final de la xmos vers la Hecate.
P.S. j ai constaté aussi -sans grande surprise-que la qualite du câble d alimentaion de son alimentation stabilisee externe avait une incidence considerable sur la musicalité de cette hecate
