Maik B.
Maik B.
Fast shipping.
The sound is excellent. Ranked 5th out of many...
Theodoros R.
NICE OPAMP
VERY NICE OPAMP FOR THE MONEY!!
Customers reviews - There are 19109 reviews.
Christian D.
Rien de spécial, à dire, c'est un bon porte-fusible!
Chebl D.
SMPS300RS Module
I am still wrapping myself around using it.The fact that it comes with no manual does not help. I will come back to you later to give you my opinion.
Christian D.
Un peu cher mais indispensable pour obtenir des résultats de qualité.
Christian D.
Très pratique.
Petite alimentation utile pour faire différents essais.
Christian D.
Indispensable!
J'avais acheté un coffret et ne savait pas comment fixer le matériel à l'intérieur sans percer le fond. Ce que je voulais éviter. Cette grille robuste a résolu le problème.
Rob S.
Surprisingly-capable detailed, dynamic, spacious, full-range sound
Not a preamp for purists or price-deluded elitists. Their loss. Featuring full dual-mono design, shunt-regulated DC, dual-stage opamp gain, relayed input switching and tri-band equalizer (!), this Chinese product offers great value for money. A most pleasant surprise.
Rob S.
Functional, well-engineered, neat industrial design
If you wish to invest in a fairly-priced, well-engineered IEC mains plug that accepts weighty-gauge wire, this Viborg plug should not disappoint. As to sonic character, it gels well with OCC copper and non-teflon dialectrics such as PET/PVC, presenting a neutral, dynamic, full-frequency result. Recommended!
Rob S.
Not as described, poor quality control, works once fixed
As of today (4 October 2020), this Audiophonics web item (Ref 11645) is described incorrectly. Of the two linear power supply modules I received in September, neither had an LT1083 regulator installed. They both came with an LT1084 small plastic format. Furthermore one of the regulators was not bolted flush with its heatsink, standing in free space 1.5mm away. Easily fixed, sure. But very poor quality control. As we are dealing with voltage and current (and sensitive, costly connected devices), please check your item carefully once it arrives. Enjoy!
Edwin P.
Nice sturdy power strip. The sockets have strong springs, gives a tight fit on the plugs. This strip shields and surpresses radio frequencies that disturb the audio. The side ends are plastic so it is not completely shielding but it works as wanted and it's positive for the micro audio signals.
The feed rails does not have a cross section of 6mm² but it is ca 5 mm2.
Elsa A.
Embase complete
Embase compacte très pratique pour le DIY, rapport Q/P imbattable , idéale serait avec contacts Au ou autre excellent conducteur au double au plus du prix, mais bon...
Elsa A.
Elégant cache!
Élégant cache pour refermer une ouverture XLR d'un ampli dual transformé en mono, en tous cas masque élégamment toute prise XLR devenue inutile.
Elsa A.
Excellent boitier
Très belle et très luxueuse fabrication , de plus les perçages de fond sont bien appropriés à l'alimentation, montage facile et très élégant , les perçages personnels sont facilités par l'épaisseur de la façade arrière, l'idéal serait avec fourniture de façade avant lisse sans perçage aucun pour les montages d'ampli mono ou autre montage sans nécessité d'accès à l'intérieur, et aussi vis de façade argentées et non noires.
Quoiqu'il en soit superbe boitier.
Victor D.
Fais le job
Premier câble optique acheté, je n'ai pas de comparaison. Semble costaud. Se branche bien, ne bouge pas, cordon souple pratique.
Audiophonics toujours au top par contre !
Francesco R.
Hexagon Socket Round Head Screw M3x6mm 10.9 Steel Black (x10) These hexagon socket round head screws are in M3x6mm format. Made of 10.9 steel, they guarantee a high durability.
Ils ne sont pas noirs, ils sont gris.
Ils ne sont pas noirs, ils sont gris clair.
Francesco R.
Hexagon Socket Countersunk Head Screw M3x8mm 10.9 Steel Black (x10) These hexagon socket head screws are in M3x8mm format. Made of 10.9 steel, they guarantee a high durability.
Ils ne sont pas noirs.
Près des surfaces noires, elles sont beaucoup plus légères
Francesco R.
Près des surfaces noires, elles sont beaucoup plus légères.
Francesco R.
Frank O.
Voor de prijs een prima kabel!
Deze kabel gekozen ter vervanging van de standaard meegeleverde Rotel Michi kabels. De WM kabel is vrij stug maar ziet er verder prima uit. Bij het verwijderen van de buitenmantel valt direct op dat deze zeer goed geïsoleerd is. Dit was dan ook meteen de reden van de aankoop. Voor deze prijs vindt je geen betere. Kabel werd heel snel verzonden door Audiophonics, waarvoor dank!
Michel B.
Qualité et solidité Irréprochables
J'avais confectionné un 1er câble XLR avec ce connecteur (et son compagnon Mâle le XLR900R-M) il y a quelques temps: la qualité est tellement impressionnante que je n'ai pas hésité une seconde lorsque j'ai dû en fabriquer à nouveau.
Jugez plutôt:
-C'est du tout métal, du très lourd et du vraiment très costaud : il n'y a pas une seule pièce en plastique et comme quelqu'un l'a déjà dit dans son commentaire, le poids sur la balance est élevé.
-Toutes les vis rentrent dans des filetages eux-mêmes en métal costaud: impossible à foirer.
-La pièce circulaire dans laquelle les 3 contacts sont enchâssés est indestructible même en étant un descendant direct de l'homme des cavernes.
-Lors du soudage des câbles sur ces 3 connecteurs, il est impossible de créer le moindre jeu même à 400°C (ce que j'ai fait), ça ne bronche pas d'un micron, ça ne devient pas souple: un vrai plaisir.
-Les contacts sont repérés par leur numéro: 1,2 et 3 du côté à souder, ce qui évite toute erreur puisque chacun le sait: il y a 3 fils à souder un connecteur XLR.
-Cerise sur le gâteau: ces pins sont également numérotées du côté extérieur...
Qualité et fiabilité sont exemplaires pour un connecteur à moins de20€ totalement indestructible, je ne vois pas la moindre chose à changer.
La seule amélioration que YARBO pourrait faire serait de proposer ce connecteur avec des contacts UP-OCC à un prix contenu: il en existe chez Yarbo mais à un tarif stratosphérique...
Alain C.
Très bon produit, livraison rapide comme toujours avec AUDIOPHONICS . On peut commander n'importe quel produit
sur ce site les yeux fermés sans etre déçu.
Yves M.
Yves
J'ai commandé cet amplificateur, je l'ai reçu très vite et en bon état par Colissimo. Je l'ai raccorde sur mon combiné audio et sur les baffles que je possédaient. Aucun problème pour la raccordement.
Je suis satisfait de mon achat.
Guillaume B.
Bonne construction
J'ai opté pour ces connecteurs (schuko et IEC de la même série) pour le cuivre pur employé et là rien à redire c'est bien fait sans fioriture, du cuivre point. Le boitier est simple et efficace, pas très esthétique mais bon il est caché derrière les appareils, donc...
VIBORG fait vraiment de bon produit.
Guillaume B.
très très bien
Un câble vraiment bien construit ce qui apporte un véritable gain acoustique, comme un meilleur control des fréquences donc moins de micro saturation, une dynamique plus franche, il apporte aussi un certain silence. Donc, bien sûr il aide votre appareil a bien mieux fonctionner. Si la section de ce câble correspond à la "consommation" de votre appareil n'hésitez pas. Encore une fois très satisfait de YARBO.
Goetz S.
KECES P8 Ultra Low Noise Regulated Linear Power Supply 9 / 12V + 18 / 19V 4A The Keces P8 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply offers a careful...
Everything worked out great
Hi,
Everything worked out great, ordered late on Monday evening and on Friday ( only 4 days later... ) the package arrived safely packed here in Karlsruhe / Germany!!
You are doing a great job !!
Serious, fast and reliable.
There is not much to say about the Keces power supply. It works great :)
Für alle deutschen Interessenten:
Audiophonics ist ein sehr zuverlässiger Shop, den ich nur empfehlen kann.
Und bitte keine Angst vor dem Versand von Bordeaux nach Deutschland:
Bis jetzt ist jedes Päckchen unbeschadet bei mir angekommen...
Die Übergabe in Deutschland erfolgt an DPD.
Von denen bekommt rechtzeitig eine Mail, wann das Paket geliefert wird. :)
Thank's a lot
Leonardos N.
Best way to connect potentiometer
Leonardos N.
Good Chassis.
Leonardos N.
Nice selector.
Leonardos N.
Smooth Potentiometer
Pavel Z.
Requires modifications
Power decoupling in this amplifier is poor: it is only bulk capacitors and two 0,1 uF film capacitors. The film capacitors are far from chip terminals so they don't really decouple anything and at the same time are close to the bulk capacitors that are low-ESR, this results in a strong antiresonance effect. You'll need at least to remove the film capacitors and then add something like SMD ceramics at chip terminals on the board back side and also add small electrolytic capacitors. See neurochrome SPICE model for an example - although I cannot recommend using solid polymer capacitors, they sounded weird here.
Also consider shorting the capacitors in feedback loop.
zhen l.
IBASSO CF01 Bluetooth 5.0 Receiver for Earphones MMCX QCC3020 aptX iBasso offers with its CF01 a discreet Bluetooth 5.0 receiver with MMCX connectivity. It will accompany your favorite earphones and will allow you to enjoy a powerful wireless...
Good seller
Fast delivery and good quality
Sylvain D.
Correction de mon précédent avis
Peut-être exige-t-il un rodage particulièrement long ?
J'avais laissé un avis plutôt négatif il y a quelques années...
En tous cas, en liaison dac-préampli, c'est aujourd'hui un de mes préférés. Alors qu'en liaison dac-intégré il est en effet un peu court dans le grave, entre un dac et un préampli je ne ressens pas de limite sur ce point.
Il propose une restitution des médiums très pleine et fluide, parmi ce que je connais de plus beau dans tous les câbles testés jusqu'à maintenant. C'est à mon sens l'un des meilleurs compromis détails/timbres, car il parvient à cumuler une opulence des timbres avec un bon niveau de transparence. L'aigu est très doux, manque peut-être un poil de rapidité sur l'attaque des notes, rien de marquant dans tous les cas.
L'écoute est assez chaude, idéale pour calmer un système incisif. Jamais démonstrative, mais tout à fait transparente.
emmanuel C.
tres bon
excellente qualité, très bonne isolation et esthétique. connexion ferme avec des fiches bananes de 4mm. je recommande !
PHILIPPE D.
pre tc 10
preampli recu aujourdui essai dans la journee tres bien mais moins bon les correcteurs en service dommage mais execellent pour le prix
pascal B.
cable rca/rca
bon câble de modulation assez universel ; très bon rapport qualité/prix
pascal B.
cable rca/rca
claude b.
fait le job , bonne connectique et fonctionnalités
bonne tenue de la batterie
mais toujours une notice chinois /anglais même si l utilisation est intuitive une notice en Français serait la bienvenue et en principe obligatoire
BRUNO B.
le top
je recherchais une solution pour brancher ma tablette a mon dac qui n'a pas de port USB ! en parcourant un forum pour ne pas le nommé, HCFR, je tombe sur un forumeur qui en fait les éloges ! après info, commandé et reçu dans la foulé, vraiment rapidement, merci a l’équipe ! cela me permet d'avoir une sortie numérique optic ou coax sur ma tablette ! elle même relié a mon DAC et le DAC, sur mon ampli hifi ! je recommande donc ! pour un budget serré !
Jacky N.
Extrêmement utile...
Ne pas utiliser une alimentation à découpage avec ce module.
Même avec une alimentation linéaire, un accrochage se produisait lorsque je déplaçais le câble d'alimentation 12V.
Cela a été résolu en soudant une capa de 470nF entre le - et le + 12V.
Lawrence T.
A Game Changer and End Game Product !!!!
Believe the hype, this is a great product best headphone amp I've had and I've had a few, I've use the balanced XLR Input so there are no ground issues at all, I don't know about RCA inputs as I've not tried these. My Audiolab Mdac+ has balanced outputs. I run Beyer Dynamic Amiron, Hi Fi Mann He 400i and Sennheiser HD660S head phones and it drives all these beautifully on low gain setting. I can't think of a better £500 Headphone amp out there, in fact you could spend a lot more and get worse results. Go Buy one today !!!
Mode Horloges
Voici une réponse de Kingwa, le fabricant, le la selection du mode des horloges.
Cher Hugo,
Dans notre test système, le son mode parallèle est plus neutre et transparent.
Le son du mode série est légèrement plus doux.
il a deux modes qui permettent aux utilisateurs de choisir la meilleure saveur sonore pour correspondre au système.
Kingwa
dominique M.
Aurait aimé un appairage pour ses deux condensateurs de bonne facture servant pour l'entrée d'un pré-ampli à tube .
dominique M.
bon câble
Me sert pour la commande du boitier trigger 12v , parfait
dominique M.
boitier bien réalisé
très bon produit et fait ce qu'on lui demande
Francisco Javier R.
Great!!
Sans conteste le meilleur op-amp que j'ai jamais ecouté. Installé les 4 dans l'étage de puissance Rotel RB-1582 MKII
Jacques D.
Une merveille
Super préamplificateur, une vraie affaire.
Je l'utilise après un pga2310, qui est même transparent mais qui n'a pas d'amplification,
mais de multiples entrées, BT et une télécommande.
Cette réplique Model Halo JC 2 sonne bien mais n'a pas la même signature qu'un étage.
J'utilise ce dernier entre DAC et pga avec beaucoup de succès. Grande synergie
j'ai u un petit problème avec le bouton de sélection il étais mal fixé une chance que jais une clef allen de 1.5 pour démonter le bouton de sélection.
la finition est parfaite. a acheter les yeux fermer c'est du vrais haut de gamme a ne pas rater. merci pour avoir mit ce produit a la vente.
Frédéric M.
Très bon matériel
Ça respire la solidité, c'est bien présenté, avec les accessoires indispensables. Le fait de disposer de la courbe d'étalonnage est vraiment bien.
Et la livraison par Audiophonics est nickel, c'est arrivé en un éclair !
Domenico G.
Très bon intra avec de très bonnes basses.
J'ai ajouté un câble Balanced avec 16 fils plaqués argents, et je ne suis totalement conquis par ces écouteurs.
Domenico G.
Whouah !!! Excellent
Je découvre les DAC et celui est excellent. Multiples connexions soit à partie de iOS ou autres (jack ou Android à condition d'acheter le câble compatible)
Depuis j'ai totalement abandonné le MP3 320K, pour passer au Flac et c'est un régal pour mes oreilles.
Damianos D.
Excellent performance and well built
Excellent performance. Transparent, fast, with no specific sound signature. Impressive accuracy in sound timbre and decay, noticeable especially in percussion (cymbals) and piano. Wide and steady soundstage. In my setup drives a pair of Magnepan 1.6.
Nice and well built assembly. My only complain is the absence of indications (e.g. XLR/RCS) on the input switch selectors at the back plate. I haven't noticed any hum or similar noise when it is switched off but remains on power. In any case I switched off the power strip when not used.
Concerning the shipment, very good packaging but quite long delivery time with TNT (a whole week).
EUSEBIO D.
Todo correcto
Buen producto y envío muy rápido.
