Patrick G.
tres bonne conception
Abdoulaye D.
Soudure
Abdoulaye D.
Pince 3 in 1
Cernat G.
WONDOM AA-JA11117 Functional Cable Package for JAB3+ / JAB4 / JAB5 Boards To facilitate the use and integration of JAB3+, JAB4 and JAB5 modules, Wondom offers a kit containing all the cables and accessories needed to fully exploit their functionalities.
Functional
Got this mainly for the potentiometers. A must have extension kit for wondom jab3/jab3+/jab4 based projects. Brings lots of functionality.
Cernat G.
Hexagon Socket Round Head Wood Screw Steel 8.8 M3x16mm Black (x10) These wood screws made of Steel 8.8 / Carbon alloy with black nickel surface treatment have a curved head with hexagon socket. They ensure good strength and durability.
Great
Good quality product.
Cernat G.
Nikola C.
Very good cable for the money!
I have bought it about 2 weeks ago and was waiting till now for the sound to open up completely.
Before I had Van Damme LC-OFC 2x4mm...also very good and hard to beat for the money.
But since I needed longer cables and also wanted to finally try to bi-wire speakers I went to try this one.
The difference was felt right on because of bi-wire.
Sound was good from beginning also...a lot of detail, better separation and more airy...but it lacked some bass quality from V.D. cable.
Now after all this time I think sound is so good that it can't be better for that cable range level. Will see.
Very neutral cable...at least in my system.
(Abrahamsen V2 up, Denafrips Pontus DAC, Rpi DIY dedicated streamer,TL speakers-IPL S2TLM )
Hervé M.
USB
Très bien, envoie rapide, les fils sont déjà étamés ce qui facilite la soudure! Parfait
Franck M.
Excellent pour mon usage...mais pas d’ATMOS (sans surprise)
J’utilise ça en entrée d’un vieux switcher audio/video avec DSP intégré et un lecteur Blu-Ray avec double sortie HDMI (dont celle qui véhicule le son vers cet extracteur). Je regarde quelques DVD et BR (quasiment rien mixé en 7.1), mais principalement Netflix via le lecteur. Aucun besoin de toucher au switch, je reste sur la position LPCM. Franchement, si vous avez la place pour un vieux et Gros récepteur de 15 ou 20 ans avec une bonne alimentation et des enceintes de bonne taille, c’est certainement une meilleure option sonore qu’acheter un récepteur 7 canaux anémique. Pas de décodage ATMOS cependant (Netflix et Amazon Prime sont mixés et 5.1.2). Il aurait sans doute fallu payer une licence à Dolby qui aurait doublé le coût du produit, et il parait que le contenu est souvent décevant....Je n’utilise pas la sortie HDMI du CYP, ni l’optique et j’aurais préféré un module avec des Jacks RCA indépendants.
Jérôme E.
VIBORG VE01R Power Plug Schuko Type F Pure Copper Silver / Rhodium Plated 250VAC 16A The Schuko Viborg VE01R uses high quality materials to ensure perfect electrical signal transmission. The contacts are made of pure Copper and benefit from a triple plating of...
A valider
Le produit est propre et efficace mais, les orifices semblent assez serrés, mon cable REAL CABLE ne rentr pas
Cédric N.
Bananes WM Audio BS 512
Elles font le job et permettent un serrage du câble correcte sans risque de casse, la finition est moyenne et l'usinage des vis manque de finesse, des points durs se font sentir sur la course du serrage, ceci étant dit aucun filetage n'a cédé pendant le montage et la fixation dans les bornes assure un bon contact le tout pour un tarif très accessible.
Cédric N.
Fourches EIZZ
Un R.Q.P très intéressant pour cet accessoire de bonne qualité avec une belle finition qui permet un bon serrage du câble sans risque de casse.
Cédric N.
Van Den Hul Skyline Hybrid
J'obtiens avec ce câble un plus bel équilibre basse, médium, aigu. Le léger voile que je constatais dans l'aigu à disparu, ce registre est a présent très fin, très détaillé mais jamais trop brillant, les basses sont elles aussi mieux équilibrées toujours toniques et tendues mais mieux détourées, les restitution a en fait plus de charme.
Il se trouve que c'est cette référence de chez Van Den Hul qui est utilisée pour réaliser le câblage interne de mes enceintes, du coup je ne pouvais pas être plus cohérent dans mon choix et le résultat encore une fois est bluffant surtout pour ce tarif !
François L.
très bon filtre actif
Cet appareil fonctionne vraiment très bien, pas de souffle, l'utilisation d'un filtre actif de ce type avec corrections paramétriques fait un petit miracle sur des enceintes 2 voies.
Si bien paramétré, le gain par rapport à un filtre passif est bien réel: meilleure transparence et définition, la scène sonore est plus aérée. Bien que les DAC du minidsp soient plutôt basiques, on se rend compte qu'ils ne sont absolument pas le maillon faible du système audio.
Du coup j'ai fait l'acquisition du minidsp SHD et conserve le 2X4 HD pour un deuxième système. Je ne pense pas revenir au filtrage passif
Angelo P.
Well constructed, good clamping, torx screws difficult to tighten without a proper screwdriver.
Angelo P.
Clean, dynamic and detailed sound, harmonics of instruments well reproduced. Great cable.
Jerome B.
RAS
Produit reçu vite et bien.
Rien à redire à part merci Audiphonics ;-)
TOPPING D30 PRO Balanced DAC 4x CS43198 32bit 384kHz DSD256 Black Powerful and compact balanced DAC, the digital-to-analog conversion stage of the Topping D30 Pro is based on no less than four Cirrus Logic CS43198 chips. These enable it to...
son HIFI
je l'ai connecté en XLR à mon topping A90, son précis ,net , qui s'exprime sans retenu avec une puissance bien présente.
les voix sont chaudes ..bon achat
petit mais costaud
son restitué de façon precise et sans empreinte tonal du circuit electronique de l'ampli.
Je recommande sans probleme
Vincent B.
Simple (un peu trop peut etre) et efficace, mais...
Tout est dans le titre. Ou presque.
Pour qui cherchera à faire une extraction audio d'un lecteur DVD/BlueRay je pense que le produit fera l'affaire (bien que je n'ai pas testé le produit dans ce but).
Par contre pour qui voudra extraire l'audio de flux videos avec du dolby digital / dts ou dolby digital ex (etc... par exemple d'un decodeur video) là plus rien n'est certain : J'ai fait l'expérience d'échecs sur plusieurs flux de ce type (malgré les 3 réglages possibles TV/AMP/DOU).
Là ou le bas blesse est l'absence d'informations sur les capacités exactes (ou détaillées) du produit et de la puce semiconn associée.
En allant sur le site de SemiConn on peut voir toutes les fonctions supportées par la puce. Mais pas de mention hélas des flux audio Dolby & Co.
En contactant le fabricant directement (yes I did lol), on arrive à choper la réponse suivante : "Some DTS or dolby audio format can be support through SPDIF output." (sic)
Dommage qu'ils n'en disent pas plus, ce serait grandement utile.
Mais j'imagine qui dit dolby ou dts dit aussi licenses...
Un downmix PCM stéréo aurait été grandement utile il me semble (comme vu sur d'autres produits).
Bref pour ceux qui sont dans cette problématique de flux DTS/Dolby je conseillerais plutot d'aller voir la ref suivante : CYP CPRO-SE2DD ( https://www.audiophonics.fr/fr/extracteurs-hdmi/cyp-cpro-se2dd-convertisseur-hdmi-uhd-dts-dolby-digital-vers-spdif-rca-p-11932.html )
Bonne extraction audio a tutti !
XDUOO XA-10 Headphone Amplifier Balanced DAC 2x AK4493 Bluetooth 5.0 32bit 768kHz DSD512 The xDuoo XA-10 is a balanced headphone and DAC desktop combo amplifier. With a beautiful design, it delivers excellent audio performance for rich, accurate and immersive...
Bel appareil bien fini, nombreuses possibilités de branchement et caractéristiques de premier ordre.
La prise en main est très facile.
A l'écoute le son procuré est simplement superbe sur toute l'étendue du spectre audio (respectueux du message originel)
De plus la possibilité de branchement symétrique est un plus.
Je suis plus que satisfait de cet achat, que je peux recommander.
Bel objet
Objet bien fini et de qualité.
Remplit très bien le rôle pour lequel il à été conçu.
Suis pleinement satisfait de cet achat
ONDER O.
Very good looking products
Price and quality is nice . recommended.
ONDER O.
Very nice and good looking products.
For the money quality is very good.
ONDER O.
Good Quality
expensive but it looks very nice on the cable.
ONDER O.
Good Quality
it's good quality product.
ONDER O.
good quality
ONDER O.
Very good entry level speaker cable
You can immediately hear the difference of the speaker cable in the high-end music system. The main thing here is to find the speaker cable where we can get top-notch sound without spending a lot of money.
So I'm trying to find the speaker cable that I can get the best performance by trying low and mid-priced cables.
Viablue sc-4 was a good price-performance cable. The sound stage was wide enough, Upper and mid frequencies were detailed and well-bodied, the bass was tight and strong.
If I will make some comparisons;
Highs are rolled off and the sound stage is narrower on the Viablue sc-2.
Highs, mids, bass and stage performance was 5% worse on the Qed xt-40.
The much more expensive Vandenhul revelation was very close.
Viablue sc-4 performance 5% lower than the VDH revelation.
I can say that VDH Revelation and Viablue cables are generally well balanced cables.
At this price level, the vialue sc-4 is a very successful speaker cable.
Aurélien B.
J'utilise l'ampli dac sur la sortie optique de la TV. Ça améliore bien le son de mon casque par rapport à la sortie jack et il n'y a plus de bruit parasite.
Attention en revanche a ne pas trop pousser le son, suivant le casque utilisé ça peut l'endommager.
Merci au sav très efficace qui m'a envoyé une alimentation toute neuve pour remplacer celle d'origine qui avait un dysfonctionnement et qui est à première vue de très mauvaise qualité.
Dario G.
Très efficace.
Produits très efficace, pourtant partie d'une alimentation spécifique..
Ce produit recule encore la distorsion, meilleure aération, douceur et réalisme des timbres.
La basse de la source...
Adelmo T.
Je suis très surpris de la qualité de ce câble. J'ai remplacé un câble 3 fois plus cher par le Neotech, fantastique. Très forte recommandation!
Giovanni M.
Molta buona
Per un mio progetto da anni cercavo una scheda del genere ,fino a qualche giorno fa non conoscevo questo sito ,appena l ho visto l ho acquistato subito. Alla ricezione della merce mi è arrivata danneggiata,ma il supporto clienti ha subito risolto la problematica è posso confermare che la professionalità e competenza è alti livelli. Per la scheda veramente ottima.
Giovanni M.
Condensatore top
Conoscevo il produttore dei condensatori, li reputo uno dei primi mondiali per cui posso dire solo eccellente qualità, il venditore ha prezzi bassi ma di alta qualità di materiali
Giovanni M.
IEC C20 Inlet 3 Poles This IEC C20 (male) socket will allow you to mount your power connectors and connect a cable with IEC C19 (female) connector. The base plate has 3 horizontal poles and is often...
Eccellente
Presa fantastica, non l ho ancora montato, ma il materiale è di buona qualità. Il fornitore è eccezionale una supporto efficiente, comprerò molto da voi.
Denis K.
Excellent appareil
Une découverte que ce petit appareil. Le DAC est très performant sur le papier, et à l'écoute aussi (Entrée USB - Flac 44.1 et 96: tout est nickel). L'ampli casque est précis et pas du tout agressif, largement suffisant en puissance pour mon AKG 702.
La sortie ligne (un ampli PP à tubes derrière) est sans défaut. On entend tout, et le son est très naturel.
Alim intégrée, ergonomie au top....
Le BT fonctionne bien (je n'utilise pas trop, juste testé.....). Ce n'est pas la philo de ce type d'appareil, je pense, mais c'est un plus.
Les 2 volumes (ligne et casque) sont indépendant et mémorisés: parfait.
L'écran n'est pas bien grand, mais l'appareil lui même est très petit. De toutes façons, une fois les réglages faits, on l'oublie, sauf éventuellement le réglage du volume.
Il me reste à explorer les filtres (il y en a 6) pour bien comprendre à quoi ça sert, et si ça s'entend.... Mais tout le reste est très bien conçu et facile à mettre en oeuvre, aucune faute de goût.
Et à ce prix là.... Rapport Qualité/Prix imbattable. Même pour le DAC seul!
Merci au support technique Audiophonics (Mr Aubert) pour les conseils avisés.
Jacques B.
Tres bon produit, fonctionne parfaitement
Denis K.
Reçu dans les délais les plus bref, ce câble remplit bien sa fonction. Construction de qualité, rien à redire. Associé à un Objective DAC. Seul bemol: s'il existait en plus court, ce serait pas mal.
Nicholas R.
Great microphone, very easy to use!
I was very impressed with the build quality and packaging of this microphone. The compatibility with Room EQ Wizard is likely the reasons others will be looking at this mic, and in that regard it performs very well.
Fred F.
Sonorité exceptionnelle
Câble de très grande qualité (conseillé une fois de plus par M.Aubert David, merci à lui !!!) qui transforme mon installation en remplacement du câble grand public. Un bon système nécessite ce type de câble. Il supporte largement la comparaison avec un câble 10 fois plus cher de grande marque que l'on voit dans les magazines spécialisés. Et cerise sur le gâteau, fabriqué en France.
Encore une fois, merci Audiophonics !
Jean Louis G.
cable
Excellent câble que j'utilise depuis son achat dans le grave en remplacement d'un câble pur cuivre industriel. La voie a retrouvé un tonique et un naturel remarquable, améliorant l'image sonore et l'ambiance ds enregistrements "live". diamètre imposant mais assez facile à dénuder.
Patrice G.
Bien mais...
Ces fiches bananes sont jolies, elles font leur travail.
Le prix de vente, comme tout le matériel en hi-fi est complètement surdimentionné. Ces fiches peuvent être trouvées sur des sites chinois à quelques euros. Alors que dire des autres produits ???
Boitier ECO EP1153220
Faciles à souder, on peut même le faire plusieures fois si besoin !
Utilisé en cable de modulation RCA
Très bien, de belles basses, un son plein, une belle énergie.
francois R.
Dépassé par le Canare L-4E6ATG ou L-4E6AT
J'ai pu comparer les Canare L-4E6AT vs L-4E6S, sur mon systeme transparent en XLR entre ampli et dac, ca s'entend à l'avantage du L-4E6AT. Les 2 cablés identiques en XLR de 1m selon datasheet Canare. Ce qui confirme bien les avis des audiophiles coté Asia.
Vraiment dommage que Audiophonics ne propose pas ces cables qui mettent tout le monde d'accord: respect de l'ensemble de la bande passante (aigus fins et conservés, basses precises)
Lionel C.
Utilisé pour raccorder deux paires d enceintes Yamaha pianocraft (une paire côté bureau et une côté lit) sur un seul ampli yamaha E810 : aucune perte de musicalité audible avant - après.
Très facile d’utilisation
Le petit modèle est largement suffisant et aucun problème place pour des connexions avec des câbles de 2x2,5
Jacques B.
Un accessoire efficace
J'utilise le filtre iFi Audio DC Blocker en entrée du conditionneur secteur qui alimente ma chaîne hifi. J'en utilise également un deuxième en entrée d'un transformateur d'isolation qui alimente d'autres équipements ailleurs dans mon logement.
Mon conditionneur secteur contient un transformateur toroïdal et émet, de temps en temps, un ronflement léger, perceptible seulement à proximité immédiate et inaudible à ma place d'écoute, même en l'absence de musique (intervalle entre deux pistes).
L'accessoire n'a pas supprimé entièrement le léger ronflement, mais celui est subjectivement plus faible, encore moins gênant. L'effet le plus marquant est une nette amélioration de la transparence de la restitution musicale: elle est plus propre, avec des détails supplémentaires et surtout, la scène sonore a pris une nouvelle ampleur (hauteur, largeur et profondeur), remarquable sur les enregistrements qui s'y prêtent.
Pas de modification de la signature sonore, ni les basses, médium et aigus n'ont été influencés dans un sens ou dans l'autre.
Ailleurs chez moi, l'effet est visible sur un écran PC de qualité: image plus propre, couleurs plus profondes et naturelles; c'est très visible sur des photos numériques.
Comme pour tous les accessoires qui agissent sur le courant électrique, une période de rodage est nécessaire. Je l'ai trouvée ici assez longue: cet accessoire a atteint son plein effet en deux semaines environ.
Je recommande, avant la mise en place, le traitement de l'entrée IEC de l'accessoire avec un produit améliorant le contact afin de limiter les pertes d'insertion.
Jean F.
A BESOIN D'UN BON FER A SOUDER
Soudure utilisé avec des bornes banane Atohm WT-FB-1960-G.
Pas évident de souder deux câble 2,5 mm2 dans la même bornes.
Il faut effectivement un bon fer.
Jean F.
TRES BON
Sertissage impeccable. Utilisée avec la plus grosse section de câble des cosses, donc très bon contact.
Jean F.
Pas utilisées, mais ...
Cosses identiques aux 2,8 mm et 4,8 mm déjà utilisées, donc pas de raison pour qu'elles soient moi bonne .
Jean F.
MUNDORF 4.8G Insulated Female Blade Terminal Gold Plated 4.8mm 1.5-2.5mm² Blue (x10) These female blade connectors allow a simple and fast connection/disconnection while ensuring excellent contact. The contacts of these connectors are gold plated to provide very...
PRODUIT TOP
Idem que cosse 2,8 mm
Cosses utilisées avec câble Atohm ZEF mini 2,5 mm2. Le contact semble Ok (pas de jeu).
Un peu de difficulté pour enficher sur cosses mâle des haut-parleurs Atohm, mais ça bouge pas.
Je n’ai pas de comparaison avec câble directement soudé à l’argent, mais ça semble équivalent.
Pas de mauvais contact à l’écoute (même à très fort niveau), mais il faut une bonne pince pour un sertissage Pro.
Jean F.
MUNDORF 2.8G Insulated Female Blade Terminal Gold Plated 2.8mm 1.5-2.5mm² Blue (x10) These female blade connectors allow a simple and fast connection/disconnection while ensuring excellent contact. The contacts of these connectors are gold plated to provide very...
TRES BON
Alberto S.
similar of many others
From China many pseudohifi objects. Nothing special. Not good not bad; just enaugh for modest hifi setup. Quick courrier.
