Francis B.
Étonnant
Un peu plus de transparence.
Un peu plus de profondeur dans les basses.
Pas mal vu l’investissement raisonnable! Excellent.
pascal B.
petit tweeter
rapport qualité/prix exceptionnel pour ce petit tweeter qui associé à 1 large bande de 13 cm a permis de restaurer de façon...
Eric v.
connexion
Customers reviews - There are 19232 reviews.
PIERRE R.
fil argent 1 mm en audio
Ce fil d'argent de 1 mm gainé de téflon avec le fil de retour plaqué contre la gaine pour le bifilaire et le tout entouré d'une gaine téflon plus large réalisent le meilleur câble de liaison entre le lecteur et le préampli à ce jour dans mes réalisations . En câblage interne il est remarquable en fluidité et précision !
Klaus B.
Impressing SPDIF-source at low price
I use this Interface combined with a RPi 3B and Volumio (which I already used before). My DAC is the AK4495SEQ-Board from Audiophonics.
This Interface is absolutely astonishing: very tight bass, nice voices and superb positioning of the Musicians. I didn't await this quality for that price!
Nicolas Rafail P.
TOPPING D10S DAC USB 32bit/384kHz DSD 256 XMOS U208 ES9038Q2M Silver Revisited version of the D10 from Topping, the D10s is an office DAC with impressive capabilities in its price range. This second version includes an ESS ES9038Q2M 32bit...
Solid, goodlooking, professional
I immediately loved it, a piece of equipment that complements every desk! Clear sound that perfectly matches my SMSL SP200. I really like the display depicting audio format (PCM or DSD) and sampling rate of the track playing.
Nicolas Rafail P.
POWER and THX quality combined!
This is trully an afordable, serious piece of equipment capable of producing the cleanest of sounds with enough power to drive ANYTHING you give it.
Nicolas Rafail P.
Really good quiality and looks nice on my desk!
Apart from the quaity i really valued the fact that 75cm version exists, that 100% suits my needs.
Nico V.
Great DAC !
Excellent DAC ! All in one - Amplifier with volume control incl. Remote control and working fine ! If you use a UP-OCC self made USB power cord it is even better in performance. Toslink is working fine.
Nyirö F.
fast shipping!
I'm still testing the sound.
Volker E.
Incredibly good DAC: Fantastic sound, stylish and very affordable!
First of all I would like to praise the support here, who answered all my (partly senseless) questions before and after the purchase.
To the initial situation: I have Adam active loudspeakers, which are controlled by an Abacus preamplifier. My old DAC was getting on in years. I have been thinking for a long time about which new DAC to buy. The only thing that was clear was, that it should be a Sabre, because I love its timbre. So I came to this product, which sounds at least five times more expensive than priced here. The room expands dramatically, both in width and depth. And even if it sounds like a cliché, you can now hear details that were previously imperceptible. At the same time the sound remains harmonious, because it does not dissolve in the manifold details, but wins through this in harmony - in my opinion a quality of the Sabre-Chips, which was perfectly staged here. The bass range plays much more nuanced. The highs are now even faster but silky smooth - The Adam performs very well with this DAC.
The assembly was easy, Volumio explains itself and the speaker looks stylish with the display. The remote control is a real asset, because you don't have to constantly reach for the iPad to control the playback.
I can only recommend the DAC all around. Thank you very much for this cheap and great device and many greetings from Berlin, Volker
Jean-Marc H.
Excellentes fiches, très belle fabrication.
Branchées en sortie de blocs mono à tube.
Ce qui a motivé cet achat était de remédier à l'inévitable oxydations de l'extrémité du câble, qui apparait au bout de quelques temps, lorsqu’on branche en direct sur les embases.
A ma grande surprise on y gagne aussi en qualité sonore. Oui surpris, car jusqu'alors, j’étais convaincu que moins on met de connecteurs sur le trajet d'un signal mieux on se porte.....et pourtant !
Attention la différence n'est pas énorme, un léger gain en clarté dans le haut médium et un grave un poil mieux articulé.
Eetu B.
Very good version of the LM3886
First pair of the amplifier boards I ordered were broken out of the box and I had to send the boards back. Despite the inconvenience, Audiophonics replied kindly and took quick action on replacing the boards. Thankyou for the excellent support! I've had the amplifier boards in use now for half a year and they sound awesome. bursting some real power out of them has never been a problem, since the board is well designed and has good fail safe mechanisms. Only improvement I can think of would be a rigid packaging for safer transport and some kind of note containing the boards information and hardware requirements.
Paul C.
Allo Digione Player Raspberry Pi 4 avec alimentation Allo Shanti
Après avoir installé le kit EvoDac avec Raspberry PI 4 dont les résultats étaient déjà excellents, mon souhait était ensuite d'installer un DIRAC Live numérique.
Pour ce faire, ce Dirac (à venir) devra être installé entre deux sources numériques, d'ou l'acquisition du Allo Digione player Raspberry PI 4 avec son alimentions Allo Shanti, directement branché sur le EVO DAC.
Les résultats sont impressionnants au niveau des différents critères auditifs. Nous gagnons encore en profondeur de champ auditif, aération holographique, définition, assise et impact des graves et bien sûr en musicalité.
Toute ma reconnaissance pour les conseils et assistance des personnes d'audiophonics, qui n'ont pas ménagé leur effort pour m'aider à cette installation dans mon système actuel.
Très bon produit!
J'ai des modèles Neotech argent et cuivre en usb, permettant aussi de comparer avec ce Pulsar.
D'emblée, le Pulsar procure une restitution détaillée, avec de jolis timbres. Comparé au Neotech usb cuivre, c'est le même niveau de qualité pour ce qui est de la définition. Le Pulsar sans doute grâce à l'argent, procure cet aigu fin et capable de variété, sans que ce soit aussi marqué que sur le Neotech argent.
Sur mes appareils, le Pulsar a un équilibre plutôt rond, concernant le grave, le haut grave et le bas médium. Comparé au Neotech cuivre, le médium semble un peu en retrait mais il a une douceur de velours qui à mon avis est un des caractères du câble.
Attention ce qui est valable chez moi ne l'est pas forcément ailleurs!
Ce qui est certain, ce câble est de grande qualité pour un prix accessible, et peut être essayé à côté des meilleurs câbles usb.
Je le préfère sur mon installation casque, et réserve le Neotech cuivre sur ma chaîne avec enceintes car le résultat et l'équilibre sont les meilleurs que j'ai trouvés pour l'instant.
Sur casque, le Pulsar fonctionne très bien, je le préfère au Neotech usb silver. Ça joue sur peu, sans doute des goûts personnels plus que la qualité des câbles.
très recommandable
J'utilise depuis longtemps le Neotech usb argent.
Surprise avec le cuivre, je n'ai pas le même rendu! dans le bon sens car c'est très équilibré, avec un médium bien présent. C'est cohérent, lié du grave en passant par le haut grave le bas médium, jusqu'au médium.
Globalement équilibre ressenti comme neutre, le grave n'est jamais envahissant, il est défini et à sa place, les voix chantées sont très cohérentes. L'aigu est de très bonne facture, je dirais qu'après avoir essayé d'autres câbles avec de l'argent, le rendu est sensiblement différent avec le cuivre seul. J'ai tendance à préférer, mais avantages et inconvénients aux deux métaux.
Pour le Neotech usb argent, c'est plus rond en bas, un aigu fin et détaillé comme l'argent sait apporter, mais son gros défaut chez moi est le médium qui semble en retrait, chose que je n'ai pas du tout avec le Neotech cuivre. Les 2 apportent autant de détail, la qualité de ces câbles est là, en dehors d'histoires d'équilibre.
Attention c'est sur mes appareils et je pense que ce n'est pas transposable forcément ailleurs! le Neotech silver chez un ami rend différemment, il est sec en bas et plutôt montant.
Diego H.
Trés bon pour le prix!
J'ai acheté cet op-amp en 2014 avec le AD797 et le BB OPA2604AP pour mon Audinst hud-mx1 dac-amp, et comparé au LME49860 de stock, le OPA627 était le meilleur pour moi. C'est curieux, il est le BB OPA627AU en double re-furbished, le prix du même est de 24€ sur Digikey et Mouser..
J'ai eu la peine d'essayer les quatre opamps soigneusement et vraiment j'ai coincidé avec des autres rapports sur internet: il est un peu plus dark, mais plus naturel. Il est moins 'étincellant' aux aigus mais plus vrai aux moyens-freqs.
Six ans se son't passés de célà, ja'i comparé avec d'autres dacs et toujours content. Merci Audiophonics.
Kevin H.
Anodized Aluminium Push Button with Orange Light Circle 2NO2NC 250V 5A Ø19mm Black This bistable switch (two positions) 250V 5A in anodised aluminium incorporates a beautiful orange LED. It is ideal for all your DIY projects and assemblies, especially as an...
Nice power switch
I bought a couple of these to change the original in some mono block power amplifiers. They work just as a switch should do, and the orange LED ring is very discrete. I am happy with my purchase.
Gabriel A.
Le boitier ultime ?
Cela faisait quelque temps que je cherchais un lecteur réseau/préampli/DAC avec quelques caractéristiques spécifiques:
- sorties XLR
- lecteur réseau "open-source", ici avec un Raspberry
- DAC de qualité
- pilotable via télécommande
Je dois dire qu'au vu de la fiche technique, ce modèle était idéal. De plus, chapeau à Audiophonics, vous montrez les mesures et faites tester certains de vos produits sur Audiosciencereview. A l'heure où nombre de marques audiophiles ne montrent quasiment pas de mesures, ça fait plaisir.
Ma chaine hifi: enceintes amplifiées Rowen AT1 (les ancêtres des PSI A215M), lecteur CD usb Asus Impresario, platine vinyle Stanton ST150 (sorties SPDIF). Il faut dire que les enceintes sont très précises et ne pardonnent pas un mauvais maillon.
L'assemblage: est relativement facile pour une personne comme moi qui a déjà monté des ordinateurs. Il y a eu une erreur de vis (la mauvaise dans le sachet) mais c'est entré en ordre avec Audiophonics facilement (très bon service d'ailleurs)
La finition du boitier respire la solidité. c'est beau, on a envie de le mettre en avant. Rien à dire.
La configuration du lecteur est facile, mais étant habitué au monde Windows en X86, allumer et éteindre un ordinateur se fait souvent à chaque utilisation. Ici j'ai eu le souci qu'en gardant cette habitude, le système d'exploitation ne fonctionnait plus au bout de quelques jours. J'ai donc changé la physolophie et je laisse le DAC H24 allumé. J'ai installé l'image Volumio modifié par Audiophonics, cela marche impeccablement.
A utiliser c'est très facile, le produit se pilote facilement. L'utilisation à la télécommande fonctionne très bien.
Le son ? Rien à dire. Il suffit de voir le test sur Audiosciencereview pour voir que ce DAC est très bon. Gros avantage: j'ai littéralement aucun souffle provenant du DAC. Il faut vraiment coller les oreilles aux enceintes pour entendre un petit frrrrrr mais c'est du aux enceintes.
Deux points d'améliorations à mon gout:
1) pouvoir dimmer la puissance des écrans
2) ce souci étant lié à la plateforme raspberry et Audiophonics n'y peut rien: avoir un stockage en SSD via connexion PCI-E. En esperant que le prochain Raspberry 5 le fasse et que son format soit au milimètre près le même que le 4 pour facilement upgrader. En effet, le stockage via micro-sd est assez lent.
En résumé: un excellent produit au très bon rapport qualité/prix.
Maxime D.
Très bon produit, très facile d'utilisation, sur Windows, il suffit d'installer le pilote et c'est terminé. La qualité est top, même sur du matériel bas de gamme, comparé à une carte son de PC, c'est le jour et la nuit. Je n'ai pas encore testé avec du DSD.
C'est vraiment une solution tout en un ce boîtier, plus de problème de son selon l'appareil que l'on branche, du coup pas besoin de se réhabituer.
Michel L.
Mon seul point de comparaison étant les IPods de Apple je ne peux qu’être content
Le rendu est bon le son reste clair la scène sonore a même un peu de relief
Je les ai connectés sur mon ampli casque sédentaire on entend la différence ce qui est également une preuve de qualité
Excellent rapport Q/P
Alain R.
Sheath 100% PTFE Transparent AWG18 Ø 1.0mm This PTFE insulation sheath allows to insulate a bare or already insulated conductor of 1mm diameter maximum. Transparent, it leaves the conductor visible.
Bon produit pour câble DIY.
Je rectifie mon précédent avis.
J'ai écrit que cette gaine était trop petite pour passer un fil de 1mm de diamètre.
En fait, les tolérances de fabrication font que vous pouvez tomber sur une gaine de 0,9mm ou sur une gaine de 1,1.
D'autre part, cela dépend aussi de la longueur que vous voulez gainer. Si c'est 50 cm, c'est assez simple, si c'est plus d'1m ça va se corser. E si vous voulez gainer du fil de cuivre émaillé (qui fait un peu plus d'1mm de diamètre...
Il faut donc prendre en considération tous ces éléments.
Alain R.
J'ai utilisé cette gaine pour isoler un fil d'argent de 0,8mm de diamètre, sur environ 1m.
Pas de problème.
Par contre, elle est trop petite pour un fil de 1mm et pour 3 fils de 0,5mm torsadés. Il faut prendre la taille au dessus, la 1,5mm de diamètre.
Alain R.
PTFE Sheath AWG14 Ø1.5mm Transparent This PTFE insulation sheath allows to insulate a bare or already insulated conductor of 1.5mm diameter maximum. Transparent, it leaves the conductor visible.
J'ai utilisé cette gaine pour enrober trois fils d'argent de 0,5mm de diamètre.
Il faut cette gaine de 1,5mm pour passer ces trois fils de 0,5.
La gaine de 1mm est trop petite.
J'ai passé mes trois fils sur 1m, sans problème.
Alain R.
Très joli connecteur XLR
Je voulais abandonner la connectique dorée et revenir à l'argentée.
Mais l'argent fini par noircir.
La protection rhodium est idéale, c'est dur en surface et ça ne bouge plus.
Le connecteur est parfaitement usine avec une belle finition.
Isolant en téflon pour une excellente isolation.
Il se connecte parfaitement avec l'embase du même fabricant CF201.
Le rhodium est un peu délicat à souder à l'étain. Il faut soit le gratter un peu pour arriver à la couche inférieure argent ou cuivre, soit chauffer un peu fort.
Par de risque, le téflon résiste parfaitement.
La doc dit qu'il ne faut pas un câble de plus de 11mm. Je rajoute que le câble ne doit pas descendre en dessous de 8mm, sinon le connecteur ne pourra pas assurer son maintien, le serre câble intégré s'arrête à 8mm. Il faudra avoir recours à de la gaine thermo si le câble est un peu plus petit.
Alain R.
VIBORG CF201 (R) 3 Poles Female XLR Panel Plug Silver / Rhodium Plated Pure Copper (Unit) This 3-pole XLR female Viborg CM201(R) XLR base has an exemplary design thanks to the use of the best materials. Indeed, the contacts of the base plate are made of 99.998% pure...
Très belle embase.
J'ai mis cette embase sur un ampli DIY à base de modules classe D de Purify.
Elles sont lourdes, massives, très bien usinées et à la finition parfaite.
Le maintien du connecteur de la même marque XF-202R est très bon avec une petite bille.
L'isolant téflon assure une excellente isolation et un confort supplémentaire lors du soudage.
Oui car pour souder sur le rhodium, il faut soit gratter un peu ce rhodium soit chauffer assez fort avec du flux.
Mais ça se fait sans problème.
Michel L.
Excellente solution nomade HiRes
Testé à partir de Tidal lis tous les fichiers avec un excellent rendu respect des timbres et spatialisation correcte convient très bien à l’IPhone encombrement réduit bonne ergonomie design sympathique
Que demander de plus à ce prix ?
Ils sont forts ces chinois
Joerg K.
Great little enclosure
Am very satisfied with this purchase. Nice design and well built. Changes the looks from the previous "cheap" plastic housing. Parts are well machined and everything fits in perfectly. Well worth the money
Paul D.
Excellent boîtier!
Coffret d’un usage simple, avec plusieurs possibilités d’agencement, très facile d’utilisation,
Il manque 4 pieds en caoutchouc, mais toutes la visserie est fournie! Impeccable!
Olivier B.
Bon
Très bonne qualité globale/ finition carte et écoute sonore, portée bluetooth même sans antenne.
Faible consommation.
Jeremy M.
Correspond a ce que je rechercher
Le produit ma été conseiller par le service client, je lai recus dans le délai et correspond bien a mes attentes.
Résultat mon ampli a retrouver de sa jeunesse et un son de meilleure qualite.
Jean Claude L.
excellent produit
Je suis entièrement d'accord avec le message précèdent de Pascal.
très bon produit qui peu rendre bien des services sans du tout dégrader la qualité audio.
A recommander.
Jean Claude L.
produit de très bonne qualité, bien fini. Bande passante très équilibrée grave excellent.
comparé à mes autres jumpers qui pourtant sont très bons dans le médium aigu , avec les 1867 phono j'obtiens un peu plus de graves
et de ce fait un peu plus de relief .très bon rapport qualité prix.
Pourquoi dépenser plus quand il manque rien!
Erhard B.
FURUTECH e-TP60E 6-Port Gold Plated Plug The e-TP60E is a luxurious, sophisticated power distributor that eliminates the problems common to Audio-Video components and caused by polluted electrical current.
very good performance
Best price for this item in Europe
Peteris B.
-good product!
Quentin B.
Très bon produit utilisé pour remplacer une prise uk
Quentin B.
Quentin B.
Très beau produit
Mais je n’arrive pas à régler le sens de la phase. Peu importe dans quel sens je mets la prise il me met toujours inversé. Du coup je ne comprends pas...
Quentin B.
Je l’ai rajouté à mon raspberry pi de chez ALLO, il marche instantanément pas besoin d’installation ni rien. Nickel !
Quentin B.
Fait le job, nickel!
Frédéric L.
Très bons "gros" câbles
Pour ma part, je suis satisfait de mon achat. Certes la câble manque un peu de souplesse et s'apparente à un "petit tuyau d'arrosage" (ou un serpent africain selon les humeurs). Mais une fois installé, c'est parfait. Les fiches bananes me semblent de bonne qualité.
Concernant Audiophonics, du traitement de la commande, à la rapidité de l'envoi en passant par la réactivité et serviabilité du service commercial, tout est parfait.
Bravo et merci à toute l'équipe
Bruno l.
Très bon cable !
J’avais en sortie de mes 4 amplis DIY audiophonics en multi amplification, 20 cm d’ ELECAUDIO FC116TC en cuivre OFC 1.6mm².
Pour voir, j’ai remplacé le câblage interne de mes amplis par de l’ELECAUDIO FC125TC cuivre OCC 2.5mm².
La différence est impressionnante, on a l’impression d’enlever un bouchon. Il y a du plus partout. + de dynamique, + d’articulation, + de profondeur.
Le cuivre OCC fait vraiment une différence avec l’OFC. Je l’avais déjà constaté avec les câbles de modulation. La différence de prix ne doit pas être un frein, c’est réellement bien mieux !
Bruno l.
Super cable !
Bruno l.
Super câble avec une articulation impressionnante
j’ai un système DIY pas trop mal, Focal audiom 15VX, appolito de cellule isodynamique fostex, tweeter à ruban Supravox avec pour driver tout cela, un audioGD nfb29h et 4 amplis classe D audiophonics STA505.
Je n’avais jamais changé les câbles HP, ( du Triangle OFC plat en 2,5mm² ) et comme je suis en tri-câblage sur 6 x 4 m, les essais ne sont pas donnés...
J’ai donc décidé après lecture des forums de tester le Mogami w3103 et Mogami 2921.
Sans aucunes hésitation, ceux sont deux très bon câbles, qui ont enterrés mes câbles triangle définitivement.
J’ai essayé le 2921 en bicablage. Il y a beaucoup d’articulation, mais on note un manque d’assise dans le grave. Après j’ai eu l’idée de relier 2 par deux les conducteurs du 2921, ce qui donne un 2 x 5mm². Et là c’est le choc ! On a le coté spatial du 3103 mais avec du mordant, du rythme et un bas médium très riche qui semble absent par comparaison avec le 3103.
J’ai essayé de mettre le 2921 dans le grave et le 3103 dans le médium-aigu. Ça ne marche absolument pas chez moi, cette configuration ne donne aucune émotion.
Par contre au final, j’ai mis le 3103 dans le grave et le 2921 dans le médium-aigu. C’est magique.
De l’émotion à l’état pure, les pieds battent la mesure et les disques s’enchaînent pour un prix dérisoire !
En résumé ces deux références Mogami sont excellentes.
Le 3103 sera parfait pour des enceintes un peu brillantes en haut et le 2921 réveillera un système un peu endormi.
Bruno l.
très bon cable, pour une ecoute apaisée
ALBERTINO GOMES A.
Excellent cable and service
Fast fast delivery (in the current pandemic time) great service from Audiophonics.
I knew the cable already and this is a great cable for the price .
Full bodied sound but manteining a very good level of detail.
Of course all the other components are very importants to get the right sinergy.
Bought this to conect to a supra md06eu ,already have another conected to my musical fidelity a300 amplifier.
A non fatiguing and easy to listen cable.
Good imaging too.
Thank you Audiophonics for the excellent service
Ugo P.
Fantastique
Très impressionnant, la qualité sonore est très nettement améliorée, même avec de la qualité Spotify premium, et les basses..sont incroyables. Avec un casque correct (ATH-M50x pour moi), je n'avais jamais entendu une telle profondeur de basse, même sur un bon ampli.
Bref je recommande vivement.
David A.
Ampli complet et de qualité
Je voulais un ampli avec une connectique complète pour le brancher à une de mes squeezebox Touch. Mes critères était l'esthétique, la qualité du matériel et la discrétion.
La boite dans lequel le MX3 arrive est de qualité, l'ampli est bien protégé. L'ampli, la télécommande, l'antenne BT et le transformateur sont bien emballés individuellement; il manque seulement les piles pour la télécommande.
Avant de le démarrer, j'ai attendu qu'il soit à la température de la pièce. Le branchement se fait très facilement. Toutes les prises derrière l'ampli sont protégées par des bouchons discrets. Avec mes gros doigts, ce fut un peu long car les connectiques sont très proches les unes des autres.
J'ai branché ma squeezebox Touch en RCA-RCA et de vieilles enceintes JBL SCS 178 4 Ohm.
A la première écoute j'ai senti que la puissance de l'ampli est inférieur au Topping PA3, logique c'était dans les spécifications !!! J'imagine qu'il faut laissé l'ampli fonctionner de nombreuses heures pour qu'il "chauffe". Mon premier test dura 2h : ce fut suffisant pour être satisfait de mon achat. Je ne pense pas avoir les enceintes adéquates mais pour l'instant je me contente de cela. Mon prochain test sera en SPDIF et avec des flac.
Concernant l'affichage celui-ci peut être réglé en intensité lumineuse uniquement via la télécommande. Cette dernière sert à régler aussi les bass et treble.
Concernant Audiophonics : j'ai reçu le colis en 2 jours : merci ! Le colis était écrasé du coté du rembourrage. Je l'ai ouvert à la poste et constatant aucun coup sur le matériel j'ai gardé le colis.
David A.
Petit ampli mais costaud
J'ai acheté cet ampli pour le connecter à une de mes squeezebox Touch. Mes critères était la qualité esthétique et matériel et la discrétion.
La boite dans lequel il arrive est de qualité, l'ampli est bien protégé.
Déjà à ce niveau le matériel semble de qualité, tout est bien emballé : l'ampli et l'énorme transfo. En effet, le transfo est très gros avec une diode bleue sur le dessus (information pour ceux qui cherche la discrétion lumineuse).
J'ai branché ma squeezebox Touch et de vieilles enceintes JBL SCS 178 4 Ohm.
A la première écoute j'ai senti la puissance de l'ampli, il en a sous le capot !!! J'imagine qu'il faut laisser l'ampli fonctionner de nombreuses heures pour qu'il "chauffe". Mon premier test dura 1h : ce fut suffisant pour être satisfait de mon achat. Je ne pense pas avoir les enceintes adéquates mais pour l'instant je me contente de cela. Mon prochain test sera avec des flac.
David A.
SOMMERCABLE ONYX 2025 Interconnect Cable Male RCA to Male RCA Gold Plated 0.5m Black The Sommercable Onyx 2025 interconnect cable is a high quality RCA male to RCA male cable at a low price. It is composed of cables with OFC copper conductors of 2x1x0.25mm²...
Câble de qualité
Ce câble (malgré son prix) est conforme à mes attentes. Il est de qualité, il est très souple et il me permet de connecter une squeezebox Touch à mon ampli Topping PA3.
José G.
Très bon produit. Simple à brancher
J'aurais du l'acheter avant
Johann a.
FX-AUDIO TUBE-02 Headphone Tube Amplifier 2x 6K4 Silver With this TUBE-02, FX-Audio offers a low-cost tube headphone amplifier with a neat design for a neat audio reproduction. Based on two 6K4 tubes, it will allow you to enjoy the...
Bon rapport qualité/prix imbattable
Appareil qui m'a permis de connaître la marque, rien à dire à part une sacré surprise niveau clarté et rendement. Le son tube pour réveiller enfin un casque assez difficile (Fostex T50RPmk3). Les tubes d'origines sont pas mauvais mais ne pas hésiter à les changer pour de l'équivalence
Bert P.
Incredible sound for little money.
This dac in combination with sony WH-1000XM4 is a fantastic match. An auduiophil sound for little money!
I can't think of any minus points.
