YANN P.
Excellente barette secteur
Jeroen v.
Jeroen
Kah Yeow K.
Great cable for REL
Accessoire ultime pour améliorer son système Hifi.
DANIEL.B
Quant on pense avoir tout essayé pour améliorer le son de son système HIFI (ligne secteur directe, barrette secteur hifi adéquate). On se dit avoir tout essayé dans le traitement du courant. Et c'est la qu'intervient l'ultime accessoire " L'IFI AC PURIFIER".A la première écoute de son système on est bluffé parce que l'on entend. Ouverture et naturelle sonore. Tout est plus vrai, je dirai même plus palpable. tous les genres musicaux deviennent une découverte.
Je conseille à tous les passionnés de hifi d'essayer cette merveille et surtout l'utiliser sans modération.
Un audiophile au nirvana.
Reis H.
Does exactly what you expect!
Using this to power my front Elac DBR-62 speakers (which are in a 5.1 setup) pre-out from Denon AVR-X3600h. Can I tell an immediate difference and upgrade from the Denon at the average listening levels I typically enjoy? No. Does it still sound great? Yes! So why bother? Well, I was mainly curious and wanted absolute assurance my speakers were being driven properly by an amp.
Chances are that unless you have a bad amplifier, or are asking a lot of your AVR (powering 7+ speakers at loud volumes) that can't really drive your speakers then you won't hear much of a difference, like in my scenario. It's a transparent power amplifier that will allow you to go to really high volume levels and supply the power you require for speakers that may demand more. It's a good product for doing this in a relatively small enclosure, it feels solid, and I expect to not need to upgrade again for a long long time.
It gets about as warm as my Denon so make sure you have some room for it to breath. Originally I put it in a drawer in my unit but after approximately 90mins of moderate usage I rechecked the heat and it was quite warm so I moved it outside of the drawer as a precaution.
I'm happy and received the product in 4 working days (ordered Thursday morning, here Tuesday morning) through TNT tracking which was great.
Reis H.
A great RCA cable
Honestly it's just a really nice RCA cable. Don't overthink it too much when you buy an RCA cable. The connectors feel solidly secured and subtly coloured (red/white) with the logos is nice.
Is it the right length for what you need? Do you want to spend more money for the same thing but different outside materials/colours? If not then it's pretty much all the same :)
I connected this from my audiophonics MPA-250NC amplifier to denon avr-x3600h pre-out and it worked as expected.
Stéphane L.
cable neutre et excellent
J'ai acheté ce câble pour relier une platine vinyle au préampli (cellule MC bas niveau - 0.5 tous petits mV passent par ce câble). Associé à des connecteurs ELECAUDIO TE-RC9W tellurium, soudure 10%ag il remplace un pro-ject RCA CC à titre de test, en vue de la fabrication d'un step up.
Le test est concluant. Alors que deux autre câbles testés avant "bouchonnaient" un peu le son, le NEI-3004 est aussi transparent que le pro-ject, mais avec légérement plus de détails et une grande homogénéité sur toute la plage de fréquence. Les timbres n'ont pas changés (je ne voulais pas que ça change). Ils sont bien blindés puisqu'aucun bruit ne vient perturber le faible signal.
Bref, ils sont parfaits pour moi qui aime la transparence et la justesse des timbres.
Lars Øystein G.
works perfect
On a RPi4 with RopieeeXL Connecting through AES/EBU connector to a topping D90 playing with Audirvana from MacBook Pro M1, sounds wonderful.
Xavier B.
VIABLUE UFO Vibration Absorbers Ø35mm Silver (Set x4) Viablue UFO absorbers can be used to dampen harmful vibrations by placing themselves under your speakers or HiFi devices. Due to their optimal pressure on the lower surfaces of...
Produit de qualité.
Dans le cadre de mon utilisation ce produit fonctionne très bien. Il remplace les patins d'origine ( 14 ans de bon services ) de mes JMR. J'ai beaucoup moins de résonances avec le plancher de la maison. C'est flagrant à l'écoute en étant dans la pièce en dessous.
Damien G.
Je trouves cet amplificateur très musicale, dynamique et puissant.
Le grave est parfaitement maîtrisé.
Même à volume élevé, il ne chauffe que très peu, (à peine tiède).
Un très bon rapport qualité / prix.
Thierry P.
DAYTON AUDIO APA150 Class A/B Amplifier 2x75W 4 Ohm Black The DAYTON AUDIO APA150 from 2x75W on 4 Ohm is the perfect integrated amplifier from in a small aluminum housing. Powerful and musical, it offers a real solution that is very...
Utilisation stappé en Mono
Je l'utilise pour alimenter mes Transducteurs Clark Synthesis, il est parfaitement adapté. Fréquence de coupure réglable, strappé en Mono, il est parfait.
Thierry P.
Superbe qualité (matériel et ecoute)
Le montage est très simple et bien documenté.
Seule remarque, ne pas serrer trop la bride du connecteur de la rallonge de la carte Micro SD. Un trop fort serrage a tendance à bloquer le coulissement de la carte et éventuellement en perturber la lecture.
L'écoute est fantastique, bel upgrade sur mon ensemble vintage Quelle vivacité et justesse des timbres.
Par la liaison USB d'une tablette PC et Foobar2000 c'est à couper le souffle.
Pour une utilisation ludique avec smartphone, je me suis limité à Volumio pour l'instant.
Clément E.
Rien à redire
Fonctionne correctement même si le câble fourni est un peu court (longueur spécifiée sur la page produit).
Clément E.
TOPPING TCR1-25 RCA Cable Male / Male Silver Plated OFC Copper 25cm Topping offers with the TCR1 a very good male / male RCA cable. It benefits from a beautiful design with a Silver Coated OFC copper conductor offering excellent signal...
Excellent câble, j'étais dubitatif de l'intérêt d'un câble à ce prix-là, je l'ai acheté pour avoir l'esprit tranquille en étant sûr qu'au moins mon système audio ne serait pas dégradé par la qualité de mauvais câbles.
En testant avec d'autres câbles plus "cheap" achetés sur Amazon (pourtant très populaires et pas premier prix) la différence en terme de qualité de son est inexistante, mais un bruit est présent sur les câbles, qui s'entends clairement lorsque je monte le son de mon amplificateur.
Pas de souci avec ces câbles-ci. D'autres part ils sont très solides (trop rigides en revanche) et surtout très design.
Vasilios T.
ess 9023 Raspberry pi 4
awesome sound far better from a directly connected pc , fast sipping
willy h.
Un cran au dessus!
En remplacement des condos d’origines sur médium et aigu Cabasse sloop M4 .
Élargissement de la scène, détails, définition, c’est à mon goût un très bon choix pour un budget relativement contenu.
Des cabasses qui jouent largement dans la cours d’enceintes à 3000 euros l’unité sans perdre leurs très grandes qualités intrinsèque!
Juste un manque de place pour les intégrer au filtres mais avec de la patience c’est possible!!
Bernard L.
Trés bon rapport qualité prix
Pour réveiller un "vieux CD80 " Atoll sur un streamer100 Atoll ,nickel .
Jean-Michel J.
Très pratique, bonne qualité sonore
On ne peut plus simple d'utilisation, le DAC est automatiquement identifié par l'OS et fonctionne aussitôt raccordé.
Très bonne qualité sonore, rien que mes oreilles puissent reprocher, prix très raisonnable, bref je suis totalement satisfait.
Jean-Michel J.
Pris modique et très bonne qualité de fabrication. Deux vis assurent un excellent contact, et les enveloppes thermo-rétractables assurent une joie finition. Difficile de demander mieux.
Christophe M.
Produit impeccable qui m'a permis de recabler un Sennheiser HD800 et un Heddphone. Assez fin et souple, il peut même être doublé sans problème, ce qui est plus pratique au final. Seul petit bémol, pas facile d'étamer le fil de Litz (avec les moyens du bord) sans que l'isolant en PVC ne prenne un coup de chaud.
Très satisfait !
Utilisé ici pour alimenter un lecteur réseau livré d’origine avec une petite alimentation à découpage externe.
Progrès très net.
Penser à l'ajout d'un transfo alimentation.
Philippe Q.
Des contacts sûrs
le montage est aisé
Le contact avec mes câbles est bien ferme et inspire confiance .
Philippe Q.
Une superbe finition
La qualité perçue des ces embases est excellente
Les contacts avec le tube est très ferme et donc positif
le tout à prix raisonnable
Michiel W.
Great value for money
I was looking for an affordable speaker cable to hear the effect of bi wiring. The SC-4 suits this purpose very well. It feels like high quality, the cable is flexible. To me it sounds clear and transparent, and it allows for good control of the bass speaker.
Daniel E.
Ideal pour câblage interne
Un peu rigide mais ce n'est pas gênant. J'ai été surpris de la facilité de dégainage! Bon rapport qualité-prix. Recommandé.
Andrej T.
Nice sound, nice stream over Bluetooth
This is my first DAC. Was choosing between Loxjie D30 and Topping DX3 Pro V2 to swim into the river of hi-res music. Connected via Toslink to UltaHD sat receiver for Mezzo HD music and via Bluetooth to stream from my iPhone. Sennheiser RS180 (uses Kleer technology) connected to Topping DX3 Pro. Now I can move over the home and listen to my favorite songs.
MUNDORF MLYTIC AG Capacitor 63V 8200μF These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of...
Bon fonctionnement mais un peu cher
En remplacement de condensateurs de filtrage sur un ampli intégré Denon pma710ae,donc un modèle de grande diffusion.
J'ai commandé ces modèles,ce sont les seules sur audiophonics qui sont compatibles...mais quand même très chers par rapport à des Elna par exemple.
L'ampli fonctionne normalement,un son un peut plus chalereux il me semble.
En conclusion,composant bien fabriqué et fiable,mais prix très élevé.
Bylna D.
Petites merveilles
Achetées en remplacement de lampes d'origine sur un Line Magnetic, le résultat est excellent et pourtant tout juste sorties des boîtes et pas encore rodées...
Certes un peu cher mais le résultat est plus que convainquant.
Je recommande vivement Audiophonics pour son sérieux et sa rapidité de traitement des commandes.
Plusieurs commandes depuis de nombreuses années et toujours la même satisfaction sur les produits et sur l'emballage de qualité.
jean noel B.
Qualité au top
Rapport qualité prix imbattable !!! Ils se font totalement oublier et c’est bien la plus grande qualité pour des jumpers. Ils laissent passer le signal dans son intégralité sans coloration ou atténuation. Que demander de plus .
Jean Claude A.
OK
fonctionne comme prévu, répond exactement au besoin avec en plus un prix attractif;
Vive la Chine.
YANN P.
GRAVissime
Je cherchais un câble secteur pour mon caisson de basse, mes recherches se sont d'abord orientées vers une marque comme FURUTECH, réputée dans ce domaine, puis PANGEA qui produit des câbles spécifiques pour les caissons et puis après réflexion mon choix s'est arrêté sur ce cable.
Pourquoi ?
Eh bien, on a une marque, ici, qui est réputée pour son rapport qualité prix, on connaît tous les commentaires dithyrambiques sur les DAC de cette marque, mais concernant les amplis, on tombe également dans l'éloge et les premières impressions des audiophiles s'attachent à remarquer une valeur ajoutée dans le domaine des GRAVES (aération, précision, impact etc..).
Au niveau technique, ce cable est capable de délivrer un courant important, à savoir 60A et il est entièrement en cuivre .
On a donc touts les ingrédients pour avoir un bon câble qui produit du courant et donc adapté aux caissons de basse ou aux amplificateurs de puissance.
Eh bien , à l'écoute, ces impressions se sont avérées une réalité, je peux augmenter le volume de mon caisson sans tomber dans la distorsion ou l'effet "BOOMY", le grave est plus précis, je découvre des nappes de grave sur certain morceau etc... Dans mes tests, j'ai également interchanger mon cable FURUTECH de mon ampli intégré avec ce cable et là, l'association est moins heureuse.
Donc ce câble est, à mon avis, un excellent choix pour une association qui demande du courant (CAISSON et AMPLI PUISSANCE).
Vincent L.
Furutech ncf clearline
Extraordinaire !
Dès le branchement, la scène sonore est bien plus vaste et précise, les harmoniques améliorées, les aiguës et médium bien plus précises sur mes Martin Logan et basses mieux tenues. Aucun besoin d’un système home cinéma en audio vidéo tellement la scène sonore est bien plus réaliste.
Les images vidéo sont également bien améliorées.
Bref, un accessoire bien moins cher qu’un changement de source ou de hauts parleurs!
Marc A.
EXCELLENT
La marque RAMM est à faire connaître....Que ce soit E7-891GT -1O OU LA VERSION RT tout est reproduit avec excellence.
Le rapport qualité/prix magnifique.
Bientôt test des cables HP!!!!
Léo D.
Très belle finition, matériau full cuivre (et pas seulement "recouvert" contrairement aux bananes ordinaires, entrée suffisamment large pour accueillir du gros câble. La tige métallique permet un appui suffisant contre le bornier pour maximiser le contact. Un excellent objet que je recommande !
FREDERIC G.
Agréablement surpris
Malgré les avis positifs, je ne m'attendais pas à un son si agréable. En effet il y a cette précision et cette douceur qui l'accompagne. Très bonne surprise pour de la classe D.
Je n'ai pas testé sa capacité à contrôler de grosses enceintes car je possède des modèle bibliothèques. En tout cas je valide le fait qu'en terme de rapport qualité prix il est très très bon
Pierre G.
FX-AUDIO D802E FDA Amplifier STA326 Streamer WiFi DLNA Bluetooth 5.0 Multiroom 2x80W / 4 Ohm Silver The E version of FDA D802 amplifiers from FX Audio now includes WiFI (DLNA) connections to complement Bluetooth connectivity.
Bon petit ampli pour mon usage
Vraiment bon ampli pour mon usage. Format compact. faible consommation. Pour la durabilité on verra à l'usage.
Utilisé sur ma TV en sortie optique du décodeur 4K pour remplacer mon très ancien ensemble audiophile (qui était déjà réutilisé sur ma TV).
Je cherche à bien entendre les voix. Sur certaines chaines la qualité du son est mauvaise. Idem pour certaines séries TV.
Je connecte ce D802E sur mes "Vecteur" première (2x60W je crois). Volume très bas. Heureusement je découvre la touche gain de la télécommande alors tout s'arrange.
Résumé :
- Volume suffisant sans distorsion. Suffisant pour écouter un film d'action en mode "fort".
- Equaliseur violent... sauf modes "Normal" et "Soft Rock". J'utilise ce dernier.
- A quoi sert la touche direct ? Les modes Hi-Fi et Tone on passent par l'équaliseur. Il y a cependant une infime différence audible dans les basses (ou bien est-ce un infime delta de volume ?).
- Le volume dans mon casque Bose quietcomfort ii (jack) est un peu faible. Le gain passe en low au branchement (securité ?). Il faut passer en high puis monter le son sur le décodeur canal (l'ampli est à volume 80 pour le casque et 60 pour le reste).
- Bluetooth ok
- Wifi ok avec Muzo. Attention attention attention à bien prérégler le volume avant d'envoyer la musique !
- La télécommande est peu sensible il faut se rapprocher
- On entend un très très léger "vibrato numérique" sur les voix masculines moyennes et féminines pas trop aigues. C'est mon premier FDA. Ce n'est pas du tout gênant.
- La doc est succincte...
Un outil extraordinaire mais sensible
Le device est incroyable. Très puissant. Le problème est l'instabilité de la machine.
Si je touche l'entrée spdif pendant qu'i est sous tension et connecté au Dac externes. je perds la télécommande. Elle ne fonctionne plus. Je dois la reprogrammer .... J'ai mis un temps fou à trouver le problème.. Ne pouvant me passer de l'appareil j'en ai acheté un second et fait plein de tests. Jusqu'à trouver le problème. A ma connaissance de type de filtre actif numérique est rare... faut faire avec.
Dommage aussi que le plug in soit en 96Khz et pas 192.
Andreas K.
Great Addon...
This power supply is of great workmanship. High quality components providing a fantastic sound to the ALLO Signature player. It is definitely worth upgrading to the Nirvana power supply, it lifted the connected device to another level of sound quality. Great advice by Audiophonics, their service is outstanding.
Andreas K.
Well thought-out quality player!
I got the ALLO Signature to stream my High Res audio from Qobuz to my brand new Quloos Amp via USB. Great combo, works fine, sounds fantastic. I got the ALLO Nirvana power supply in addition to the player, a good investment since it provides even lower noise clean power to the player. With volumio operating system, the player is easy to use and to configure, but there are also alternatives you can use. I'm definitely convinced by the ALLO player, another great piece of equipment in the Audiophonis wide range of excellent products.
Après quelques mois
Je ne retire rien de ce que j'ai déjà écrit précédemment, cet appareil est un petit bijoux de technologie.
Une remarque, question ergonomie, pourquoi avoir mis le bouton de réglage des basses au dessus de l'aigu, car il est logique de faire l'inverse, comme le sont toutes les enceintes. Une autre remarque, cet appareil chauffait beaucoup raccordé en RCA, et à présent à peine tiède en XLR (symétrique).
Andreas K.
What an amp!!
I have bought this amplifier after a long and extremely informative exchange with David from Audiophonics. He recommended me this amp as an ideal match for my power hungry KEF LS50. He was so right!! The amp has so much authority over the KEF's, running them with ease. The sound is amazing, detailed, clear and far away from being harsh in any way. It also has a certain warm and deepness to it, you wouldn't immediately expect from a Class D amp. The Quloos has a lot to offer, he would easily compete with far more expensive amplifiers with his specs. The build quality is very solid and for years to last. I love this thing already and I want to say thank you to David and the Audiophonics team for their advice and their patience during my decision making. This amp is an insider tip, for sure!!!
Peter S.
Hello. I'm waiting for this item (and also 'FURUTECH FT-H800 (R) ródiové konektory pre SENNHEISER HD800 pair') .
When we can await delivering?
Thanks.
guy v.
Parfait 5/5!
Ce module compact et auto-alimenté via USB est une interface parfaite pour extraire l'audio d'un PC, dans mon cas un iMac Pro sous MacOS Mojave et sous Windows 10 en bootcamp, afin de disposer de l'entrée TOSLINK de mon ampli SONY 5.1. Ceci permet d'éviter les HP de monitoring lors de mixage/écoute de productions numériques, en mode surround. Quelques difficultés avec drivers Windows, mais résolues ... aucun soucis sous MacOS, mais ne pas oublier de rediriger le son de l'appli vers le module xCore au lieu des HP's intégrés!
Laurent T.
Top produit !
Excellente alternative au embouts à sertir wbt qui ont malheureusement augmenté par deux et même plus ces dernières années ...
Laurent T.
Excellent produit !
Excellente gaine thermo bien épaisse , idéal pour finition de câbles en hp par exemple ...
Laurent T.
Excellent produit !
stephane d.
TINYSINE TSA1110 Volume Control by Bluetooth Android / iOS Compatible This TinySine TSA1110 will allow you to control the volume of your audio system of your choice via the rotary knob on the case or remotely, directly via your smartphone.
Tinysine TSA110 super pratique
acheté pour piloter le volume de mon ampli à tubes qui ne dispose pas de controle de ce dernier, celui ci etait intercalé entre l'ampli, un selecteur audio video vsw41 et enfin un lecteur reseau, après maintes essais infructueux je peux doneravant l'utiliser, c'est vraiment une solution bien pratique et confortable quand on ne peut pas controler le volume de son ampli, utile, pratique et pas cher pour le service rendu, merci.
Emmanuel l.
IPAR 1023A Preamplifier / Volume Controller / Headphone Amplifier / Source Selector The IPAR 1023A is a hybrid device headset amplifier / preamplifier / source selector that displays excellent audio characteristics including a high power level, two isolated...
Bon amplii casque
bon préampli/ampli casque
je l'utilise surtout en préampli sur un atoll in 50 se en by pass très bon son a tel point que je vais m'équiper d'un ampli de puissance de la même marque il a juste un petit ploque au démarrage et a l'extinction
Sandy G.
bornes pour haur haut parleur
super qualité pour ce bornier, si vous utilisez des câbles de section sup ou égale à 2.5 mm2https://www.artisanbeton.fr/chape-flottante.html#:~:text=En%20d'autres%20termes%2C%20la,pertes%20%C3%A9nerg%C3%A9tiques%20de%20la%20maison.
Sandy G.
bornes pour haut parleur
super qualité , pas de souci.
TOPPING D10S DAC USB 32bit/384kHz DSD 256 XMOS U208 ES9038Q2M Silver Revisited version of the D10 from Topping, the D10s is an office DAC with impressive capabilities in its price range. This second version includes an ESS ES9038Q2M 32bit...
Fait parfaitement son travail.
Côté USB: raccordé à une Raspberry Pi 8Go et l’OS Volumio.
Côté RCA: Je l’utilise sur un ampli HiFi Pionneer SA-610 des années 80 et je suis plus que satisfait !
Sandy G.
super qualité si vous devez utiliser des câbles de section de 2.5 mm2 au moins.
Sandy G.
condensateur électrolytique
la qualité MUNDORF n'est pas un mythe, elle s'entend. : très bon résultat en filtrage d'alimentation, sur le petit ampli de jean marie plantefeve 2x30ww
